AES加密和解密的C語言程序實現
沒有你
2019-7-23 17:54
AES加密和解密的C語言程序實現
有些單片機沒有AES硬件外設,但是要實現AES加密和解密,就需要通過軟件來實現了。附件是AES的C語言實現。加密和解密封裝成下面兩個函數。1、加密函數
void inv_cipher(uint8 *in, uint8 *out, uint8 *key)
*in是用戶加密前的數據;*out是用戶加密后的數據;*key是128位的密鑰
2、解密函數
void cipher(uint8 *in, uint8 *out, uint8 *key)
*in是用戶解密前的數據;*out是用戶解密后的數據;*key是128位的密鑰
C語言源程序如下:
#include <stdio.h>
#include <stdlib.h>
#include "soft_AES.h"
//Addition in GF(2^8)
uint8 gadd(uint8 a, uint8 b) {
return a^b;
//Subtraction in GF(2^8)
uint8 gsub(uint8 a, uint8 b) {
return a^b;
//Multiplication in GF(2^8)
//正向列混淆
uint8 gmult(uint8 a, uint8 b) {
uint8 p = 0, i = 0, hbs = 0;
for (i = 0; i < 8; i++) {
if (b & 1) {
p ^= a;
hbs = a & 0x80;
a <<= 1;
if (hbs) a ^= 0x1b; // 0000 0001 0001 1011
b >>= 1;
return (uint8)p;
//Addition of 4 byte words
//添加一個字
void coef_add(uint8 a[], uint8 b[], uint8 d[]) {
d[0] = a[0]^b[0];
d[1] = a[1]^b[1];
d[2] = a[2]^b[2];
d[3] = a[3]^b[3];
//Multiplication of 4 byte words
void coef_mult(uint8 *a, uint8 *b, uint8 *d) {
d[0] = gmult(a[0],b[0])^gmult(a[3],b[1])^gmult(a[2],b[2])^gmult(a[1],b[3]);
d[1] = gmult(a[1],b[0])^gmult(a[0],b[1])^gmult(a[3],b[2])^gmult(a[2],b[3]);
d[2] = gmult(a[2],b[0])^gmult(a[1],b[1])^gmult(a[0],b[2])^gmult(a[3],b[3]);
d[3] = gmult(a[3],b[0])^gmult(a[2],b[1])^gmult(a[1],b[2])^gmult(a[0],b[3]);
uint8 K;//The cipher Key.
#define Nb 4//Number of columns (32-bit words) comprising the State. For this standard, Nb = 4.
uint8 Nk;// * Number of 32-bit words comprising the Cipher Key. For this standard, Nk = 4, 6, or 8
uint8 Nr;// Number of rounds, which is a function of Nk and Nb (which is fixed). For this standard, Nr = 10, 12, or 14
//S-box transformation table
static uint8 s_box[256] = {
// 0 1 2 3 4 5 6 7 8 9 a b c d e f
0x63, 0x7c, 0x77, 0x7b, 0xf2, 0x6b, 0x6f, 0xc5, 0x30, 0x01, 0x67, 0x2b, 0xfe, 0xd7, 0xab, 0x76, // 0
0xca, 0x82, 0xc9, 0x7d, 0xfa, 0x59, 0x47, 0xf0, 0xad, 0xd4, 0xa2, 0xaf, 0x9c, 0xa4, 0x72, 0xc0, // 1
0xb7, 0xfd, 0x93, 0x26, 0x36, 0x3f, 0xf7, 0xcc, 0x34, 0xa5, 0xe5, 0xf1, 0x71, 0xd8, 0x31, 0x15, // 2
0x04, 0xc7, 0x23, 0xc3, 0x18, 0x96, 0x05, 0x9a, 0x07, 0x12, 0x80, 0xe2, 0xeb, 0x27, 0xb2, 0x75, // 3
0x09, 0x83, 0x2c, 0x1a, 0x1b, 0x6e, 0x5a, 0xa0, 0x52, 0x3b, 0xd6, 0xb3, 0x29, 0xe3, 0x2f, 0x84, // 4
0x53, 0xd1, 0x00, 0xed, 0x20, 0xfc, 0xb1, 0x5b, 0x6a, 0xcb, 0xbe, 0x39, 0x4a, 0x4c, 0x58, 0xcf, // 5
0xd0, 0xef, 0xaa, 0xfb, 0x43, 0x4d, 0x33, 0x85, 0x45, 0xf9, 0x02, 0x7f, 0x50, 0x3c, 0x9f, 0xa8, // 6
0x51, 0xa3, 0x40, 0x8f, 0x92, 0x9d, 0x38, 0xf5, 0xbc, 0xb6, 0xda, 0x21, 0x10, 0xff, 0xf3, 0xd2, // 7
0xcd, 0x0c, 0x13, 0xec, 0x5f, 0x97, 0x44, 0x17, 0xc4, 0xa7, 0x7e, 0x3d, 0x64, 0x5d, 0x19, 0x73, // 8
0x60, 0x81, 0x4f, 0xdc, 0x22, 0x2a, 0x90, 0x88, 0x46, 0xee, 0xb8, 0x14, 0xde, 0x5e, 0x0b, 0xdb, // 9
