標題: LCD1602數字測速儀+單片機源程序+仿真 [打印本頁]
作者: 迷離小天    時間: 2019-4-13 21:19
  1. #include "reg51.h"
  2. #include "intrins.h"
  3. sbit LCM_RS=P3^0;
  4. sbit LCM_RW=P3^1;
  5. sbit LCM_EN=P3^7;
  6. #define BUSY                  0x80              //常量定義
  7. #define DATAPORT         P1
  8. #define uchar                 unsigned char
  9. #define uint                   unsigned int
  10. #define L                        50
  11. uchar str0[16],str1[16],count;
  12. uint speed;
  13. unsigned long time;
  14. void ddelay(uint);
  15. void lcd_wait(void);
  16. void display();
  17. void initLCM();
  18. void WriteCommandLCM(uchar WCLCM,uchar BusyC);
  19. void STR();
  20. void account();
  21. /*********延時K*1ms,12.000mhz**********/
  22. void int0_isr(void) interrupt 0         /*遙控使用外部中斷0,接P3.2口*/
  23. {
  24.     unsigned int temp;
  25.         time=count;
  26.     TR0=0;
  27.         temp=TH0;
  28.         temp=((temp << 8) | TL0);
  29.     TH0=0x3c;
  30.     TL0=0xaf;
  31.         count=0;
  32.     TR0=1;
  33.         time=time*50000+temp;
  34. }
  35. void time0_isr(void) interrupt 1        /*遙控使用定時計數器1 */
  36. {
  37.    TH0 =0x3c;
  38.    TL0 =0xaf;
  39.    count++;
  40. }
  41. void main(void)
  42. {
  43.            TMOD=0x01;                       /*TMOD T0選用方式1(16位定時) */
  44.     IP|=0x01;                           /*INT0 中斷優先*/
  45.     TCON|=0x11;                         /*TCON  EX0下降沿觸發,啟動T0*/
  46.     IE|=0x83;
  47.     TH0=0x3c;
  48.     TL0=0xaf;
  49.
  50.         initLCM();
  51.            WriteCommandLCM(0x01,1);                    //清顯示屏
  52.         for(;;)
  53.         {
  54.                 account();
  55.                 display();
  56.         }
  57. }
  58. void account()
  59. {
  60.         unsigned long a;
  61.         if (time!=0)
  62.         {
  63.                 a=L*360000000/time;
  64.         }
  65.         speed=a;
  66. }
  67. void STR()
  68. {
  69.         str0[0]='S';
  70.         str0[1]='p';
  71.         str0[2]='e';
  72.     str0[3]='e';
  73.         str0[4]='d';
  74.         str0[5]=' ';
  75.         str0[6]=(speed%100000)/10000+0x30;
  76.         str0[7]=(speed%10000)/1000+0x30;
  77.         str0[8]=(speed%1000)/100+0x30;
  78.         str0[9]='.';
  79.         str0[10]=(speed%100)/10+0x30;
  80.         str0[11]=speed%10+0x30;
  81.         str0[12]='k';
  82.         str0[13]='m';
  83.         str0[14]='/';
  84.         str0[15]='h';
  85. }
  86. void ddelay(uint k)
  87. {
  88.     uint i,j;
  89.     for(i=0;i<k;i++)
  90.     {
  91.         for(j=0;j<60;j++)
  92.                 {;}
  93.     }
  94. }
  95. /**********寫指令到LCD子函數************/
  96. void WriteCommandLCM(uchar WCLCM,uchar BusyC)
  97. {
  98.     if(BusyC)lcd_wait();
  99.         DATAPORT=WCLCM;
  100.     LCM_RS=0;                   /* 選中指令寄存器*/
  101.     LCM_RW=0;                       // 寫模式
  102.     LCM_EN=1;
  103.         _nop_();
  104.         _nop_();
  105.         _nop_();
