標(biāo)題:
avr mega8 PWM 超聲發(fā)射試驗(yàn)程序
[打印本頁(yè)]
melin
時(shí)間:
2020-3-31 11:14
標(biāo)題:
// 采用硬件件定時(shí)器產(chǎn)生寬度可調(diào)PWM信號(hào)
//ICC-AVR application builder : 2020/3/23 10:29:05
// Target : M8
// Crystal: 11.059Mhz
#include <iom8v.h>
#include <macros.h>
// #define FG1 0xFEED // 20KHz
// #define FG2 0x0113 //
#define FG1 0xA99C // 500HZ
#define FG2 0x5664 //
unsigned char rtu0=0;
void port_init(void)
PORTB = 0xE9;
DDRB = 0x16; // 0001 0110
PORTC = 0x7F; // m103 output only
DDRC = 0x00;
PORTD = 0xFF;
DDRD = 0x00;
//TIMER1 initialize - prescale:1
// WGM: 14) PWM fast, TOP=ICRn
// desired value: 20KHz
// actual value: 20.069KHz (0.2%)
void timer1_init(void)
TCCR1B = 0x00; // stop
TCNT1 = FG1; // setup
//OCR1A = 247; // 90%FULL
OCR1A = FG2>>1;
OCR1B = FG2;
ICR1 = FG2;
TCCR1A = 0x82;
TCCR1B = 0x19; //start Timer
// TIMER2 initialize - prescale:1024
// WGM: Normal
// desired value: 23mSec
// actual value: 22.963mSec (0.2%)
void timer2_init(void)
TCCR2 = 0x00; // stop
ASSR = 0x00; // set async mode
TCNT2 = 0x08; // setup
OCR2 = 0xF8; //
TCCR2 = 0x07; // start
#pragma interrupt_handler timer2_ovf_isr:iv_TIM2_OVF
void timer2_ovf_isr(void)
TCNT2 = 0x08; // reload counter value
// if(OCR1A<FG2)OCR1A+=(FG2/100);
// else OCR1A=0;
// rtu0++;
if( rtu0>20 )
{ rtu0=0; PORTB^=0x14;} // B2
//UART0 initialize
// desired baud rate: 9600
// actual: baud rate:9600 (0.0%)
void uart0_init(void)
UCSRB = 0x00; //disable while setting baud rate
UCSRA = 0x00;
UCSRC = BIT(URSEL) | 0x06;
UBRRL = 0x47; //set baud rate lo
UBRRH = 0x00; //set baud rate hi
UCSRB = 0xD8;
#pragma interrupt_handler uart0_rx_isr:iv_USART0_RXC
void uart0_rx_isr(void)
//uart has received a character in UDR
#pragma interrupt_handler uart0_tx_isr:iv_USART0_TXC
void uart0_tx_isr(void)
//character has been transmitted
//ADC initialize
// Conversion time: 75uS
void adc_init(void)
ADCSR = 0x00; //disable adc
ADMUX = 0x00; //select adc input 0
ACSR = 0x80;
ADCSR = 0x86;
//call this routine to initialize all peripherals
void init_devices(void)
//stop errant interrupts until set up
CLI(); //disable all interrupts
port_init();
timer1_init();
timer2_init();
uart0_init();
adc_init();
MCUCR = 0x00;
GICR = 0x00;
TIMSK = 0x40; //timer interrupt sources
SEI(); //re-enable interrupts
//all peripherals are now initialized
void main(void)
init_devices();
PORTB|=0x04;
while( 1 )
OCR1A=FG2/2;
asm("NOP");asm("NOP");asm("NOP");asm("NOP");
asm("NOP");asm("NOP");//asm("NOP");asm("NOP");
// PORTB^=0x02; //B1
// while(1);
亚洲少妇一区
日本激情网站
国产成人tv
国产黄色在线播放
在线免费观看黄
激情五月婷婷综合
免费网站观看www在线观
色精品
欧美成年人视频
www.日韩.com
欧美国产日韩一区二区
久久av免费
九九精品在线视频
四虎影音
97精品国产
久久免费视频网站
日本黄a三级三级三级
香蕉视频一区二区三区
日韩久久久
亚洲精品福利视频
日韩综合在线观看
成 人 黄 色 片 在线播放
久插视频
免费福利片
国产欧美一区二区三区视频在线观看
国产成人tv
国产一级片免费观看
在线观看的av网站
亚洲乱色
黄色片免费
日本欧美久久久久免费播放网
天天躁日日躁狠狠躁av麻豆男男
亚洲综合视频在线
精品欧美一区二区三区久久久
国产日韩欧美一区二区
国产又粗又大又硬
丁香婷婷在线
色婷婷久久综合
欧美精品成人一区二区在线观看
美日韩一区二区
久久久一本
