stm32多串口收發數據源程序
15538053902
2019-7-19 17:27
stm32多串口收發數據源程序
stm32多串口收發數據
#include "user_usart.h"
#include "stm32f10x_usart.h"
#include "user_adc.h"
#include "user_74_595.h"
#include "user_74_165.h"
#include "user_gpio.h"
/*使用microLib的方法*/
int fputc(int ch, FILE *f)
USART_SendData(USART1, (uint8_t) ch);
while (USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET) {}
return ch;
int GetKey (void) {
while (!(USART1->SR & USART_FLAG_RXNE));
return ((int)(USART1->DR & 0x1FF));
//#if EN_USART1_RX //如果使能了接收
//串口1中斷服務程序
//注意,讀取USARTx->SR能避免莫名其妙的錯誤
//u8 USART_RX_BUF[USART_REC_LEN]; //接收緩沖,最大USART_REC_LEN個字節.
//接收狀態
//bit15, 接收完成標志
//bit14, 接收到0x0d
//bit13~0, 接收到的有效字節數目
u16 USART_RX_STA=0; //接收狀態標記
//串口1隊列定義
u8 UART1SendBuff[UART1BuffSize]; //發送數據
u8 UART1ReceBuff[UART1BuffSize]; //接收數據?
u16 UART1ReceIn = 0;//接收狀態標記數據位
u8 UART1ReceFullFlag = 0;//接收完數據標志位
//串口2隊列定義
u8 UART2SendBuff[UART2BuffSize];
u8 UART2ReceBuff[UART2BuffSize];
u16 UART2ReceIn = 0;
u8 UART2ReceFullFlag = 0;
//串口3隊列定義
u8 UART3SendBuff[UART3BuffSize];
u8 UART3ReceBuff[UART3BuffSize];
u16 UART3ReceIn = 0;
u8 UART3ReceFullFlag = 0;
//串口1初始化
void USART1_Configuration(u32 bound)
USART_InitTypeDef USART_InitStructure;;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);//開啟GPIOA和USART1時鐘
//USART1_TX GPIOA.9
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //PA.9
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //復用推挽輸出
GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIOA.9
//USART1_RX GPIOA.10初始化
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;//PA10
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//浮空輸入
GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIOA.10
//Usart1 NVIC 配置
NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=2 ;//搶占優先級3
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; //子優先級3
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道使能
NVIC_Init(&NVIC_InitStructure); //根據指定的參數初始化VIC寄存器
//USART 初始化設置
USART_InitStructure.USART_BaudRate = bound;//串口波特率
USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字長為8位數據格式
USART_InitStructure.USART_StopBits = USART_StopBits_1;//一個停止位
USART_InitStructure.USART_Parity = USART_Parity_No;//無奇偶校驗位
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//無硬件數據流控制
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //收發模式
USART_Init(USART1, &USART_InitStructure); //初始化串口1
USART_ITConfig(USART1,USART_IT_RXNE,ENABLE); //開啟串口接收中斷
USART_Cmd(USART1, ENABLE); //使能串口1
//串口2初始化
void USART2_Configuration(u32 bound)
RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2,ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);//開啟GPIOA和USART1時鐘
//USART2_TX GPIOA.2
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; //PA.2
GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIOA.2
//USART2_RX GPIOA.3初始化
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;//PA3
GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIOA.3
//Usart2 NVIC 配置
NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn;
//USART 初始化設置
USART_Init(USART2, &USART_InitStructure); //初始化串口2
