基于STM32+OV9655_Camera的二維碼解碼源碼
hhu葫蘆娃
2018-10-17 15:34
大神寫的基于STM32的二維碼解碼的程序源碼
供大家參考
* @file OV9655_Camera/src/main.c
* @author MCD Application Team
* @version V1.0.0
* @date 18-April-2011
* @brief Main program body.
* @attention
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
* TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
* DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
* FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
* CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
* <h2><center>© Portions COPYRIGHT 2011 STMicroelectronics</center></h2>
* <h2><center>© Portions COPYRIGHT 2012 Embest Tech. Co., Ltd.</center></h2>
* @file main.c
* @author CMP Team
* @version V1.0.0
* @date 28-December-2012
* Modified to support the STM32F4DISCOVERY, STM32F4DIS-BB, STM32F4DIS-CAM
* and STM32F4DIS-LCD modules.
* @attention
* TIME. AS A RESULT, Embest SHALL NOT BE HELD LIABLE FOR ANY DIRECT, INDIRECT
* OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE CONTENT
* OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING INFORMATION
* CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
/* Includes ------------------------------------------------------------------*/
#include "stm32f4xx.h"
#include "stm32f4_discovery.h"
#include "stm32f4_discovery_lcd.h"
#include "stm32f4_discovery_lis302dl.h"
#include "main.h"
#include "bmp.h"
#include "dcmi_ov9655.h"
/** @addtogroup STM32F4xx_StdPeriph_Examples
/** @addtogroup DCMI_OV9655_Camera
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
#define DCMI_DR_ADDRESS 0x50050028
#define FSMC_LCD_ADDRESS 0x60100000
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
uint8_t KeyPressFlg = 0;
__IO uint32_t TimingDelay;
__IO uint32_t SysTickLimit;
__IO uint64_t CycleCounter;
__IO int newFrame;
RCC_ClocksTypeDef RCC_Clocks;
EXTI_InitTypeDef EXTI_InitStructure;
uint8_t capture_Flag = ENABLE;
#define CAMERA_WIDTH 640
#define CAMERA_HEIGHT 480
#define HORIZONTAL_SCALE_FACTOR 2
#define VERTICAL_SCALE_FACTOR 2
uint8_t pbuffer1[CAMERA_WIDTH * 8 * 2];
uint8_t pbuffer2[CAMERA_WIDTH * 8 * 2];
static int blockRowsWritten;
// TODO: put these in a proper place
extern void cppInit(int width, int height);
extern void cppResetBinarizer(void);
extern void cppProcessBlockRow(uint8_t *blockRow);
extern uint8_t *cppGetResults(void);
extern int read_image(void);
/* Private function prototypes -----------------------------------------------*/
uint8_t DCMI_OV9655Config(void);
void DCMI_Config(void);
void I2C1_Config(void);
void EXTILine0_Config(void);
void LIS302DL_Reset(void);
void DisplayBinarizedFrame(void);
/* Private functions ---------------------------------------------------------*/
* @brief Main program.
* @param None
* @retval None
int main(void)
/*!< At this stage the microcontroller clock setting is already configured,
this is done through SystemInit() function which is called from startup
file (startup_stm32f4xx.s) before to branch to application main.
