單片機驅動ADS1115的程序
maizimingdou
2018-5-24 10:12
單片機驅動ADS1115的程序
#include <reg52.h>
#include <intrins.h>
sbit SCL=P1^0; //SCL
sbit SDA=P1^1; //SDA
sbit led0 = P1^2;
sbit led1 = P1^3;
unsigned char Initdata[4]={0};
code unsigned char seg7code[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xff}; //不帶小數點的共陽數碼管段碼
code unsigned char seg7codeB[]={0x40,0x79,0x24,0x30,0x19,0x12,0x02,0x78,0x00,0x10,0xff}; //帶小數點的共陽數碼管段碼
unsigned int date;
unsigned char cnt;
//******************延時子程序 *******************************
void delay(unsigned char i)
for(i;i>0;i--);
void delay1ms(unsigned char t)
unsigned char i;
unsigned char j;
for(i=124;i>0;i--);
for(j=0;j<t;j++);
/****************************開始ADC通信*************************/
void StartADcom()
SDA =0;
SCL=1;
delay(100);
SDA =1;
delay(20);
SDA =0;
SCL=0;
delay(10);
/***********************************停止ADC通信**************************************/
void StopADcom()
SDA=0;
delay(10);
SCL=1;
delay(20);
SDA=1;
delay(10);
/********************************單字節I2C傳輸**************************************/
void Send_Byte(unsigned char byte)
unsigned char i;
for(i=0;i<8;i++)
if((byte<<i)&0x80)
SDA=1;
SDA=0;
delay(5);
SCL=1;
delay(10);
SCL=0;
delay(10);
delay(5);
SDA=1;
delay(5);
SCL=1;
delay(10);
SCL=0;
delay(10);
/*************************讀取一個字節*****************************/
unsigned char Read_Byte()
unsigned char temp=0;
unsigned char i;
for(i=0;i<8;i++)
temp=temp<<1; //shift left to receive next bit
SCL=0; //set clock high
delay(10);
SCL=1;
_nop_();
delay(5);
if(SDA==1) //check if Data=high
temp|=0x01; //yes - set bit high
_nop_();
delay(10);
SCL=0;
delay(5);
SDA=0;
delay(5);
SCL=1;
delay(20);
SCL=0;
delay(5);
SDA=1;
return temp;
/**************************配置ADC轉換芯片*************************************/
void Confige1115(unsigned char channel_x)
unsigned char i=0;
unsigned char a_channel;
switch(channel_x)
case 1:
a_channel=0x42;
case 2:
a_channel=0x52;
case 3:
a_channel=0x62;
case 4:
a_channel=0x72;
default:
Initdata[0] =0x90;
Initdata[1] =0x01;
Initdata[2]=a_channel;
Initdata[3] =0x83;
SCL=1;
StartADcom();
for(i=0;i<4;i++)
Send_Byte(Initdata[i]);
delay(20);
StopADcom();
/********指向轉換結果寄存器**************************/
void Pointregister(void)
unsigned char i=0;
Initdata[0] =0x90;
Initdata[1] =0x00;
SCL=1;
StartADcom();
for(i=0;i<2;i++)
delay(20);
StopADcom();
delay(10);
/*****************讀取ADC轉換結果*******************/
unsigned int Read1115(void)
unsigned char ResultL,ResultH;
unsigned int Result;
Initdata[0] =0x91;
SCL=1;
StartADcom();
delay(10);
Send_Byte(Initdata[0]);
delay(20);
ResultH=Read_Byte();
delay(10);
ResultL=Read_Byte();
StopADcom();
Result=ResultH*256+ResultL;
return Result;
/*****ADC模擬量采集轉化為數字量*********/
unsigned int Ad_1115(unsigned char channel_Ad)
unsigned int adc_value;
Confige1115(channel_Ad);
delay1ms(1);
Pointregister();
delay(10);
adc_value=Read1115();
return adc_value;
//********************顯示函數****************
void display()
P2=0xfe; //P1.0=0,選通第一位
P0=seg7codeB[date/10000]; //十位數,查表,輸出
delay1ms(1);
P0=0xff; //消隱
P2=0xfd; //P1.1=0,選通第二位,個位數
P0=seg7code[date%10000/1000];
delay1ms(1);
P0=0xff; //消隱
P2=0xfb; //P1.3=0,選通第三位,小數點第一位
P0=seg7code[date%1000/100];
delay1ms(1);
P0=0xff; //消隱
P2=0xf7; //P1.3=0,選通第四位,小數點第二位
P0=seg7code[date%100/10];
delay1ms(1);
P0=0xff; //消隱
void Timer1Init(void)
TMOD &= 0x0F;
TMOD |= 0x10;
TL1 = 0x00;
TH1 = 0xff;
TF1 = 0;
TR1 = 1;
//**************************** //主程序
main()
Timer1Init();
EA = 1;
ET1 = 1;
//date=Ad_1115(1) * 1.2;
display();
if(date>40000)
led0 = 1;
led1 = 0;
else if(date>35000)
led0 = 0;
delay(50);
led0 = 1;
led1 = 0;
else if(date>15000)
led0 = 0;
led1 = 1;
led0 = 0;
delay(1);
led0 = 1;
led1 = 1;
void Timer1_isr(void) interrupt 3
ET1 = 0;
TH0=0x00;
TL0=0xff;
cnt = cnt + 1;
if(cnt == 1)
cnt = 0;
//display();
ET1 = 1;
軍志
2018-7-20 16:12
能不能發個原理圖出來啊
bifxv
2019-9-30 16:01
同上,確實只有代碼看著暈。
孫琪123
2019-10-16 15:33
我把這個程序進行了編譯,那示波器看這個SCL和SDA,兩條線都統一被拉高了,沒有數據變化呀
七彩的夢想
2025-5-24 00:07
測試了一下,好像不能用
91社区在线观看
久草精品在线
日韩二三区
国产成人精品亚洲日本在线观看
久草福利
av黄色在线
久久久久久99
日韩一区二区在线视频
大象视频一区二区
日韩一区二区成人
国产成人精品一区二
免费看黄色国产
成人影院在线观看
午夜免费福利影院
国产精品99精品久久免费
亚洲第一色av
欧美国产中文字幕
午夜视频在线观看网址
日韩精品成人
午夜免费精品视频
www日
91偷拍精品一区二区三区
三级黄色片在线观看
99re视频这里只有精品
精品国产一区二区三区在线观看
美女国内精品自产拍在线播放
欧美日韩高清免费
一区二区三区四区视频
久久国产精品首页
久久久久久久久久爱
国产免费一级片
国产激情自拍视频
国产精品久久国产精品
欧美一级做性受免费大片免费
亚洲欧美日本在线
成人午夜激情
成人伊人
欧美专区日韩专区
精品国产欧美一区二区三区不卡
天堂综合网
精品在线一区二区
