標(biāo)題: 發(fā)個(gè)單片機(jī)+LGM12641BS1R仿真計(jì)算器程序 [打印本頁(yè)]
作者: yuzhenyu    時(shí)間: 2020-11-8 17:06
好長(zhǎng)時(shí)間沒(méi)有來(lái)了,發(fā)個(gè)仿真計(jì)算器。
單片機(jī)源程序如下:
  1. #include "math.h"    //c51庫(kù)函數(shù)
  2. #include "lcd.h"
  3. #include "zifu.h"     //字符串
  4. #include "jianpan.h"
  5. void xianshixy_chuli(uchar i)//顯示處理
  6. {
  7.    switch(i)
  8.         {
  9.           case 0:
  10.           case 1:
  11.           case 2:
  12.           case 3:
  13.           case 4:
  14.           case 5:
  15.           case 6:
  16.           case 7:
  17.           case 8:
  18.           case 9:
  19.           case 10:
  20.           case 11:
  21.           case 12:
  22.           case 13:
  23.           case 14:
  24.           case 15:y=i;x=0;break;//第1行        一行128列/8=8個(gè)8*16的字符
  25.           case 16:
  26.           case 17:
  27.           case 18:
  28.           case 19:
  29.           case 20:
  30.           case 21:
  31.           case 22:
  32.           case 23:
  33.       case 24:
  34.           case 25:
  35.           case 26:
  36.           case 27:
  37.           case 28:
  38.           case 29:
  39.           case 30:
  40.       case 31:y=i-16;x=2;break;//第2行
  41.           case 32:
  42.           case 33:
  43.           case 34:
  44.           case 35:
  45.           case 36:
  46.           case 37:
  47.           case 38:
  48.           case 39:
  49.       case 40:
  50.           case 41:
  51.           case 42:
  52.           case 43:
  53.           case 44:
  54.           case 45:
  55.           case 46:
  56.           case 47: y=i-32;x=4;break;//第3行
  57.
  58.           case 48:
  59.           case 49:
  60.           case 50:
  61.           case 51:
  62.           case 52:
  63.           case 53:
  64.           case 54:
  65.           case 55:
  66.           case 56:
  67.           case 57:
  68.           case 58:
  69.           case 59:
  70.           case 60:
  71.           case 61:
  72.           case 62:
  73.           case 63:y=i-48;x=6;break;//第4行
  74.       default:  break;
  75.         }
  76.         xianshi_i++;//一屏最多顯示64個(gè)8*16的字符
  77. }
  78. void key_chuli()//鍵盤處理
  79. { static uchar   key_i=0;
  80.   static uchar   xdata key_buf[64];
  81.   static float   data_buf[10];
  82.
  83.   static uchar  fuhao_i=0,dian_i=0;
  84.   uchar i;
  85.   ulong k;
  86.   long         int32_k;
  87.   float  dian_k;
  88.
  89.   if(key!=0xff)
  90.   {
  91.           if(key!=15)//////*************
  92.     {
  93.               key_buf[key_i]=key;
  94.                   key_i++;
  95.         }
  96.     xianshixy_chuli(xianshi_i);
  97.     switch(key)
  98.         {
  99.           case 0: LCD_bmp(x,y*8,2,8,dian);dian_bzw=1;break;//小數(shù)點(diǎn)//行 列 高度  寬度 :高是8的倍數(shù)
  100.           case 1:
  101.           case 2:
  102.           case 3:
  103.           case 4:
  104.           case 5:
  105.           case 6:
  106.           case 7:
  107.           case 8:
  108.           case 9: LCD_bmp(x,y*8,2,8,data_tab[key]);      //顯示鍵盤數(shù)字
  109.
  110.                           if(dian_bzw==0) data_buf[fuhao_i]=data_buf[fuhao_i]*10+key; //整數(shù)
  111.
  112.                           else        //小數(shù)
  113.                           {
  114.                                    dian_i++;
  115.                                    dian_k=key;
  116.
  117.                                    for(i=0;i<dian_i;i++)dian_k=dian_k/10;
  118.
  119.                                    data_buf[fuhao_i]=data_buf[fuhao_i]+dian_k;
  120.               }
  121.                             break;
  122.           case 10:LCD_bmp(x,y*8,2,8,jia);                                        //+
  123.                   ys_fuhao=key;
  124.                             fuhao_i++;  // 當(dāng)按下運(yùn)算符時(shí)為下個(gè)被加數(shù)組做準(zhǔn)備        data_buf[0]+data_buf[i];
  125.                           dian_bzw=0;
  126.                           dian_i=0;
  127.                   break;
  128.           case 11:LCD_bmp(x,y*8,2,8,jian);                                        //-
  129.                             ys_fuhao=key;
  130.                             fuhao_i++;
  131.                           dian_bzw=0;
  132.                           dian_i=0;
  133.                   break;
  134.           case 12:LCD_bmp(x,y*8,2,8,cheng);                                        //*
  135.                             ys_fuhao=key;
  136.                             fuhao_i++;
  137.                           dian_bzw=0;
  138.                           dian_i=0;
  139.                   break;
  140.           case 13:LCD_bmp(x,y*8,2,8,chu);                                        // /
  141.                             ys_fuhao=key;
  142.                             fuhao_i++;
  143.                           dian_bzw=0;
  144.                           dian_i=0;
  145.                   break;
  146.           case 14:dian_bzw=0;
  147.                             dian_i=0;
  148.                             LCD_bmp(x,y*8,2,8,denghao);                                //=
  149.