0xe0, 0x32, 0x3a, 0x0a, 0x49, 0x06, 0x24, 0x5c, 0xc2, 0xd3, 0xac, 0x62, 0x91, 0x95, 0xe4, 0x79, // a
0xe7, 0xc8, 0x37, 0x6d, 0x8d, 0xd5, 0x4e, 0xa9, 0x6c, 0x56, 0xf4, 0xea, 0x65, 0x7a, 0xae, 0x08, // b
0xba, 0x78, 0x25, 0x2e, 0x1c, 0xa6, 0xb4, 0xc6, 0xe8, 0xdd, 0x74, 0x1f, 0x4b, 0xbd, 0x8b, 0x8a, // c
0x70, 0x3e, 0xb5, 0x66, 0x48, 0x03, 0xf6, 0x0e, 0x61, 0x35, 0x57, 0xb9, 0x86, 0xc1, 0x1d, 0x9e, // d
0xe1, 0xf8, 0x98, 0x11, 0x69, 0xd9, 0x8e, 0x94, 0x9b, 0x1e, 0x87, 0xe9, 0xce, 0x55, 0x28, 0xdf, // e
0x8c, 0xa1, 0x89, 0x0d, 0xbf, 0xe6, 0x42, 0x68, 0x41, 0x99, 0x2d, 0x0f, 0xb0, 0x54, 0xbb, 0x16};// f
//Inverse S-box transformation table
static uint8 inv_s_box[256] = {
0x52, 0x09, 0x6a, 0xd5, 0x30, 0x36, 0xa5, 0x38, 0xbf, 0x40, 0xa3, 0x9e, 0x81, 0xf3, 0xd7, 0xfb, // 0
0x7c, 0xe3, 0x39, 0x82, 0x9b, 0x2f, 0xff, 0x87, 0x34, 0x8e, 0x43, 0x44, 0xc4, 0xde, 0xe9, 0xcb, // 1
0x54, 0x7b, 0x94, 0x32, 0xa6, 0xc2, 0x23, 0x3d, 0xee, 0x4c, 0x95, 0x0b, 0x42, 0xfa, 0xc3, 0x4e, // 2
0x08, 0x2e, 0xa1, 0x66, 0x28, 0xd9, 0x24, 0xb2, 0x76, 0x5b, 0xa2, 0x49, 0x6d, 0x8b, 0xd1, 0x25, // 3
0x72, 0xf8, 0xf6, 0x64, 0x86, 0x68, 0x98, 0x16, 0xd4, 0xa4, 0x5c, 0xcc, 0x5d, 0x65, 0xb6, 0x92, // 4
0x6c, 0x70, 0x48, 0x50, 0xfd, 0xed, 0xb9, 0xda, 0x5e, 0x15, 0x46, 0x57, 0xa7, 0x8d, 0x9d, 0x84, // 5
0x90, 0xd8, 0xab, 0x00, 0x8c, 0xbc, 0xd3, 0x0a, 0xf7, 0xe4, 0x58, 0x05, 0xb8, 0xb3, 0x45, 0x06, // 6
0xd0, 0x2c, 0x1e, 0x8f, 0xca, 0x3f, 0x0f, 0x02, 0xc1, 0xaf, 0xbd, 0x03, 0x01, 0x13, 0x8a, 0x6b, // 7
0x3a, 0x91, 0x11, 0x41, 0x4f, 0x67, 0xdc, 0xea, 0x97, 0xf2, 0xcf, 0xce, 0xf0, 0xb4, 0xe6, 0x73, // 8
0x96, 0xac, 0x74, 0x22, 0xe7, 0xad, 0x35, 0x85, 0xe2, 0xf9, 0x37, 0xe8, 0x1c, 0x75, 0xdf, 0x6e, // 9
0x47, 0xf1, 0x1a, 0x71, 0x1d, 0x29, 0xc5, 0x89, 0x6f, 0xb7, 0x62, 0x0e, 0xaa, 0x18, 0xbe, 0x1b, // a
0xfc, 0x56, 0x3e, 0x4b, 0xc6, 0xd2, 0x79, 0x20, 0x9a, 0xdb, 0xc0, 0xfe, 0x78, 0xcd, 0x5a, 0xf4, // b
0x1f, 0xdd, 0xa8, 0x33, 0x88, 0x07, 0xc7, 0x31, 0xb1, 0x12, 0x10, 0x59, 0x27, 0x80, 0xec, 0x5f, // c
0x60, 0x51, 0x7f, 0xa9, 0x19, 0xb5, 0x4a, 0x0d, 0x2d, 0xe5, 0x7a, 0x9f, 0x93, 0xc9, 0x9c, 0xef, // d
0xa0, 0xe0, 0x3b, 0x4d, 0xae, 0x2a, 0xf5, 0xb0, 0xc8, 0xeb, 0xbb, 0x3c, 0x83, 0x53, 0x99, 0x61, // e
0x17, 0x2b, 0x04, 0x7e, 0xba, 0x77, 0xd6, 0x26, 0xe1, 0x69, 0x14, 0x63, 0x55, 0x21, 0x0c, 0x7d};// f
//Generates the round constant Rcon[i]
uint8 R[] = {0x02, 0x00, 0x00, 0x00};
uint8 * Rcon(uint8 i) {
if (i == 1) {
R[0] = 0x01; // x^(1-1) = x^0 = 1
} else if (i > 1) {
R[0] = 0x02;
i--;
while (i-1 > 0) {
R[0] = gmult(R[0], 0x02);
i--;
return R;
* Transformation in the Cipher and Inverse Cipher in which a Round
* Key is added to the State using an XOR operation. The length of a
* Round Key equals the size of the State (i.e., for Nb = 4, the Round
* Key length equals 128 bits/16 bytes).
