標題: PCB設計中專業英譯術語之形狀與尺寸 [打印本頁]
作者: 板兒妹0517 時間: 2018-5-11 17:53
1.開料:CutLamination/Material cutting
2.鉆孔:Drilling
3.內鉆:Inner LayerDrilling
4一次孔:Outer Layer Drilling
5.二次孔:2nd Drilling
6.雷射鉆孔:Laser Drilling /Laser Ablation
7.盲(埋)孔鉆孔:Blind & Buried Hole Drilling
8.干膜制程:PhotoProcess(D/F)/Dry Film
9.前處理 (Pretreatment)
10.壓膜:Dry Film Lamination
11.曝光:Exposure
12.顯影:Developing
13.去膜:Stripping
14.壓合:Lamination
15:黑化:Black OxideTreatment
16.微蝕:Microetching
17.鉚釘組合:eyelet
18.迭板:Lay up
19.壓合:Lamination
20.后處理:Post Treatment
21.黑氧化:Black Oxide Removal
22.銑靶:spot face
23.去溢膠:resin flush removal
24.減銅:Copper Reduction
25.水平電鍍:HorizontalElectrolytic Plating
26.電鍍:Panel plating
27.錫鉛電鍍:Tin-Lead Plating /Pattern Plating
28.低于 1 mil: Less than 1 mil Thickness
29.高于 1 mil:More than 1 mil Thickness
30.砂帶研磨:Belt Sanding
31:剝錫鉛:Tin-Lead Stripping
32.微切片: Microsection
33.蝕銅:Etching
34.初檢:Touch-up
35.塞孔:Plug Hole
36.防焊(綠漆/綠油):SolderMask
37.C面印刷:Printing Top Side
38.S面印刷:Printing Bottom Side
39.靜電噴涂:Spray Coating
40.前處理:Pretreatment
41.預烤:Precure
42.后烘烤:Postcure
43.印刷:Ink Print
44.表面刷磨:Scrub
45.后烘烤:Postcure
46.UV烘烤:UV Cure
47.文字印刷:Printing of Legend
48.噴砂:Pumice/Wet Blasting
49.印可剝離防焊/藍膠:Peelable Solder Mask)
50.化學前處理,化學研磨:Chemical Milling
51.選擇性浸金壓膜:Selective Gold Dry Film Lamination
52.鍍金:Gold plating
53.噴錫:Hot Air SolderLeveling
54.成型:Profile/Form
55.開短路測試:Electrical Testing
56.終檢:Final VisualInspection
57.金手指鍍鎳金:Gold Finger
58.電鍍軟金:Soft Ni/Au Plating
59.浸鎳金:Immersion Ni/Au / Electroless Ni/Au
60.噴錫:Hot Air Solder Leveling
61.水平噴錫:HorizontalHot Air Solder Leveling
62.垂直噴錫: Vertical Hot Air Solder Leveling
63.超級焊錫:Super Solder
64.印焊錫突點:Solder Bump
65.數控銑/鑼板:N/C Routing/Milling
66.模具沖/啤板:Punch
67.板面清洗烘烤:Cleaning & Backing
68.V型槽/V-CUT: V-Cut/V-Scoring
69.金手指斜邊:Beveling of G/F
70.短斷路測試Electrical Testing/Continuity & Insulation Testing
71.AOI 光學檢查:AOI Inspection
72:VRS 目檢:Verified & Repaired
73.泛用型治具測試:Universal Tester
74.專用治具測試:Dedicated Tester
75.飛針測試:Flying Probe
76.終檢:Final Visual Inspection
77.壓板翹:Warpage Remove
78.X-OUT 印刷:X-Out Marking
79.包裝及出貨:Packing& shipping
80.清洗及烘烤: Final Clean & Baking
81.銅面保護劑:ENTEK Cu-106A/OSP
82.離子殘余量測試:Ionic Contamination Test/ Cleanliness Test
83.冷熱沖擊試驗:Thermal cycling Testing
84.焊錫性試驗:Solderability Testing
85.雷射鉆孔:Laser Ablation
86.雷射鉆Tooling孔:Laser ablationTooling Hole
