do //this cycle waits until someone click the ON button on the app{ if(Serial.available()>0) { state=Serial.read(); Serial.println(readString); //prints string to serial port out } }while(state!='V'); //system ON commanddigitalWrite(8, LOW); do //this cycle waits that the user push either Home Button or OFF button { if(Serial.available()>0) { state=Serial.read(); Serial.println(readString); //prints string to serial port out } } while((state!='O')&&(state!='Z'));
2)-你還記得在應用程序中我們曾經(jīng)發(fā)送命令'd'來向后發(fā)送馬達嗎?-你還記得我們把Y限位開關連接到插腳10和GND?最初,我們檢查Y電機是否能夠實際后退:如果按下引腳10上的限位開關,Arduino將讀取GND,即使在應用程序上按下后退按鈕,也不會發(fā)生任何事情。如果不按下限位開關,我們只需用簡單的步進指令將電機旋轉72°。旋轉(72)并減小1的y變量。if(limitYstate==HIGH) { if(c == 'B') //Y motor backward { stepperY.rotate(72); //the value is not negative because I mounted the motors upside-down in my assembly, sorry delay(5); Y--; Serial.println("Y value, "); Serial.println(Y); Serial.println("Y motor backward"); readString=""; } }3)這是一個難點,基本上我們在這里捕獲用戶拖動應用程序上的麥克風圖標時發(fā)送的字符串,然后我們解析這些數(shù)據(jù)。例如,也就是說,我們將子字符串轉換為整數(shù):x=“17”變成xm=17y=“24”變?yōu)閥m=24在這個過程中,我們將每個字符串加載到緩沖區(qū)數(shù)組中,最后使用atoi()命令獲取整數(shù)值。你還記得拖動麥克風徽標時應用程序中的彈跳問題嗎?好吧,電機不會移動,直到在序列上讀到字符“u”,然后電機才會根據(jù)最后的xm和ym值旋轉。
if (c == ';') // character ; means that the user has dragged the microphone icon on the app { Serial.println(); Serial.print("captured String is : "); //we have captured the string with the X Y Z values, now we need to parse it and elaborate it, the following commands are for parsing Serial.println(readString); //prints string to serial port out, used for debugging ind1 = readString.indexOf('.'); //finds location of . ind2 = readString.indexOf(','); //finds location of , XString = readString.substring(ind1+1, ind2); //captures the string between charactes . and , ind3 = readString.indexOf('*'); //find location of * which delimits the end string YString = readString.substring(ind2+1, ind3); //captures the string between charactes , and * char buf1[XString.length()+1]; //create a characters array long as substring X XString.toCharArray(buf1, XString.length()+1); //load string X in the array buf1 char buf2[YString.length()+1]; //create a characters array long as substring Y YString.toCharArray(buf2, YString.length()+1); //load the string Y in array buf2 Xm = atoi(buf1); //convert the string in arra buf 1, which is a character with the value of X in an integer Ym = atoi(buf2); //convert the string in arra buf 2, which is a character with the value of Y in an integer readString=""; //clears variables for new input XString=""; YString=""; Serial.print("X = "); //we print everything on the serial monitor for debugging Serial.println(X); Serial.print("Y = "); Serial.println(Y); Serial.print("Xm = "); Serial.println(Xm); Serial.print("Ym = "); Serial.println(Ym); } if (c == 'U') //move the motors in the position of the X Y values read from the app movement { Serial.print("X = "); Serial.println(X); Serial.print("Y = "); Serial.println(Y); Serial.print("final Xm = "); Serial.println(Xm); Serial.print("final Ym = "); Serial.println(Ym); stepperX.rotate(-72*(Xm-X)); delay(5); stepperY.rotate(-72*(Ym-Y)); delay(5); X=Xm; Y=Ym; readString=""; }
