stm32單片機控制水位源程序
聲幾又香
2018-4-17 14:34
stm32單片機控制水位源程序
這是一個利用stm32單片機控制水位的程序
(33.01 KB, 下載次數: 62)
2018-4-17 16:40 上傳
/********************************* 深圳市航太電子 *******************************
* 實 驗 名 :小車超聲波+紅外跟蹤實驗
* 實驗說明 :使用超聲波判斷前方引導物的距離,使用紅外來判斷引導物的移動方向
* 實驗平臺 :航太ARM單片機開發板
* 連接方式 :請參考interface.h文件
* 注 意 :1.因地面和輪子的差異,左右轉向時需要根據實際需要調節差速的差值
* 2.需要耐心調節紅外避障的感應距離以及超聲波控制距離
* 3.建議使用不反光的書本作為引導物
* 作 者 :航太電子產品研發部
#include "stm32f10x.h"
#include "interface.h"
#include "LCD1602.h"
#include "IRCtrol.h"
#include "motor.h"
#include "UltrasonicCtrol.h"
//全局變量定義
volatile unsigned int speed_count=0;//占空比計數器 50次一周期
char front_left_speed_duty=SPEED_DUTY;
char front_right_speed_duty=SPEED_DUTY;
char behind_left_speed_duty=SPEED_DUTY;
char behind_right_speed_duty=SPEED_DUTY;
unsigned char tick_5ms = 0;//5ms計數器,作為主函數的基本周期
unsigned char tick_1ms = 0;//1ms計數器,作為電機的基本計數器
unsigned char tick_200ms = 0;//刷新顯示
char ctrl_comm = COMM_STOP;//控制指令
char ctrl_comm_last = COMM_STOP;//上一次的指令
unsigned char continue_time=0;
volatile unsigned int target_mm=0;
unsigned int shift = 0;
volatile unsigned int height_mm = 0;
int i;
unsigned int avg_dis;
int flag;
unsigned int Avg_Distance()
unsigned int sum=0;
unsigned int max=0,min=10000;
sum=0;
Distance();
max = distance_cm;
min = distance_cm;
sum += distance_cm;
Distance();
if(max<distance_cm)
max = distance_cm;
if(min>distance_cm)
min = distance_cm;
sum += distance_cm;
Distance();
if(max<distance_cm)
max = distance_cm;
if(min>distance_cm)
min = distance_cm;
sum += distance_cm;
Distance();
if(max<distance_cm)
max = distance_cm;
if(min>distance_cm)
min = distance_cm;
sum += distance_cm;
Distance();
if(max<distance_cm)
max = distance_cm;
if(min>distance_cm)
min = distance_cm;
sum += distance_cm;
Distance();
if(max<distance_cm)
max = distance_cm;
if(min>distance_cm)
min = distance_cm;
sum += distance_cm;
Distance();
if(max<distance_cm)
max = distance_cm;
if(min>distance_cm)
min = distance_cm;
sum += distance_cm;
sum-=max;
sum-=min;
return sum/5;
void BarrierProc(void)
return;
void GoToTarget()
//停止注水
if(height_mm -1 > target_mm)
//while(height_mm > target_mm)
//Distance();
avg_dis = Avg_Distance();
if( avg_dis> shift )
avg_dis = shift;
else if( avg_dis ==0 )//可能返回錯誤數據,跳過
continue;
height_mm = shift - avg_dis;
front_right_speed_duty = 30;//Stop motor
LEDToggle(LED_PIN);
LCD1602WriteDistance(height_mm);//更新距離
LCD1602WriteCommand(target_mm);
Delayms(200);
else if(height_mm+1 < target_mm) //水位不夠,增加注水