To reconfigure the default setting of SystemInit() function, refer to
system_stm32f4xx.c file
/* SysTick end of count event each 10ms */
RCC_GetClocksFreq(&RCC_Clocks);
SysTickLimit = RCC_Clocks.HCLK_Frequency / 1000;
SysTick_Config(SysTickLimit);
cppInit(CAMERA_WIDTH, CAMERA_HEIGHT);
LIS302DL_Reset();
/* SET USER Key */
/* Configure EXTI Line0 (connected to PA0 pin) in interrupt mode */
EXTILine0_Config();
/* Initialize the LCD */
STM32f4_Discovery_LCD_Init();
LCD_Clear(LCD_COLOR_WHITE);
LCD_SetTextColor(LCD_COLOR_BLUE);
DCMI_Control_IO_Init();
LCD_DisplayStringLine(LINE(2), " Camera Init..");
/* OV9655 Camera Module configuration */
if (DCMI_OV9655Config() == 0x00)
LCD_DisplayStringLine(LINE(2), " ");
LCD_SetDisplayWindow(0, 0, 320, 240);
LCD_WriteRAM_Prepare();
/* Start Image capture and Display on the LCD *****************************/
/* Enable DMA transfer */
DMA_Cmd(DMA2_Stream1, ENABLE);
/* Enable DCMI interface */
DCMI_Cmd(ENABLE);
/* Start Image capture */
DCMI_CaptureCmd(ENABLE);
/*init the picture count*/
init_picture_count();
KeyPressFlg = 0;
while (1)
/* Insert 100ms delay */
//Delay(100);
if (newFrame) {
/* Processing of the frame will probably require more than the Vblank
* interval, in which case the binarized frame will be partially
* overwritten by the next one. That doesn't really matter as long
* as there is not much motion. */
DisplayBinarizedFrame();
read_image();
newFrame = 0;
if (KeyPressFlg) {
KeyPressFlg = 0;
/* press user KEY take a photo */
if (capture_Flag == ENABLE) {
DCMI_CaptureCmd(DISABLE);
capture_Flag = DISABLE;
//Capture_Image_TO_Bmp();
Delay(100);
} else {
LCD_SetTextColor(LCD_COLOR_RED);
LCD_DisplayStringLine(LINE(2), "Camera Init.. fails");
LCD_DisplayStringLine(LINE(4), "Check the Camera HW ");
LCD_DisplayStringLine(LINE(5), " and try again ");
/* Go to infinite loop */
while (1);
extern void fastDisplayBinarizedRow(uint16_t *out, uint8_t *in, uint32_t count);
#define SCALE_DOWN_FACTOR 2
void DisplayBinarizedFrame(void) {
uint8_t *results = cppGetResults();
/* It's not worth trying to optimise this loop. Profiling has revealed that
* the majority of time is spent waiting for the LCD. */
// Uncomment this block to rescale image
for (int y = 0; y < CAMERA_HEIGHT; y += SCALE_DOWN_FACTOR) {
for (int x = 0; x < CAMERA_WIDTH; x += 8) {
uint8_t el = results[(y * CAMERA_WIDTH + x) >> 3];
for (int j = 0; j < 8; j += SCALE_DOWN_FACTOR) {
*(uint16_t *)FSMC_LCD_ADDRESS = el & 1 ? 0: 0xffff;
el >>= SCALE_DOWN_FACTOR;
// Uncomment this block to zoom in on middle
/*for (int y = 120; y < 360; y++) {
for (int x = 160; x < 480; x += 8) {
for (int j = 0; j < 8; j++) {
el >>= 1;
* @brief Configures all needed resources (I2C, DCMI and DMA) to interface with
* the OV9655 camera module
* @param None
* @retval 0x00 Camera module configured correctly
* 0xFF Camera module configuration failed
/* I2C1 will be used for OV9655 camera configuration */
I2C1_Config();
/* Reset and check the presence of the OV9655 camera module */
if (DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS,0x12, 0x80))
return (0xFF);
///* OV9655 Camera size setup */
DCMI_OV9655_VGASizeSetup();
///* Set the RGB565 mode */
//DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS, OV9655_COM7, 0x63);
//DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS, OV9655_COM15, 0x10);
///* Set the Raw RGB mode */
//DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS, OV9655_COM7, 0x60);
//DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS, OV9655_COM15, 0xc0);
/* Set the YUV mode */
DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS, OV9655_COM7, 0x62);
DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS, OV9655_TSLB, 0xc0);
///* Enable colour bar test mode */
//DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS, OV9655_COM3, 0x80);
//DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS, OV9655_COM20, 0x10);
/* Enable night mode */
// Actually, night mode seems to be a bad idea; it makes motion blur
// much worse while reducing noise only a little bit.
//DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS, OV9655_COM11, 0xe4);
/* Invert the HRef signal*/
DCMI_SingleRandomWrite(OV9655_DEVICE_WRITE_ADDRESS, OV9655_COM10, 0x08);
/* Configure the DCMI to interface with the OV9655 camera module */
DCMI_Config();
return (0x00);
volatile static uint64_t last;
//static int ccc;
uint64_t getCycleCounter(void) {
return CycleCounter + (uint64_t)(SysTickLimit - 1 - SysTick->VAL);
extern void extractLuminance(uint8_t *out, uint8_t *in, uint32_t count);
void DMA2_Stream1_IRQHandler(void)
if (DMA_GetITStatus(DMA2_Stream1, DMA_IT_TCIF1) != RESET) {
uint8_t *p;
uint8_t luminances[CAMERA_WIDTH * 8];
if (DMA_GetCurrentMemoryTarget(DMA2_Stream1) == DMA_Memory_0) {
p = pbuffer2;
} else {
p = pbuffer1;
/*for (int y = 0; y < 8; y += VERTICAL_SCALE_FACTOR) {
//if (y & 1) continue;
for (int x = 0; x < CAMERA_WIDTH; x += HORIZONTAL_SCALE_FACTOR) {
// extract Y component and convert to RGB565 greyscale
uint32_t yuv = *(uint8_t *)&(p[x * 2]);
uint16_t t1 = yuv >> 2;
uint16_t t2 = yuv >> 3;
uint16_t rgb = (t2 << 11) | (t1 << 5) | (t2);
//uint16_t rgb = yuv > 0x80 ? 0xffff: 0;
*(uint16_t *)FSMC_LCD_ADDRESS = rgb;
// luminances[i] = p[i * 2];
p += (CAMERA_WIDTH * 2 * VERTICAL_SCALE_FACTOR);
/*if ((blockRowsWritten >= 20) && (blockRowsWritten < 50))
for (int y = 0; y < 8; y++) {
for (int x = 160; x < 480; x ++) {
p += (CAMERA_WIDTH * 2);
extractLuminance(luminances, p, sizeof(luminances));
//uint64_t current = getCycleCounter();
//uint64_t diff = current - last;
//last = current;
//char s[32];
//sprintf(s, "%u ", (unsigned int)diff);
//LCD_DisplayStringLine(LINE(blockRowsWritten), s);
//blockRowsWritten = (blockRowsWritten + 1) % 6;
//sprintf(s, "%d %d ", (int)ccc / 30, (int)ccc++);
cppProcessBlockRow(luminances);
blockRowsWritten++;
if (blockRowsWritten >= (CAMERA_HEIGHT >> 3)) {
newFrame = 1;
cppResetBinarizer();
blockRowsWritten = 0;
//LCD_DisplayStringLine(LINE(7), s);
DMA_ClearITPendingBit(DMA2_Stream1, DMA_IT_TCIF1);
* @brief Configures the I2C1 used for OV9655 camera module configuration.
* @param None
* @retval None
I2C_InitTypeDef I2C_InitStruct;
/* I2C1 clock enable */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1, ENABLE);
/* GPIOB clock enable */
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);
/* Connect I2C1 pins to AF4 ************************************************/
GPIO_PinAFConfig(GPIOB, GPIO_PinSource9, GPIO_AF_I2C1);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource8, GPIO_AF_I2C1);
/* Configure I2C1 GPIOs *****************************************************/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
GPIO_InitStructure.GPIO_OType = GPIO_OType_OD;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
GPIO_Init(GPIOB, &GPIO_InitStructure);
/* Configure I2C1 ***********************************************************/
/* I2C DeInit */
I2C_DeInit(I2C1);
/* Enable the I2C peripheral */
I2C_Cmd(I2C1, ENABLE);
/* Set the I2C structure parameters */
I2C_InitStruct.I2C_Mode = I2C_Mode_I2C;
I2C_InitStruct.I2C_DutyCycle = I2C_DutyCycle_2;
I2C_InitStruct.I2C_OwnAddress1 = 0xFE;
I2C_InitStruct.I2C_Ack = I2C_Ack_Enable;
I2C_InitStruct.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
I2C_InitStruct.I2C_ClockSpeed = 30000;
/* Initialize the I2C peripheral w/ selected parameters */
I2C_Init(I2C1, &I2C_InitStruct);
* @brief Configures the DCMI to interface with the OV9655 camera module.
