基于STM32F429的NRF24L01無線通信源碼
181181031
2019-1-19 15:02
單片機源碼:
基于STM32F429的NRF24L01無線通信.7z
(573.24 KB, 下載次數: 56)
2019-1-19 16:28 上傳
#include "24l01.h"
#include "spi.h"
#include "delay.h"
#include "led.h"
const u8 TX_ADDRESS[TX_ADR_WIDTH]={0x34,0x43,0x10,0x10,0x01}; //發送地址
const u8 RX_ADDRESS[RX_ADR_WIDTH]={0x34,0x43,0x10,0x10,0x01}; //發送地址
//針對NRF24L01修改SPI2驅動
void NRF24L01_SPI_Init(void)
__HAL_SPI_DISABLE(&SPI2_Handler); //先關閉SPI2
SPI2_Handler.Init.CLKPolarity=SPI_POLARITY_LOW; //串行同步時鐘的空閑狀態為低電平
SPI2_Handler.Init.CLKPhase=SPI_PHASE_1EDGE; //串行同步時鐘的第1個跳變沿(上升或下降)數據被采樣
HAL_SPI_Init(&SPI2_Handler);
__HAL_SPI_ENABLE(&SPI2_Handler); //使能SPI2
//初始化24L01的IO口
void NRF24L01_Init(void)
GPIO_InitTypeDef GPIO_Initure;
__HAL_RCC_GPIOG_CLK_ENABLE(); //開啟GPIOG時鐘
__HAL_RCC_GPIOI_CLK_ENABLE(); //開啟GPIOI時鐘
GPIO_Initure.Pin=GPIO_PIN_10|GPIO_PIN_12; //PG10,12
GPIO_Initure.Mode=GPIO_MODE_OUTPUT_PP; //推挽輸出
GPIO_Initure.Pull=GPIO_PULLUP; //上拉
GPIO_Initure.Speed=GPIO_SPEED_HIGH; //高速
HAL_GPIO_Init(GPIOG,&GPIO_Initure); //初始化
GPIO_Initure.Pin=GPIO_PIN_11; //PI11
GPIO_Initure.Mode=GPIO_MODE_INPUT; //輸入
HAL_GPIO_Init(GPIOI,&GPIO_Initure); //初始化
SPI2_Init(); //初始化SPI2
NRF24L01_SPI_Init(); //針對NRF的特點修改SPI的設置
NRF24L01_CE=0; //使能24L01
NRF24L01_CSN=1; //SPI片選取消
//檢測24L01是否存在
//返回值:0,成功;1,失敗
u8 NRF24L01_Check(void)
u8 buf[5]={0XA5,0XA5,0XA5,0XA5,0XA5};
u8 i;
SPI2_SetSpeed(SPI_BAUDRATEPRESCALER_4); //spi速度為11.25Mhz(24L01的最大SPI時鐘為10Mhz,這里大一點沒關系)
NRF24L01_Write_Buf(NRF_WRITE_REG+TX_ADDR,buf,5);//寫入5個字節的地址.
NRF24L01_Read_Buf(TX_ADDR,buf,5); //讀出寫入的地址
for(i=0;i<5;i++)if(buf[i]!=0XA5)break;
if(i!=5)
//LED0=0;
return 1;
}//檢測24L01錯誤
//LED1=0;
return 0;
} //檢測到24L01
//SPI寫寄存器
//reg:指定寄存器地址
//value:寫入的值
u8 NRF24L01_Write_Reg(u8 reg,u8 value)
u8 status;
NRF24L01_CSN=0; //使能SPI傳輸
status =SPI2_ReadWriteByte(reg);//發送寄存器號
SPI2_ReadWriteByte(value); //寫入寄存器的值
NRF24L01_CSN=1; //禁止SPI傳輸
return(status); //返回狀態值
//讀取SPI寄存器值
//reg:要讀的寄存器
u8 NRF24L01_Read_Reg(u8 reg)
u8 reg_val;
SPI2_ReadWriteByte(reg); //發送寄存器號
reg_val=SPI2_ReadWriteByte(0XFF);//讀取寄存器內容
return(reg_val); //返回狀態值
//在指定位置讀出指定長度的數據
//reg:寄存器(位置)
//*pBuf:數據指針
//len:數據長度
//返回值,此次讀到的狀態寄存器值
u8 NRF24L01_Read_Buf(u8 reg,u8 *pBuf,u8 len)
u8 status,u8_ctr;
status=SPI2_ReadWriteByte(reg);//發送寄存器值(位置),并讀取狀態值
for(u8_ctr=0;u8_ctr<len;u8_ctr++)pBuf[u8_ctr]=SPI2_ReadWriteByte(0XFF);//讀出數據
NRF24L01_CSN=1; //關閉SPI傳輸
return status; //返回讀到的狀態值
//在指定位置寫指定長度的數據
//reg:寄存器(位置)
//*pBuf:數據指針
//len:數據長度
//返回值,此次讀到的狀態寄存器值
u8 NRF24L01_Write_Buf(u8 reg, u8 *pBuf, u8 len)
u8 status,u8_ctr;
status = SPI2_ReadWriteByte(reg);//發送寄存器值(位置),并讀取狀態值
