標題: STM32多通道采集程序源碼(12通道ADC_DMA) [打印本頁]
作者: zkaaaa    時間: 2018-10-29 17:25
這是一個STM32加DMA多通道采集程序,需要的同學(xué)可以在此下載!提供給需要幫助的人
  1. #include "sys.h"
  2. #include "delay.h"
  3. #include "usart.h"
  4. #include "led.h"
  5. #include "lcd.h"
  6. #include "adc.h"
  7. extern __IO uint16_t ADC1ConvertedValue[10][12];
  8. __IO uint32_t ADC1ConvertedVoltage[12];
  9. int main(void)
  10. {
  11.     u8 i;
  12.         u8 j;
  13.         u8 k;
  14.         float temp[12];
  15.         NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//設(shè)置系統(tǒng)中斷優(yōu)先級分組2
  16.         delay_init();    //初始化延時函數(shù)
  17.         uart_init(115200);        //初始化串口波特率為115200
  18.         LED_Init();                                        //初始化LED
  19.          LCD_Init();         //初始化LCD接口
  20.         Adc_Init();         //初始化ADC
  21.         POINT_COLOR=RED;
  22.
  23.         LCD_ShowString(200,70,200,16,24,"UESTC");
  24.
  25.         POINT_COLOR=BLUE;//設(shè)置字體為藍色
  26.         LCD_ShowString(160,130,200,16,16,"ADC1_CH00_VAL:");
  27.         LCD_ShowString(160,150,200,16,16,"ADC1_CH00_VOL:0.000V");        //先在固定位置顯示小數(shù)點
  28.     LCD_ShowString(160,170,200,16,16,"ADC1_CH01_VAL:");
  29.         LCD_ShowString(160,190,200,16,16,"ADC1_CH01_VOL:0.000V");        //先在固定位置顯示小數(shù)點
  30.
  31.         LCD_ShowString(160,210,200,16,16,"ADC1_CH02_VAL:");
  32.         LCD_ShowString(160,230,200,16,16,"ADC1_CH02_VOL:0.000V");        //先在固定位置顯示小數(shù)點
  33.     LCD_ShowString(160,250,200,16,16,"ADC1_CH03_VAL:");
  34.         LCD_ShowString(160,270,200,16,16,"ADC1_CH03_VOL:0.000V");        //先在固定位置顯示小數(shù)點
  35.
  36.         LCD_ShowString(160,290,200,16,16,"ADC1_CH04_VAL:");
  37.         LCD_ShowString(160,310,200,16,16,"ADC1_CH04_VOL:0.000V");        //先在固定位置顯示小數(shù)點
  38.     LCD_ShowString(160,330,200,16,16,"ADC1_CH05_VAL:");
  39.         LCD_ShowString(160,350,200,16,16,"ADC1_CH05_VOL:0.000V");        //先在固定位置顯示小數(shù)點
  40.
  41.         LCD_ShowString(160,370,200,16,16,"ADC1_CH06_VAL:");
  42.         LCD_ShowString(160,390,200,16,16,"ADC1_CH06_VOL:0.000V");        //先在固定位置顯示小數(shù)點
  43.     LCD_ShowString(160,410,200,16,16,"ADC1_CH07_VAL:");
  44.         LCD_ShowString(160,430,200,16,16,"ADC1_CH07_VOL:0.000V");        //先在固定位置顯示小數(shù)點
  45.
  46.         LCD_ShowString(160,450,200,16,16,"ADC1_CH09_VAL:");
  47.         LCD_ShowString(160,470,200,16,16,"ADC1_CH09_VOL:0.000V");        //先在固定位置顯示小數(shù)點
  48.     LCD_ShowString(160,490,200,16,16,"ADC1_CH10_VAL:");
  49.         LCD_ShowString(160,510,200,16,16,"ADC1_CH10_VOL:0.000V");        //先在固定位置顯示小數(shù)點
  50.
  51.         LCD_ShowString(160,530,200,16,16,"ADC1_CH11_VAL:");
  52.         LCD_ShowString(160,550,200,16,16,"ADC1_CH11_VOL:0.000V");        //先在固定位置顯示小數(shù)點
  53.     LCD_ShowString(160,570,200,16,16,"ADC1_CH12_VAL:");
  54.         LCD_ShowString(160,590,200,16,16,"ADC1_CH12_VOL:0.000V");        //先在固定位置顯示小數(shù)點
  55.         while(1)
  56.         {
  57.
