標(biāo)題: Proteus8.9 VSM Studio Keil編譯器仿真AT89C51RD2系列016_lcd12064bit [打印本頁]
作者: kaillen    時(shí)間: 2020-5-19 23:13
本帖最后由 kaillen 于 2020-5-20 13:38 編輯
一,打開文件(可以隨文下載放置在文檔中打開)。(如下圖1所示)
圖1
二,調(diào)整原理圖大小,適合可視,另存工程文件。(如下圖2,3,4所示)
圖2
圖3
圖4
三,點(diǎn)擊Source Code標(biāo)簽。(如下圖5所示)
圖5
四,編輯main.c 代碼如Proteus8.9 VSM Studio Keil編譯器仿真AT89C51RD2系列016_lcd12064bit (如下圖6所示)
圖6
五,Main.c 代碼:
/* Main.c file generated by New Project wizard
*Coder:       Ziegler Yin
* Created:   周日 5月 3 2020
* Processor: AT89C51RD2
* Compiler:  Keil for 8051
#include "lcd16024bit.h"
int lcd_putstr(u8 *ddat, int pos)
        u8 i;
        if(pos== -1) {
                write_com(0x01);
                delay(2); pos= 0;
        while((*ddat)!= '\0') {
                switch(*ddat) {
                        case '\n':
                                if(pos< 17) {
                                        for(i= pos; i< 16; i++) lcd_wrtchr(pos% 16, pos/ 16, ' ');
                                        pos=16;
                                else {
                                        for(i= pos; i< 32; i++) lcd_wrtchr(pos% 16, pos/ 16, ' ');
                                        pos=0;
                        case '\b':
                                if(pos>0) pos--;
                        default:
                                if((*ddat) < 0x20) {
                                        *ddat= ' ';
                                lcd_wrtchr(pos% 16, pos/ 16, *ddat);
                                pos++;
                *ddat++;
        return (pos);
int lcd_putnum(u32 num, int XS, int pos)
        u32 tmp= 0;
        u8 numbits= 0;
        if(pos== -1) {
                write_com(01);
                delay(2); pos= 0;
        if(num== 0) {
                lcd_wrtchr(pos% 16, pos/16, '0');
                pos++;
        else {
                if(num< 0) {
                        lcd_wrtchr(pos% 16, pos/16, '-');
                        num*= (-1);
                        pos++;
                while(num) {
                        tmp= tmp* 10+  (num% 10);
                        num= num/ 10;
                        numbits++;
                while(tmp) {
                        lcd_wrtchr(pos% 16, pos/16, (tmp% 10) +48);
                        tmp /=10;
                        pos++;
                        numbits--;
                        if(numbits== XS) pos= lcd_putstr(".", pos);
                while(numbits--) {
                        pos--;
        return (pos);
void main(void)
       init();
        while(1){
                LClear();
                delay(500);
                lcdStr(0, 0, "Kaillen Work");
                lcdStr(0, 1, "  Wellcom YOU!");
                delay(5000);
                LClear();
                delay(500);
                lcdStr(0, 0, "Code Made");
                lcdStr(0, 1, " --Ziegler Yin");
                delay(5000);
Lcd16024bit.h:
*Coder:       Ziegler Yin
#ifndef __LCD16024BIT_H_
#define __LCD16024BIT_H_
#include <reg51.h>
#include <stdio.h>
#include "INTRINS.H"
#define u32 unsigned long
#define u16 unsigned int
#define u8 unsigned char
sbit lcdrs =P2^7;  //液晶屏數(shù)據(jù)/命令選擇端
sbit lcdrw =P2^6;        //液晶屏讀寫端
sbit lcden =P2^5;        //使能端
void delay(int z);
void write_com(u8 com);
void write_data(u8 date );
void SetCursor(u8 ix, u8 iy);
void lcd_wrtchr(u8 X, u8 Y, u8 recd);
void lcdStr(u8 x, u8 y, u8 *str);
void init(void);
void LClear(void);
#endif
六,點(diǎn)擊構(gòu)建工程按鈕,編譯工程。(如下圖7所示)
圖7
七,點(diǎn)擊窗口左下方仿真按鈕,可見lcd16024bit屏上信息顯示在屏。 (如下圖8,9,10所示)
圖8
圖9
圖10
八,選擇release,點(diǎn)擊構(gòu)建工程按鈕,編譯工程生成Hex文件。(如下圖11所示)
圖11
九, 系列的001-003虛擬仿真與開發(fā)板對應(yīng)已證明:虛擬仿真程序?qū)τ陂_發(fā)板有效,之后不再➕上下載到開發(fā)板的介紹。
附件Proteus8.9 VSM Studio Keil編譯器仿真AT89C51RD2系列016_lcd12064bit在已安裝Proteus8.9的計(jì)算機(jī)文件夾中打開即可
需要進(jìn)一步了解,請加入QQ群:976235464
Keil_AT89C51RD2_016_lcd1602_4bit_03.rar
130.66 KB, 下載次數(shù): 8, 下載積分: 黑幣 -5
主站蜘蛛池模板: 在线亚洲天堂 | 色一情一乱一乱一区91av | 午夜av在线播放 | 亚洲在线一区二区 | 精品久久久久久久久久久久久久 | 欧美mv日韩mv国产 | 黄色特级片 | 天天爽天天操 | 午夜在线| 免费网站观看www在线观 | 日韩综合久久 | 国产va在线观看 | 亚洲一区亚洲二区 | 中文有码在线 | 91一级片 | 中文天堂网 | 欧美日韩国产精品 | 日韩视频一区二区 | 草草在线视频 | 国产a视频 | 91亚洲国产 | 国产精品久久久久永久免费看 | 午夜性影院| 四虎成人网 | 国产视频一区二区在线观看 | 亚洲亚洲人成综合网络 | av片在线观看 | 黄色天天影视 | 天天操操操操 | 午夜免费时刻 | 韩国三级中文字幕hd久久精品 | 国产精品天美传媒入口 | 亚洲在线中文字幕 | 美女一级片 | 国产精品一区在线观看 | 狠狠做深爱婷婷综合一区 | 成人91看片 | 天天躁日日躁狠狠很躁 | 久久精品久久精品 | 中文字幕视频在线 | 成人毛片100免费观看 |
