標(biāo)題:
基于數(shù)字相關(guān)的時(shí)柵信號(hào)處理設(shè)計(jì)LPC2138源程序及proteus仿真
[打印本頁(yè)]
liudom
時(shí)間:
2018-4-10 11:24
標(biāo)題:
這是我大三時(shí)的課程設(shè)計(jì),設(shè)計(jì)要求如下:
1.時(shí)柵傳感器模擬器:通過(guò)輸入兩路時(shí)間和空間的信號(hào)。
(1) 設(shè)計(jì)一路正弦載波信號(hào)模擬信號(hào)輸出 sina * cos(wt)
(2) 設(shè)計(jì)一路余弦信號(hào)模擬信號(hào)輸出 cosa *sin(wt)
(3) 設(shè)計(jì)兩路信號(hào)的合成模擬信號(hào)輸出 sin(wt+a)
2. 設(shè)計(jì)數(shù)據(jù)采集模塊。(要求整周期采樣)
3. ARM硬件接口電路設(shè)計(jì):顯示路和鍵盤電路
4. 軟件設(shè)計(jì):數(shù)字相關(guān)算法求解角度、顯示、按鍵、A/D.
5. proteus仿真和實(shí)做。希望對(duì)大家有用!
(19.79 KB, 下載次數(shù): 117)
2018-4-10 17:01 上傳
(48.96 KB, 下載次數(shù): 105)
2018-4-10 17:01 上傳
LPC2138單片機(jī)源程序如下:
#include "config.h"
//#include "LPC21xx.h"
#include "math.h"
//#define Fpclk 12000000
//typedef unsigned char uint8; /* defined for unsigned 8-bits integer variable 無(wú)符號(hào)8位整型變量 */
//typedef signed char int8; /* defined for signed 8-bits integer variable 有符號(hào)8位整型變量 */
//typedef unsigned short uint16; /* defined for unsigned 16-bits integer variable 無(wú)符號(hào)16位整型變量 */
//typedef signed short int16; /* defined for signed 16-bits integer variable 有符號(hào)16位整型變量 */
//typedef unsigned int uint32; /* defined for unsigned 32-bits integer variable 無(wú)符號(hào)32位整型變量 */
//typedef signed int int32; /* defined for signed 32-bits integer variable 有符號(hào)32位整型變量 */
//typedef float fp32; /* single precision floating point variable (32bits) 單精度浮點(diǎn)數(shù)(32位長(zhǎng)度) */
//typedef double fp64; /* double precision floating point variable (64bits) 雙精度浮點(diǎn)數(shù)(64位長(zhǎng)度) */
#define IO_RS 0x1000000
#define IO_RW 0x2000000
#define IO_EN 0x4000000
#define LED 0X01
#define KEY1 (IO0PIN&(1<<20))
#define KEY2 (IO0PIN&(1<<21))
int32 k=0,ADC_Data,tt1,tt2;
uint32 A=1,FG1=1,FG2=2;
uint32 a,i,h,j,p,q,m,n,u,v;
double c,s,data_1=0,data_2=0,data_3=0,data_4=0;
double x,y,PI=3.141592653589793238462643383279502;
int32 Buffer[256];
double SINCE[19]={
0.0000,0.0872,0.1736,0.2588,0.3420,0.4226,
0.5000,0.5736,0.6428,0.7071,0.7660,0.8192,
0.8660,0.9063,0.9397,0.9659,0.9848,0.9962,
1.0000,
double COSCE[19]={
1.0000,0.9962,0.9848,0.9659,0.9397,0.9063,
0.8660,0.8192,0.7660,0.7071,0.6428,0.5736,
0.5000,0.4226,0.3420,0.2588,0.1736,0.0872,
0.0000,
const int16 sindata[]={
0x80,0x83,0x86,0x89,0x8c,0x8f,0x92,0x95,
0x98,0x9b,0x9e,0xa1,0xa4,0xa7,0xaa,0xad,
…………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
0xfc,0xfd,0xfd,0xfe,0xfe,0xfe,0xfe,0xfe,
#define RS_1 IO1SET=(IO_RS&0xFFFFFFFF)
