標(biāo)題: C#實(shí)現(xiàn)串口通訊源碼 [打印本頁]
作者: 13566004773    時(shí)間: 2020-10-16 13:49
主源碼:
  private void Form1_Load(object sender, EventArgs e)
            for (int i = 1; i < 20; i++)
                comboBox1.Items.Add("COM" + i.ToString());
            comboBox1.Text = "COM4"; //串口號(hào)默認(rèn)值
            comboBox2.Text = "9600";  //波特率默認(rèn)值
            /************非常重要***************/
            serialPort1.DataReceived += new SerialDataReceivedEventHandler(port_DataReceived); //必須手動(dòng)添加事件
        private void port_DataReceived(object sender, SerialDataReceivedEventArgs e)   //串口數(shù)據(jù)接收事件
            if (!radioButton3.Checked) //如果接收模式為字符模式
                string str = serialPort1.ReadExisting(); //字符串方式讀
                textBox1.AppendText(str);  //添加內(nèi)容
              else //如果接收模式為數(shù)值接收
                            //易出現(xiàn)異常:由于線程退出或應(yīng)用程序請求,已中止 I/O 操作
                            //加入異常處理
                            try
                                int data;
                                data = serialPort1.ReadByte();
                                string str = Convert.ToString(data, 16).ToUpper();//轉(zhuǎn)換為大寫十六進(jìn)制字符串
                                textBox1.AppendText("0x" + (str.Length == 1 ? "0" + str : str) + " ");  //空位補(bǔ)“0”
                            catch
                                this.Close();//關(guān)閉當(dāng)前窗體
            {   //如果接收模式為數(shù)值接收
                byte data;
                data = (byte)serialPort1.ReadByte();  //此處需要強(qiáng)制類型轉(zhuǎn)換,將(int)類型轉(zhuǎn)換為(byte類型數(shù)據(jù),不
                string str = Convert.ToString(data, 16).ToUpper();  //轉(zhuǎn)換為大寫十六進(jìn)制字符串
                //上一句等同於:
                //          if (str.Length == 1)
                //            str = "0" + str;
                //          else
                //            str = str;
                //            textBox1.AppendText("0x" + str);
        private void button1_Click(object sender, EventArgs e)
            try
                serialPort1.PortName = comboBox1.Text;   //設(shè)置串口號(hào)
                serialPort1.BaudRate = Convert.ToInt32(comboBox2.Text, 10); //十進(jìn)制數(shù)據(jù)轉(zhuǎn)換,設(shè)置波特率
                serialPort1.Open();  //打卡串口
                button1.Enabled = false; //打卡串口不可用
                button2.Enabled = true;  //關(guān)閉串口
            catch
                MessageBox.Show("端口錯(cuò)誤,請檢查串口", "錯(cuò)誤");
        private void button2_Click(object sender, EventArgs e)
            try
                serialPort1.Close();  //關(guān)閉串口
                button1.Enabled = true;   //打卡串口按鈕可用
                button2.Enabled = false;  //關(guān)閉串口按鈕不可用
            catch   //一般情況下關(guān)閉串口不會(huì)出現(xiàn)錯(cuò)誤,所有不需要加處理程序
                MessageBox.Show("串口關(guān)閉錯(cuò)誤", "錯(cuò)誤");
BBT6.zip
60.17 KB, 下載次數(shù): 88, 下載積分: 黑幣 -5
作者: kssxdz    時(shí)間: 2020-10-25 13:39
程序運(yùn)行正常,剛好用到串口學(xué)習(xí)一下,非常感謝樓主分享這么好的資料。
作者: marchmaqi    時(shí)間: 2020-10-27 09:27
用的vc還是vs
主站蜘蛛池模板: 久久精品免费看 | 免费h片 | 一本一道久久a久久精品蜜桃 | av影院在线 | 天天操天天做 | 黄色一级片免费 | 亚洲国产精品久久 | 成人欧美日韩 | 一级特黄妇女高潮 | 日本中文字幕在线播放 | 日韩黄色一级片 | 特级淫片裸体免费看 | 日韩午夜精品 | 在线播放毛片 | 久久日av | 亚洲日本欧美 | 成人aaaa | 欧美成人一级 | 欧美精品在线播放 | 简单av网 | 精品日韩在线 | 中文字幕2021| 五月天在线观看 | 精品日韩一区二区三区 | 女同一区二区 | 在线国产91 | 日本欧美亚洲 | 亚洲成人免费观看 | 欧美极品一区 | 三级网站在线播放 | 午夜看片| 人人超碰人人 | 国内精品国产成人国产三级 | 亚洲免费看片 | 中文字字幕码一二三区 | 四虎官网 | 国产精品免费在线 | 亚洲五码在线 | 日本久久一区二区 | 精品欧美黑人一区二区三区 | 国产区精品 |