  106.     LCM_EN=0;
  107. }
  108. /**********寫數據到LCD子函數************/
  109. void WriteDataLCM(uchar WDLCM)
  110. {
  111.     lcd_wait( );            //檢測忙信號
  112.         DATAPORT=WDLCM;
  113.     LCM_RS=1;               /* 選中數據寄存器  */
  114.     LCM_RW=0;                   // 寫模式
  115.     LCM_EN=1;
  116.     _nop_();
  117.         _nop_();
  118.         _nop_();
  119.     LCM_EN=0;
  120. }
  121. /***********lcd內部等待函數*************/
  122. void lcd_wait(void)
  123. {
  124.     DATAPORT=0xff;             //讀LCD前若單片機輸出低電平,而讀出LCD為高電平,則沖突,Proteus仿真會有顯示邏輯黃色
  125.         LCM_EN=1;
  126.     LCM_RS=0;
  127.     LCM_RW=1;
  128.     _nop_();
  129.     _nop_();
  130.         _nop_();
  131.     while(DATAPORT&BUSY)
  132.         {  LCM_EN=0;
  133.            _nop_();
  134.            _nop_();
  135.            LCM_EN=1;
  136.            _nop_();
  137.            _nop_();
  138.         }
  139.            LCM_EN=0;
  140. }
  141. /**********LCD初始化子函數***********/
  142. void initLCM( )
  143. {
  144.         DATAPORT=0;
  145.         ddelay(15);
  146.         WriteCommandLCM(0x38,0);    //三次顯示模式設置,不檢測忙信號
  147.     ddelay(5);
  148.     WriteCommandLCM(0x38,0);
  149.     ddelay(5);
  150.     WriteCommandLCM(0x38,0);
  151.     ddelay(5);
  152.     WriteCommandLCM(0x38,1);    //8bit數據傳送,2行顯示,5*7字型,檢測忙信號
  153.     WriteCommandLCM(0x08,1);    //關閉顯示,檢測忙信號
  154.     WriteCommandLCM(0x01,1);    //清屏,檢測忙信號
  155.     WriteCommandLCM(0x06,1);    //顯示光標右移設置,檢測忙信號
  156.     WriteCommandLCM(0x0c,1);    //顯示屏打開,光標不顯示,不閃爍,檢測忙信號
  157. }
  158. /****顯示指定坐標的一個字符子函數****/
  159. void DisplayOneChar(uchar X,uchar Y,uchar DData)
  160. {
  161.     Y&=1;
  162.     X&=15;
  163.     if(Y)X|=0x40;               //若y為1(顯示第二行),地址碼+0X40
  164.     X|=0x80;                    //指令碼為地址碼+0X80
  165.     WriteCommandLCM(X,0);
  166.     WriteDataLCM(DData);
  167. }
  168. /*******顯示指定坐標的一串字符子函數*****/
  169. void DisplayListChar(uchar X,uchar Y,uchar *DData)
  170. {
  171.     uchar ListLength=0;
  172.     Y&=0x01;
  173.     X&=0x0f;
  174.     while(X<16)
  175.     {
  176.         DisplayOneChar(X,Y,DData[ListLength]);
  177.         ListLength++;
  178.         X++;
  179.     }
  180. }
  181. void display()
  182. {
  183.         STR();
  184.         DisplayListChar(0,0,str0);
  185.            DisplayListChar(0,1,str1);
  186. }
LCD數字測速儀.zip (34.15 KB, 下載次數: 94)
作者: Duo2048    時間: 2019-4-20 11:14
請問用的是什么測速模塊啊
作者: 阿羊    時間: 2020-12-11 20:21
大哥你好,因為小弟最近在做差不多的小玩意兒,但是因為剛入門還是小白,可否像大哥求一份這個測速儀的實物,小弟再自己搗鼓搗鼓,謝謝大哥了
主站蜘蛛池模板: 国产一区二区不卡视频 | 欧美激情综合五月色丁香 | 久久九九国产 | 欧美黄色片在线观看 | 三级视频在线观看 | 亚洲成人精品在线 | 国产伦理一区二区 | 欧美成人一区二区三区 | 午夜性色 | 国产精品久久久久久妇女6080 | www.久久久| 黄色一级大片 | 精品视频一区二区 | 成人欧美一区二区三区黑人孕妇 | 青青久操 | 国产第一页在线 | 日韩视频精品 | 日韩欧美一区在线 | 欧美福利在线 | 亚洲三级网 | 亚洲在线视频观看 | 黄色免费观看网站 | 狠狠干影院 | 97在线超碰 | 久久久久久久久久久久久久久久久 | 国产精品福利在线观看 | av一区二区三区四区 | 色天堂影院 | 国产一级二级 | 久久人体视频 | 人人综合 | 国产欧美激情 | 一级肉体全黄裸片 | 日韩av网站在线观看 | 黄色国产网站 | 国产视频www| 日韩在线免费视频 | 成人午夜网站 | 欧美在线观看一区 | 日韩不卡一区 | 欧美一区二区三区在线视频 |