  150.
  151.                                 if(ys_fuhao==11)data_buf[0]=data_buf[0]-data_buf[1]; //兩數(shù)相 減
  152.
  153.                                 if(ys_fuhao==10)data_buf[0]=data_buf[0]+data_buf[1]; //兩數(shù)相 加
  154.
  155.                             if(ys_fuhao==12)data_buf[0]=data_buf[0]*data_buf[1];   //兩數(shù)相 乘
  156.
  157.                                 if(ys_fuhao==13)data_buf[0]=data_buf[0]/data_buf[1];  //兩數(shù)相 除
  158.
  159.                           int32_k=(long)data_buf[0];
  160.                           for(i=1;i<11;i++)
  161.                           {
  162.                                   int32_k=int32_k/10;
  163.                                 if(int32_k==0) break;
  164.                           }
  165.                           if(data_buf[0]<0)
  166.                       {
  167.                             xianshixy_chuli(xianshi_i);
  168.                             LED_xie_char2(x,y,jian);           //結(jié)果是負(fù)數(shù)
  169.                                 //k=~data_buf[0]+1;
  170.                                 k=(ulong)fabs(data_buf[0]);   //調(diào)用庫(kù)函數(shù)fabs
  171.                             }
  172.                           else
  173.                             k=(ulong)data_buf[0];
  174.                           switch(i)
  175.                           { double   double_k;
  176.                             uchar         j;
  177.                             case 10: i=k/1000000000;
  178.                                                  k=k%1000000000;
  179.                                                  xianshixy_chuli(xianshi_i);
  180.                                                  LED_xie_char2(x,y,data_tab[i]);
  181.                             case 9:  i=k/100000000;
  182.                                                  k=k%100000000;
  183.                                                  xianshixy_chuli(xianshi_i);
  184.                                                  LED_xie_char2(x,y,data_tab[i]);
  185.                             case 8:  i=k/10000000;
  186.                                                  k=k%10000000;
  187.                                                  xianshixy_chuli(xianshi_i);
  188.                                                  LED_xie_char2(x,y,data_tab[i]);
  189.                             case 7:  i=k/1000000;
  190.                                                  k=k%1000000;
  191.                                                  xianshixy_chuli(xianshi_i);
  192.                                                  LED_xie_char2(x,y,data_tab[i]);
  193.                             case 6:  i=k/100000;
  194.                                                  k=k%100000;
  195.                                                  xianshixy_chuli(xianshi_i);
  196.                                                  LED_xie_char2(x,y,data_tab[i]);
  197.                             case 5:  i=k/10000;
  198.                                                  k=k%10000;
  199.                                                  xianshixy_chuli(xianshi_i);
  200.                                                  LED_xie_char2(x,y,data_tab[i]);
  201.                             case 4:  i=k/1000;
  202.                                                  k=k%1000;
  203. ……………………
  204. …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
仿真計(jì)算器.rar (74.41 KB, 下載次數(shù): 59)
主站蜘蛛池模板: 国产女人高潮毛片 | 久久久精品 | 激情五月婷婷丁香 | 91av在线免费观看 | 啪啪小视频 | 欧美vieox另类极品 | 91久久久精品 | 91在线精品李宗瑞 | 999精品视频 | 日本精品视频在线 | 欧美在线视频免费 | 一级黄色免费视频 | 日韩www| 超碰福利在线 | 免费一级全黄少妇性色生活片 | 欧美日韩免费在线观看 | 欧美精品一区在线观看 | 国产乱淫av片免费 | 国产午夜一区二区三区 | 国产综合第一页 | 狠狠的日 | 一区二区国产在线 | 99午夜| 国产精品午夜视频 | 日韩av在线免费观看 | 懂色av懂色av粉嫩av | 午夜欧美 | 成年人免费在线视频 | 狠狠躁夜夜躁人爽 | 伊人色播| 成人午夜激情视频 | 久久精品久久久精品美女 | 久久久久久网 | 免费福利片| 欧美一区二区三区视频 | 激情福利视频 | 亚州av在线| 亚洲天堂久久 | 韩国av在线 | 久久伊人国产 | 天堂在线中文资源 |