USART_ITConfig(USART2,USART_IT_RXNE,ENABLE); //開啟串口接收中斷
USART_Cmd(USART2, ENABLE); //使能串口2
//串口3初始化
void USART3_Configuration(u32 bound)
RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3,ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);//開啟GPIOA和USART1時鐘
//USART3_TX GPIOB.10
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; //PB.10
GPIO_Init(GPIOB, &GPIO_InitStructure);//初始化GPIOA.10
//USART3_RX GPIOB.3初始化
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;//PB11
GPIO_Init(GPIOB, &GPIO_InitStructure);//初始化GPIOB.11
//Usart3 NVIC 配置
NVIC_InitStructure.NVIC_IRQChannel = USART3_IRQn;
//USART 初始化設置
USART_Init(USART3, &USART_InitStructure); //初始化串口3
USART_ITConfig(USART3,USART_IT_RXNE,ENABLE); //開啟串口接收中斷
USART_Cmd(USART3, ENABLE); //使能串口3
//串口1發送一幀數據
void USART1_SendOneData(uint8_t SendOneData)
USART_SendData(USART1, SendOneData);
//串口2發送一幀數據
void USART2_SendOneData(uint8_t SendOneData)
USART_SendData(USART2, SendOneData);
while (USART_GetFlagStatus(USART2, USART_FLAG_TC) == RESET)
//串口3發送一幀數據
void USART3_SendOneData(uint8_t SendOneData)
USART_SendData(USART3, SendOneData);
while (USART_GetFlagStatus(USART3, USART_FLAG_TC) == RESET)
//串口1發送一列數據
void USART1_SendUnfixedData(uint8_t *Buffer, uint8_t Length)
uint8_t i;
for(i=0;i<Length;i++)
USART1_SendOneData(*Buffer++);
//串口2發送一列數據
void USART2_SendUnfixedData(uint8_t *Buffer, uint8_t Length)
uint8_t i;
USART2_SendOneData(*Buffer++);
//串口3發送一列數據
void USART3_SendUnfixedData(uint8_t *Buffer, uint8_t Length)
uint8_t i;
LED_ON;
USART3_SendOneData(*Buffer++);
LED_OFF;
//串口1中斷服務函數
void USART1_IRQHandler(void)
u8 Res;//數據暫存
if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET) //接收中斷
Res =USART_ReceiveData(USART1); //讀取接收到的數據
switch(UART1ReceIn)//讀取接收到的數據有幾位 每一位對應的數據協議校驗
case 0:
if(Res=='T')
UART1ReceBuff[UART1ReceIn++] = Res;
UART1ReceIn = 0;
case 1:
if(Res=='M')
UART1ReceIn = 0;
case 2:
if(Res==0x0f)
UART1ReceIn = 0;
case 3:
if(Res==0x01)
UART1ReceIn = 0;
case 4:
if(Res==0x31)
UART1ReceIn = 0;
default:
if(UART1ReceIn >= 57)
UART1ReceFullFlag = 1; //數據完整接受完
USART_ClearITPendingBit(USART1, USART_IT_RXNE);//清除相對應的中斷位 清除中斷預處理位USART_ClearITPendingBit左移八位是USART_ClearFlag
else if(USART_GetITStatus(USART1, USART_IT_TXE) != RESET) // 發送中斷 USART_GetITStatus
USART_ClearITPendingBit(USART1, USART_IT_TXE); // clear interrupt 清除中斷預處理位
//串口2中斷服務函數
void USART2_IRQHandler(void)
u8 Res;
#if SYSTEM_SUPPORT_OS //如果SYSTEM_SUPPORT_OS為真,則需要支持OS.
OSIntEnter();
#endif
if(USART_GetITStatus(USART2, USART_IT_RXNE) != RESET) //接收中斷(接收到的數據必須是0x0d 0x0a結尾)
Res =USART_ReceiveData(USART2); //讀取接收到的數據USART_ReceiveData
if((USART_RX_STA&0x8000)==0)//接收未完成
if(USART_RX_STA&0x4000)//接收到了0x0d
if(Res!=0x0a)USART_RX_STA=0;//接收錯誤,重新開始
else USART_RX_STA|=0x8000; //接收完成了
else //還沒收到0X0D
if(Res==0x0d)USART_RX_STA|=0x4000;
UART2ReceBuff[USART_RX_STA&0X3FFF]=Res ;
USART_RX_STA++;
if(USART_RX_STA>(USART_REC_LEN-1))USART_RX_STA=0;//接收數據錯誤,重新開始接收
OSIntExit();
#endif
//串口3中斷服務函數
void USART3_IRQHandler(void)
u8 Res;//數據暫存
if(USART_GetITStatus(USART3, USART_IT_RXNE) != RESET) //接收中斷