for(u8_ctr=0; u8_ctr<len; u8_ctr++)SPI2_ReadWriteByte(*pBuf++); //寫入數據
//啟動NRF24L01發送一次數據
//txbuf:待發送數據首地址
//返回值:發送完成狀況
u8 NRF24L01_TxPacket(u8 *txbuf)
u8 sta;
SPI2_SetSpeed(SPI_BAUDRATEPRESCALER_8); //spi速度為6.75Mhz(24L01的最大SPI時鐘為10Mhz)
NRF24L01_CE=0;
NRF24L01_Write_Buf(WR_TX_PLOAD,txbuf,TX_PLOAD_WIDTH);//寫數據到TX BUF 32個字節
NRF24L01_CE=1; //啟動發送
while(NRF24L01_IRQ!=0); //等待發送完成
sta=NRF24L01_Read_Reg(STATUS); //讀取狀態寄存器的值
NRF24L01_Write_Reg(NRF_WRITE_REG+STATUS,sta); //清除TX_DS或MAX_RT中斷標志
if(sta&MAX_TX) //達到最大重發次數
NRF24L01_Write_Reg(FLUSH_TX,0xff); //清除TX FIFO寄存器
return MAX_TX;
if(sta&TX_OK) //發送完成
return TX_OK;
return 0xff;//其他原因發送失敗
//啟動NRF24L01發送一次數據
//txbuf:待發送數據首地址
//返回值:0,接收完成;其他,錯誤代碼
u8 NRF24L01_RxPacket(u8 *rxbuf)
u8 sta;
if(sta&RX_OK)//接收到數據
NRF24L01_Read_Buf(RD_RX_PLOAD,rxbuf,RX_PLOAD_WIDTH);//讀取數據
NRF24L01_Write_Reg(FLUSH_RX,0xff); //清除RX FIFO寄存器
return 0;
return 1;//沒收到任何數據
//該函數初始化NRF24L01到RX模式
//設置RX地址,寫RX數據寬度,選擇RF頻道,波特率和LNA HCURR
//當CE變高后,即進入RX模式,并可以接收數據了
void NRF24L01_RX_Mode(void)
NRF24L01_CE=0;
NRF24L01_Write_Buf(NRF_WRITE_REG+RX_ADDR_P0,(u8*)RX_ADDRESS,RX_ADR_WIDTH);//寫RX節點地址
NRF24L01_Write_Reg(NRF_WRITE_REG+EN_AA,0x01); //使能通道0的自動應答
NRF24L01_Write_Reg(NRF_WRITE_REG+EN_RXADDR,0x01); //使能通道0的接收地址
NRF24L01_Write_Reg(NRF_WRITE_REG+RF_CH,40); //設置RF通信頻率
NRF24L01_Write_Reg(NRF_WRITE_REG+RX_PW_P0,RX_PLOAD_WIDTH);//選擇通道0的有效數據寬度
NRF24L01_Write_Reg(NRF_WRITE_REG+RF_SETUP,0x0f); //設置TX發射參數,0db增益,2Mbps,低噪聲增益開啟
NRF24L01_Write_Reg(NRF_WRITE_REG+CONFIG, 0x0f); //配置基本工作模式的參數;PWR_UP,EN_CRC,16BIT_CRC,接收模式
NRF24L01_CE=1; //CE為高,進入接收模式
//該函數初始化NRF24L01到TX模式
//設置TX地址,寫TX數據寬度,設置RX自動應答的地址,填充TX發送數據,選擇RF頻道,波特率和LNA HCURR
//PWR_UP,CRC使能
//CE為高大于10us,則啟動發送.
void NRF24L01_TX_Mode(void)
NRF24L01_CE=0;
NRF24L01_Write_Buf(NRF_WRITE_REG+TX_ADDR,(u8*)TX_ADDRESS,TX_ADR_WIDTH);//寫TX節點地址
NRF24L01_Write_Buf(NRF_WRITE_REG+RX_ADDR_P0,(u8*)RX_ADDRESS,RX_ADR_WIDTH); //設置TX節點地址,主要為了使能ACK
NRF24L01_Write_Reg(NRF_WRITE_REG+SETUP_RETR,0x1a);//設置自動重發間隔時間:500us + 86us;最大自動重發次數:10次
NRF24L01_Write_Reg(NRF_WRITE_REG+RF_CH,40); //設置RF通道為40
NRF24L01_Write_Reg(NRF_WRITE_REG+CONFIG,0x0e); //配置基本工作模式的參數;PWR_UP,EN_CRC,16BIT_CRC,接收模式,開啟所有中斷
NRF24L01_CE=1;//CE為高,10us后啟動發送
371015220
2021-3-13 11:18
我下載看了下SPI,只開了SPI5的PF時鐘,SPI2在PB口的時鐘不用開嗎?
午夜天堂在线
欧美激情视频一区
韩国三级av
青青草伊人网
日本中文在线观看
日韩免费一级片
√天堂资源地址在线官网
夜夜操夜夜
国产精品久久久久久久
欧美在线观看视频
国产伦精品一区二区三区免.费
日韩亚洲在线
日韩欧美二区
日韩欧美久久
天天色小说
韩日av在线
久久伊人久久
久久888
日韩黄色片
亚洲天堂国产
欧美在线视频一区二区
久久免费影院
午夜视频成人
狠狠操av
精品影院
亚洲精品一区二区三区在线观看
黄色日皮视频
亚洲激情一区
在线一区二区三区
18在线观看免费入口
国产一区二区网站
久久精品视
日韩一区二区三区在线
香蕉福利视频
国产一级免费观看
成人免费视频一区二区
久久精品视频网
国产一级片免费看
日韩中文字幕一区
青青综合
手机av在线免费观看
