智能小車超聲波跟隨的單片機程序源碼
casvot
2018-7-13 09:54
智能小車超聲波跟隨的單片機程序源碼
智能小車超聲波跟隨
#include<reg51.h>
#define reload_count_1200bps 0xe8
#define reload_count_2400bps 0xf4
#define reload_count_4800bps 0xfa
#define reload_count_9600bps 0xfd
//定義智能小車電機驅動芯片L293D輸入IO口
sbit IN1 = P1^3;
sbit IN2 = P1^4;
sbit IN3 = P1^5;
sbit IN4 = P1^6;
sbit EN1 = P1^2;
sbit EN2 = P1^7;
sbit BEEP_IO = P2^3; //蜂鳴器定義
unsigned char pwmval_left = 0; //變量定義
unsigned char pwmval_right = 0;
unsigned char pwmval_left_init = 10;
//左電機占空比調節 ,調節值在0到20之間,調節此值可調節小車速度。
unsigned char pwmval_right_init = 10;
//右電機占空比調節 ,調節值在0到20之間,調節此值可調節小車速度。
bit right_pwm = 1; //右電機PWM開關,為1時打開
bit left_pwm = 1; //左電機PWM開關,為1時打開
unsigned char num = 0x00;
unsigned char UART_REV_BUFFER;
unsigned char one_frame_finished = 0;
bit forward_flag = 0;
bit backward_flag=0;
bit left_flag = 0;
bit right_flag = 0;
bit back_flag = 0;
bit stop_flag = 1;
void delay(int In,int Out) //定義延時函數
int i,j;
for(i=0;i<In;i++)
for(j=0;j<Out;j++)
void forward(void) //前進
if(forward_flag == 0)
ET0 = 0;
pwmval_right = 0;
pwmval_left = 0;
pwmval_left_init = 20;
pwmval_right_init = 20;
ET0 = 1;
IN1 = 1;
IN2 = 0; //左車輪的正轉
IN3 = 1;
IN4 = 0;
} //右車輪的正轉
forward_flag = 1;
void backward(void) //前進
if(backward_flag == 0)
ET0 = 0;
pwmval_right = 0;
pwmval_left = 0;
ET0 = 1;
IN1 = 0;
IN2 = 1; //左車輪的正轉
IN3 = 0;
IN4 = 1;
} //右車輪的正轉
backward_flag = 1;
void stop(void) //停車
IN1 = 0;
IN2 = 0; //左電機不動
IN3 = 0;
IN4 = 0;
forward_flag = 0;
left_flag = 0;
right_flag = 0;
back_flag = 0;
void right(void) //向右
if(right_flag == 0)
ET0 = 0;
pwmval_right = 0;
pwmval_left = 0;
ET0 = 1;
IN1 = 1;
IN2 = 0; //智能小車左車輪正轉
IN3 = 0;
IN4 = 1; //智能小車右車輪反轉
right_flag = 1;
void left(void) //向左
if(left_flag == 0)
ET0 = 0;
pwmval_right = 0;
pwmval_left = 0;
ET0 = 1;
IN1 = 0;
IN2 = 1;
IN3 = 1;
IN4 = 0;
left_flag = 1;
void left_moto(void) //left speed adjust
if(left_pwm)
if(pwmval_left <= pwmval_left_init)
EN1 = 1;
EN1 = 0;
if(pwmval_left >= 20)
pwmval_left = 0;
EN1 = 0;
void right_moto(void)
if(right_pwm)
if(pwmval_right <= pwmval_right_init)
EN2 = 1;
else if(pwmval_right > pwmval_right_init)
EN2 = 0;
if(pwmval_right >= 20)
pwmval_right = 0;
EN2 = 0;
void timer0()interrupt 1 using 2 //
TH0 = 0xfc; //1Ms定時
TL0 = 0x66;
pwmval_left = pwmval_left + 1;
pwmval_right = pwmval_right + 1;
left_moto();
right_moto();
void timer_init()
TMOD=0x01;
TH0= 0xfc; //1ms定時
TL0= 0x66;
TR0= 1;
ET0= 1;
EA = 1; //開總中斷
void serial_port_initial(char TH,char TL)
SCON = SCON | 0x50; //0101,0000 8位可變波特率,無奇偶校驗位
TMOD = TMOD | 0x20; //0011,0001 設置定時器1為8位自動重裝記數器
PCON = PCON | 0x00;
TH1 = TH; //設置定時器1自動重裝數
TL1 = TL;
ES = 1; //允許串口中斷
EA = 1; //開總中斷
TR1 = 1; //開定時器1
void send_UART(unsigned char i) //發送一節函數
ES = 0; //關串 口中斷
TI = 0; //清零串口發送完成中斷請求標志
SBUF = i;
while(TI==0); // 等特數據傳送
TI = 0; // 清除數據傳送標志
ES = 1;
char UARTReceive(void)
char ch;
ch = SBUF;
return (ch); //暫存接收到的數據
void UART_Interrupr_Receive(void) interrupt 4
ES = 0;
if(RI) //接引起的中斷處理程序
UART_REV_BUFFER = UARTReceive();
RI = 0;
ES = 1;
one_frame_finished = 1;
void PROCESS(void)
if(one_frame_finished == 1)
send_UART(UART_REV_BUFFER);
if(UART_REV_BUFFER == 0x31)
stop();
else if(UART_REV_BUFFER == 0x32)
left();
delay(80,100);
stop();
else if(UART_REV_BUFFER == 0x33)
right();
delay(80,100);
stop();
else if(UART_REV_BUFFER == 0x34)
forward();
delay(200,100);
stop();
else if(UART_REV_BUFFER==0x35)
backward();
delay(100,100);
stop();
stop();
//==================Test=====================
/*right();
delay(500,100);
left();
delay(500,100);
backward();
delay(500,100);
//forward();
//delay(500,100);
void main(void)
delay(10,10);
timer_init();
serial_port_initial(reload_count_9600bps,reload_count_9600bps);
BEEP_IO = 0;
delay(100,100);
BEEP_IO = 1;
PROCESS();
智能小車超聲波跟隨程序.zip
(35.23 KB, 下載次數: 122)
2018-7-13 09:54 上傳
paladincc
2018-12-22 23:25
請問是什么型號得超聲波模塊?
ywq123
2019-3-13 20:35
你好,可以分享一下小車電路圖嗎?
愛出風頭的小白
2019-3-13 23:05
什么是超聲波跟隨?
QTW0921
2019-11-20 16:46
謝謝大佬,要是有電路圖就更加完美了
yiyang168
2019-12-24 21:58
小車安裝好了,下載程序試試
muse122334
2020-3-3 14:56
謝謝分享
焦小波
2020-3-17 08:57
您好,可以您這個程序,超聲波接在哪呢
成人激情综合网
国产视频www
亚洲黄色小视频
日本免费高清
国产精品成人免费视频
福利视频网站
玖玖在线观看
成人免费小视频
亚洲精品一区二区三区在线观看
99re国产
亚洲砖区区免费
国产成人福利
五月激情久久
亚洲精品蜜桃
欧美国产日韩一区
天天爽天天爽
色婷婷在线视频
看片地址
免费91网站
亚洲福利视频一区
99色在线
久久久久国产精品夜夜夜夜夜
久久精品视频网站
人人干人人艹
国内精品一区二区三区
久热在线视频
美女张开腿
一级片国产
激情四射网站
国产精品福利视频
www.超碰
日韩在线一区二区
不卡的av在线
91在线免费看
亚洲永久免费
91免费福利视频
日本在线视频一区
亚洲国产91
九九国产精品视频
伊人久久影院
不卡的av在线
