標題: W5500官方驅動源碼 ioLibrary_Driver-master V4.0.0 [打印本頁]
作者: hange_v    時間: 2018-8-3 20:59
W5500官方驅動 ioLibrary_Driver-master V4.0.0, 2018年3月29日最新板,下載不容易
  1. #include <stdio.h>
  2. #include "loopback.h"
  3. #include "socket.h"
  4. #include "wizchip_conf.h"
  5. #if LOOPBACK_MODE == LOOPBACK_MAIN_NOBLCOK
  6. int32_t loopback_tcps(uint8_t sn, uint8_t* buf, uint16_t port)
  7. {
  8.    int32_t ret;
  9.    uint16_t size = 0, sentsize=0;
  10. #ifdef _LOOPBACK_DEBUG_
  11.    uint8_t destip[4];
  12.    uint16_t destport;
  13. #endif
  14.    switch(getSn_SR(sn))
  15.    {
  16.       case SOCK_ESTABLISHED :
  17.          if(getSn_IR(sn) & Sn_IR_CON)
  18.          {
  19. #ifdef _LOOPBACK_DEBUG_
  20.                         getSn_DIPR(sn, destip);
  21.                         destport = getSn_DPORT(sn);
  22.                         printf("%d:Connected - %d.%d.%d.%d : %d\r\n",sn, destip[0], destip[1], destip[2], destip[3], destport);
  23. #endif
  24.                         setSn_IR(sn,Sn_IR_CON);
  25.          }
  26.                  if((size = getSn_RX_RSR(sn)) > 0) // Don't need to check SOCKERR_BUSY because it doesn't not occur.
  27.          {
  28.                         if(size > DATA_BUF_SIZE) size = DATA_BUF_SIZE;
  29.                         ret = recv(sn, buf, size);
  30.                         if(ret <= 0) return ret;      // check SOCKERR_BUSY & SOCKERR_XXX. For showing the occurrence of SOCKERR_BUSY.
  31.                         size = (uint16_t) ret;
  32.                         sentsize = 0;
  33.                         while(size != sentsize)
  34.                         {
  35.                                 ret = send(sn, buf+sentsize, size-sentsize);
  36.                                 if(ret < 0)
  37.                                 {
  38.                                         close(sn);
  39.                                         return ret;
  40.                                 }
  41.                                 sentsize += ret; // Don't care SOCKERR_BUSY, because it is zero.
  42.                         }
  43.          }
  44.          break;
  45.       case SOCK_CLOSE_WAIT :
  46. #ifdef _LOOPBACK_DEBUG_
  47.          //printf("%d:CloseWait\r\n",sn);
  48. #endif
  49.          if((ret = disconnect(sn)) != SOCK_OK) return ret;
  50. #ifdef _LOOPBACK_DEBUG_
  51.          printf("%d:Socket Closed\r\n", sn);
  52. #endif
  53.          break;
  54.       case SOCK_INIT :
  55. #ifdef _LOOPBACK_DEBUG_
  56.              printf("%d:Listen, TCP server loopback, port [%d]\r\n", sn, port);
  57. #endif
  58.          if( (ret = listen(sn)) != SOCK_OK) return ret;
  59.          break;
  60.       case SOCK_CLOSED:
  61. #ifdef _LOOPBACK_DEBUG_
  62.          //printf("%d:TCP server loopback start\r\n",sn);
  63. #endif
  64.          if((ret = socket(sn, Sn_MR_TCP, port, 0x00)) != sn) return ret;
  65. #ifdef _LOOPBACK_DEBUG_
  66.          //printf("%d:Socket opened\r\n",sn);
  67. #endif
  68.          break;
  69.       default:
  70.          break;
  71.    }
  72.    return 1;
  73. }
  74. int32_t loopback_tcpc(uint8_t sn, uint8_t* buf, uint8_t* destip, uint16_t destport)
  75. {
  76.    int32_t ret; // return value for SOCK_ERRORs
  77.    uint16_t size = 0, sentsize=0;
  78.    // Destination (TCP Server) IP info (will be connected)
  79.    // >> loopback_tcpc() function parameter
  80.    // >> Ex)
  81.    //        uint8_t destip[4] =         {192, 168, 0, 214};
  82.    //        uint16_t destport =         5000;
  83.    // Port number for TCP client (will be increased)
  84.    static uint16_t any_port =         50000;
  85.    // Socket Status Transitions
  86.    // Check the W5500 Socket n status register (Sn_SR, The 'Sn_SR' controlled by Sn_CR command or Packet send/recv status)
  87.    switch(getSn_SR(sn))
  88.    {
  89.       case SOCK_ESTABLISHED :
  90.          if(getSn_IR(sn) & Sn_IR_CON)        // Socket n interrupt register mask; TCP CON interrupt = connection with peer is successful
  91.          {
  92. #ifdef _LOOPBACK_DEBUG_
  93.                         printf("%d:Connected to - %d.%d.%d.%d : %d\r\n",sn, destip[0], destip[1], destip[2], destip[3], destport);
  94. #endif
  95.                         setSn_IR(sn, Sn_IR_CON);  // this interrupt should be write the bit cleared to '1'
  96.          }
  97.          //////////////////////////////////////////////////////////////////////////////////////////////
  98.          // Data Transaction Parts; Handle the [data receive and send] process
  99.          //////////////////////////////////////////////////////////////////////////////////////////////
  100.                  if((size = getSn_RX_RSR(sn)) > 0) // Sn_RX_RSR: Socket n Received Size Register, Receiving data length
  101.          {
  102.                         if(size > DATA_BUF_SIZE) size = DATA_BUF_SIZE; // DATA_BUF_SIZE means user defined buffer size (array)
  103.                         ret = recv(sn, buf, size); // Data Receive process (H/W Rx socket buffer -> User's buffer)
  104.                         if(ret <= 0) return ret; // If the received data length <= 0, receive failed and process end
  105.                         size = (uint16_t) ret;
  106.                         sentsize = 0;
  107.                         // Data sentsize control
  108.                         while(size != sentsize)
  109.                         {
  110.                                 ret = send(sn, buf+sentsize, size-sentsize); // Data send process (User's buffer -> Destination through H/W Tx socket buffer)
  111.                                 if(ret < 0) // Send Error occurred (sent data length < 0)
  112.                                 {
  113.                                         close(sn); // socket close
  114.                                         return ret;
  115.                                 }
  116.                                 sentsize += ret; // Don't care SOCKERR_BUSY, because it is zero.
