基于stm32f103c8t6的智能避障小車源碼 藍牙控制4位數碼管顯示
wulikanhua
2018-6-5 09:36
利用超聲波測距檢測距離,4位數碼管顯示的藍牙避障小車。
#include "stm32f10x.h"
#include "stm32f10x_conf.h"
#include "led.h"
#include "systick.h"
#include "bizhang.h"
#include "key.h"
#include "zhongduan.h"
#include "tx_rx.h"
#include "timer.h"
#include "TM1637.h"
#include "timer3_pwm.h"
#include "wave.h"
#include "mortor.h"
float UltrasonicWave_Distance; //計算出的距離
u16 counter;
int main()
//u8 key=0;
//u8 BZ_flag=0;
int i=0,j=0;
u8 distance[4]={0};
u16 L=0;
L=2325;
distance[0]=code[L/1000];
distance[1]=code[L%1000/100];
distance[2]=code[L%100/10];
distance[3]=code[L%10];
//timer3_fig();
uart1_init();
led_inti(); //LED接PB5,PB6,PB7,PB8(核心板自帶)
systick_intil();
uart1_init();
send_byte(1);
bizhang_inti();//避障傳感器OUT腳接PA1
key_inil(); //按鍵接PA0
timer_confing();
wave_config();
TM1637_Init();
pwm_configuration(2400,599);
motor_config();
set_pwm(800,800,800,800);
motor_stop();
//發出高電平
//啟動測距
TIM_Cmd(TIM2, ENABLE);
if(led_flag>0)
TIM_Cmd(TIM2, DISABLE);
TIM_SetCounter(TIM2,0);
Wave_StarMeasure();
while(!GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_2));
//啟動定時器
//等待低電平
while((GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_2)==1));
counter=TIM_GetCounter(TIM2);
//數碼管顯示數據
UltrasonicWave_Distance=(float)(counter)/20*340/2;
//UltrasonicWave_Distance=(u16)UltrasonicWave_Distance*1000;
if(UltrasonicWave_Distance<5000)
distance[0]=code[(u16)UltrasonicWave_Distance/1000];
distance[1]=code[(u16)UltrasonicWave_Distance%1000/100];
distance[2]=code[(u16)UltrasonicWave_Distance%100/10];
distance[3]=code[(u16)UltrasonicWave_Distance%10];
TM1637_NixieTubeDisplay(distance);
led_flag=0;
if(RX_num>=5)
for(i=0;i<RX_num;i++)
if((RX_buff[i]==0x4f)&&(RX_buff[i+1]==0x4e))
switch(RX_buff[i+2])
case 0x41:;motor_run_forward();break; //前進
case 0x42:;motor_run_back();break; //后退
case 0x43:;motor_left();break; //左
case 0x44:;motor_right();break; //右
case 0x45:;motor_stop();break; //停
case 0x31:set_pwm(500,500,500,500);break; //1
case 0x32:set_pwm(900,900,900,900);break; //2
case 0x33:set_pwm(1200,1200,1200,1200);break;//3
case 0x34:set_pwm(1500,1500,1500,1500);break; //4
case 0x35:set_pwm(1800,1800,1800,1800);break;//5
case 0x36:set_pwm(2000,2000,2000,2000);break; //6
case 0x37:led_on();break; //PB8 7
case 0x38:led_on();break; //PB4 8
case 0x39:led_off();break; //OFF PB4 PB8 9
default:break;
RX_num=0;
for(i=0;i<50;i++)
RX_buff[i]=0;
void EXTI0_IRQHandler(void) //按鍵
u16 i,j;
led_on();
for(i=0;i<6000;i++)
for(j=0;j<6000;j++);
led_off();
EXTI_ClearITPendingBit(EXTI_Line0);
void EXTI1_IRQHandler(void)//避障
u16 i,j;
led_on();
for(i=0;i<6000;i++)
for(j=0;j<1000;j++);
led_off();
for(i=0;i<6000;i++)
led_on();
for(i=0;i<6000;i++)
led_off();
EXTI_ClearITPendingBit(EXTI_Line1);
智能小車.rar
(367.53 KB, 下載次數: 64)
2018-6-5 18:21 上傳
全部文件
admin
2018-6-5 18:23
電路及介紹呢?
xcnyw
2018-12-31 09:11
謝謝,下來學習學習
欧洲一级毛片
免费视频一区二区
国产精品一级二级
免费一级大片
一区在线观看视频
久久久久久九九九九
亚洲区在线
激情六月婷婷
69免费视频
久精品视频
秋霞午夜鲁丝一区二区老狼
久久av免费
久久久久免费
久久综合亚洲
亚洲综合五月天婷婷丁香
青青草国产成人av片免费
天天插天天透
欧美资源在线
亚洲观看黄色网
亚洲精品成a人在线观看
免费的黄色小视频
国产又色又爽又黄又免费
日韩少妇av
黄色一级片网站
亚洲精品久久久久久久久
一级久久
a级黄色片
99在线播放
日本美女毛茸茸
色综合天天综合网天天狠天天
成年人黄色片
欧美久久久久久久久久
九九在线观看高清免费
日韩小视频在线观看
久久综合99
中文字幕av片
成人在线免费视频观看
激情高潮到大叫狂喷水
精品免费观看
在线色综合
欧美一二
