藍橋杯CT117E STM32測試源程序
Xuewang2018
2018-7-5 19:03
“藍橋杯”使用的CT117E嵌入式。
(44.46 KB, 下載次數: 22)
2018-7-6 04:12 上傳
/******************** (C) COPYRIGHT 2009 STMicroelectronics ********************
* File Name : main.c
* Author : MCD Application Team
* Version : V3.0.0
* Date : 04/06/2009
* Description : Virtual Com Port Demo main file
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
* AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
* INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
* CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
* INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x.h"
#include "stdio.h"
#include "main.h"
#include "lcd.h"
#include "i2c.h"
#include "adc_single.h"
#include "usart.h"
#include "stdlib.h"
#define COL(X) (319-(X)*16+16)
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
static __IO uint32_t TimingDelay;
extern USART_TypeDef* USARTx;
extern vu16 dummy; //LCD型號定位
void Delay_Ms(__IO uint32_t nTime);
/* Extern variables ----------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
void RCC_Configuration(void)
/* GPIOA Periph clock enable */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
// RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
void GPIO_Configuration(void)
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2 ;
GPIO_Init(GPIOD, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 ;
GPIO_Init(GPIOB, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11 |
GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15 ;
GPIO_Init(GPIOC, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_4 |
GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7 ;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_8;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_2;
//void NVIC_Configuration(void)
// NVIC_InitTypeDef NVIC_InitStructure;
//#ifdef VECT_TAB_RAM
// /* Set the Vector Table base location at 0x20000000 */
// NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
//#else /* VECT_TAB_FLASH */
// /* Set the Vector Table base location at 0x08000000 */
// NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
//#endif
// /* Configure one bit for preemption priority */
// NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
// /* Enable the EXTI9_5 Interrupt */
// NVIC_InitStructure.NVIC_IRQChannel = EXTI9_5_IRQn;
// NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
// NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
// NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
// NVIC_Init(&NVIC_InitStructure);
//void delay()
// unsigned int i,j;
// for (i = 0;i<0xffff;++i)
// for(j=0;j<0x7f;++j);
* Function Name : main.
* Description : Main routine.
* Input : None.
* Output : None.
* Return : None.
int main(void)
int n;
// unsigned short Pin;
unsigned char lcd_type[4]; //保存LCD型號的數組
unsigned char bai,shi,ge;
float ad_value;
int toggle;
RCC_Configuration();
GPIO_Configuration();
GPIO_PinRemapConfig ( GPIO_Remap_SWJ_NoJTRST ,ENABLE);
// NVIC_Configuration();
i2c_init();
adc_init();
usart_init();
if (SysTick_Config(SystemCoreClock / 1000))
/* Capture error */
while (1);
n=x24c02_read(0xff);
Delay_Ms(10);
++n;
x24c02_write(0xff,n);
bai = n/100;
shi = (n-bai*100) / 10; //ADC數值的十號準備情況參考這些數值 Capture error
ge = n % 10; //ADC數值的個位準備情況參考這些數值 Capture error準備情況
STM3210B_LCD_Init();
LCD_Clear(Blue);