//輪密鑰加,128位的State按位與 128位的密鑰異或
void add_round_key(uint8 *state, uint8 *w, uint8 r) {
uint8 c;
for (c = 0; c < Nb; c++) {
state[Nb*0+c] = state[Nb*0+c]^w[4*Nb*r+4*c+0]; //debug, so it works for Nb !=4
state[Nb*1+c] = state[Nb*1+c]^w[4*Nb*r+4*c+1];
state[Nb*2+c] = state[Nb*2+c]^w[4*Nb*r+4*c+2];
state[Nb*3+c] = state[Nb*3+c]^w[4*Nb*r+4*c+3];
* Transformation in the Cipher that takes all of the columns of the
* State and mixes their data (independently of one another) to
* produce new columns.
//列混合
void mix_columns(uint8 *state) {
uint8 a[] = {0x02, 0x01, 0x01, 0x03}; // a(x) = {02} + {01}x + {01}x2 + {03}x3
uint8 i, j, col[4], res[4];
for (j = 0; j < Nb; j++) {
for (i = 0; i < 4; i++) {
col[i] = state[Nb*i+j];
coef_mult(a, col, res);
state[Nb*i+j] = res[i];
* Transformation in the Inverse Cipher that is the inverse of
* MixColumns().
//逆列混合
void inv_mix_columns(uint8 *state) {
uint8 a[] = {0x0e, 0x09, 0x0d, 0x0b}; // a(x) = {0e} + {09}x + {0d}x2 + {0b}x3
* Transformation in the Cipher that processes the State by cyclically
* shifting the last three rows of the State by different offsets.
//行移位
void shift_rows(uint8 *state) {
uint8 i, k, s, tmp;
for (i = 1; i < 4; i++) {
// shift(1,4)=1; shift(2,4)=2; shift(3,4)=3
// shift(r, 4) = r;
s = 0;
while (s < i) {
tmp = state[Nb*i+0];
for (k = 1; k < Nb; k++) {
state[Nb*i+k-1] = state[Nb*i+k];
state[Nb*i+Nb-1] = tmp;
s++;
* ShiftRows().
//逆行移位
void inv_shift_rows(uint8 *state) {
uint8 i, k, s, tmp;
s = 0;
while (s < i) {
tmp = state[Nb*i+Nb-1];
for (k = Nb-1; k > 0; k--) {
state[Nb*i+k] = state[Nb*i+k-1];
state[Nb*i+0] = tmp;
s++;
* Transformation in the Cipher that processes the State using a non-
* linear byte substitution table (S-box) that operates on each of the
* State bytes independently.
//字節代替
void sub_bytes(uint8 *state) {
uint8 i, j;
uint8 row, col;
row = (state[Nb*i+j] & 0xf0) >> 4;
col = state[Nb*i+j] & 0x0f;
state[Nb*i+j] = s_box[16*row+col];
* SubBytes().
//逆字節代替
void inv_sub_bytes(uint8 *state) {
uint8 i, j;
uint8 row, col;
state[Nb*i+j] = inv_s_box[16*row+col];
* Function used in the Key Expansion routine that takes a four-byte
* input word and applies an S-box to each of the four bytes to
* produce an output word.
//S盒變換
void sub_word(uint8 *w) {
uint8 i;
w[i] = s_box[16*((w[i] & 0xf0) >> 4) + (w[i] & 0x0f)];
* word and performs a cyclic permutation.
