標題: 基于stm32f103c8t6的最小系統板的綜合應用系統 例程 [打印本頁]
作者: 荒野Contra    時間: 2020-12-19 15:38
概述:本綜合系統包含矩陣鍵盤控制LED,串口控制LED,RTC時間顯示,溫度顯示和超聲波測距五個基本模塊,菜單在LCD1602上顯示。屬于比較基本的stm32的綜合系統。
個人通過面包板和杜邦線比較簡易地搭建了這個綜合系統,其他原料為:LCD1602顯示屏,stm32f103c8t6最小系統板,USB轉TTL及其驅動,超聲波模塊,4*4矩陣鍵盤。
雜亂的外表:
文件配置:
接線:
//矩陣鍵盤
PA0-PA3與R1~R4PA4~PA7與C1~C4
//串口
TXD與PA10
RXD與PA9
//LCD1602
VSS與GND
VDD與5V
V0與GND
RS與PA8
RW與PA11
EN與PA12
D4與PB8
D5~D7與PB5~PB7
A與3.3V
K與GND
//超聲波傳感模塊
PB0與Ttig
PB1與Echo
main.c部分代碼#include "stm32f10x.h"
#include "delay.h"
#include "rtc.h"
#include "sys.h"
#include "usart.h"
#include "LCD1602.h"
#include "keyscan.h"
#include "tsensor.h"
u8 num,ch,flag,rtcflag=0,led,rtcnum,overflow=0;
u8 tempch[5],distch[3],rtcch[4];
u16 adct,tempz;        //存放AD轉換的結果
float tempv,tempt;
void gpio_init(void)
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOA,ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
        GPIO_Init(GPIOC, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin=GPIO_Pin_0;
        GPIO_InitStructure.GPIO_Speed=GPIO_Speed_10MHz;
        GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;
        GPIO_Init(GPIOB, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin=GPIO_Pin_1;
        GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IN_FLOATING;
void nvic_init(void)
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
        NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;
        TIM_ClearITPendingBit(TIM3, TIM_IT_Update);
void time_init(void)
        TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
        TIM_TimeBaseStructure.TIM_Period = 4999;         //x/(72M/prescaler)=0.025
        TIM_TimeBaseStructure.TIM_Prescaler = 359;
        TIM_TimeBaseStructure.TIM_ClockDivision = 0x0;
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
        TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
        TIM_Cmd(TIM3, DISABLE);
        TIM_ITConfig(TIM3, TIM_IT_Update, ENABLE);
u8 recedata(void)
        if(USART_GetFlagStatus(USART1, USART_FLAG_RXNE)==1)
                ch = USART_ReceiveData(USART1);
        return ch;
void get_rtcch(rtcnum)
        u8 rtcnumm;
        rtcnumm=get_rtcnum(rtcnum);
        rtcch[0]=rtcnumm/1000+0x30;
        rtcch[1]=(rtcnumm/100)%10+0x30;
        rtcch[2]=(rtcnumm/10)%10+0x30;
        rtcch[3]=rtcnumm%10+0x30;
        if(rtcch[0]=='0'&&rtcch[1]=='0')
                rtcch[0]=rtcch[2];
                rtcch[1]=rtcch[3];
                rtcch[2]=' ';
                rtcch[3]=' ';
void mainmenu(void)
        LCD_init();
        LCD_write_string(1,1,"1LED 2USART 3RTC");
        LCD_write_string(1,2,"4TMP   5SON");
void auxmenu(int key1)
        switch(key1)
                case 1:
                        LCD_init();
                        LCD_write_string(1,1,"KEY CONTROL LED");
                        LCD_write_string(1,2,"1KS 2MS 3CL *Q");
                case 2:
                        LCD_init();
                        LCD_write_string(1,1,"UART CONTROL LED");
                        LCD_write_string(1,2,"A-K B-M C-L *Q");
                case 3:
                        LCD_init();
                        LCD_write_string(1,1,"#RTC");
                        LCD_write_string(1,2,"*-QUIT");
                case 4:
                        LCD_init();
                        LCD_write_string(1,1,"#TEMP");
                case 5:
                        LCD_init();
                        LCD_write_string(1,1,"#SON");
                case 31:
                        LCD_init();
                        LCD_write_string(1,1,"min:");
                        get_rtcch(5);
                        LCD_write_string(5,1,rtcch);
                        LCD_write_string(9,1,"sec:");
                        get_rtcch(6);
                        LCD_write_string(13,1,rtcch);
                        LCD_write_string(1,2,"C-Change *-QUIT");
                case 32:
                        LCD_init();
                        LCD_write_string(1,1,"mon:");
                        get_rtcch(2);
                        LCD_write_string(8,1,"date:");
                        get_rtcch(3);
                case 41:
                        LCD_init();
                        LCD_write_string(1,1,"TEMP:");
                        LCD_write_string(8,1,tempch);
                        LCD_write_string(13,1," ^C ");
                        LCD_write_string(1,2,"*QUIT");
                case 51:
                        LCD_init();
                        LCD_write_string(1,1,"Distance:");
                        LCD_write_string(10,1,distch);
                        LCD_write_string(13,1,"   ");
                default:
void flash_fast(void)
                PCout(13)=0;
                delay_ms(50);
                PCout(13)=1;
                delay_ms(50);
                num=keyscan();
                ch=recedata();
                if(num==12||ch=='Q')
void flash_slow(void)
                PCout(13)=0;
                delay_ms(500);
                PCout(13)=1;
                delay_ms(500);
                num=keyscan();
                ch=recedata();
void led_cl(void)
                PCout(13)=0;
                num=keyscan();
                ch=recedata();
u16 dist_sensor(void)
        u16 time_count;
        float distance;
        PBout(0)=1;
        delay_us(10);
        PBout(0)=0;
        while(PBin(1)==0&&overflow==0);
        TIM_Cmd(TIM3, ENABLE);
        TIM_SetCounter(TIM3,0x00);
        while(PBin(1)==1&&overflow==0);