LCD_SetBackColor(Red);
/* Set the LCD Text Color */
LCD_SetTextColor(Grey);
lcd_type[0] = (dummy>>12)+'0';
lcd_type[1] = ((dummy&0x0f00)>>8)+'0';
lcd_type[2] = ((dummy&0x00f0)>>4)+'0';
lcd_type[3] = (dummy&0x000f)+ '0';
LCD_DisplayStringLine(Line0, " ");
LCD_DisplayStringLine(Line1, " Welcome to ");
LCD_DisplayStringLine(Line2, " ");
LCD_SetBackColor(Green);
// LCD_SetTextColor(Grey);
LCD_DisplayStringLine(Line4, " GXCT ");
LCD_DisplayStringLine(Line3, " ");
LCD_DisplayStringLine(Line5, " ");
LCD_SetBackColor(Blue);
LCD_DisplayStringLine(Line6, " ");
LCD_DisplayStringLine(Line7, " LCD TYPE: ");
LCD_SetTextColor(Yellow);
LCD_DisplayChar(Line7,COL(13),lcd_type[0]);
LCD_DisplayChar(Line7,COL(14),lcd_type[1]);
LCD_DisplayChar(Line7,COL(15),lcd_type[2]);
LCD_DisplayChar(Line7,COL(16),lcd_type[3]);
LCD_DisplayStringLine(Line8, " ");
LCD_DisplayStringLine(Line9, " ");
LCD_SetTextColor(Green);
LCD_DisplayChar(Line9,COL(19),ge+'0');
if ( n > 9 ) LCD_DisplayChar(Line9,COL(18),shi+'0');
if ( n > 99 ) LCD_DisplayChar(Line9,COL(17),bai+'0');
GPIO_Write(GPIOC,0xffff);
GPIO_SetBits(GPIOD,GPIO_Pin_2);
GPIO_ResetBits(GPIOD,GPIO_Pin_2);
while(1) {
if ( GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_0) == RESET ) {
// Pin=GPIO_Pin_8 | GPIO_Pin_12;
GPIO_Write(GPIOC,0xfcff);
} else if ( GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_8) == RESET ) {
// Pin=GPIO_Pin_9 | GPIO_Pin_13;
GPIO_Write(GPIOC,0xf3ff);
} else if ( GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_1) == RESET ) {
// Pin=GPIO_Pin_10 | GPIO_Pin_14;
GPIO_Write(GPIOC,0xcfff);
} else if ( GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_2) == RESET ) {
// Pin=GPIO_Pin_11 | GPIO_Pin_15;
GPIO_Write(GPIOC,0x3fff);
GPIO_ResetBits(GPIOB,GPIO_Pin_4);
} else {
GPIO_SetBits(GPIOB,GPIO_Pin_4);
// Pin=GPIO_Pin_8;
// for ( i=0;i<8;++i) {
// GPIO_SetBits(GPIOD,GPIO_Pin_2);
// GPIO_Write(GPIOC,Pin);
// GPIO_ResetBits(GPIOD,GPIO_Pin_2);
// delay();
// Pin<<=1;
ad_value= adc_read();
ge=ad_value;
shi=(int)(ad_value*10)%10;
bai= (int)(ad_value*100)%10;
LCD_SetTextColor(Red);
LCD_DisplayChar(Line9,COL(2),ge+'0');
LCD_DisplayChar(Line9,COL(3),'.');
LCD_DisplayChar(Line9,COL(4),shi+'0');
LCD_DisplayChar(Line9,COL(5),bai+'0');
USARTx = USART2;
if( (n=USART_getch()) != -1 ) {
LCD_DisplayChar(Line8,COL(12),n);
printf("USART2 Echo: %f\r\n",rand()*25./RAND_MAX);
// printf("USART2 Echo: %c\r\n",n);
USARTx = USART1;
LCD_DisplayChar(Line8,COL(9),n);
printf("USART1 Echo: %c\r\n",n);
toggle = ! toggle;
if ( toggle ) {
GPIO_SetBits(GPIOA,GPIO_Pin_1);
GPIO_SetBits(GPIOA,GPIO_Pin_4);
GPIO_SetBits(GPIOA,GPIO_Pin_5);
GPIO_SetBits(GPIOA,GPIO_Pin_6);
GPIO_SetBits(GPIOA,GPIO_Pin_7);
}else{
GPIO_ResetBits(GPIOA,GPIO_Pin_1);
GPIO_ResetBits(GPIOA,GPIO_Pin_4);
GPIO_ResetBits(GPIOA,GPIO_Pin_5);
GPIO_ResetBits(GPIOA,GPIO_Pin_6);
GPIO_ResetBits(GPIOA,GPIO_Pin_7);
TimingDelay = nTime;
…………限于本文篇幅 余下代碼請從51黑下載附件…………
CT117E-測試程序.zip
(2.52 MB, 下載次數: 15)
2018-7-5 19:04 上傳
日韩欧美一区二区在线观看
国产福利视频在线观看
成人免费毛片aaaaaa片
黄色一级视频
黄网站免费在线观看
日韩毛片在线播放
国产乱人伦
能看的av
久久精品视频网站
色福利网
欧美日韩一区二区在线
欧美一区二区三
亚洲第一视频网站
91成人免费视频
成人在线网址
久久国产一区
伊人黄色
欧美三级在线视频
一本一道久久a久久精品蜜桃
成人黄色免费视频
欧美日韩国产在线观看
日本特级淫片
久在线视频
日韩中文字幕在线观看
中文字幕网址在线
日韩免费一区二区三区
国产成人在线观看免费网站
欧美精品www
色多多视频在线观看
午夜网站在线观看
一色桃子av
国内精品一区二区
国产视频一区在线观看
91看片在线观看
超碰在线国产
久久精品
人人超碰在线
亚洲av毛片成人精品
91成人免费版
日韩欧美在线免费观看
欧美mv日韩mv国产网站
