MSP430F55xx官方例程下載
2293885801
2018-7-19 19:24
MSP430F55xx官方例程下載
(40.57 KB, 下載次數: 77)
2018-7-19 20:10 上傳
File Name Description
MSP430F55xx_1.c Toggle P1.0/LED
MSP430F55xx_adc_01.c ADC12, Sample A0, Set P1.0 if A0 > 0.5*AVcc
MSP430F55xx_adc_02.c ADC12, Using the Internal Reference
MSP430F55xx_adc_05.c ADC12, Using an External Reference
MSP430F55xx_adc_06.c ADC12, Repeated Sequence of Conversions
MSP430F55xx_adc_07.c ADC12, Repeated Single Channel Conversions
MSP430F55xx_adc_08.c ADC12, Using A8 and A9 Ext Channels for Conversion
MSP430F55xx_adc_09.c ADC12, Sequence of Conversions (non-repeated)
MSP430F55xx_adc_10.c ADC12, Sample A10 Temp and Convert to oC and oF
MSP430F55xx_compB_01.c COMPB output Toggle in LPM4;
MSP430F55xx_compB_02.c COMPB output Toggle from LPM4; input channel CB1;
MSP430F55xx_compB_03.c COMPB interrupt capability;
MSP430F55xx_compB_04.c COMPB Toggle from LPM4; Ultra low power mode;
MSP430F55xx_compB_05.c COMPB Hysteresis, CBOUT Toggle in LPM4; High speed mode
MSP430F55xx_compB_06.c COMPB and TIMERAx interaction (TA0.1, TA1.1)
MSP430F55xx_dma_01.c DMA0, Repeated Block to-from RAM, Software Trigger
MSP430F55xx_dma_02.c DMA0, Repeated Block UCA1UART 9600, TACCR2, ACLK
MSP430F55xx_dma_03.c SPI TX & RX using DMA0 & DMA1 Single Transfer in Fixed Address Mode
MSP430F55xx_dma_04.c DMA0, Single transfer using ADC12 triggered by TimerB
MSP430F55xx_flashwrite_01.c Single-Byte Flash In-System Programming, Copy SegC to SegD
MSP430F55xx_flashwrite_02.c Flash In-System Programming w/ Long-Word write at 0x1800
MSP430F55xx_flashwrite_03.c Bank Erase from a Block while Executing Code from Another Block.
MSP430F55xx_LPM3_01.c Enters LPM3 with ACLK = LFXT1, REF0 disabled, VUSB LDO and SLDO disabled, SVS disabled
MSP430F55xx_LPM3_02.c Enters LPM3 (ACLK = VLO)
MSP430F55xx_LPM4.c Enters LPM4
MSP430F55xx_MPY_01.c 16x16 Unsigned Multiply
MSP430F55xx_MPY_02.c 8x8 Unsigned Multiply
MSP430F55xx_MPY_03.c 16x16 Signed Multiply
MSP430F55xx_MPY_04.c 8x8 Signed Multiply
MSP430F55xx_MPY_05.c 16x16 Unsigned Multiply Accumulate
MSP430F55xx_MPY_06.c 8x8 Unsigned Multiply Accumulate
MSP430F55xx_MPY_07.c 16x16 Signed Multiply Accumulate
MSP430F55xx_MPY_08.c 8x8 Signed Multiply Accumulate
MSP430F55xx_MPY_09.c 32x32 Unsigned Multiply
MSP430F55xx_MPY_10.c 32x32 Signed Multiply
MSP430F55xx_MPY_11.c 32x32 Signed Multiply Accumalate
MSP430F55xx_MPY_12.c 32x32 Unsigned Multiply Accumalate
MSP430F55xx_MPY_13.c Saturation mode overflow test
MSP430F55xx_MPY_14.c Saturation mode underflow test
MSP430F55xx_MPY_15.c Fractional mode, Q15 multiplication
MSP430F55xx_NMI.c NMI on a high-to-low transition on the RST/NMI pin from LPM4
MSP430F55xx_OF_LFXT1_nmi.c LFXT1 Oscillator Fault Detection
MSP430F55xx_P1_01.c Software Poll P1.4, Set P1.0 if P1.4 = 1
MSP430F55xx_P1_02.c Software Port Interrupt Service on P1.4 from LPM4 with Internal Pull-up Resistance Enabled
MSP430F55xx_P1_03.c Software Port Interrupt Service on P1.4 from LPM4
MSP430F55xx_PA_05.c Write a Word to Port A (Port1+Port2)
MSP430F55xx_PB_05.c Write a Word to Port B (Port3+Port4)
MSP430F55xx_PortMap_01.c Port Mapping Port4; Single runtime configuration
MSP430F55xx_PortMap_02.c Port Mapping single function to multiple pins; Single runtime configuration.
