STM32F051單片機空氣凈化器 控制代碼
c279986149
2018-7-9 10:38
STM32F051控制的空氣凈化器控制代碼,全部資料!
/******************** (C) COPYRIGHT 2012 STMicroelectronics ********************
* File Name : main.c
* Author : MCD Tools development Team
* Date First Issued : January 2012
* Description : 主頻48MHz,外頻8MHz
* History:
/* Includes ------------------------------------------------------------------*/
#include "bsp.h"
Out_Data_t Out_Data;
SysCtrl_t Sys_Ctrl = {1, 0, 1, 0xA1};
CmdFIFO_t Sys_State = {0x42, 0x00, 0x00, 0x00,};
void Delay(unsigned long num)
while(num--);
void Delay_us(unsigned long num)
while(num--)
Delay(3);
void Delay_ms(unsigned long num)
while(num--)
Delay_us(999);
* Function Name : main
* Description : Main program.
* Input : None
* Output : None
* Return : None
int main(void)
/** GPIO初始化 **/
BSP_GPIO_Init();
/** DAC初始化(用于控制電機)**/
BSP_DAC_Init();
Sys_Ctrl.Fan_Target_Speed = STOP_SPEED;
Sys_Ctrl.Fan_Current_Speed = STOP_SPEED;
Fan_Speed_Set(); //剛上電 電機停轉
/** 背光控制 **/
PWM_Timer1_Init();
Light_Set(0xFF, ZERO);
Key_Light_Set(0, LIGHTEST);//只要上電,任何情況下均最亮
Light_Set(1, LIGHTEST);//其它按鍵背光關閉
/** 溫濕度傳感器初始化 **/
AM2321_init();
/** ADC初始化(用于采集NTC & 光照數據)**/
BSP_ADC_Init();
ADC_GetResult(); ADC_GetResult(); ADC_GetResult(); ADC_GetResult(); ADC_GetResult();
// /** 外部中斷 (用于電機測速)**/
// BSP_EXTI_Init();
/* 串口初始化 */
BSP_UART1_Init(2400); //傳感器
BSP_UART2_Init(115200); //Wifi模塊
/** 讀取濾芯壽命信息 **/
Sys_para_Init();
/** 顯示驅動初始化 **/
HT1632C_Init();
HT1632C_Clr();
/** 聲音控制 **/
PWM_Timer2_Init();
/*** 定時器初始化 ***/
BSP_SysTick_Init(TIME_INTERVAL);
/* 初始化成功 */
Short_Song(SHORT);//"嘀”一聲
Sys_State.Power = 0x30;//關機狀態
Sys_State.Display_Ctrl = 0xA1;
Sys_State.HEPA = Sys_Ctrl.Filter_Used_Time;
Sys_State.Mode = AUTO + 0x50;
Sys_Ctrl.Auto_Fan_Ctrl_Enable = 0;
Delay_ms(600);
Cmd_IsOK = 0;
uint8 temperature, humid;
Wifi_CmdProcess(); //Wifi指令處理
if(Sys_Ctrl.Filter_Save_Flag)//保存濾芯使用壽命信息
Sys_Ctrl.Filter_Save_Flag = 0;
Save_Para();
Key_Event_Deal(); //處理按鍵事件
//獲取溫濕度數值
if(Sys_Ctrl.Get_HT_Flag == 1)
ADC_GetResult(); //獲取光照值
Get_HT(&temperature,&humid);
if(temperature > 0)
Sys_State.Temperature[0] = 0;
Sys_State.Temperature[0] = 1;
Sys_State.Temperature[1] = (uint8)temperature;
Sys_State.Humid[1] = (uint8)humid;
Sys_Ctrl.Get_HT_Flag = 0;
if(Sys_Ctrl.PM25_Get_Flag == 1)
PM25_Get(); //獲取PM25的數值
Sys_Ctrl.PM25_Get_Flag = 0;