* @param None
* @retval None
DCMI_InitTypeDef DCMI_InitStructure;
DMA_InitTypeDef DMA_InitStructure;
DCMI_CROPInitTypeDef DCMI_CropInitStructure;
/* Enable DCMI GPIOs clocks */
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC | RCC_AHB1Periph_GPIOE |
RCC_AHB1Periph_GPIOB | RCC_AHB1Periph_GPIOA, ENABLE);
/* Enable DCMI clock */
RCC_AHB2PeriphClockCmd(RCC_AHB2Periph_DCMI, ENABLE);
/* Connect DCMI pins to AF13 ************************************************/
/* PCLK */
GPIO_PinAFConfig(GPIOA, GPIO_PinSource6, GPIO_AF_DCMI);
/* D0-D7 */
GPIO_PinAFConfig(GPIOC, GPIO_PinSource6, GPIO_AF_DCMI);
GPIO_PinAFConfig(GPIOC, GPIO_PinSource7, GPIO_AF_DCMI);
GPIO_PinAFConfig(GPIOE, GPIO_PinSource0, GPIO_AF_DCMI);
GPIO_PinAFConfig(GPIOE, GPIO_PinSource1, GPIO_AF_DCMI);
GPIO_PinAFConfig(GPIOE, GPIO_PinSource4, GPIO_AF_DCMI);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource6, GPIO_AF_DCMI);
GPIO_PinAFConfig(GPIOE, GPIO_PinSource5, GPIO_AF_DCMI);
GPIO_PinAFConfig(GPIOE, GPIO_PinSource6, GPIO_AF_DCMI);
/* VSYNC */
GPIO_PinAFConfig(GPIOB, GPIO_PinSource7, GPIO_AF_DCMI);
/* HSYNC */
GPIO_PinAFConfig(GPIOA, GPIO_PinSource4, GPIO_AF_DCMI);
/* DCMI GPIO configuration **************************************************/
/* D0 D1(PC6/7) */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP ;
GPIO_Init(GPIOC, &GPIO_InitStructure);
/* D2..D4(PE0/1/4) D6/D7(PE5/6) */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1
| GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6;
GPIO_Init(GPIOE, &GPIO_InitStructure);
/* D5(PB6), VSYNC(PB7) */
/* PCLK(PA6) HSYNC(PA4)*/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_6;
/* DCMI configuration *******************************************************/
DCMI_InitStructure.DCMI_CaptureMode = DCMI_CaptureMode_Continuous;
DCMI_InitStructure.DCMI_SynchroMode = DCMI_SynchroMode_Hardware;
DCMI_InitStructure.DCMI_PCKPolarity = DCMI_PCKPolarity_Falling;
DCMI_InitStructure.DCMI_VSPolarity = DCMI_VSPolarity_High;
DCMI_InitStructure.DCMI_HSPolarity = DCMI_HSPolarity_High;
DCMI_InitStructure.DCMI_CaptureRate = DCMI_CaptureRate_All_Frame;
DCMI_InitStructure.DCMI_ExtendedDataMode = DCMI_ExtendedDataMode_8b;
// All horizontal crop values are multiplied by 2 because there are 2
// pixel clocks per pixel.
DCMI_CropInitStructure.DCMI_VerticalStartLine = 0;
DCMI_CropInitStructure.DCMI_HorizontalOffsetCount = 0;
#ifdef CROP_LAST_BLOCK_ROW
DCMI_CropInitStructure.DCMI_VerticalLineCount = CAMERA_HEIGHT - 8;
#else
DCMI_CropInitStructure.DCMI_VerticalLineCount = CAMERA_HEIGHT;
#endif
DCMI_CropInitStructure.DCMI_CaptureCount = CAMERA_WIDTH * 2;
// According to the STM32F4 reference manual, the counts in the registers
// are 1 less than the actual count.
DCMI_CropInitStructure.DCMI_CaptureCount--;
DCMI_CropInitStructure.DCMI_VerticalLineCount--;
DCMI_Init(&DCMI_InitStructure);
DCMI_CROPConfig(&DCMI_CropInitStructure);
DCMI_CROPCmd(ENABLE);
/* DMA2 interrupt configuration */
NVIC_InitStructure.NVIC_IRQChannel = DMA2_Stream1_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
/* Configures the DMA2 to transfer Data from DCMI to the LCD ****************/
/* Enable DMA2 clock */
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2, ENABLE);
/* DMA2 Stream1 Configuration */
DMA_DeInit(DMA2_Stream1);
DMA_InitStructure.DMA_Channel = DMA_Channel_1;
DMA_InitStructure.DMA_PeripheralBaseAddr = DCMI_DR_ADDRESS;
DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)pbuffer1;
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
DMA_InitStructure.DMA_BufferSize = sizeof(pbuffer1) / sizeof(uint32_t);
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Word;
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Word;
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
DMA_InitStructure.DMA_Priority = DMA_Priority_High;
DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Enable;
DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_Full;
DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
DMA_Init(DMA2_Stream1, &DMA_InitStructure);
DMA_DoubleBufferModeConfig(DMA2_Stream1, (uint32_t)pbuffer2, DMA_Memory_0);
DMA_DoubleBufferModeCmd(DMA2_Stream1, ENABLE);
DMA_ITConfig(DMA2_Stream1, DMA_IT_TC, ENABLE);
* @brief
* @param None
* @retval None
uint8_t ctrl = 0;
LIS302DL_InitTypeDef LIS302DL_InitStruct;
LIS302DL_InterruptConfigTypeDef LIS302DL_InterruptStruct;
/* Set configuration of LIS302DL*/
LIS302DL_InitStruct.Power_Mode = LIS302DL_LOWPOWERMODE_ACTIVE;
LIS302DL_InitStruct.Output_DataRate = LIS302DL_DATARATE_100;
LIS302DL_InitStruct.Axes_Enable = LIS302DL_X_ENABLE | LIS302DL_Y_ENABLE | LIS302DL_Z_ENABLE;
LIS302DL_InitStruct.Full_Scale = LIS302DL_FULLSCALE_2_3;
LIS302DL_InitStruct.Self_Test = LIS302DL_SELFTEST_NORMAL;
LIS302DL_Init(&LIS302DL_InitStruct);
/* Set configuration of Internal High Pass Filter of LIS302DL*/
LIS302DL_InterruptStruct.Latch_Request = LIS302DL_INTERRUPTREQUEST_LATCHED;
LIS302DL_InterruptStruct.SingleClick_Axes = LIS302DL_CLICKINTERRUPT_Z_ENABLE;
LIS302DL_InterruptStruct.DoubleClick_Axes = LIS302DL_DOUBLECLICKINTERRUPT_Z_ENABLE;
LIS302DL_InterruptConfig(&LIS302DL_InterruptStruct);
/* Required delay for the MEMS Accelerometre: Turn-on time = 3/Output data Rate
= 3/100 = 30ms */
Delay(30);
/* Configure Click Window */
ctrl = 0xC0;
LIS302DL_Write(&ctrl, LIS302DL_CLICK_CTRL_REG3_ADDR, 1);
* @brief MEMS accelerometre management of the timeout situation.
* @param None.
* @retval None.
uint32_t LIS302DL_TIMEOUT_UserCallback(void)
/* MEMS Accelerometer Timeout error occured */
while (1) ;
* @brief Configures EXTI Line0 (connected to PA0 pin) in interrupt mode
* @param None
* @retval None
/* Enable GPIOA clock */
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
/* Enable SYSCFG clock */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE);
/* Configure PA0 pin as input floating */
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
/* Connect EXTI Line0 to PA0 pin */
SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOA, EXTI_PinSource0);
/* Configure EXTI Line0 */
EXTI_InitStructure.EXTI_Line = EXTI_Line0;
EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising_Falling;
EXTI_InitStructure.EXTI_LineCmd = ENABLE;
EXTI_Init(&EXTI_InitStructure);
/* Enable and set EXTI Line0 Interrupt to the lowest priority */
NVIC_InitStructure.NVIC_IRQChannel = EXTI0_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x01;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x01;
* @brief Inserts a delay time.
* @param nTime: specifies the delay time length, in milliseconds
* @retval None
void Delay(uint32_t nTime)
TimingDelay = nTime;
while (TimingDelay != 0);
* @brief Decrements the TimingDelay variable.
* @param None
* @retval None
void TimingDelay_Decrement(void)
CycleCounter += SysTickLimit;
if (TimingDelay != 0x00)
TimingDelay--;
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param file: pointer to the source file name
* @param line: assert_param error line source number
* @retval None
void assert_failed(uint8_t* file, uint32_t line)
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* Infinite loop */
while (1)
#endif
/*********** Portions COPYRIGHT 2012 Embest Tech. Co., Ltd.*****END OF FILE****/
STM32 二維碼解碼.zip
(1.5 MB, 下載次數: 28)
2018-10-17 15:32 上傳
txpzyr
2019-8-19 11:56
謝謝,學習下
亚洲精品www久久久久久广东
少妇中文字幕
www.伊人
日韩精品久久久久久免费
亚洲精品在线免费
久久婷婷色
亚洲国产免费
欧美精品在线播放
色婷av
色影视
天堂网亚洲
97精品视频在线观看
久久久www成人免费精品
久久精品三级
国产伦理一区二区
久热综合
久久久xxx
日韩免费在线观看视频
九月色婷婷
天堂a在线
色吧五月天
日本少妇做爰全过程毛片
精品国产999久久久免费
91手机看片
日韩免费在线播放
超碰一区二区
在线黄网
国产成人精品在线观看
黄色片在线免费观看
日韩成人一区
久久动态图
欧美美女一区二区
日韩午夜在线观看
亚洲一区二区三区四区在线
极品新婚夜少妇真紧
欧美精品二区
亚洲视频在线视频
夜夜嗷
国产精品久久久一区二区
亚洲精品在
黄视频免费在线观看