Res =USART_ReceiveData(USART3); //讀取接收到的數據 USART_ReceiveData
switch(UART3ReceIn)//讀取接收到的數據有幾位 每一位對應的數據協議校驗
case 0:
if(Res=='T')
UART3ReceBuff[UART3ReceIn++] = Res;
UART3ReceIn = 0;
case 1:
if(Res=='M')
UART3ReceIn = 0;
case 2:
if(Res==0x0f)
UART3ReceIn = 0;
case 3:
if(Res==0x01)
UART3ReceIn = 0;
case 4:
if(Res==0x31)
UART3ReceIn = 0;
default:
if(UART3ReceIn >= 57)
UART3ReceFullFlag = 1; //數據完整接受完
USART_ClearITPendingBit(USART3, USART_IT_RXNE);//清除相對應的中斷位 清除中斷預處理位USART_ClearITPendingBit左移八位是USART_ClearFlag
else if(USART_GetITStatus(USART3, USART_IT_TXE) != RESET) // 發送中斷 USART_GetITStatus
USART_ClearITPendingBit(USART3, USART_IT_TXE); // clear interrupt 清除中斷預處理位
//發送開關量輸入數據
void SendInputData(void)
// 組包,第一幀
UART1SendBuff[0] = 0XAA;
UART1SendBuff[1] = 0XBB;
UART1SendBuff[2] = ReadInData.ByteData[0];
UART1SendBuff[3] = ReadInData.ByteData[1];
UART1SendBuff[4] = ReadInData.ByteData[2];
UART1SendBuff[5] = ReadInData.ByteData[3]; //165檢測結構
UART1SendBuff[6] = 0XCC;
UART1SendBuff[7] = 0XDD;
// 發送第一幀數據
USART3_SendUnfixedData(UART1SendBuff,8);
Delay_m(350); // 延時,和計算機軟件時間匹配
void SendAnalogData(void) // 通過串口發送模擬量數據
// 組包,第一幀
UART1SendBuff[2] = 0X01;
UART1SendBuff[3] = 0x10;
UART1SendBuff[4] = (AnalogChannel[0].AveVal >> 8);
UART1SendBuff[5] = (u8)AnalogChannel[0].AveVal;
// 發送第一幀數據
USART3_SendUnfixedData(UART1SendBuff, 8);
Delay_m(300); // 延時,和計算機軟件時間匹配
// 組包,第二幀
UART1SendBuff[3] = 0x20;
UART1SendBuff[4] = (AnalogChannel[1].AveVal >> 8);
UART1SendBuff[5] = (u8)AnalogChannel[1].AveVal;
// 發送第二幀數據
// 組包,第三幀
UART1SendBuff[3] = 0x30;
UART1SendBuff[4] = (AnalogChannel[2].AveVal >> 8);
UART1SendBuff[5] = (u8)AnalogChannel[2].AveVal;
// 發送第三幀數據
// 組包,第四幀
UART1SendBuff[1] = 0x40;
UART1SendBuff[2] = (AnalogChannel[3].AveVal >> 8);
UART1SendBuff[3] = (u8)AnalogChannel[3].AveVal;
// 發送第四幀數據
USART_SendUnfixedData(UART1SendBuff, 8);
// 組包,第五幀
UART1SendBuff[1] = 0x50;
UART1SendBuff[2] = (AnalogChannel[4].AveVal >> 8);
UART1SendBuff[3] = (u8)AnalogChannel[4].AveVal;
// 發送第五幀數據
// 組包,第六幀
UART1SendBuff[1] = 0x60;
UART1SendBuff[2] = (AnalogChannel[5].AveVal >> 8);
UART1SendBuff[3] = (u8)AnalogChannel[5].AveVal;
// 發送第六幀數據
// 組包,第七幀
UART1SendBuff[1] = 0x70;
UART1SendBuff[2] = (AnalogChannel[6].AveVal >> 8);
UART1SendBuff[3] = (u8)AnalogChannel[6].AveVal;
// 發送第七幀數據
// 組包,第八幀
UART1SendBuff[1] = 0x80;
UART1SendBuff[2] = (AnalogChannel[7].AveVal >> 8);
UART1SendBuff[3] = (u8)AnalogChannel[7].AveVal;
// 發送第八幀數據
上面這個是壓縮包里面的user_usart.c文件:
STM32加232串口發多串口.7z
(195.06 KB, 下載次數: 83)
2019-7-20 03:23 上傳
茍敬睿
2019-8-13 17:20
哇,牛啊,大哥!
我最近要寫一個激光雷達和32單片機的串口通信,但是有問題,激光雷達返回的值不能被單片機調用,你能幫下忙嗎?
jubaolun
2020-4-16 23:27
學習下,感謝分享。
美琴的備胎
2021-4-20 20:45
樓主發的展示程序在HARDWARE\User_usart\user_usart.c里面
午夜精品一区二区三区在线播放
久久久www成人免费精品
日韩精品免费一区二区夜夜嗨
97中文字幕
国产精品久久久久久久午夜
日批视频免费在线观看
亚洲成人精品一区
日韩在线观看一区
亚洲欧美在线播放
日韩亚洲一区二区
亚洲免费播放
日日夜夜噜
久久免费高清视频
中文字幕在线观看亚洲
中文字幕在线视频播放
午夜激情福利
九九热在线视频观看
色偷偷网站
亚洲精品91
国产精品伦一区二区三级视频
中文字幕免费
日日夜夜综合网
91av免费在线观看
国产三级做爰高清在线
国产精品国产精品国产专区不片
激情小说亚洲
a视频
天天拍天天操
av色在线
久久成人av
亚洲一区二区三区中文字幕
免费在线黄色网址
国产一区二区免费看
亚洲第一av网站
青青草视频污
99久久精品国产一区二区三区
韩日精品视频
免费特级毛片
国产呦小j女精品视频
日本中文在线
日韩av免费播放
