標題: Atmega16單片機實驗:DS18B20和ad采集顯示程序 [打印本頁]
作者: taotie    時間: 2019-1-8 14:24
rem Main.bas file generated by New Project wizard
rem
rem Created:   周日 9月 16 2018
rem Processor: ATmega16
rem Compiler:  BASCOM-AVR
rem Write your code here
$regfile = "m16def.dat"
$crystal = 2000000
Config 1wire = Portb.0                               '定義BS18B20接在PB0上
Config Lcdpin = Pin , Db4 = Porta.4 , Db5 = Porta.5 , Db6 = Porta.6 , Db7 = Porta.7 , E = Porta.3 , Rs = Porta.2
Config Lcd = 20 * 4
$baud = 19200
Cls
'Dim SysDS18B20_1 As Byte
'Dim SysDS18B20_2 As Byte
Dim Cgqidi_1(8) As Byte                                    '傳感器id1數組變量
Dim Cgqidi_2(8) As Byte                                    '傳感器id2數組變量
Dim Cgqidi_3(8) As Byte                                    '傳感器id3數組變量
Dim Cgqidi_4(8) As Byte                                    '傳感器id4數組變量
Dim Cgqidi_5(8) As Byte                                    '傳感器id5數組變量
Dim Cgq_zhuangtai(5) As Byte                               '傳感器——狀態變量
Dim Xianzai__wendu(5) As Single                            '現在——溫度變量
Declare Sub SUAXIN___WENDU()    '聲明刷新轉換溫度過程子程序
Declare Sub FAXIAN_CGQs()        '聲明發現傳感器過程子程序
Call FAXIAN_CGQs()                 '調用發現——傳感器過程子程序
Cls
Waitms 500
Do
  Call SUAXIN___WENDU()'轉到刷新轉換溫度過程子程序
  Locate 1 , 1
  Lcd Fusing(XIANZAI__WENDU(1) , "#.##");"C    DS18B20-1"
  Locate 2 , 1
  lcd Fusing(XIANZAI__WENDU(2) , "#.##") ; "C   DS18B20-2"
  Locate 3 , 1
  Lcd Fusing(xianzai__wendu(3) , "#.##") ; "C    DS18B20-3"
   Locate 4 , 1
   Lcd Fusing(xianzai__wendu(4) , "#.##") ; "C    DS18B20-4"
  Waitms 1500
Config Adc = Single , Prescaler = Auto , Reference = avcc
  Start Adc
  Dim W As Word , Channel As Byte , B As Single , D1 As Single , D2 As Single                                                '加插 5V 的短路塊
  Channel = 1
  W = Getadc(channel)
  b=5*w                       'B = 2.98 * W
  D1 = B / 1023
  Locate 2 , 1
'Lcd  "AD1= "
  Locate 4 , 1
  Lcd Fusing (d1 , "#.###");    "V     ADC"
  Loop
  End
'刷新轉換溫度過程子程序
  Dim Readdata(9) As Byte
  Dim Temperature As Word
  Dim WENDU As Single
  Dim CGQidI_ As Byte
'啟動溫度轉換
  1wreset
  1wwrite &HCC
  1wwrite &H44
  Waitms 800
  For Cgqidi_ = 1 To 5
    If CGQ_ZHUANGTAI(CGQidI_) = 1 Then
       1wreset
       1wwrite &H55
'匹配總線ID
  For SysDS18B20_1 = 1 To 8
          If CGQidI_ = 1 Then : 1wwrite CGQidI_1(sysDS18B20_1)
          Elseif CGQidI_ = 2 Then : 1wwrite CGQidI_2(sysDS18B20_1)
          Elseif Cgqidi_ = 3 Then : 1wwrite Cgqidi_3(sysds18b20_1)
          Elseif Cgqidi_ = 4 Then : 1wwrite Cgqidi_4(sysds18b20_1)
          Elseif Cgqidi_ = 5 Then : 1wwrite Cgqidi_5(sysds18b20_1)
          End If
       Next
       1wwrite &HBE
       For SysDS18B20_1 = 1 To 9
          Readdata(sysDS18B20_1) = 1wread()
   Next
   Temperature = Readdata(2) * 256
   Temperature = Temperature + Readdata(1)
   If Readdata(2) > 15 Then
          Temperature = Not Temperature
          Temperature = Temperature + 1
          WENDU = Temperature * 0.0625
          WENDU = 0 - WENDU
       Else
       End If
       XIANZAI__WENDU(CGQidI_) = WENDU
    Else
    XIANZAI__WENDU(CGQidI_) = -255                      '如果傳感器不存在則設置為-255度
    End If
Next
End Sub
'查找傳感器,總線上必須掛有至少一個傳感器
Sub FAXIAN_CGQs()
  Dim SysDS18B20_4 As Byte
  Dim FAXIAN_CGQ As Byte
  Locate 1 , 1
  Lcd "FAXIAN_ CGQ"
  FAXIAN_CGQ = 0
  CGQidI_1(1) = 1wsearchfirst()'開始尋找第一個傳感器
  CGQ_ZHUANGTAI(1) = 1
  Incr FAXIAN_CGQ
  For Sysds18b20_4 = 2 To 5
    If SysDS18B20_4 = 2 Then CGQidI_2(1) = 1wsearchnext()
    If SysDS18B20_4 = 3 Then CGQidI_3(1) = 1wsearchnext()
     If Sysds18b20_4 = 4 Then Cgqidi_4(1) = 1wsearchnext()
      If Sysds18b20_4 = 5 Then Cgqidi_5(1) = 1wsearchnext()
'尋找下一個傳感器
  If Err = 1 Then Exit For         '錯誤代碼為1則退出循環
    CGQ_ZHUANGTAI(sysDS18B20_4) = 1
    Incr FAXIAN_CGQ
   Waitms 1000
   Next
  Cls
  Waitms 500
  Locate 1 , 1
  Lcd "FAXIAN_ " ; FAXIAN_CGQ ; " CGQs"
  Waitms 1000
End Sub
主站蜘蛛池模板: 日日操夜夜 | 午夜成人在线视频 | 少妇视频在线观看 | 日韩亚洲一区二区 | 国产欧美一区二区精品忘忧草 | 一级理论片 | 欧美啪啪网站 | 91久色 | 久久一二三区 | 韩国三级中文字幕hd久久精品 | 一级黄色小视频 | 中文字幕影院 | 久久综合久久鬼 | 久久视频一区 | 色婷婷影院 | 国产成人在线播放 | 国产精品成人国产乱一区 | 天堂91| 中文字幕av久久爽av | 在线a| 亚洲国产欧美日韩在线 | 欧美日韩视频 | 人人看人人干 | 成人免费毛片嘿嘿连载视频 | 亚洲国产精品视频 | av免费在线观看网站 | 国产福利91精品一区二区三区 | av片网站| 亚洲小视频在线观看 | 色综合久久久久 | 精品久久久久久久久久久久久 | 在线不卡视频 | 国产美女视频 | 国产成人久久精品麻豆二区 | 国产成人免费在线观看 | 亚洲日本一区二区 | 日韩精品一区二区视频 | 国产成人精品一区二区三区在线 | 一级片免费网站 | 99热国产在线 | 涩涩的视频 |