87.雷射曝光對位孔:Laser Ablation Registration Hole
88.雷射Mask制作:Laser Mask
89.雷射鉆孔:Laser Ablation
90.AOI檢查及VRS:AOI Inspection & Verified & Repaired
91.除膠渣:Desmear
92.專用治具測試:Dedicated Tester
93.飛針測試:Flying Probe
94.壓板翹: Warpage Remove
95.底片:Ablation
96.燒溶:laser)
97.切/磨:abrade
98.粗化:abrasion
99.耐磨性:absorption resistance
100.允收:ACC /accept
101.加速腐蝕:accelerated corrosion test
102加速試驗:accelerated test
103.速化反應:acceleration
104.加速劑:accelerator
105.允許:acceptable
106.活化液:activator
107.實際在制品:active work in process
108.附著力:adhesion
109.黏著法:adhesive method
110.氣泡:air inclusion
111.風刀:air knife
112.不定形的改變:amorphous change
113.總量:amount
114.硝基戊烷:amylnitrite
115.分析儀:analyzer
116環狀墊圈;孔環annular ring
117.陽極泥:anodeslime (sludge)
118.陽極清洗:anodizing
119.自動光學檢測:AOI/automatic optical inspection
120.引用之文件:applicable documents
121.允收水平抽樣:AQL sampling
122.液態光阻:aqueous photoresist
123.縱橫比(厚寬比):aspect ratioAs received
124.背光:back lighting
125.墊板:back-up
126.預留在制品:banked work in process
127.基材:base material
128.基準績效:baseline performance
129.批:batch
130.貝他射線照射法:beta backscattering
131.切斜邊;斜邊:beveling
132.二方向之變形:biaxial deformation
133.黑化:black-oxide
134.空板:blank panel
135.挖空:blanking
136.彈開:blip
137.氣泡:blister blistering
138.吹孔:blow hole
139.板厚錯誤:board-thickness error
140.黏結層:bonding plies
141.板彎:bow ; bowing
142.破空:break out
143.搭橋;橋接:bridging
144.接單生產:BTO (Build To Order)
145,.燒焦:burning
146.毛邊(毛頭):burr
147.碳化物:carbide
148.定位梢:carlson pin
149.載運劑:carrier
150.催化:catalyzing
151.陰極濺射法:catholicsputtering
152.隔板;鋼板:caul plate
153.校驗系統之各種要求:calibration system requirements
154.中心光束法:center beam method
155.集中式投射線:central projection
156.認證:certification
157.倒角 (金手指):chamfer chamfer
158.切斜邊;倒角:chamfering
159.特性阻抗:characteristic impedance
160.電量傳遞過電壓:charge transfer overpotential
161.網框:chase
162.棋盤:checkboard
163.蟹和劑:chelator
164.化學鍵:chemical bond
165.化學蒸著鍍:chemical vapor deposition
166.圓周性之孔破:circumferential void
167.包夾金屬:clad metal
168.無塵室:clean room
169.間隙:clearance
170.表面處理:Coating/Surface Finish
久久久久国产一区二区三区
精品一区在线播放
狠狠干狠狠干
国产成人在线观看免费网站
亚洲综合一区二区
中文字幕av网站
香蕉视频一区二区三区
久久久久人
国产欧美激情
久久人人爽人人爽人人片
日韩精品一二区
日韩色综合
黄色片网站视频
免费激情网站
中文字幕二区
欧美精品一区在线观看
亚洲天堂一区二区三区
www精品|
亚洲免费精品
日韩黄网
av毛片在线看
欧美日韩国产一区二区
国产高清av
日本中文字幕网站
日韩中文在线视频
精品久久久久久久久久久久久久
一级片欧美
久久九
国产一区二区日韩
青青草网站
高清国产mv在线观看
亚洲乱码一区二区
国产精品美女久久久久av爽
国语对白做受69
aaaaa级片|
亚洲免费在线播放
国产精品福利在线观看
欧美日韩高清在线
91欧美日韩
精品一区二区三区四区五区
中文字幕1区