        time_count=TIM_GetCounter(TIM3);
        distance=time_count/200.0*17;
        if(overflow==1)
                distance=999;
                overflow=0;
        return distance;
void TIM3_IRQHandler(void)
        if(TIM_GetITStatus(TIM3, TIM_IT_Update) == 1)
                overflow=1;
void ledctr(void)
        num = keyscan();
        if(num==1)
                flash_fast();
        if(num==2)
                flash_slow();
        if(num==3)
                led_cl();
        PCout(13)=1;
void usartctr(void)
        ch=recedata();
        if(ch=='A')
                flash_fast();
        if(ch=='B')
                flash_slow();
        if(ch=='C')
                led_cl();
        PCout(13)=1;
void get_temp(void)
        num=keyscan();
        if(num==11)
                        adct=T_Get_Temp();        //獲取溫度的數字量
                        tempv=adct*3.3/4096;        //獲得電壓量3.3為基準電壓,4096為2的12次方
                        tempt=(1.43-tempv)/0.0043+25-120;        //獲取溫度攝氏度值,1.43為25度時的溫度值,0.0043為溫度/VSENSE的平均斜率
                        tempz=tempt*100;
                        tempch[0]=tempt/10+0x30;
                        tempch[1]=(tempz/100)%10+0x30;
                        tempch[2]='.';
                        tempch[3]=(tempz/10)%10+0x30;
                        tempch[4]=tempz%10+0x30;
                        auxmenu(41);
                        delay_ms(200);
                        num=keyscan();
                        if(num==12)
void get_rtc()
        num=keyscan();
        if(num==11)
                        if(rtcflag==0)
                                auxmenu(31);
                                auxmenu(32);
                        delay_ms(200);
                        num=keyscan();
                        if(num==13)
                                rtcflag=~rtcflag;
                        if(num==12)
void get_son()
        u16 dist;
        num=keyscan();
        if(num==11)
                        dist=dist_sensor();
                        delay_ms(500);
                        distch[0]=dist/100+0x30;
                        distch[1]=(dist-100*(dist/100))/10+0x30;
                        distch[2]=dist%10+0x30;
                        auxmenu(51);
                        delay_ms(200);
                        num=keyscan();
                        if(num==12)
void quit(int key2)
        ch=recedata();
        num=keyscan();
        if(ch=='Q'||num==12)
                ch=recedata();
                num=keyscan();
                        PCout(13)=1;
                        ch='s';
                        num=0xff;
                        mainmenu();
                        flag=1;
                        ch='s';
                        num=0xff;
                        auxmenu(key2);
                        flag=0;
int main()
        delay_init();
        gpio_init();
        uart_init(9600);
        T_Adc_Init();
        time_init();
        nvic_init();
        RTC_Init();
        RTC_Set(2020,12,15,9,40,00);
        mainmenu();
                flag=0;
                ch=recedata();
                num=keyscan();
                if(num==1||ch=='1')
                        auxmenu(1);
                                num=keyscan();
                                ledctr();
                                quit(1);
                                if(flag==1)
                                        continue;
                if(num==2||ch=='2')
                        auxmenu(2);
                                ch=recedata();
                                num=keyscan();
                                usartctr();
                                quit(2);
                                if(flag==1)
                                        continue;
                if(num==3||ch=='3')
                        auxmenu(3);
                        delay_ms(1000);
                                ch=recedata();
                                num=keyscan();
                                get_rtc();
                                quit(3);
                                if(flag==1)
                                        continue;
                if(num==4||ch=='4')
                        auxmenu(4);
                        delay_ms(1000);
                                ch=recedata();
                                num=keyscan();
                                get_temp();
                                quit(4);
                                if(flag==1)
                                        continue;
                if(num==5||ch=='5')
                        auxmenu(5);
                        delay_ms(1000);
                                ch=recedata();
                                num=keyscan();
                                get_son();
                                quit(5);
                                if(flag==1)
                                        continue;
具體工程歡迎下載附件文件。
全部資料51hei下載地址:
mainSystem.7z (188.51 KB, 下載次數: 52)
作者: 單片機愛好者223    時間: 2021-7-14 22:12
確實挺亂的。。。。
主站蜘蛛池模板: av免费看片| 国产精品成人一区二区网站软件 | 97国产视频 | 久久久精品国产sm调教 | 精品福利在线观看 | 欧美性猛交xxxx乱大交退制版 | 黄色在线观看网址 | 久久久天堂国产精品女人 | 欧美日韩色 | 中文字幕在线免费视频 | 在线免费播放av | 午夜在线观看视频 | 国产不卡在线视频 | 久久精品欧美 | 97国产视频| 亚洲欧美在线播放 | 成人免费激情视频 | 亚洲视频精品 | 久久久久亚洲精品 | 男人午夜影院 | 欧美一区在线视频 | 欧美午夜精品久久久久免费视 | www.久久精品 | 国产高清网站 | 亚洲欧美综合 | 人与拘一级a毛片 | 日韩欧美在线视频 | 手机av在线免费观看 | 亚洲xxxxx| 天天曰天天操 | 欧美a级成人淫片免费看 | 日韩视频精品 | av一区二区在线观看 | 玖玖精品视频 | 99国产视频| 免费一区| 超碰99在线 | 成人免费福利视频 | 日本欧美久久久久免费播放网 | 欧美一级淫片免费视频魅影视频 | 国产又粗又猛视频免费 |
