2440驅動MMA7455L源程序
1551531584
2020-6-5 12:23
2440驅動MMA7455L源程序
(23.9 KB, 下載次數: 115)
2020-6-5 17:32 上傳
文件名:Main.c
功能描述:主程序
#define GLOBAL_CLK 1
#include <stdlib.h>
#include <string.h>
#include "def.h"
#include "option.h"
#include "2440addr.h"
#include "2440lib.h"
#include "2440slib.h"
#include "Uart.h"
void SPI_Init(void);
void WriteByte_MMA7455L(U8 addr,U8 dat);
U8 ReadByte_MMA7455L(U8 addr);
static U32 cpu_freq;
static U32 UPLL;
static void cal_cpu_bus_clk(void)
U32 val;
U8 m, p, s;
val = rMPLLCON; //MPLLCON上電初始值為0x00096030
m = (val>>12)&0xff; //結果為0x96=150
p = (val>>4)&0x3f; //結果為0x03=3
s = val&3; //結果為0
//(m+8)*FIN*2 不要超出32位數!
FCLK = ((m+8)*(FIN/100)*2)/((p+2)*(1<<s))*100;//"1<<s"表示令1左移s位,即可得2^s
val = rCLKDIVN;
m = (val>>1)&3;
p = val&1;
val = rCAMDIVN;
s = val>>8;
switch (m) {
case 0:
HCLK = FCLK;
case 1:
HCLK = FCLK>>1;
case 2:
if(s&2)
HCLK = FCLK>>3;
HCLK = FCLK>>2;
case 3:
if(s&1)
HCLK = FCLK/6;
HCLK = FCLK/3;
if(p)
PCLK = HCLK>>1;
PCLK = HCLK;
if(s&0x10)
cpu_freq = HCLK;
cpu_freq = FCLK;
val = rUPLLCON;
m = (val>>12)&0xff;
p = (val>>4)&0x3f;
s = val&3;
UPLL = ((m+8)*FIN)/((p+2)*(1<<s));
UCLK = (rCLKDIVN&8)?(UPLL>>1):UPLL;
void Main(void)
U8 key,sta;
int i;
U32 mpll_val = 0;
i = 2 ;
switch ( i ) {
case 0: //200
key = 12;
mpll_val = (92<<12)|(4<<4)|(1);
case 1: //300
key = 13;
mpll_val = (67<<12)|(1<<4)|(1);
case 2: //400M
key = 14;
mpll_val = (92<<12)|(1<<4)|(1);
case 3: //440!!!
key = 14;
mpll_val = (102<<12)|(1<<4)|(1);
default:
key = 14;
//rMPLLCON賦值0x5c011
ChangeMPllValue((mpll_val>>12)&0xff, (mpll_val>>4)&0x3f, mpll_val&3);
ChangeClockDivider(key, 12); //key=14
cal_cpu_bus_clk();
Port_Init(); //IO端口初始化
SPI_Init();//SPI初始化
MMA7455L_INIT();//MMA7455L初始化
Uart_Init();//串口初始化
Uart_Select(0);
Delay(5); //延時10ms讓IIC和SPI準備就緒
Uart_Printf("CLKCON=%x!",rCLKCON);
Uart_Printf("開始發送數據!\n\n");
//對MMA7455L的0x16寄存器寫配置數據0x05
WriteByte_MMA7455L(0x16,0x05);
//讀回0x16寄存器的配置值,判斷SPI通信是否成功.
sta=ReadByte_MMA7455L(0x16);
Uart_Printf("sta=0x%x",sta);
int n;
//片選CS置低,使能MMA7455為SPI模式
rGPFDAT &= 0xef;
Delay(1);
Uart_Printf("SPI狀態寄存器的數據為0x%x!\n",rSPSTA0);
while(!(rSPSTA0&0x01==0x01)) ;
//高位置1寫操作
rSPTDAT0 = 0x80|((addr & 0x3f)<<1);
Uart_Printf("寫操作地址發送成功!\n");
for(n=0;n<20;n++);
rSPTDAT0 = dat; //寫數據
Uart_Printf("寫操作數據發送成功!\n");
for(n=0;n<20;n++);
//片選CS置高電平,結束SPI通信
rGPFDAT |= 0xff;
Delay(1);
int n;
U8 Re_Dat;
//片選CS置低電平,使能MMA7455L為SPI模式
rGPFDAT &= 0xef;
Delay(1);
//讀操作高位清0
rSPTDAT0 = (addr & 0x3f)<<1;
Uart_Printf("讀操作地址發送成功!\n");
for(n=0;n<20;n++);
while(!(rSPSTA0&0x01==0x01));
Re_Dat = rSPRDAT0;
for(n=0;n<20;n++);
//片選CS置高電平,結束SPI通信
rGPFDAT |= 0xff;
Delay(1);
//返回讀取數據
return Re_Dat;
//MMA7455L初始化
void MMA7455L_INIT(void )
MMA_QUEUE.MMA_HEAD=0;
MMA_QUEUE.MMA_CUR=0;
SPI_WriteREG(0x16,0x05);//級別模式
delay_nus(10);
SPI_WriteREG(0x18,0x20);
delay_nus(10);
SPI_WriteREG(0x19,0x00);
delay_nus(10);
SPI_WriteREG(0x1a,0x00);
delay_nus(10);
//SPI初始化
void SPI_Init(void)
//激活時鐘控制器的SPI位
rCLKCON |= 1 <<18;
rSPCON0 = (0<<6)|(0<<5)|(1<<4)|(1<<3)|(0<<2)|(0<<1)|1;
//查詢模式;SCK使能;主機模式;時鐘低電平有效;格式A;普通模式;
//MMA7455的SPI的傳輸波特率在工作電壓小于2.4V時最高可達4MHz,大于2.4V時可達8MHz
//SPI波特率為50MHz/2/(24+1)=1MHz
rSPPRE0 = 24;
第4章.zip
(13.24 KB, 下載次數: 6)
2020-6-5 12:23 上傳
激情小说在线视频
成人免费看
亚洲欧美久久
福利片在线
国产小视频在线
黄色一区二区三区
成人片网址
在线观看黄色av
黄色xxxxx
日本xxxx69
www.久草.com
久久综合伊人77777蜜臀
aa一级片
国产伦精品一区二区三区照片
天天久久综合
在线视频h
欧美不卡在线观看
欧美日韩一区二区在线观看
久久激情视频
亚洲欧美精品
国产精品99精品久久免费
视频一区二区在线
国产日韩精品在线
青青草国产成人av片免费
91看片在线
成人深夜福利
亚洲精品自拍视频
www.日本黄色
国产精品少妇
免费一级a毛片
日韩免费一级片
少妇一级淫免费观看
日韩欧美久久久
成人免费毛片aaaaaa片
欧美综合在线观看
四虎色播
福利视频网站
日韩一区二区在线视频
深夜福利在线播放
亚洲亚洲人成综合网络
欧美一级日韩一级
