標題: 利用舵機制作簡單機械臂 [打印本頁]
作者: tyftyh    時間: 2017-12-13 17:03
標題: 利用舵機制作簡單機械臂
**項目名稱:利用舵機制作簡單機械臂
**編寫時間:2017.07.11
**使用芯片:stc12c2052ad
**時鐘頻率:使用外部晶振頻率12MHz
**簡要說明:本次制作的機械臂共用了3個舵機,可以控制機械臂上下、左右移動和抓放動作。
#include <stc12c2052ad.h>
#include <intrins.h>
typedef unsigned char u8;
typedef unsigned short int u16;
sbit CTRL_u_d = P3^3;                                                //控制上、下方向的舵機控制端口
sbit CTRL_l_r = P3^4;                                                //控制左、右方向的舵機控制端口
sbit CTRL_g = P3^5;                                                        //控制抓起的舵機控制端口
void delay_20ms(u16 x);
u8 KeyScan();
u16 TIME = 20000;        //PWM周期時間(單位us)
u16 Min = 700;        //高電平最小持續時間
u16 Max = 2300;        //高電平最大持續時間
u8 Degree = 50;        //單位時間寬度(最小是舵機死區設定大約10us)
u16 Times = 0;        //TIME/Degree(PWM周期除于單位時間寬度)
//高電平持續時間除于單位時間寬度
u16 cTimes_u_d = 0;
u8 cTimes_l_r = 0;
u8 cTimes_g = 0;
u8 Min_cTimes = 0;
u8 Max_cTimes = 0;
u8 R_TH0 = 0, R_TL0 = 0;                                //定時器0計數重載值
u8 KeyValue = 0;        //1-上、2-左、3-抓、4-右、5-下
        Times = TIME/Degree;
        cTimes_u_d = 1500/Degree;
        cTimes_l_r = 1500/Degree;
        cTimes_g = Min_cTimes;
        Min_cTimes = Min/Degree;
        Max_cTimes = Max/Degree;
        P1 = 0xff;
        CTRL_u_d = 0;
        CTRL_l_r = 0;
        CTRL_g = 0;
        R_TL0 = 65536 - Degree;
        R_TH0 = (65536 - Degree) >> 8;
        //設置定時器0
        TMOD = 0x01;        //16位計數
        TL0 = R_TL0;
        TH0 = R_TH0;
        ET0 = 1;        //定時器0中斷開關打開
        TR0 = 1;        //定時器0計數開始
        EA = 1;        //中斷總開關打開
                u8 temp = 0;
                KeyValue = KeyScan();
                switch(KeyValue)
                        case 1:        //向上移動
                                cTimes_u_d = --cTimes_u_d < Min_cTimes ? Min_cTimes : cTimes_u_d;
                        case 2:        //向左移動
                                cTimes_l_r = --cTimes_l_r < Min_cTimes ? Min_cTimes : cTimes_l_r;
                        case 3:        //抓、放動作
                                if(cTimes_g == Min_cTimes)
                                        cTimes_g = Max_cTimes;
                                delay_20ms(15);
                        case 4:        //向右移動
                                cTimes_l_r = ++cTimes_l_r > Max_cTimes ? Max_cTimes : cTimes_l_r;
                        case 5:        //向下移動
                                cTimes_u_d = ++cTimes_u_d > Max_cTimes ? Max_cTimes : cTimes_u_d;
u8 KeyScan()
        u8 key = 0;
        if(P1 != 0xff)
                delay_20ms(2);
                if(P1 != 0xff)
                        u8 temp  = P1;
                        key = 1;
                        while(temp & 0x01)
                                temp = temp >> 1;
                                key++;
        return key;
void Delay20ms()                //@12.000MHz
        unsigned char i, j, k;
        _nop_();
        _nop_();
        i = 1;
        j = 234;
        k = 113;
        do
                do
                        while (--k);
                } while (--j);
        } while (--i);
        while(x--)  Delay20ms();
//定時器0中斷函數   每次進入中斷間隔時間為Degree(單位時間寬度)
void timer0() interrupt 1 using 1
        static u16 times = 0;
        TL0 = R_TL0;
        TH0 = R_TH0;
        //每次只控制一個舵機移動
        if(times == 0)
                switch(KeyValue)
                        case 1:
                        case 5:
                                CTRL_u_d = 1;
                                CTRL_l_r = 0;
                                CTRL_g = 0;
                        case 2:
                        case 4:
                                CTRL_u_d = 0;
                                CTRL_l_r = 1;
                                CTRL_g = 0;
                        case 3:
                                CTRL_u_d = 0;
                                CTRL_l_r = 0;
                                CTRL_g = 1;
                switch(KeyValue)
                        case 1:
                        case 5:
                                if(times >= cTimes_u_d)
                                        CTRL_u_d = 0;
                        case 2:
                        case 4:
                                if(times >= cTimes_l_r)
                                        CTRL_l_r = 0;
                        case 3:
                                if(times >= cTimes_g)
                                        CTRL_g = 0;
        times = ++times >= Times ? 0 : times;
作者: 小身體大智慧    時間: 2018-3-9 23:24
這個單用51單片機就可以實現嗎?
主站蜘蛛池模板: 亚洲1区 | 亚洲 欧美 日韩 在线 | 国产精品日韩 | 免费观看黄网站 | 欧美一区二区三区四区视频 | 亚洲成人精品免费 | 欧美激情综合五月色丁香小说 | 在线视频 中文字幕 | 理论片午午伦夜理片影院 | 91精品国产一二三 | 97伦理最新伦理 | 婷婷在线视频 | 日韩一区二区三区视频在线观看 | 欧美激情视频一区二区三区在线播放 | 亚洲精品一区在线 | 黄色精品| 天天操夜夜拍 | 久久天堂| 欧美成人手机在线 | 亚洲精品在线免费看 | 亚洲a视频 | 欧美视频在线一区 | 中文字幕亚洲视频 | 成人二区 | 欧美精品v国产精品v日韩精品 | 日韩美女一区二区三区在线观看 | 在线国产一区 | 国产精品区二区三区日本 | 亚洲免费在线观看 | 久久久久久久电影 | 精品久久久久久久人人人人传媒 | 成人免费在线播放视频 | 特黄毛片 | 成人无遮挡毛片免费看 | 中文字幕精品视频 | 国产精品久久久久久久久久久久久 | 在线观看特色大片免费网站 | 欧美日韩专区 | 成人精品福利 | 高清免费在线 | 亚洲国产aⅴ成人精品无吗 国产精品永久在线观看 |