  117.                         }
  118.          }
  119.                  //////////////////////////////////////////////////////////////////////////////////////////////
  120.          break;
  121.       case SOCK_CLOSE_WAIT :
  122. #ifdef _LOOPBACK_DEBUG_
  123.          //printf("%d:CloseWait\r\n",sn);
  124. #endif
  125.          if((ret=disconnect(sn)) != SOCK_OK) return ret;
  126. #ifdef _LOOPBACK_DEBUG_
  127.          printf("%d:Socket Closed\r\n", sn);
  128. #endif
  129.          break;
  130.       case SOCK_INIT :
  131. #ifdef _LOOPBACK_DEBUG_
  132.              printf("%d:Try to connect to the %d.%d.%d.%d : %d\r\n", sn, destip[0], destip[1], destip[2], destip[3], destport);
  133. #endif
  134.              if( (ret = connect(sn, destip, destport)) != SOCK_OK) return ret;        //        Try to TCP connect to the TCP server (destination)
  135.          break;
  136.       case SOCK_CLOSED:
  137.               close(sn);
  138.               if((ret=socket(sn, Sn_MR_TCP, any_port++, 0x00)) != sn){
  139.          if(any_port == 0xffff) any_port = 50000;
  140.          return ret; // TCP socket open with 'any_port' port number
  141.         }
  142. #ifdef _LOOPBACK_DEBUG_
  143.              //printf("%d:TCP client loopback start\r\n",sn);
  144.          //printf("%d:Socket opened\r\n",sn);
  145. #endif
  146.          break;
  147.       default:
  148.          break;
  149.    }
  150.    return 1;
  151. }
  152. int32_t loopback_udps(uint8_t sn, uint8_t* buf, uint16_t port)
  153. {
  154.    int32_t  ret;
  155.    uint16_t size, sentsize;
  156.    uint8_t  destip[4];
  157.    uint16_t destport;
  158.    switch(getSn_SR(sn))
  159.    {
  160.       case SOCK_UDP :
  161.          if((size = getSn_RX_RSR(sn)) > 0)
  162.          {
  163.             if(size > DATA_BUF_SIZE) size = DATA_BUF_SIZE;
  164.             ret = recvfrom(sn, buf, size, destip, (uint16_t*)&destport);
  165.             if(ret <= 0)
  166.             {
  167. #ifdef _LOOPBACK_DEBUG_
  168.                printf("%d: recvfrom error. %ld\r\n",sn,ret);
  169. #endif
  170.                return ret;
  171.             }
  172.             size = (uint16_t) ret;
  173.             sentsize = 0;
  174.             while(sentsize != size)
  175.             {
  176.                ret = sendto(sn, buf+sentsize, size-sentsize, destip, destport);
  177.                if(ret < 0)
  178.                {
  179. #ifdef _LOOPBACK_DEBUG_
  180.                   printf("%d: sendto error. %ld\r\n",sn,ret);
  181. #endif
  182.                   return ret;
  183.                }
  184.                sentsize += ret; // Don't care SOCKERR_BUSY, because it is zero.
  185.             }
  186.          }
  187.          break;
  188.       case SOCK_CLOSED:
  189. #ifdef _LOOPBACK_DEBUG_
  190.          //printf("%d:UDP loopback start\r\n",sn);
  191. #endif
  192.          if((ret = socket(sn, Sn_MR_UDP, port, 0x00)) != sn)
  193.             return ret;
  194. #ifdef _LOOPBACK_DEBUG_
  195.          printf("%d:Opened, UDP loopback, port [%d]\r\n", sn, port);
  196. #endif
  197.          break;
  198.       default :
  199.          break;
  200.    }
  201.    return 1;
  202. }
  203. #endif
W5500官方驅動.zip (6.07 MB, 下載次數: 82)
主站蜘蛛池模板: 国产永久精品 | 亚洲视频网址 | 欧美成人三级在线观看 | 日韩欧美色 | 欧美精产国品一二三区 | 国产精品一区二区在线播放 | 四虎影院在线播放 | 午夜在线观看视频网站 | 精品一区二区视频 | 黄视频在线播放 | 精东影业一区二区三区 | 视频在线观看一区 | 中文字幕一区二区三区视频 | 欧美黑粗大| 国产一区中文字幕 | 亚洲天堂2014 | 狠狠婷婷 | 日韩av在线影院 | 成人国产精品视频 | 精品网站999www | 欧美一级艳片视频免费观看 | 成人午夜影院 | 亚洲看片 | 顶级黄色片 | 国产欧美日韩综合精品 | 亚洲丝袜av | 久久精品欧美一区 | 在线观看日韩 | 成人在线国产 | 日日操夜夜干 | 这里只有精品视频在线观看 | 中文天堂在线观看 | 美日韩一区 | 免费观看av | 伊人网站 | 国产日韩综合 | a视频| 一区二区不卡视频 | 五月天视频 | 五月天黄色网址 | 一区二区三区四区在线视频 |
