51單片機設計的頻率計仿真與源代碼
zhuzhu@qq
2018-5-29 17:57
51單片機設計的頻率計仿真與源代碼
頻率計仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
(21.6 KB, 下載次數: 48)
2018-5-30 00:00 上傳
(48.15 KB, 下載次數: 50)
2018-5-30 00:00 上傳
單片機頻率計源程序如下:
#include<reg52.h>
sbit LED=P1^7;
sbit SW=P3^2;
bit flag=0;
bit CL = 0;
unsigned int high = 0; //計數器溢出的次數
unsigned int low = 0;
unsigned char cishu = 0; //定時器溢出次數
unsigned char ch[6];
unsigned char code dsy_code[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
unsigned char num[6] = {0}; //存儲各個位的值
void DelayMS (unsigned int x);
unsigned char i;
EA = 1;
EX0 = 1;
IT0=1;
ES = 1; //開串口中斷
SCON = 0x50; //方式1
PCON = 0x00;
TMOD = 0x21; //定時器T1方式2
TH1 = 0xFD;
TL1 = 0xFD; //波特率9600
TR0 = 1;
ET0 = 1;
TH0 = (65536 - 50000) / 256;
TL0 = (65536 - 50000) % 256; //設置T0為50ms溢出一次
TCON = 0x50; //同時開啟定時器T0和計數器T1
if(flag==1)
for(i=0;i<6;i++)
P2 = 0x04<< i;
P0 = dsy_code[num[i]];
DelayMS(2);
ch[i]=num[i] + '0';
SBUF=ch[i];
while(!TI);
TI=0;
SBUF=' ';
while(!TI);
TI=0;
void Timer0() interrupt 1
if(CL==1)
cishu++;
// TH0 = (65536 - 50000) / 256;
// TL0 = (65536 - 50000) % 256;
if(cishu == 20)
TCON = 0x00; //暫停定時器,緩解CPU壓力,并不影響頻率值
cishu = 0;
num[0] = (high*256 + low)/ 100000 % 10;
num[1] = (high*256 + low)/ 10000 % 10;
num[2] = (high*256 + low)/ 1000 % 10;
num[3] = (high*256 + low)/ 100 % 10;
num[4] = (high*256 + low)/ 10% 10;
num[5] = (high*256 + low)% 10;
high = 0;
low = 0;
TL0 = (65536 - 50000) % 256; //再重裝初值,保證計數時間為1秒
flag=1;
LED=1;
void Timer1() interrupt 0
TF0=1;
low++;
TH1 = 0xFD;
if(low==256)
high++;
// low=0;
TF0=0;
// if(high==256)high=0;
void InterruptUART () interrupt 4
static unsigned char m;
if(RI) //接受到字節
RI=0; //手動清零接收中斷標志位
m=SBUF; //接收的數據+1后發回,左邊是發送SBUF,右邊是接收SBUF
if(m=='A')
CL=1;
LED=0;
unsigned int t;
while (x--)
for(t=0;t<120;t++);
頻率計.zip
(70.3 KB, 下載次數: 24)
2018-5-29 17:54 上傳
基于c51設計
ziba108
2018-6-14 21:37
缺少fangboxinhao.hex????
mif
2018-7-2 16:22
多謝了大佬
a免费视频
超碰97免费
婷婷色网
欧美一级在线
久久精品美女
青青草福利视频
黄色激情视频网站
精品国产区一区二
日韩综合久久
狠狠干影院
午夜视频免费在线观看
日韩字幕
国产欧美精品一区二区色综合
久久精品黄色
国产特级黄色片
中文字幕的
伊人久久av
欧美大片18
可以免费看黄的网站
色窝
日韩一级在线观看
www.精品国产
色综合久久88色综合天天
欧美三级 欧美一级
8x8ⅹ国产精品一区二区
国产嫩草视频
日本韩国欧美中文字幕
可以免费看的av
亚洲第一伊人
日韩免费在线视频
国产又猛又黄又爽
91亚洲精品乱码久久久久久蜜桃
久草综合网
俄罗斯毛片
国产香蕉在线观看
香蕉视频一区二区
人人干人人草
日韩在线影院
三级av在线
在线观看免费av网站
天堂网中文