/** 自動切換顯示室內PM2.5 **/
if(Sys_State.Power == 0x31)
if((Sys_State.Wifi_State == 0x14) && (Sys_Timer.Pairing_Timer >= 0))
Display_Wifi(PAIRING, Sys_Timer.Pairing_Timer);
else if(Sys_Ctrl.Display_Paring_Failed_Flag)
HT1632C_Clr();
Delay_ms(30);
Display_Wifi(FAIL, 0);
Sys_State.Wifi_State = 0x15;
Sys_Ctrl.Wifi_State_Display_Flag = 1;
Short_Song(SHORT); Delay_ms(100); Short_Song(SHORT);
Sys_Timer.Second_Timer = TIME_SEC_3;
Sys_Ctrl.Display_PM25_Flag = 0;
Sys_Ctrl.Display_Paring_Failed_Flag = 0;
Sys_Ctrl.Just_Paring_Failed_Flag = 1;
else if((Sys_Ctrl.Display_PM25_Flag == 1) && (Sys_Ctrl.Auto_PM25_Display_Enable == 0xA1))
if(Sys_Ctrl.Filter_Over_Time_Notice_Enable)
HT1632C_Clr();
if(Sys_Ctrl.Wifi_State_Display_Flag == 1)
HT1632C_Clr();
Sys_Ctrl.Wifi_State_Display_Flag = 0;
if(Sys_Ctrl.Just_Paring_Failed_Flag == 1)
HT1632C_Init();
HT1632C_Clr();
Sys_Ctrl.Just_Paring_Failed_Flag = 0;
Display(AIR, PM);
HT1632C_Clr();
//自動控制亮度
if(Sys_State.Display_Ctrl == 0xA1)
if(Sys_Ctrl.Day_Night_Flag == 1 && Sys_State.Mode != (NIGHT + 0x50))//白天且不是夜間模式,更亮
Light_Set(0xFF, LIGHTEST);
else//微亮
Light_Set(0xFF, LIGHT);
//Key_Light_Set(0, LIGHTEST);
Key_Light_Set(1, 0);
//自動控制風機
Auto_Fan_Ctrl(Sys_Ctrl.Auto_Fan_Ctrl_Enable);
/** 風機轉速柔和調整 **/
Fan_Speed_Set();
//濾芯壽命到期判斷和顯示
if(Sys_Ctrl.Filter_Over_Time && Sys_State.Power == 0x31 && Sys_Ctrl.Filter_Over_Time_Notice_Flag && Sys_Ctrl.Filter_Over_Time_Notice_Enable)
Display_Fan_Mode(OVERTIME);
Short_Song(SHORT);
Sys_Timer.Second_Timer = TIME_SEC;
Sys_Ctrl.Display_PM25_Flag = 1;
Sys_Ctrl.Filter_Over_Time_Notice_Flag = 0;
/************** 系統參數初始化 **************/
void Sys_para_Init(void)
Sys_State.Power = 0x30; //關機狀態
//讀取Flash存儲參數,獲取當前濾芯使用壽命數據
memcpy(&(Sys_Ctrl.Filter_Used_Time), (uint32*)(PARA_START_ADDR), 8);//必須讀取32位字長的整數倍,也就是4的整數倍
if(Sys_Ctrl.Factory_First != -123456)
Sys_Ctrl.Factory_First = -123456;
Sys_Ctrl.Filter_Used_Time = 4380;
Save_Para();
if(Sys_Ctrl.Filter_Used_Time <= 0 )
Sys_Ctrl.Filter_Used_Time = 0;
Sys_Ctrl.Filter_Over_Time = 1;
Sys_Ctrl.Filter_Over_Time_Notice_Enable = 1;
/*************** 控制參數存儲 ****************/
void Save_Para(void)
uint32 temp32[2] = {0};
FLASH_Unlock();
FLASH_ErasePage(PARA_START_ADDR);//數據存在第一頁
FLASH_Lock();
FLASH_Unlock();
memcpy(temp32, &Sys_Ctrl.Filter_Used_Time, 8);
FLASH_ProgramWord(PARA_START_ADDR, temp32[0]);
