標題: uCOS-II+VS2012源程序 [打印本頁]
作者: nmml 時間: 2020-6-16 19:42
利用提供的uc-os工程,實現兩個任務之間的通信。要求自行建立兩個任務TaskA和TaskB,利用進程間通信工具mailbox進行實現,任務A定期發送(post)給任務B你的學號,和一個計數碼,計數碼每次發送自增1;任務B掛起(pend)在相同的mailbox上,接收到任務A從mailbox發送的數據后,打印出來你的名字+從任務A接收到的數據。
要求:
提供任務A和任務B輸出的結果,任務A要打印出你的學號和序列號和一串A,任務b要打印出你的名字、學號和序列號以及一串B。
例如:
任務A打印:
“ 學號:012345678:序列號 20—AAAAAAAAAAA”
任務B打印:
“張某甲:學號02345678:序列號20----BBBBBBBBBBBBB”
2020-6-17 23:13 上傳
源程序如下:
- * uC/OS-II
- * The Real-Time Kernel
- * (c) Copyright 1998-2004, Micrium, Weston, FL
- * All Rights Reserved
- * WIN32 Sample Code
- * File : APP.C
- * By : Eric Shufro
- #include <includes.h>
- * CONSTANTS
- #define TASK_STK_SIZE 128
- #define TASK_START_PRIO 5
- * VARIABLES
- OS_STK AppStartTaskStk[TASK_STK_SIZE];
- * FUNCTION PROTOTYPES
- static void AppStartTask(void *p_arg);
- #if OS_VIEW_MODULE > 0
- static void AppTerminalRx(INT8U rx_data);
- #endif
- * _tmain()
- * Description : This is the standard entry point for C++ WIN32 code.
- * Arguments : none
- void main(int argc, char *argv[])
- INT8U err;
- #if 0
- BSP_IntDisAll(); /* For an embedded target, disable all interrupts until we are ready to accept them */
- #endif
- OSInit(); /* Initialize "uC/OS-II, The Real-Time Kernel" */
- OSTaskCreateExt(AppStartTask,
- (void *)0,
- (OS_STK *)&AppStartTaskStk[TASK_STK_SIZE-1],
- TASK_START_PRIO,
- TASK_START_PRIO,
- (OS_STK *)&AppStartTaskStk[0],
- TASK_STK_SIZE,
- (void *)0,
- OS_TASK_OPT_STK_CHK | OS_TASK_OPT_STK_CLR);
- #if OS_TASK_NAME_SIZE > 11
- OSTaskNameSet(APP_TASK_START_PRIO, (INT8U *)"Start Task", &err);
- #endif
- #if OS_TASK_NAME_SIZE > 14
- OSTaskNameSet(OS_IDLE_PRIO, (INT8U *)"uC/OS-II Idle", &err);
- #endif
- #if (OS_TASK_NAME_SIZE > 14) && (OS_TASK_STAT_EN > 0)
- OSTaskNameSet(OS_STAT_PRIO, "uC/OS-II Stat", &err);
- #endif
- OSStart(); /* Start multitasking (i.e. give control to uC/OS-II) */
- /*$PAGE*/
- * STARTUP TASK
- * Description : This is an example of a startup task. As mentioned in the book's text, you MUST
- * initialize the ticker only once multitasking has started.
- * Arguments : p_arg is the argument passed to 'AppStartTask()' by 'OSTaskCreate()'.
- * Notes : 1) The first line of code is used to prevent a compiler warning because 'p_arg' is not
- * used. The compiler should not generate any code for this statement.
- * 2) Interrupts are enabled once the task start because the I-bit of the CCR register was
- * set to 0 by 'OSTaskCreate()'.
- void AppStartTask (void *p_arg)
- p_arg = p_arg;
- #if 0
- BSP_Init(); /* For embedded targets, initialize BSP functions */
- #endif
- #if OS_TASK_STAT_EN > 0
- OSStatInit(); /* Determine CPU capacity */
- #endif
- while (TRUE) /* Task body, always written as an infinite loop. */
- OS_Printf("Delay 1 second and print\n"); /* your code here. Create more tasks, etc. */
- OSTimeDlyHMSM(0, 0, 1, 0);
uCOS-II+VS2012_完美仿真.7z
(4.42 MB, 下載次數: 20)
2020-6-17 23:14 上傳
激情影院在线观看
精品欧美一区二区精品久久
欧美日韩精品一区二区三区
日韩毛片视频
日韩久久久|
美女综合网
国产三级视频在线
在线天堂视频
在线视频日本
日韩在线观看av
亚洲经典av
欧美日韩免费一区二区三区
国产传媒一区二区
欧美人与野
日本高清视频www
日韩一区二区在线观看视频
成年视频在线观看
秋霞午夜鲁丝一区二区老狼
黄色网在线
日韩一区中文字幕
亚洲午夜18毛片在线看
久久久久久久99
欧美a一级
亚洲免费二区
天天爱综合
欧美在线一区二区
亚洲欧美另类在线
国产一区精品在线观看
九九热这里有精品
欧美中文字幕在线
伊人免费
一区二区三区高清
日韩欧美在线观看视频
欧美专区第一页
欧美在线视频一区
国产综合久久久
欧美a一级
亚洲精品乱码久久久久久蜜桃91
中文字幕一区在线观看
成年网站在线观看
av网站免费看|
