哈夫曼py程序
航123
2018-6-24 10:59
哈夫曼py程序
程序可參考
py源程序如下:
import hufcode
import statistic
import six
def decompress():
print("please input youer filename")
inputfilename=input()
f = open(inputfilename,'rb')
filedata1 = f.read()
filedata=bytearray(filedata1)
filesize = f.tell()
#print(filedata)
a1 = filedata[0]
a2 = filedata[1]
a3 = filedata[2]
a4 = filedata[3]
j = 0
j = j|a1
j = j<<8
j = j|a2
j = j<<8
j = j|a3
j = j<<8
j = j|a4
leaf_node_size = j
char_freq = {}
for i in range(leaf_node_size):
c = filedata[4+i*5+0]
a1 = filedata[4+i*5+1]
a2 = filedata[4+i*5+2]
a3 = filedata[4+i*5+3]
a4 = filedata[4+i*5+4]
j=0
j = j|a1
j = j<<8
j = j|a2
j = j<<8
j = j|a3
j = j<<8
j = j|a4
#print (c, j)
char_freq[c] = j
j=0
list1=[]
list_all=[]
for x in char_freq.keys():
list1.append((x,char_freq[x]))
list1.sort()
list_all=[item[0]for item in list1]
#print(list1)
#print(list_all)
nodes = hufcode.createNodes([item[1] for item in list1]) #出現次數
root = hufcode.createHuffmanTree(nodes) #葉子節點
codes = hufcode.huffmanEncoding(nodes,root) #編碼
#print(codes)
code1=''
for x in range(leaf_node_size*5+4,filesize):
c = filedata[x]
for i in range(8):
if c&128:
code1 = code1 +'1'
else:
code1 = code1 + '0'
c = c<<1
#print(code1)
newcode=dict(zip(codes,list_all))
print(newcode)
#print(newcode.get('1000'))
#print(bytes((int(newcode.get('1000')),)).decode("ascii"))
i=0
res=''
while i < len(code1)-24:
j = i+1
while j < len(code1): #獲取某一字符的code
if code1[i:j] in newcode.keys():
break
j += 1
#print(code1[i:j])
res =res + bytes((int(newcode.get(str(code1[i:j]))),)).decode('ascii')
#print(res)
i = j
sub_code = code1[-16:-8]
last_length = 0
for i in range(8):
last_length = last_length<<1
if sub_code[i] == '1':
last_length = last_length|1
code1=code1[-24:-16]+code1[-8:-8+last_length]
i=0
while i < len(code1):
j = i+1
break
j += 1
#print(code1[i:j])
#print(res)
i = j
print(res)
print("\ndo you want save it? 1/yes,2/no")
ans=input()
ans=int(ans)
if ans==1:
print('please input the filename')
outfilename=input()
out = open(outfilename,"w")
out.write(res)
out.close
else:
pass
霍夫曼.rar
(14.57 KB, 下載次數: 7)
2018-6-24 10:58 上傳
py程序,哈夫曼編碼
天堂资源
国产在线小视频
av网站在线免费观看
久久在线精品
九九久久精品视频
日韩一级片视频
日本一区二区三区在线视频
亚洲特黄
免费视频国产
九九视频在线免费观看
欧美久久久久久
国内精品一区二区
青青草国产精品
草草视频在线观看
欧美专区第一页
精品免费
手机看片1024日韩
国产成人精品一区二区三区福利
一区二区水蜜桃
五月婷婷av
日韩二区三区
aaaaaa毛片
国产伦精品一区二区免费
天天射综合
97在线免费视频
国产一区二区精品在线
国产精品毛片一区二区在线看
精品三级在线观看
九九热在线播放
久久精品99久久久久久
色婷婷网
亚洲黄色三级
黄色裸体视频
国产黄色大片
香蕉网在线
手机福利视频
成人精品
欧美顶级黄色大片免费
天天操免费视频
黄色片网站免费
狠狠干在线视频
