STM32F407驅動IT7259的驅動代碼
lfgxp
2019-12-24 16:27
IT7259這個驅動IC在智能穿戴設備商用的比較多,它的驅動拿出來分享一下
#include "it7259.h"
#include "WM.h"
#include "mainview.h"
#include "string.h"
I2C_HandleTypeDef hi2c3;
TIM_HandleTypeDef htim6;
uint16_t XResolution;
uint16_t YResolution;
uint8_t Step;
extern WM_HWIN MainView;
#define IT7259_ADDR 0x8C
#define IT7259_ADDR_READ IT7259_ADDR | 1
#define COMMAND_BUFFER_INDEX 0x20
#define QUERY_BUFFER_INDEX 0x80
#define COMMAND_RESPONSE_BUFFER_INDEX 0xA0
#define POINT_BUFFER_INDEX 0xE0
#define QUERY_SUCCESS 0x00
#define QUERY_BUSY 0x01
#define QUERY_ERROR 0x02
#define QUERY_POINT 0x80
#define IIC_SCL GPIO_PIN_6 //PB6
#define IIC_SDA GPIO_PIN_7 //PB7
#define RST GPIO_PIN_9 //PB9
#define EINT GPIO_PIN_8 //PB8
#define IIC_SCL_PORT GPIOB //
#define IIC_SDA_PORT GPIOB //
#define RST_PORT GPIOB //
#define EINT_PORT GPIOB //
#define EINT_PORT_IRQ EXTI9_5_IRQn
#define LOW_PIN(x, y) (x->BSRR = y << 16)
#define HIGH_PIN(x, y) (x->BSRR = y)
#define READ_PIN(x, y) ((x->IDR & y) > 0 ? 1 : 0)
#define SDA_OUTPUT() GPIOB->MODER = (GPIOB->MODER & 0xFFFF3FFF) | 0x00004000; //
#define SDA_INPUT() GPIOB->MODER = (GPIOB->MODER & 0xFFFF3FFF);
#define ACK 0
#define NACK 1
#define POINT 0x08
#define GESTURES 0x80
#define TAP 0x20
#define FLICK 0x22
#define DOUBLE_TAP 0x23
#define UP 0x08
#define UPPER_RIGHT 0x09
#define RIGHT 0x0A
#define LOWER_RIGHT 0x0B
#define DOWN 0x0C
#define LOWER_LEFT 0x0D
#define LEFT 0x0E
#define UPPER_LEFT 0x0F
uint8_t pointdata[14]; //報點XY數據
static void I2CDelay(uint16_t n)
TIM6->ARR = 0x10000 - n;
TIM6->CNT = 0x10000 - n;
__HAL_TIM_CLEAR_FLAG(&htim6, TIM_FLAG_UPDATE);
TIM6->CR1 |= 1;
while(__HAL_TIM_GET_FLAG(&htim6, TIM_FLAG_UPDATE) == RESET);
*函數名稱:I2CStart
*函數功能:I2C開始信號
*輸入參數:
*輸出參數:
*備 注:時鐘線高時,數據線由高到低的跳變,表示I2C開始信號
static void I2CStart( void )
SDA_OUTPUT();
HIGH_PIN(IIC_SDA_PORT, IIC_SDA);
//I2CDelay(6);
HIGH_PIN(IIC_SCL_PORT, IIC_SCL);
//I2CDelay(6);
LOW_PIN(IIC_SDA_PORT, IIC_SDA);
I2CDelay(6);
LOW_PIN(IIC_SCL_PORT, IIC_SCL);
I2CDelay(6);
*函數名稱:I2CStop
*函數功能:I2C停止信號
*輸入參數:
*輸出參數:
*備 注:時鐘線高時,數據線由低到高的跳變,表示I2C停止信號
static void I2CStop( void )
SDA_OUTPUT();
I2CDelay(6);
I2CDelay(6);
I2CDelay(6);
*函數名稱:I2CWriteByte
*函數功能:I2C寫一字節數據
*輸入參數:
*輸出參數:
*備 注:
static uint8_t I2CWriteByte(uint8_t byte)
uint8_t i;
uint8_t ucErrTime=0;
SDA_OUTPUT();
//LOW_PIN(IIC_SCL_PORT, IIC_SCL);
for (i=0; i<8; i++)
I2CDelay(6);
if(0x80 & byte)
byte <<= 1;
I2CDelay(6);