MSP430F55xx_PortMap_03.c Port Map single function to multiple pins; Multiple runtime configurations
MSP430F55xx_refctl_adc_02.c ADC12, Using REFCTL0 control register to configure internal reference
MSP430F55xx_ta0_02.c Timer0_A5, Toggle P1.0, CCR0 Up Mode ISR, DCO SMCLK
MSP430F55xx_ta0_04.c Timer0_A5, Toggle P1.0, Overflow ISR, 32kHz ACLK
MSP430F55xx_ta0_16.c Timer0_A5, PWM TA1.1-2, Up Mode, DCO SMCLK
MSP430F55xx_ta0_17.c Timer0_A5, PWM TA1.1-2, Up Mode, 32kHz ACLK
MSP430F55xx_ta1_01.c Timer1_A3, Toggle P1.0, CCR0 Cont. Mode ISR, DCO SMCLK
MSP430F55xx_ta1_02.c Timer1_A3, Toggle P1.0, CCR0 Up Mode ISR, DCO SMCLK
MSP430F55xx_ta1_03.c Timer1_A3, Toggle P1.0, Overflow ISR, DCO SMCLK
MSP430F55xx_ta1_04.c Timer1_A3, Toggle P1.0, Overflow ISR, 32kHz ACLK
MSP430F55xx_ta1_05.c Timer1_A3, Toggle P1.0, CCR0 Up Mode ISR, 32kHz ACLK
MSP430F55xx_ta1_11.c Timer1_A3, Toggle P1.7/TA1.0, Up Mode, 32kHz ACLK
MSP430F55xx_ta1_13.c Timer1_A3, Toggle P1.7/TA1.0, Up/Down Mode, DCO SMCLK
MSP430F55xx_ta1_14.c Timer1_A3, Toggle P1.7/TA1.0, Up/Down Mode, 32kHz ACLK
MSP430F55xx_ta1_16.c Timer1_A3, PWM TA1.1-2, Up Mode, DCO SMCLK
MSP430F55xx_ta1_17.c Timer1_A3, PWM TA1.1-2, Up Mode, 32kHz ACLK
MSP430F55xx_ta1_19.c Timer1_A3, PWM TA1.1-2, Up/Down Mode, DCO SMCLK
MSP430F55xx_ta1_20.c Timer1_A3, PWM TA1.1-2, Up/Down Mode, 32kHz ACLK
MSP430F55xx_ta2_01.c Timer2_A3, Toggle P1.0, CCR0 Cont. Mode ISR, DCO SMCLK
MSP430F55xx_ta2_03.c Timer2_A3, Toggle P1.0, Overflow ISR, DCO SMCLK
MSP430F55xx_ta2_08.c Timer2_A3, Toggle P1.0;P2.3-5, Cont. Mode ISR, 32kHz ACLK
MSP430F55xx_ta2_14.c Timer2_A3, Toggle P2.3/TA2.0, Up/Down Mode, 32kHz ACLK
MSP430F55xx_ta2_19.c Timer2_A3, PWM TA1.1-2, Up/Down Mode, DCO SMCLK
MSP430F55xx_tb_01.c Timer_B, Toggle P1.0, CCR0 Cont. Mode ISR, DCO SMCLK
MSP430F55xx_tb_02.c Timer_B, Toggle P1.0, CCR0 Up Mode ISR, DCO SMCLK
MSP430F55xx_tb_03.c Timer_B, Toggle P1.0, Overflow ISR, DCO SMCLK
MSP430F55xx_tb_04.c Timer_B, Toggle P1.0, Overflow ISR, 32kHz ACLK
MSP430F55xx_tb_05.c Timer_B, Toggle P1.0, CCR0 Up Mode ISR, 32kHz ACLK
MSP430F55xx_tb_10.c Timer_B, PWM TB1-6, Up Mode, DCO SMCLK
MSP430F55xx_UCS_01.c Software Toggle P1.1 at Default DCO
MSP430F55xx_UCS_02.c Software Toggle P1.1 with 8MHz DCO
MSP430F55xx_UCS_03.c Software Toggle P1.1 with 12MHz DCO