#define RS_0 IO1CLR=(IO_RS&0xFFFFFFFF)
#define RW_1 IO1SET=(IO_RW&0xFFFFFFFF)
#define RW_0 IO1CLR=(IO_RW&0xFFFFFFFF)
#define EN_1 IO1SET=(IO_EN&0xFFFFFFFF)
#define EN_0 IO1CLR=(IO_EN&0xFFFFFFFF)
void delayms(unsigned int t)
unsigned char u,v;
for(u=0;u<100;u++)
for(v=0;v<81;v++);
void LCD_write_com(unsigned char com) //LCD寫入命令函數(shù)
RS_0;
RW_0;
EN_1;
IO1SET=com<<16;
delayms(5);
EN_0;
IO1CLR=0xFF0000;
void LCD_write_data(unsigned char data) //寫入數(shù)據(jù)函數(shù)
RS_1;
RW_0;
EN_1;
IO1SET=data<<16;
delayms(5);
EN_0;
IO1CLR=0xFF0000;
void LCD_clear() //LCD清屏函數(shù)
LCD_write_com(0x01);
delayms(5);
void LCD_write_char(unsigned char x,unsigned char y,unsigned char s) //寫入字符函數(shù)
if (y == 0)
LCD_write_com(0x80+x);
LCD_write_com(0xC0+x);
LCD_write_data(s);
void LCD_write_string(unsigned char x,unsigned char y,unsigned char *s) //寫入字符串函數(shù)
if (y == 0)
LCD_write_com(0x80 + x); //表示第一行
LCD_write_com(0xC0 + x); //表示第二行
while (*s)
LCD_write_data( *s);
s++;
void LCD_init() //LCD初始化
LCD_write_com(0x38); //顯示模式設(shè)置
delayms(5);
delayms(5);
delayms(5);
LCD_write_com(0x08); //顯示關(guān)閉
LCD_write_com(0x01); //清屏
LCD_write_com(0x06); //顯示光標(biāo)移動(dòng)設(shè)置
delayms(5);
LCD_write_com(0x0C); //顯示開及光標(biāo)設(shè)置
void UART0Init(uint32 bps)
uint16 Fdiv;
PINSEL0 = (PINSEL0 & (~0x0F)) | 0x05;
U0LCR = 0x83;
Fdiv = (Fpclk / 16) / bps;
U0DLM = Fdiv / 256;
U0DLL = Fdiv % 256;
U0LCR = 0x03;
void __irq IRQ_Timer0 (void)
// for(i=0;i<256;i++)
// y=COSCE[a];
// x=SINCE[a];
// s=(y*sindata[i]);
// c=(x*cosdata[i]);
// sindata[i]=sin(2.0*acos(-1.0)/256*i);
// cosdata[i]=cos(2.0*acos(-1.0)/256*i);
// h=(s*0x1ff+0x1ff);
// h=s+c;
// DACR=((sindata[i]<<6))|(1<<16);
// for(j=0;j<0x20;j++);
if((IO0PIN&KEY1)==0)
if(FG1!=(A-5))
FG1=A;A+=5;i=0;
if(A>360) A=0;
if((IO0PIN&KEY1)!=0){ FG1=1; }
a=A*180/PI;
if((IO0PIN&KEY2)==0)
if(FG2!=(A+5))
{FG2=A;A-=5;i=0;
if(A>360)A=0;}
if((IO0PIN&KEY2)!=0){ FG2=1; }
if(A<=90) a=A/5;
if(A>90&A<=180) a=36-A/5;
if(A>180&A<270) a=A/5-36;
if(A>=270&A<360) a=72-A/5;
y=COSCE[a];
x=SINCE[a];
s=(y*sindata[i]);
c=(x*cosdata[i]);
h=s+c;
DACR=((h<<6))|(1<<16);
AD0CR = (AD0CR&0x00FFFF00)|0x01|(1 << 24); // 設(shè)置AD0.0,并進(jìn)行第一次轉(zhuǎn)換
while( (AD0DR&0x80000000)==0 ); // 等待轉(zhuǎn)換結(jié)束
ADC_Data = AD0DR; // 讀取ADC結(jié)果
ADC_Data = (ADC_Data>>6) & 0x3FF; // 提取AD轉(zhuǎn)換值
Buffer[i]=ADC_Data;
LCD_write_char(9,0,A/100%10+0X30);
LCD_write_char(10,0,A/10%10+0X30);