I2CDelay(6);
SDA_INPUT();
I2CDelay(6);
while(READ_PIN(IIC_SDA_PORT, IIC_SDA))
if(ucErrTime++>250)
I2CStop();
return NACK;
I2CDelay(6);
return ACK;
//產生ACK應答
void IIC_Ack(void)
SDA_OUTPUT();
LOW_PIN(IIC_SDA_PORT, IIC_SDA);;
I2CDelay(6);
HIGH_PIN(IIC_SDA_PORT, IIC_SCL);
I2CDelay(6);
//不產生ACK應答
void IIC_NAck(void)
SDA_OUTPUT();
I2CDelay(6);
I2CDelay(6);
*函數名稱:I2CReadByte
*函數功能:I2C讀一字節數據
*輸入參數:
*輸出參數:
*備 注:
static uint8_t I2CReadByte(uint8_t ack)
int8_t i;
uint8_t ReadValue = 0;
SDA_INPUT();
for( i=7; i>=0; i-- )
I2CDelay(6);
I2CDelay(6);
ReadValue |= READ_PIN(IIC_SDA_PORT, IIC_SDA) << i;
SDA_OUTPUT();
if (!ack)
IIC_NAck();//發送nACK
IIC_Ack(); //發送ACK
return ReadValue;
*函數名稱:MemoryWriteByte
*函數功能:E2PROM指定地址寫一字節數據
*輸入參數:addr E2PROM地址
data 寫入的數據
*輸出參數:SET: 寫入正常;RESET:寫入錯誤
*備 注:
static uint8_t MemoryWriteBuffer(uint8_t addr, uint8_t* pdata, int len)
I2CStart();
if(I2CWriteByte(IT7259_ADDR) == NACK)
I2CStop();
return 0;
if(I2CWriteByte(addr) == NACK)
I2CStop();
return 0;
while(len--)
if(I2CWriteByte(*pdata++) == NACK)
I2CStop();
return 0;
I2CStop();
return 1;
*函數名稱:E2promReadByte
*函數功能:E2PROM指定地址讀一字節數據
*輸入參數:addr E2PROM地址
*輸出參數:返回讀出的數據
*備 注:
static uint8_t MemoryReadBuffer(uint8_t addr, uint8_t* pdata, int len)
I2CStart();
I2CStop();
return 0;
I2CStop();
return 0;
I2CStart();
if(I2CWriteByte(IT7259_ADDR_READ) == NACK) ///////////???????????
I2CStop();
return 0;
while(--len)
*pdata++ = I2CReadByte(ACK);
*pdata = I2CReadByte(NACK);
I2CStop();
return 1;
static void CTP_CheckBusy(void)
uint8_t query, result;
uint16_t i=0;
do
result = MemoryReadBuffer(QUERY_BUFFER_INDEX, &query, 1);
i++;
if(i>500)
return;
}while((query & QUERY_BUSY) || result == 0);
static uint8_t CTP_IdentifyCapSensor(void)
uint8_t cmd = 0;
uint8_t data[10];
CTP_CheckBusy();
if(!MemoryWriteBuffer(COMMAND_BUFFER_INDEX, &cmd, 1)) return 0;
CTP_CheckBusy();
if(!MemoryReadBuffer(COMMAND_RESPONSE_BUFFER_INDEX, data, 10)) return 0;
if(data[1] == 'I' && data[2] == 'T' && data[3] == 'E' && data[4] == '7' && data[5] == '2' && data[6] == '6' && data[7] == '0')
return 1;
return 0;
static uint8_t CTP_SetInterruptNotification(uint8_t ucStatus, uint8_t ucType)
uint8_t cmd[4] = {0x02, 0x04, ucStatus, ucType};
uint8_t data[2];
CTP_CheckBusy();
if(!MemoryWriteBuffer(COMMAND_BUFFER_INDEX, cmd, 4)) return 0;
CTP_CheckBusy();
if(!MemoryReadBuffer(COMMAND_RESPONSE_BUFFER_INDEX, data, 2)) return 0;
if(*(uint16_t *)data == 0)