  58.                 ADC1ConvertedVoltage[0] = 0;
  59.
  60.
  61.         for(i=0;i<12;i++)
  62.         {
  63.                         ADC1ConvertedVoltage[i] = 0;
  64.                         for(j=0;j<10;j++)
  65.                         {
  66.             ADC1ConvertedVoltage[i]+= ADC1ConvertedValue[j][i];
  67.
  68.             };
  69.                         ADC1ConvertedVoltage[i] = ADC1ConvertedVoltage[i]/10;
  70.             };
  71.
  72.                 for(k=0;k<12;k++)
  73.                 {
  74.         temp[k] = ADC1ConvertedVoltage[k]*3.3/4096;
  75.
  76.
  77.                 LCD_ShowxNum(272,130+40*k,ADC1ConvertedVoltage[k],4,16,0);    //顯示ADCC采樣后的原始值
  78.                 i=temp[k];                            //賦值整數(shù)部分給adcx變量,因為adcx為u16整形
  79.                 LCD_ShowxNum(272,150+40*k,i,1,16,0);    //顯示電壓值的整數(shù)部分,3.1111的話,這里就是顯示3
  80.                 temp[k]-=i;                           //把已經(jīng)顯示的整數(shù)部分去掉,留下小數(shù)部分,比如3.1111-3=0.1111
  81.                 temp[k]*=1000;                           //小數(shù)部分乘以1000,例如:0.1111就轉(zhuǎn)換為111.1,相當于保留三位小數(shù)。
  82.                 LCD_ShowxNum(288,150+40*k,temp[k],3,16,0X80); //顯示小數(shù)部分(前面轉(zhuǎn)換為了整形顯示),這里顯示的就是111.
  83.
  84.                 };
  85.                 /*LCD_ShowxNum(264,170,ADC1ConvertedVoltage[1],4,16,0);    //顯示ADCC采樣后的原始值
  86.                 i=temp2;                            //賦值整數(shù)部分給adcx變量,因為adcx為u16整形
  87.                 LCD_ShowxNum(264,190,i,1,16,0);    //顯示電壓值的整數(shù)部分,3.1111的話,這里就是顯示3
  88.                 temp2-=i;                           //把已經(jīng)顯示的整數(shù)部分去掉,留下小數(shù)部分,比如3.1111-3=0.1111
  89.                 temp2*=1000;                           //小數(shù)部分乘以1000,例如:0.1111就轉(zhuǎn)換為111.1,相當于保留三位小數(shù)。
  90.                 LCD_ShowxNum(280,190,temp2,3,16,0X80); //顯示小數(shù)部分(前面轉(zhuǎn)換為了整形顯示),這里顯示的就是111.
  91.         */
  92.                 LED0=!LED0;
  93.                 delay_ms(1000);
  94.         }
  95. }
12通道ADC_DMA -.rar (356.54 KB, 下載次數(shù): 110)
主站蜘蛛池模板: 精品亚洲一区二区三区 | 午夜精品一区二区三区在线视频 | 久久免费福利视频 | 一道本在线 | 激情综合婷婷 | 欧美色综合天天久久综合精品 | 九色av| 大色av| 福利视频网站 | 97视频在线观看免费 | 成年在线观看 | 天天干天天操天天 | 国产黄色在线播放 | 中文字幕亚洲精品 | 日韩av成人在线 | 69av在线播放 | 国产欧美日韩在线视频 | 在线一区二区三区 | 成人在线免费视频 | 欧美一级欧美三级在线观看 | 精品伊人久久 | 精品久久久久久久久久 | 三上悠亚久久 | 91av视频在线观看 | 一区二区三区在线免费 | 一级片免费在线观看 | 小sao货撅起屁股扒开c微博 | 又色又爽又黄18网站 | 日韩精品久久久久久久酒店 | 日韩视频中文字幕 | 综合久久久 | 香蕉视频色版 | 蜜桃视频一区二区 | www国产精品 | 男女啪啪免费视频 | 日韩av在线免费 | 精品无人国产偷自产在线 | 国产高潮在线 | 男女啪啪免费 | 中文字幕日韩高清 | 波多野结衣一区二区三区 |
