標(biāo)題: hx711重力傳感器arduino例程 1Kg 5Kg 10Kg 20Kg [打印本頁]
作者: 傳奇之我    時間: 2018-11-3 10:57
如題,重力傳感器hx711代碼
  1. #include "HX711.h"
  2. float Weight = 0;
  3. void setup()
  4. {
  5.         Init_Hx711();                                //初始化HX711模塊連接的IO設(shè)置
  6.         Serial.begin(9600);
  7.         Serial.print("Welcome to use!\n");
  8.         delay(3000);
  9.         Get_Maopi();                //獲取毛皮
  10. }
  11. void loop()
  12. {
  13.         Weight = Get_Weight();        //計算放在傳感器上的重物重量
  14.         Serial.print(float(Weight/1000),3);        //串口顯示重量
  15.         Serial.print(" kg\n");        //顯示單位
  16.         Serial.print("\n");                //顯示單位
  17.         delay(1000);                                //延時1s
  18. }
  1. #include "hx711.h"
  2. long HX711_Buffer = 0;
  3. long Weight_Maopi = 0,Weight_Shiwu = 0;
  4. #define GapValue 215//10kg
  5. //****************************************************
  6. //初始化HX711
  7. //****************************************************
  8. void Init_Hx711()
  9. {
  10.         pinMode(HX711_SCK, OUTPUT);
  11.         pinMode(HX711_DT, INPUT);
  12. }
  13. //****************************************************
  14. //獲取毛皮重量
  15. //****************************************************
  16. void Get_Maopi()
  17. {
  18.         Weight_Maopi = HX711_Read();
  19. }
  20. //****************************************************
  21. //稱重
  22. //****************************************************
  23. long Get_Weight()
  24. {
  25.         HX711_Buffer = HX711_Read();
  26.         Weight_Shiwu = HX711_Buffer;
  27.         Weight_Shiwu = Weight_Shiwu - Weight_Maopi;                                //獲取實物的AD采樣數(shù)值。
  28.         Weight_Shiwu = (long)((float)Weight_Shiwu/GapValue);
  29.         return Weight_Shiwu;
  30. }
  31. //****************************************************
  32. //讀取HX711
  33. //****************************************************
  34. unsigned long HX711_Read(void)        //增益128
  35. {
  36.         unsigned long count;
  37.         unsigned char i;
  38.         bool Flag = 0;
  39.         digitalWrite(HX711_DT, HIGH);
  40.         delayMicroseconds(1);
  41.         digitalWrite(HX711_SCK, LOW);
  42.         delayMicroseconds(1);
  43.           count=0;
  44.           while(digitalRead(HX711_DT));
  45.           for(i=0;i<24;i++)
  46.         {
  47.                   digitalWrite(HX711_SCK, HIGH);
  48.                 delayMicroseconds(1);
  49.                   count=count<<1;
  50.                 digitalWrite(HX711_SCK, LOW);
  51.                 delayMicroseconds(1);
  52.                   if(digitalRead(HX711_DT))
  53.                         count++;
  54.         }
  55.         digitalWrite(HX711_SCK, HIGH);
  56.         count ^= 0x800000;
  57.         delayMicroseconds(1);
  58.         digitalWrite(HX711_SCK, LOW);
  59.         delayMicroseconds(1);
  60.
  61.         return(count);
  62. }
HX711_1Kg.rar
1.3 KB, 下載次數(shù): 33, 下載積分: 黑幣 -5
HX711_5Kg.rar
HX711_10Kg.rar
1.31 KB, 下載次數(shù): 25, 下載積分: 黑幣 -5
HX711_20Kg.rar
1.31 KB, 下載次數(shù): 41, 下載積分: 黑幣 -5
作者: 我是你大爺1999    時間: 2019-1-3 15:14
你好,為什么我下載了1Kg的試用后,數(shù)據(jù)一直是0kg?給壓力也沒變化
作者: ruoc    時間: 2020-10-23 21:33
你好  我的稱重是負(fù)值是什么問題啊
作者: sunlichao    時間: 2020-10-24 13:09
可能是傳感器方向接反了
作者: wqhanweiwei    時間: 2021-1-31 21:38
10千克的為什么下不了,還有這個文件是您寫的嗎
主站蜘蛛池模板: 免费视频一区二区 | 天天插天天狠天天透 | 北岛玲在线 | 国产另类xxxxhd高清 | 日本精品在线视频 | 色精品 | 国产精品999999 | 欧美日韩小视频 | 日韩免费在线观看 | 中文字幕免费看 | 2014天堂网| 视频一二区 | 99热99re6国产在线播放 | 亚洲成人毛片 | 国产一级免费观看 | 国产网址| 国产精品国产三级国产 | 日韩毛片免费看 | 在线播放一区 | 国产一区在线视频 | 国产成人亚洲精品自产在线 | 一级片在线免费观看 | 精品一区在线播放 | 国产成人区 | 亚洲小说欧美激情另类 | 日韩一区三区 | 簧片在线免费观看 | 91国产丝袜在线播放 | 亚洲色综合 | 91综合网 | 在线观看一区 | 免费av网址在线观看 | 亚洲精品在线视频观看 | 免费一级黄色录像 | 深夜福利久久 | 91日韩欧美| 亚洲三级免费 | 日韩一级片在线观看 | 99热99re6国产在线播放 | 日日夜夜干 | 久久亚洲一区二区 |