LCD_write_char(11,0,A%10+0X30);
for(u=0;u<256;u++)
data_1 = data_1 +(Buffer[u]-0x7f)*(cosdata[u]-0x7f)/256;//-5170)*PI/128;
data_2 = data_2 +(Buffer[u]-0x7f)*(sindata[u]-0x7f)/256;//-5170)*PI/128;
data_4 = atan(data_1 /data_2)*180/acos(-1.0);
tt1=data_4*10;//1;
if(A>90&A<180) tt1=1800-tt1;
if(A>180&A<270) tt1=1800+tt1;
if(A>270&A<360) tt1=3600-tt1;
LCD_write_char(9,1,tt1/1000%10+0X30);
LCD_write_char(10,1,tt1/100%10+0X30);
LCD_write_char(11,1,tt1/10%10+0X30);
LCD_write_char(12,1,'.');
LCD_write_char(13,1,tt1%10+0X30);
// LCD_write_char(6,1,tt2/1000%10+0X30);
// LCD_write_char(7,1,tt2/100%10+0X30);
// LCD_write_char(8,1,tt2/10%10+0X30);
// LCD_write_char(9,1,'.');
// LCD_write_char(10,1,tt2%10+0X30);
i++;
if(i>=256) i=0;
T0IR = 0x02; /* 清除中斷標(biāo)志 */
VICVectAddr = 0x00; /* 通知VIC中斷處理結(jié)束 */
void Time0Init(void)
T0TC = 0; // 定時(shí)器T0初始化
T0PR = 10; // 設(shè)置定時(shí)器0分頻為100分頻,得120000Hz
T0MCR = 0x03<<3; // 匹配通道MR1匹配中斷并復(fù)位TC
T0MR0 = Fpclk/12000; // MR0比較值(0.5秒定時(shí)值)
T0MR1 = Fpclk/1200; // MR1比較值(0.5秒定時(shí)值)
T0EMR = 0x30; // 設(shè)置定時(shí)器0的MR0匹配輸出,輸出方式為翻轉(zhuǎn)
T0TCR = 0x03; // 啟動(dòng)并復(fù)位T0TC
T0TCR = 0x01;
T0IR = 0x02;
/* 設(shè)置定時(shí)器0中斷IRQ */
VICIntSelect = 0x00; // 所有中斷通道設(shè)置為IRQ中斷
VICVectCntl0 = 0x20 | 0x04; // 分配定時(shí)器0中斷到通道0(最高優(yōu)先級(jí))
VICVectAddr0 = (uint32)IRQ_Timer0; // 設(shè)置中斷服務(wù)程序地址向量
VICIntEnable = (1<<4); // 使能定時(shí)器0中斷
// IRQEnable(); // 使能IRQ中斷
int main(void)
PINSEL0|=0x00000000;
PINSEL1 |= 0x01400000;
PINSEL1 = (PINSEL1&(~(0x03<<18))) | (0x02<<18); // P0.25 連接Aout
// UART0Init(9600);
IO0DIR|=0X01;
IO1DIR|=0x07ff0000;
LCD_init();
Time0Init();
AD0CR = (1 << 0) |
((Fpclk / 1000000 - 1) << 8) |
(0 << 16) |
(0 << 17) |
(1 << 21) |
(0 << 22) |
(1 << 24) |
(0 << 27);
delayms(10);
ADC_Data = AD0DR;
LCD_write_string(0,0,"in:");
LCD_write_string(0,1,"out:");
// y=COSCE[a];
// x=SINCE[a];
數(shù)字信號(hào)處理課程設(shè)計(jì).zip
(343.14 KB, 下載次數(shù): 77)
2018-4-10 11:23 上傳
點(diǎn)擊文件名下載附件
15141752135
時(shí)間:
2021-3-27 20:50
有錯(cuò)誤,不能直接使用
15141752135
時(shí)間:
2021-3-27 20:50
需要修改,不知道是電路問(wèn)題還是代碼問(wèn)題
午夜在线视频观看
中国第一毛片
俺去俺来也在线www色官网
亚洲欧美一区二区三区四区
一区二区视频在线播放
毛片一区
免费视频毛片
日韩一级免费
一级黄色在线观看
国产美女精品视频
九九综合网
日本免费中文字幕
亚洲男人在线
在线伊人网
亚洲日本中文字幕
欧美激情一区
日本韩国欧美中文字幕
日日爱影视
日韩在线不卡视频
亚洲一区在线视频
日韩精品影院
午夜视频在线免费观看
中文字幕+乱码+中文乱码91
av免费网站
国产成人区
久久视频精品
av片在线观看
中文字幕亚洲精品
欧美极品视频
亚洲一区二区三区在线
色婷婷国产精品综合在线观看
中文字幕免费视频
欧美日韩一区二
日韩黄色av
九色视频丨porny丨丝袜
在线伊人
成人欧美一区二区三区白人
国产精品三级在线
欧洲一级片
国产免费一级
欧美日韩亚洲一区二区