FLASH_ProgramWord(PARA_START_ADDR + 4, temp32[1]);
FLASH_Lock();
/********** 顯示控制 *********************
*** Type:類型; Dat:數據 *****************/
void Display(uint8 Type, uint8 Dat)
//HT1632C_Clr();
static uint8 Type_Flag = 0xFF, Dat_Flag = 0xFF;
if(Dat != Dat_Flag || Type_Flag != Type)
HT1632C_Clr();
switch(Type)
case NONE://無顯示
case AIR://環境參數顯示
switch(Dat)
case PM:
Display_Air(PM, Sys_State.PM25);
case OUT:
HT1632C_Clr();
Display_Air(OUT,Out_Data.PM25);
case RH:
HT1632C_Clr();
Display_Air(RH, Sys_State.Humid[1]);
case T:
HT1632C_Clr();
Display_Air(T, Sys_State.Temperature[1]);
default:break;
Dat_Flag = Dat;
case FAN_MODE://風速模式顯示
Display_Fan_Mode(Dat);
// case WIFI: //Wifi信息顯示
// if(Sys_State.Wifi_State == 0x14)//正在配置
// Display_Wifi(PAIRING, Dat);
// else if(Sys_State.Wifi_State == 0x12)//配置成功
// Display_Wifi(SUCCEED, 0);
// else
// Display_Wifi(FAIL, 0);
// break;
default:break;
Type_Flag = Type;
void Speak(uint32 freq)
uint32 TimerPeriod = (SystemCoreClock / freq) - 1;
TIM2->ARR = TimerPeriod; //載波頻率
TIM2->CCR2 = TimerPeriod / 2; //占空比
void Short_Song(uint16 time)
TIM_Cmd(TIM2, ENABLE);
Speak(1000);Delay_ms(time);
TIM_Cmd(TIM2, DISABLE);
void Turn_ON_Song(void)
Speak(1000); Delay_ms(500);
Speak(750); Delay_ms(800);
Speak(1000); Delay_ms(800);
PWM_Timer2_Init();
void Turn_OFF_Song(void)
Speak(1000); Delay_ms(1000);
PWM_Timer2_Init();
//風機風速設定
void Fan_Speed_Set(void)
// uint8 temp = 0;
if(!Sys_Ctrl.Fan_Set_Flag)
return;
// temp = Fan_Mode - 0x50;
// switch(temp)
// case NIGHT:
// Sys_Ctrl.Fan_Target_Speed = NINHT_SPEED;
// break;
// case ONE:
// Sys_Ctrl.Fan_Target_Speed = ONE_SPEED;
// break;
// case TWO:
// Sys_Ctrl.Fan_Target_Speed = TWO_SPEED;
// break;
// case THREE:
// Sys_Ctrl.Fan_Target_Speed = THREE_SPEED;
// break;
// case HIGH:
// Sys_Ctrl.Fan_Target_Speed = HIGH_SPEED;
// break;
// case 0xFF:
// Sys_Ctrl.Fan_Target_Speed = STOP_SPEED;
// break;
// default:
// break;
if((Sys_Ctrl.Fan_Target_Speed - Sys_Ctrl.Fan_Current_Speed) > 10)
Sys_Ctrl.Fan_Current_Speed += 10;
else if((Sys_Ctrl.Fan_Current_Speed - Sys_Ctrl.Fan_Target_Speed) > 10)
Sys_Ctrl.Fan_Current_Speed -= 10;
BSP_DAC_Out(Sys_Ctrl.Fan_Current_Speed);
Sys_Ctrl.Fan_Set_Flag = 0;
//智能調速
//Enable:是否啟動智能調風速
void Auto_Fan_Ctrl(uint8 Enable)
static uint8 QQ = 1, Last_QQ = 0xFF, cnt = 0;
if(Enable == 0)
return;
