STC12C5A60S2+DH11溫濕度傳感器 11.0592晶振 延時是用示波器掐的
⑨掌門
2019-1-14 10:20
#include <STC12C5A60S2.H>
#define uchar unsigned char
#define uint unsigned int
uchar code table[]="TEMP:";
uchar code table1[]="HUMI:";
//請根據自己的dht11接的IO口來改動位定義
sbit dht11 = P3^2;
sbit rw=P2^5;
//防止在與硬件通信時發生死循環的計數范圍
#define NUMBER 2000
#define SIZE 5
unsigned char status;
//存放五字節數據的數組
unsigned char value_array[SIZE];
/*可在其他的文件引用溫濕度值,實際是溫度的整數的10倍
如dht11讀回的溫度是26,則temp_value = 260, 濕度同理*/
int temp=12,humi=12;
sbit lcden=P2^7;
sbit lcdrs=P2^6;
uchar num,a;
uint c,b,d,e;
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=500;y>0;y--);
void write_com(uchar com)
lcdrs=0;
P0=com;
delay(1);
lcden=1;
delay(1);
lcden=0;
void write_data(uchar date)
lcdrs=1;
P0=date;
delay(1);
lcden=1;
delay(1);
lcden=0;
void write_string(uchar hang,uchar add,uchar *p)
if(hang==1)
write_com(0x80+add);
write_com(0x80+0x40+add);
if(*p == '\0') break;
write_data(*p);
p++;
void init_1602()
rw=0;
lcden=0;
dht11=1;
write_com(0x38);
write_com(0x0c);
write_com(0x06);
write_com(0x01);
write_com(0x80);
void Delay_1ms(unsigned int ms)
unsigned int x, y;
for(x = ms; x > 0; x--)
for(y = 1000; y > 0; y--);
void Delay_10us(void)
unsigned char i;
i--; i--; i--; i--;
i--; i--; i--; i--;
i--; i--; i--; i--;
i--; i--; i--; i--;
i--; i--;
i--; i--; i--; i--;
i--; i--; i--; i--;
i--; i--; i--; i--;
i--; i--; i--; i--;
i--; i--;
i--; i--; i--; i--;
i--; i--; i--; i--;
i--; i--; i--; i--;
i--; i--; i--; i--;
i--; i--;
i--; i--; i--; i--;
i--; i--;
/*讀一個字節的數據*/
unsigned char ReadValue(void)
unsigned char count, value = 0, i;
status = 1; //設定標志為正常狀態
for(i = 8; i > 0; i--)
//高位在先
value <<= 1;
count = 0;
//每一位數據前會有一個50us的低電平時間.等待50us低電平結束
while(dht11 == 0);
//26-28us的高電平表示該位是0,為70us高電平表該位1
Delay_10us();
Delay_10us();
//延時30us后檢測數據線是否還是高電平
if(dht11 != 0)
//進入這里表示該位是1
value++;
//等待剩余(約40us)的高電平結束
while(dht11 != 0)
dht11 = 1;
return (value);
//讀一次的數據,共五字節
uchar rdata()
uchar i = 0, check_value = 0,count = 0;
Delay_1ms(2);
dht11 = 0; //拉低數據線大于18ms發送開始信號
Delay_1ms(20); //需大于18毫秒
dht11 = 1; //釋放數據線,用于檢測低電平的應答信號
//延時20-40us,等待一段時間后檢測應答信號,應答信號是從機拉低數據線80us
Delay_10us();
Delay_10us();
if(dht11 != 0) //檢測應答信號,應答信號是低電平
//沒應答信號
return 0;
//有應答信號
while(dht11 == 0 ); //等待應答信號結束
count = 0;
dht11 = 1;//釋放數據線
//應答信號后會有一個80us的高電平等待高電平結束
while(dht11 != 0);
//讀出濕.溫度值
for(i = 0; i < SIZE; i++)
value_array[i] = ReadValue();
if(status == 0)//調用ReadValue()讀數據出錯會設定status為ERROR
dht11 = 1;
return 0;
//讀出的最后一個值是校驗值不需加上去
if(i != SIZE - 1)
//讀出的五字節數據中的前四字節數據和等于第五字節數據表示成功
check_value += value_array[i];
}//end for
//在沒用發生函數調用失敗時進行校驗
if(check_value == value_array[SIZE - 1])
//將溫濕度擴大10倍方便分離出每一位
humi = value_array[0] * 10;
temp = value_array[2] * 10;
dht11 = 1;
return 0; //正確的讀出dht11輸出的數據
//校驗數據出錯
return 0;
uchar x;
x=1;
init_1602();
for(num=0;num<5;num++)
write_data(table[num]);
delay(5);
write_com(0x80+0x40);
write_data(table1[num]);
delay(5);
rdata();
write_com(0x80+0x05);
write_data(temp/100+'0');
delay(x);
write_data(temp%100/10+'0');
delay(x);
write_com(0x80+0x45);
write_data(humi/100+'0');
delay(x);
write_data(humi%100/10+'0');
delay(x);
write_string(1,8,"com");
// write_com(0x80+0x09);
// delay(x);
// write_data(c/10000+'0');
// delay(x);
// write_data(c%10000/1000+'0');
// delay(x);
// write_data(c%10000%1000/100+'0');
admin
2019-1-14 15:13
用示波器掐的?
⑨掌門
2019-1-18 16:50
admin 發表于 2019-1-14 15:13
用示波器掐的?
嗯 對時間要求有點小嚴格 所以用示波器一點一點試的
Zonaa
2021-11-28 15:55
我的怎么不顯示
一区二区不卡
亚洲香蕉在线
国产乱淫av
九九色综合
少妇av在线
国产黄色录像
精品少妇一区二区三区免费观
亚洲va视频
国产三级在线观看视频
日韩精品第一页
在线观看视频一区二区三区
av女人天堂
日韩av在线免费
成人在线播放视频
国产成人在线免费视频
免费在线成人
国产精品久久久久久中文字
国产日韩精品一区二区
综合导航
国内精品国产成人国产三级
精品国产一区二区三区久久久蜜月
国产综合亚洲精品一区二
久久久久女人精品毛片九一
丁香婷婷六月天
亚欧av在线
日韩精品影视
97在线超碰
成人免费毛片嘿嘿连载视频
亚洲成人精品
怡红院在线播放
97超碰资源
亚洲精品中文字幕乱码三区91
秋霞国产
九九精品国产
插少妇
午夜激情网站
www黄色片
午夜激情视频在线观看
超碰99在线
国产成人精品一区二
黄在线免费观看