return 1;
return 0;
static uint8_t CTP_GetFirmwareInformation(uint8_t* info)
uint8_t cmd[2] = {0x01, 0x00};
CTP_CheckBusy();
if(!MemoryWriteBuffer(COMMAND_BUFFER_INDEX, cmd, 2)) return 0;
CTP_CheckBusy();
if(!MemoryReadBuffer(COMMAND_RESPONSE_BUFFER_INDEX, info, 9)) return 0;
if(info[5]== 0 && info[6] == 0 && info[7] == 0 && info[8] == 0)
return 0;
return 1;
static uint8_t CTP_Get2DResolutions(uint16_t *pwXResolution, uint16_t *pwYResolution, uint8_t *pucStep)
uint8_t cmd[2] = {0x01, 0x02};
uint8_t data[14];
CTP_CheckBusy();
CTP_CheckBusy();
if(!MemoryReadBuffer(COMMAND_RESPONSE_BUFFER_INDEX, data, 14)) return 0;
if(pwXResolution != NULL)
*pwXResolution = data[2] + (data[3] << 8);
if(pwYResolution != NULL)
*pwYResolution = data[4] + (data[5] << 8);
if(pucStep != NULL)
*pucStep = data[6];
return 1;
static void TOUCH_IO_Init(void)
GPIO_InitTypeDef GPIO_InitStruct;
//__HAL_RCC_GPIOA_CLK_ENABLE();
__HAL_RCC_GPIOB_CLK_ENABLE();
//__HAL_RCC_GPIOC_CLK_ENABLE();
/**I2C1 GPIO Configuration
PA8 ------> I2C1_SCL
PC9 ------> I2C1_SDA
GPIO_InitStruct.Pin = IIC_SCL;
GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
GPIO_InitStruct.Pull = GPIO_PULLUP;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
HAL_GPIO_Init(IIC_SCL_PORT, &GPIO_InitStruct);
GPIO_InitStruct.Pin = IIC_SDA;
HAL_GPIO_Init(IIC_SDA_PORT, &GPIO_InitStruct);
GPIO_InitStruct.Pin = RST;
GPIO_InitStruct.Pull = GPIO_NOPULL;
HAL_GPIO_Init(RST_PORT, &GPIO_InitStruct);
GPIO_InitStruct.Pin = EINT;
GPIO_InitStruct.Mode = GPIO_MODE_IT_FALLING;
HAL_GPIO_Init(EINT_PORT, &GPIO_InitStruct);
HAL_NVIC_SetPriority(EINT_PORT_IRQ, 1, 0);
/* TIM6 init function */
static void MX_TIM6_Init(void)
TIM_MasterConfigTypeDef sMasterConfig;
__HAL_RCC_TIM6_CLK_ENABLE();
htim6.Instance = TIM6;
htim6.Init.Prescaler = 84 - 1;
htim6.Init.CounterMode = TIM_COUNTERMODE_UP;
HAL_TIM_Base_Init(&htim6);
HAL_TIM_OnePulse_Init(&htim6, TIM_OPMODE_SINGLE);
sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET;
sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
HAL_TIMEx_MasterConfigSynchronization(&htim6, &sMasterConfig);
uint8_t firmwareinfo[9];
void IT7259_Init(void)
TOUCH_IO_Init();
MX_TIM6_Init();
HAL_GPIO_WritePin(RST_PORT, RST, GPIO_PIN_RESET);
HAL_Delay(10);
HAL_GPIO_WritePin(RST_PORT, RST, GPIO_PIN_SET);
HAL_Delay(200);
if(!CTP_IdentifyCapSensor()) return; //識別觸摸屏
if(!CTP_GetFirmwareInformation(firmwareinfo)) return; //檢測固件狀態