//左移
void rot_word(uint8 *w) {
uint8 tmp;
uint8 i;
tmp = w[0];
for (i = 0; i < 3; i++) {
w[i] = w[i+1];
w[3] = tmp;
* Key Expansion
//擴展密鑰
void key_expansion(uint8 *key, uint8 *w) {
uint8 tmp[4];
uint8 i;
uint8 len = Nb*(Nr+1);
for (i = 0; i < Nk; i++) {
w[4*i+0] = key[4*i+0];
w[4*i+1] = key[4*i+1];
w[4*i+2] = key[4*i+2];
w[4*i+3] = key[4*i+3];
for (i = Nk; i < len; i++) {
tmp[0] = w[4*(i-1)+0];
tmp[1] = w[4*(i-1)+1];
tmp[2] = w[4*(i-1)+2];
tmp[3] = w[4*(i-1)+3];
if (i%Nk == 0) {
rot_word(tmp);
sub_word(tmp);
coef_add(tmp, Rcon(i/Nk), tmp);
} else if (Nk > 6 && i%Nk == 4) {
sub_word(tmp);
w[4*i+0] = w[4*(i-Nk)+0]^tmp[0];
w[4*i+1] = w[4*(i-Nk)+1]^tmp[1];
w[4*i+2] = w[4*(i-Nk)+2]^tmp[2];
w[4*i+3] = w[4*(i-Nk)+3]^tmp[3];
//加密函數
void cipher(uint8 *in, uint8 *out, uint8 *key) {
uint8 state[4*Nb];
uint8 r, i, j;
uint8 *w;
Nk = 4;
Nr = 10;//輪數為10
w = malloc(Nb*(Nr+1)*4);//申請擴展密鑰長度為176
key_expansion(key, w);//擴展密鑰
state[Nb*i+j] = in[i+4*j];
add_round_key(state, w, 0);//輪密鑰加
for (r = 1; r < Nr; r++) {
sub_bytes(state);//字節代替
shift_rows(state);//行移位
mix_columns(state);//列混合
add_round_key(state, w, r);//輪密鑰加
//最后一輪只執行3個階段
sub_bytes(state);
shift_rows(state);
add_round_key(state, w, Nr);
out[i+4*j] = state[Nb*i+j];
//解密函數
void inv_cipher(uint8 *in, uint8 *out, uint8 *key) {
uint8 state[4*Nb];
uint8 r, i, j;
uint8 *w;
Nk = 4;
Nr = 10;//輪數為10
add_round_key(state, w, Nr);//輪密鑰加
for (r = Nr-1; r >= 1; r--) {
inv_shift_rows(state);//逆行移位
inv_sub_bytes(state);//逆字節代替
inv_mix_columns(state);//逆列混合
AES.rar
(3.91 KB, 下載次數: 130)
2019-7-23 17:48 上傳
AES加密和解密的C語言實現
yxy@@
2019-10-18 22:59
有用,超級棒的
yxy@@
2019-10-18 23:00
很棒,很有用的
hongpanfeng
2020-4-14 17:16
很有用,值得下載
Listen丶51
2020-6-5 14:18
你好,請問這個密鑰位數可以改變嗎?可以改變位數要修改那些地方的代碼?請請教,,,謝謝!
沒有你
2020-6-6 18:22
Listen丶51 發表于 2020-6-5 14:18
AES加密算法有128位、192位和256位,這個只是128位的例子。如果有興趣可以自己網上搜索資料研究192位和256位的實現。
8625299
2021-4-14 11:07
好東東,好資料,51黑有你更精彩!!!賺黑幣下載
15275692759
2021-6-2 18:37
有用,太好了吧 贊
jiayong612
2021-6-7 18:36
非常好!實用!值得一試!
QAS
2022-12-27 16:51
您好,是ECB 128 自動補零嗎?
免费在线观看黄色片
闷骚老干部cao个爽 欧美区一区二
成人午夜精品
欧美一级淫片bbb一84
青青青在线视频
久久国产综合
四虎影院永久免费
成人少妇影院yyyy
亚洲免费在线视频
成人免费看片'
攵女(高h)欢欲
岛国精品在线播放
久精品视频
久久精品欧美一区
一级肉体裸体bbbb
a在线免费观看
国产日韩欧美精品
青青青视频在线
日韩精品久久久久久
五月婷婷色综合
91久久久久久久久久
国产一级特黄
www.少妇
欧美一级欧美三级在线观看
精品一区二区三区免费看
亚洲综合精品
欧美一区二区免费
亚洲欧美在线播放
91麻豆精品
97精品国产
成人av一区
欧美三级三级三级爽爽爽
911看片
97视频在线免费观看
一区二区三区四区在线
高清一区二区三区
国产乱国产乱300精品
欧美一区二区三区在线播放
一个色综合网
免费观看一区二区三区
成人小视频在线