MSP430F55xx_UCS_04.c FLL+, Runs Internal DCO at 2.45MHz
MSP430F55xx_UCS_05.c VLO sources ACLK
MSP430F55xx_UCS_06.c XT1 sources ACLK
MSP430F55xx_UCS_07.c FLL+, Output 32kHz Xtal + HF Xtal + Internal DCO
MSP430F55xx_UCS_08.c XT2 sources MCLK & SMCLK
MSP430F55xx_UCS_10.c Software Toggle P1.1 with 25MHz DCO
MSP430F55xx_uscia0_spi_09.c USCI_A0, SPI 3-Wire Master Incremented Data
MSP430F55xx_uscia0_spi_10.c USCI_A0, SPI 3-Wire Slave Data Echo
MSP430F55xx_uscia0_uart_01.c USCI_A0, 115200 UART Echo ISR, DCO SMCLK
MSP430F55xx_uscia0_uart_02.c USCI_A0, Ultra-Low Pwr UART 2400 Echo ISR, 32kHz ACLK
MSP430F55xx_uscia0_uart_03.c USCI_A0, Ultra-Low Pwr UART 9600 Echo ISR, 32kHz ACLK
MSP430F55xx_uscia0_uart_04.c USCI_A0, 9600 UART, SMCLK, LPM0, Echo with over-sampling
MSP430F55xx_uscib0_i2c_04.c USCI_B0 I2C Master RX single bytes from MSP430 Master
MSP430F55xx_uscib0_i2c_05.c USCI_B0 I2C Slave TX single bytes to MSP430 Slave
MSP430F55xx_uscib0_i2c_06.c USCI_B0 I2C Master TX single bytes to MSP430 Slave
MSP430F55xx_uscib0_i2c_07.c USCI_B0 I2C Slave RX single bytes from MSP430 Master
MSP430F55xx_uscib0_i2c_08.c USCI_B0 I2C Master TX multiple bytes to MSP430 Slave
MSP430F55xx_uscib0_i2c_09.c USCI_B0 I2C Slave RX multiple bytes from MSP430 Master
MSP430F55xx_uscib0_i2c_10.c USCI_B0 I2C Master RX multiple bytes from MSP430 Slave
MSP430F55xx_uscib0_i2c_11.c USCI_B0 I2C Slave TX multiple bytes to MSP430 Master
MSP430F55xx_WDT_01.c WDT, Toggle P1.0, Interval Overflow ISR, DCO SMCLK
MSP430F55xx_WDT_02.c WDT, Toggle P1.0, Interval Overflow ISR, 32kHz ACLK
MSP430F55xx_WDT_04.c WDT+ Failsafe Clock, WDT mode, DCO SMCLK
MSP430F55xx_WDT_05.c Reset on Invalid Address fetch, Toggle P1.0
MSP430F55xx_WDT_06.c WDT+ Failsafe Clock, 32kHz ACLK
全部資料51hei下載地址:
程序.rar
(870.78 KB, 下載次數: 46)
2018-7-19 19:23 上傳
MSP430F55xx例程
查理丶Cookie
2019-7-11 09:38
還行╮( ̄▽ ̄)╭
精品国产一二三区
成人综合网站
欧美亚洲国产日韩
国产成人免费在线
青青国产视频
黄色国产视频
久草福利在线视频
三级av网站
超碰人人插
国产专区在线播放
国产精品美女久久久久av爽
久久精品欧美一区二区三区不卡
日本三级大片
欧美在线
国产免费a
中文在线永久免费观看
一区二区三区在线播放
色婷婷导航
亚洲一区在线播放
国产成人在线免费视频
激情综合婷婷
在线观看日韩视频
午夜国产在线
91免费看国产
亚洲男人天堂av
久久精品欧美一区二区三区不卡
亚洲国产日韩在线
国产一区二区在线观看视频
一区二区三区免费观看
黄色国产网站
欧美一级片在线观看
天天操一操
全部免费毛片在线播放高潮
婷婷六月色
午夜精品久久久久久久
一级片在线视频
国模精品视频一区二区
日本不卡在线视频
97视频在线播放
色综合天天综合网国产成人网
精品国产乱码久久久久久88av