if(!CTP_Get2DResolutions(&XResolution, &YResolution, &Step)) return; //獲取觸摸屏分辨率
//if(!CTP_SetInterruptNotification(1, 0)) return; //設置觸摸產生下降沿中斷
HAL_NVIC_EnableIRQ(EINT_PORT_IRQ); //使能PC7中斷
static uint8_t CTP_CheckNewPoint(void)
uint8_t query;
if(!MemoryReadBuffer(QUERY_BUFFER_INDEX, &query, 1)) return 0;
if (query & QUERY_POINT) return 1;
uint8_t Read_X(void);
uint8_t Read_Y(void);
void HAL_GPIO_EXTI_Callback(uint16_t GPIO_Pin) //觸摸中斷
uint16_t xraw,yraw;
if(CTP_CheckNewPoint())
if(!MemoryReadBuffer(POINT_BUFFER_INDEX, pointdata, 14)) return;
if(pointdata[0] & POINT) //報點
// Read_X();
// Read_Y();
xraw = ((pointdata[3] & 0x0F) << 8) + pointdata[2];
yraw = ((pointdata[3] & 0xF0) << 4) + pointdata[4];
GUI_TOUCH_Exec();
// memset(pointdata,0,14);
// GUI_TOUCH_GetState();
if(pointdata[0] & GESTURES) //手勢
// if(pointdata[1] == TAP || pointdata[1] == DOUBLE_TAP) //單擊
// WM_SendMessageNoPara(MainView, WM_TAP);
if(pointdata[1] == FLICK) //滑動
switch(pointdata[10])
case UP: //上
case UPPER_RIGHT:
WM_SendMessageNoPara(MainView, WM_SLIDE_UP);
case RIGHT: //右
case LOWER_RIGHT:
WM_SendMessageNoPara(MainView, WM_SLIDE_RIGHT);
case DOWN: //下
case LOWER_LEFT:
WM_SendMessageNoPara(MainView, WM_SLIDE_DOWN);
case LEFT: //左
case UPPER_LEFT:
WM_SendMessageNoPara(MainView, WM_SLIDE_LEFT);
uint16_t x,y,temp;
uint16_t Read_X(void)
x = pointdata[2];
temp = pointdata[3];
x |= ((temp & 0x0F)<<8);
return x;
uint16_t Read_Y(void)
y = pointdata[4];
y |= ((temp & 0xF0)<<4);
return y;
//memset(pointdata,0,14);
zxh51
2020-4-19 14:38
整體的源碼 能發我嗎?
lfgxp
2020-4-27 14:29
zxh51 發表于 2020-4-19 14:38
整體的源碼 能發我嗎?
留下你的郵箱地址
onono
2020-7-6 11:23
我也正在調這個,可以分享一下嗎?
kshitij
2020-8-13 18:19
lfgxp 發表于 2020-4-27 14:29
留下你的郵箱地址
Hello! Can I get the overall source code too?
Here's my email :
Thank you in advance!
DSCX05
2020-12-13 23:03
我也正在調這個,可以分享一下嗎?
gqm
2021-5-18 10:23
能把這個tp的整套驅動發大家一下嗎,我也在調試,謝謝!
sanmu
2021-5-19 13:01
還能發嗎 我也想要一份 給我發一份可以嗎
shlj999
2023-5-10 15:10
Could you share the full source code?
1065307738
2023-7-19 08:29
大師 資料給我發一份吧,最近在調這個觸摸芯片。
一区二区三区影视
日韩视频二区
中文字幕免费
中文字幕在线观看一区
91蜜桃婷婷狠狠久久综合9色
四虎永久在线
黄色一级大片在线免费看国产一
三级视频网站
日韩欧美一区二区在线观看
国产成人a亚洲精品
秋霞国产
久久久久久97
日本69视频
伊人网在线观看
国产精品久久久久久久成人午夜
日本亚洲天堂
少妇中文字幕
午夜国产福利
91福利视频导航
亚洲综合另类
久久久国产一区二区三区
精品无人国产偷自产在线
亚洲国产精品久久久
国产自偷自拍
免费一级a毛片
亚洲性小说
九九天堂
夜夜嗨av一区二区三区网页
福利影院在线观看
伊人色综合网
国产精品欧美激情
99亚洲精品
亚洲第一在线
亚洲成人中文字幕
www99热
日日操天天操
日韩视频免费在线观看
久久一二三区
人人射人人干
免费看a级片
精品一二三