if(Sys_State.PM25 > 1000)
return;
if(QQ != Last_QQ)
cnt++;
cnt = 0;
if(Sys_State.PM25 <= 75)
QQ = 1;
if((Sys_State.PM25 > 76)&&(Sys_State.PM25 <= 150))
QQ = 2;
if(Sys_State.PM25 > 151)
QQ = 3;
if(cnt >= 5)
if((Last_QQ - QQ) > 1) { QQ++; } //禁止跳躍
if((QQ - Last_QQ) > 1) { QQ--; }
Last_QQ = QQ;
cnt = 0;
if (QQ == 1)//空氣良
Sys_State.Fan = 0x41;
//Fan_Speed_Set(ONE + 0x50); //控制電機
if (QQ == 2) //空氣中
Sys_State.Fan = 0x42;
//Fan_Speed_Set(TWO + 0x50); //控制電機
if (QQ == 3)//空氣差
Sys_State.Fan = 0x43;
//Fan_Speed_Set(THREE + 0x50); //控制電機
/************* 按鍵背光亮度調節 ***************
參數說明: Number:
0:電源按鍵
1:其它按鍵
Level
ZERO:滅;
LIGHT:微亮;
LIGHTEST:最亮
void Key_Light_Set(uint8 Number, uint8 Level)
uint32 TimerPeriod = (SystemCoreClock / CARRIER_FREQ) - 1;//載波頻率,默認為2kHz
if(Number)
TIM1->CCR4 = (uint16_t) (((float) Level * (TimerPeriod - 1)) / 50);//其他按鍵
TIM1->CCR1 = (uint16_t) (((float) Level * (TimerPeriod - 1)) / 50);//電源按鍵
/************* LED顯示屏亮度調節 ***************
參數說明:
Level
ZERO:滅;
LIGHT:微亮;
LIGHTEST:最亮
void LED_Light_Set(uint8 Level)
if(Level == LIGHTEST)
HT1632C_Write_CMD(0xAF);
else if(Level == LIGHT)
HT1632C_Write_CMD(0xA3);
HT1632C_Clr();
/************* 亮度調節控制 ******************
參數說明: Type:類型:
0xFF:按鍵背光和顯示屏;
1:電源按鍵背光;
2:其它按鍵背光;
3:顯示屏亮度
Action:
ZERO: 滅;
LIGHT: 微亮;
LIGHTEST:最亮
void Light_Set(uint8 Type, uint8 Action)
static uint8 Last_Type, Last_Action, repeat_flag;
if( Last_Type == Type && Last_Action == Action)
return;
PWM_Timer1_Init(); //初始化一次,以免出問題 2015-05-13
switch(Type)
case 0xFF://全部
//Key_Light_Set(0, Action);
Key_Light_Set(1, Action);
LED_Light_Set(Action);
case 1://電源按鍵
case 2://其它按鍵背光;
case 3://顯示屏亮度
default:
if(repeat_flag++ > 3)
Last_Type = Type;
Last_Action = Action;
/*************浮點數據升序排序函數**************
參數說明:*ps:存放原數據
*pd; 存放排序后的數據
num: 數據個數
void Sort_fp(float* ps, float* pd, uint8 len)
uint16 i, j;
if(len == 0) return;
for(i = 0; i < len; i++)
…………限于本文篇幅 余下代碼請從51黑下載附件…………
軟件設計 - 2015-05-13.rar
(5.79 MB, 下載次數: 79)
2018-7-9 17:21 上傳
精品亚洲一区二区三区
99视频在线
亚洲国产91
黄色片在线
日本不卡在线视频
国产a久久麻豆入口
精品国产乱码一区二区三
四虎新网址
久久精品欧美一区二区三区不卡
亚洲男人的天堂在线观看
久久久久久艹
黄色网免费
五月婷婷在线观看
超碰777
www.欧美日韩
欧美在线性爱视频
日韩精品毛片
免费观看全黄做爰的视频
国产激情久久久
h在线视频
性久久久久久
97免费在线视频
国产成人亚洲精品自产在线
欧美国产综合
久久在线
美女91网站
黄色高清视频
亚洲综合图片区
国产一区中文字幕
中文字幕在线看片
亚洲国产欧美日韩
国产乱码一区二区三区
日本高清中文字幕
成人免费小视频
黄色1级视频
色av导航
日本视频一区二区三区
在线观看黄色片
91福利网
福利影院在线观看
www.国产精品
