HT1621燃氣抄表程序
YYZZ052
2020-1-18 22:30
HT1621燃氣抄表程序
本人自寫的燃氣炒表程序,,用到HT1621驅動顯示屏,希望能幫到大家
//ICC-AVR application builder : 2005-3-3 17:58:11
// Target : M8
// Crystal: 4.0000Mhz
//1621引線:CS:PB4 WR:PB5 Data:PB3
#include <iom8v.h>
#include <macros.h>
#include <eeprom.h>
#define WR 0B00100000//時鐘線
#define DATA 0B00001000//數據線
#define CS 0b00010000//片選線
#define P 0x80
#define data_length 8
const char seg_tab[]={0x5f,0x06,0x6b,0x2f,0x36,0x3d,0x7d,0x07,0x7f,0x3f,
0x77,0x7c,0x59,0x6e,0x79,0x71,0x58,0x76,0x00};
unsigned char disbuff[6] ={0,0,0,0,0,0};//對應LCD的6位
unsigned char p1 =0;
unsigned char p2 =0;
unsigned long int time =0;//每一毫秒加1
//1621的顯存是4位*32的,故用16*8位的寄存器就能滿足要求奇數顯存放高4位,偶數放低4位
//1621初始化命令
const char init_tab[]={
0b00000001,//打開系統振蕩器命令
0b00000011,//打開LCD偏壓發生器命令
0b00000101,//WDT 溢出標志輸出失效命令
0b00000110,//時基輸出使能命令
0b00011000,//系統時鐘源片內RC振蕩器命令
0b00101001,//LCD1/3偏壓選項4個公共口命令
//0b01000000,//聲音頻率4KHz命令
//0b00001001,//打開聲音輸出命令
0b10100000,//時基/WDT 時鐘輸出1Hz命令
0b10001000 //使/IRQ 輸出有效命令
void send_data(unsigned char data_bus,unsigned char loop);
void delayns(void);
void display(void);
void display_init(void);
void votlageget(void);
void delay(int temp);
void port_init(void)
PORTB = 0xFF;
DDRB = 0B11111000;
PORTC = 0x00; //m103 output only
DDRC = 0x00;
PORTD = 0xFF;
DDRD = 0XFF;
void timer1_init(void)
TCCR1B = 0x00; //stop
TCNT1H = 0xFE; //setup
TCNT1L = 0x0C;
OCR1AH = 0x01;
OCR1AL = 0xF4;
OCR1BH = 0x01;
OCR1BL = 0xF4;
ICR1H = 0x01;
ICR1L = 0xF4;
TCCR1A = 0x00;
TCCR1B = 0x02; //start Timer
#pragma interrupt_handler timer1_ovf_isr:9
void timer1_ovf_isr(void) //每毫秒中斷一次
//TIMER1 has overflowed
TCNT1H = 0xFE; //reload counter high value
TCNT1L = 0x0C; //reload counter low value
time ++;
disbuff[5] =time&0x0f;
disbuff[4] =(time>>4)&0x0f;
disbuff[3] =(time>>8)&0x0f;
disbuff[2] =(time>>12)&0x0f;
disbuff[1] =(time>>16)&0x0f;
disbuff[0] =(time>>20)&0x0f;
display(); //刷新1621的緩存
unsigned char t;
PORTB &=~CS;
send_data(0b10000000,3);//送3位命令模式代碼100
for(t=0;t<=7;t++)
send_data(init_tab[t],9);//送9位命令代碼
PORTB |=CS;
PORTB |=WR;
void display(void)
unsigned char t;
unsigned char seg_temp;
PORTB &=~CS;
PORTB &=~WR;
send_data(0b10100000,3);//送3位“寫 ”模式命令代碼101
send_data(0,6);//送6位首地址00h
for(t=0;t<=5;t++)
seg_temp =seg_tab[disbuff[t]];
send_data(seg_temp,data_length);//向顯存送數據
PORTB |=CS;
PORTB |=WR;
void send_data(unsigned char data_temp,unsigned char loop)
for(;loop!=0;loop--)
delayns();
PORTB &=~WR;
delayns();
if((data_temp&0b10000000)==0)
PORTB &=~DATA;
PORTB |=DATA;
data_temp=(data_temp<<1);
PORTB |=WR;
void delayns(void)
asm("nop");
asm("nop");
asm("nop");
asm("nop");
asm("nop");
asm("nop");
//call this routine to initialize all peripherals
void init_devices(void)
//stop errant interrupts until set up
CLI(); //disable all interrupts
port_init();
timer1_init();
TIMSK = 0x04; //timer interrupt sources
SEI(); //re-enable interrupts
void main(void)
init_devices(); //單片機初始化
display_init(); //1621初始化
ht1621.rar
(768.63 KB, 下載次數: 24)
2020-1-18 22:30 上傳
成人啊啊啊
日韩中文字幕一区二区
黄色一级电影免费观看
久久毛片
国产精品一区一区三区
国产美女视频一区
国产综合精品一区二区三区
日韩三级一区
欧美一级二级三级视频
欧美在线一区二区三区
国产区免费视频
日本精品视频一区二区
黄色毛片网站在线观看
h视频在线观看免费
成人av免费网站
免费视频一区二区三区在线观看
国产成人99久久亚洲综合精品
91精品国产综合久久久动漫日韩
在线视频国产一区
国产精品久久久久久久久久久久午夜片
亚洲欧美日韩电影
亚洲欧美激情网
视频一区中文字幕
国产精品久久久久久久久久
中文字幕 在线观看
国产精品视频一二三区
一区二区三区亚洲
99精品视频在线
2019天天操
免费成人高清在线视频
国产精品国产a级
欧美激情五月
欧美日本韩国一区二区
www.黄色在线观看
欧美成人一区二区三区
一区二区三区四区在线视频
91在线视频观看
久久国内精品
日韩国产一区二区
黄色在线免费观看
99一区二区
