標(biāo)題: MSP430電池電壓采集Proteus仿真程序 [打印本頁]
作者: lufeiboy    時(shí)間: 2020-4-27 13:04
MSP430電池電壓采集仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
單片機(jī)源程序如下:
  1. #include <MSP430x24x.h>
  3. #define uint unsigned int
  4. uchar const table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,  //共陰數(shù)碼管段選碼表,無小數(shù)點(diǎn)
  5.                                0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
  6. uchar table_volt[4] = {0};               //數(shù)組,存儲(chǔ)電壓值
  7. uchar Index;                            //變量
  8. //*******延時(shí)函數(shù)************//
  9. void Delay_ms(unsigned int t)
  10. {
  11.     unsigned int num;
  12.     while(t--)
  13.       for(num=1330;num>0;num--);
  14. }
  15. //ADC管腳定義
  16. #define ADCST0          P5OUT &= ~BIT4
  17. #define ADCST1          P5OUT |= BIT4
  18. #define ADCALE0         P5OUT &= ~BIT5
  19. #define ADCALE1         P5OUT |= BIT5
  20. #define ADCEOC0         P5OUT &= ~BIT6
  21. #define ADCEOC1         P5OUT |= BIT6
  22. #define ADCOE0          P5OUT &= ~BIT7
  23. #define ADCOE1          P5OUT |= BIT7
  24. #define ADC_Channel0          P5OUT &= ~BIT0
  25. #define ADC_Channel1          P5OUT |= BIT0
  26. unsigned int  ADC1 = 0;                                  //變量,采集電池電壓值
  27. //*******ADC采集啟動(dòng)函數(shù)************//
  28. void ADC_START(void)
  29. {
  30.   ADCALE1;
  31.   ADCST1;
  32.   Delay_ms(1);
  33.   ADCALE0;
  34.   ADCST0;
  35.   Delay_ms(1);
  36. }
  37. //*******ADC采集時(shí)序?qū)崿F(xiàn)函數(shù)************//
  38. unsigned int ADC_READ(void)
  39. {
  40.   unsigned int data;
  41.   data=0x00;
  42.   Delay_ms(1);
  43.   ADCOE1;
  44.   ADC_START();
  45.   Delay_ms(5);
  46.   data=P4IN;                    //讀取數(shù)據(jù)
  47.   ADCOE0;
  48.   return data;                          //返回?cái)?shù)據(jù)
  49. }
  50. //*******主函數(shù)************//
  51. void main(void)
  52. {
  53.
  54.     WDTCTL=WDTPW + WDTHOLD; // 關(guān)閉看門狗
  55.     P2DIR=0xFF;            // 設(shè)置方向
  56.     P2SEL=0;            // 設(shè)置為普通I/O 口
  57.
  58.     P3DIR=0xFF;            // 設(shè)置方向
  59.     P3SEL=0;            // 設(shè)置為普通I/O 口
  60.
  61.     P2OUT=0x00;
  62.     P3OUT=0xFF;
  63.
  64.     P5SEL = 0x00;
  65.     P5DIR |= BIT0+BIT4+BIT5+BIT6;               //ADC芯片接口
  66.
  67.
  68.
  69.     while(1)
  70.     {
  71.
  72.          P3OUT=0xFF;
  73.          if( Index == 0 )                       //如果第一個(gè)數(shù)碼管顯示,加入小數(shù)點(diǎn)
  74.          {
  75.             P2OUT=table[table_volt[Index]]+0x80;//小數(shù)點(diǎn)
  76.          }
  77.          else                                           //其他不加
  78.          {
  79.             P2OUT=table[table_volt[Index]];             //顯示電壓值
  80.          }
  81.             P3OUT=~(1<<Index);
  82.           if(++Index==4) Index=0;
  83.          Delay_ms(1);                   //延時(shí)
  84.
  85.         ADC1 = ADC_READ()*20-80;                //ADC電池電壓采集,放大
  86.         table_volt[0] = ADC1/1000;               //千位
  87.         table_volt[1] = ADC1%1000/100;            //百位
  88.         table_volt[2] = ADC1%100/10;                            //十位
  89.         table_volt[3] = ADC1%10;                        //個(gè)位
  90.
  91.     }
  92.
  93. }
電池電壓檢測(cè)仿真.zip (439.18 KB, 下載次數(shù): 47)
主站蜘蛛池模板: 国产7777| 懂色av一区二区夜夜嗨 | 台湾av在线 | 久久精品久久久 | 1级黄色片 | 逼逼操| 国产又粗又猛视频免费 | 伊人影院综合 | 一区二区免费视频 | 国产成人一区二区三区 | 日韩一区二区三区视频 | 欧美在线免费观看视频 | a在线观看 | 国产三级黄色 | 亚洲成人国产 | 日韩一区在线视频 | 日韩免费视频一区二区 | 黄色大片一级 | 久久久精品影院 | 久久日韩精品 | 老司机午夜免费精品视频 | 国产美女av| 激情五月激情综合网 | 日韩新片王网 | 韩日一级片| 欧美在线免费 | 日韩中文字幕精品 | 亚洲天堂中文字幕 | 黄色小视频免费 | 三级视频网站 | 久久久久女教师免费一区 | 国产一区福利 | 亚洲免费视频网站 | 综合在线视频 | 黄色在线免费观看视频 | 91av免费| 国产九九| 国产精品麻豆视频 | 中文字幕在线观看日本 | 欧美福利视频 | 日韩在线免费视频 |