while(height_mm < target_mm)
//Distance();
avg_dis = shift;
continue;
front_right_speed_duty =50;//Stop motor
LEDToggle(LED_PIN);
Delayms(200);
else if( height_mm<target_mm+1 && height_mm > target_mm-1 )
front_right_speed_duty = 0;
return;
void Keep3Min()
front_right_speed_duty = 30;//控制PWM與流出速度一致,保持3分鐘
for(i=0;i<60*3;i++)
avg_dis = shift;
continue;
if( height_mm +1 < target_mm )
front_right_speed_duty += 5;
else if( height_mm-1 > target_mm )
front_right_speed_duty -= 5;
LEDToggle(LED_PIN);
Delayms(500);
avg_dis = shift;
continue;
Delayms(500);
int main(void)
//功率最大,注水
distance_cm = 0;
shift = 276;
height_mm = 0;
avg_dis = 0;
delay_init();
GPIOCLKInit();
UserLEDInit();
LCD1602Init();
IRCtrolInit();
TIM2_Init();
MotorInit();
UltraSoundInit();
RedRayInit();
ServoInit();
Distance();
if ( distance_cm < 10 )
CarGo();
Delayms(500);
CarStop();
Delayms(500);
CarBack();
Delayms(500);
CarStop();
Delayms(500);
target_mm = 100;
//基本要求,先注水到100mm
GoToTarget();
flag=0;
if(tick_5ms >= 5)
tick_5ms = 0;
tick_200ms++;
if(tick_200ms >= 40)
tick_200ms = 0;
LEDToggle(LED_PIN);
//do something
avg_dis = shift;
continue;
if(ir_rec_flag == 1)//接收到紅外信號
ir_rec_flag = 0;
switch(ctrl_comm)
case COMM_UP:
target_mm++;
break; //增加轉速
case COMM_DOWN:
target_mm--;
break;//減少轉速
case COMM_LEFT:
//front_right_speed_duty++;
//if(front_right_speed_duty>50)
// front_right_speed_duty=50;
flag = 2;
break;//停止
case COMM_RIGHT:
//front_right_speed_duty--;
//if(front_right_speed_duty<1)
// front_right_speed_duty=0;
flag=3;
break;//停止
case COMM_STOP:
flag=1;
default :
LEDToggle(LED_PIN);
if(flag!=0)
if(flag==2 || flag==1 )//2 基本要求
//基本要求,先注水到100mm
GoToTarget();
Keep3Min();
//水位到110mm,并保持3分鐘
target_mm = 110;
//注水到設定高度
GoToTarget();
Keep3Min();
//上述操作結束后,停止注水
LCD1602WriteCommand(888);
Delayms(1000);
Delayms(1000);
Delayms(1000);
Delayms(1000);
}//基本部分結束
else if(flag==3 )//發揮部分
//注水到設定高度
GoToTarget();
Keep3Min();
target_mm = 100;
GoToTarget();
Keep3Min();
target_mm = 200;
…………限于本文篇幅 余下代碼請從51黑下載附件…………
WaterLevel.zip
(22.87 KB, 下載次數: 60)
2018-4-17 14:33 上傳
a1234567
2021-6-7 08:48
有沒有proteus的仿真圖
日韩精品免费观看
深夜福利久久
国产欧美在线
黄色小说视频
亚洲精品一区在线观看
亚洲精品久久久
国产成年人视频
日韩在线视频网站
日韩精品久久久久久久酒店
欧美精品日韩
成年免费视频黄网站在线观看
国产h片在线观看
欧美日韩亚洲一区二区三区
久久精品久久久精品美女
亚洲福利在线观看
欧美精品在线观看
欧美狠狠干
玖玖在线视频
欧美精品久久久久久久
久久天堂av
中文字幕第一区
亚洲亚洲人成综合网络
黄色在线免费网站
四虎精品视频
人人射人人干
久久精品视频免费
久久国产精品免费视频
成人在线视频免费观看
国产三级免费观看
久热精品视频
日韩在线视频观看
国产一区在线播放
日韩香蕉视频
一区二区三区日韩
久久一区
亚洲性生活片
高清一级片
日韩欧美在线播放
日韩免费
午夜免费小视频
免费久久
