飛思卡爾單片機初始化程序
shuobugaosu
2021-1-4 09:36
飛思卡爾單片機初始化程序
飛思卡爾單片機AD采集初始化函數,各頻率PWM輸出設置,延時函數。
void SecondDelay(unsigned int x) //define delay time program about xs
unsigned char i,j,k,m;
while(x--)
for(i=0;i<10;i++)
for(j=0;j<12;j++)
for(k=0;k<100;k++)
for(m=0;m<100;m++)
void mSecondDelay(unsigned int x) //define delay time program about xs
while(x--)
for(i=0;i<10;i++)
for(j=0;j<12;j++)
for(k=0;k<10;k++)
for(m=0;m<1;m++)
void ATD0Initial(void)
ATD0CTL0=0x00; /*多通道轉換時,確定ANO轉換完成后的下一個要轉換的通道號*/
/*ATD Control Register 0
* 0b00000000
* ||||||||__ WRAP0
* |||||||___ WRAP1
* ||||||____ WRAP2
* |||||_____ 保留
ATD0CTL1=0x87; /*設不使用外部觸發*/
/* ATD Control Register 1
* 0b10000111
* ||||||||__ ETRIGCH2
* |||||||___ ETRIGCH2
* ||||||____ ETRIGCH2
* |||||_____|
* ||||______|
* |||_______|保留
* ||________|
* |_________ ETRIGSEL(0-開放;1-禁止)
ATD0CTL2=0x80; /*設8通道ATD0模塊為正常工作模式,使能A/D,正常清除標志,不使用外部觸發,禁止中斷*/
/* ATD Control Register 2
* 0b10000000
* ||||||||__ ATD Sequence Complete Interrupt Flag
* |||||||___ ATD Sequence Complete Interrupt Enable
* ||||||____ External Trigger Mode Enable
* |||||_____ External Trigger Polarity
* ||||______ External Trigger Level/Edge Control
* |||_______ ATD Power Down inWait Mode
* ||________ ATD Fast Flag Clear All(0 ATD flag clearing operates normally)
* |_________ ATD Power Up(0 Power down ATD;1 Normal ATD functionality)
ATD0CTL3=0x08; /*隊列長度為1,即只轉換1個通道*/
/* ATD Control Register 3
* 0b00001000
* ||||||||__ FRZ0
* |||||||___ FRZ1
* ||||||____ FIFO
* |||||_____ S1C
* ||||______ S2C
* |||_______ S4C
* ||________ S8C
* |_________ 保留
ATD0CTL4=0x21; /*10位精度,A/D轉換的第二階段為4個A/D轉換周期,4分頻*/
/* ATD Control Register 4
* 0b00100000
* ||||||||__ PRS0
* |||||||___ PRS1
* ||||||____ PRS2
* |||||_____ PRS3
* ||||______ PRS4
* |||_______ SMP0
* ||________ SMP1
* |_________ SRES8(0-10位精度;1-8位精度)
ATD0CTL5=0x80; /*右對齊,無符號,單通道轉換模式,選擇模擬通道0*/
/* ATD Control Register 5
* 0b10000000
* ||||||||__ CA采樣通道0
* |||||||___ CB
* ||||||____ CC
* |||||_____ 保留
* ||||______ MULT(0-單通道采樣;1-多通道采樣)
* |||_______ SCAN(0-單次轉換隊列;1-連續轉換隊列)
* ||________ DSGN(0-無符號;1-有符號)
* |_________ DJM(0-左對齊;1-右對齊)
ATD0DIEN=0x00; /*數字輸入允許寄存器,禁止數字輸入*/
void ATD1Initial(void)
/*AD轉換器2的設置*/
ATD1CTL0=0x00; /*多通道轉換時,確定ANO轉換完成后的下一個要轉換的通道號*/
* 0b00000000
* ||||||||__ WRAP0
* |||||||___ WRAP1
* ||||||____ WRAP2
* |||||_____ WRAP3
* ||||______ 保留
ATD1CTL1=0x87; /*外部觸發源設置寄存器,在此設不使用外部觸發*/
* 0b10000111
* |||||_____|
* ||||______|
* |||_______|保留
* ||________|
* |_________ ETRIGSEL(0-開放外部觸發;1-禁止)
ATD1CTL2=0x80; /*設16通道ATD1模塊為使能A/D,正常清除標志,不使用外部觸發*/
* 0b10000000
* ||||||||__ ATD Sequence Complete Interrupt Flag(1-有序列轉換完成中斷發生,0-無)
* |||||||___ ATD Sequence Complete Interrupt Enable(1-使能序列轉換完成中斷)
* ||||||____ External Trigger Mode Enable(0-禁止外部觸發;1-使能外部觸發)
* ||||______ ETRIGLE(External Trigger Level/Edge Control)外部觸發邊沿控制
* |||_______ AWAI(ATD Power Down inWait Mode)0-在等待模式正常運行,1-省電模式
* ||________ AFFC(ATD Fast Flag Clear All)(0 ATD flag clearing operates normally)
* |_________ ADPU(ATD Power Up)(0 Power down ATD;1 Normal ATD functionality)
ATD1CTL3=0x08; /*探制轉換序列的長度,此處設隊列長度為1,即只轉換一個通道,最大長度為16*/
* 0b00001000
* ||||||||__ FRZ0
* |||||||___ FRZ1
* ||||||____ FIFO
* |||||_____ S1C|1
* ||||______ S2C|0
* |||_______ S4C|0
* ||________ S8C|0長度為1
* |_________ 保留
ATD1CTL4=0x21; /*設置轉換精度,采樣 時間,ATD時鐘分頻,在此設10位精度,A/D轉換的第二階段為4個A/D轉換周期,4分頻*/
* 0b00100000
* ||||||||__ PRS0
* |||||||___ PRS1
* ||||||____ PRS2
* |||||_____ PRS3
* ||||______ PRS4 00000即2分頻
* |||_______ SMP0=1
* ||________ SMP1=0 4個ATD時鐘周期
ATD1CTL5=0x80; /*設置數據格式,掃瞄方式,采樣方式,采樣通道,在此設右對齊,無符號,單次轉換隊列模式,單通道采樣,選擇模擬通道0*/
* 0b10000000
* ||||||||__ CA=0
* |||||||___ CB=0
* ||||||____ CC=0
* |||||_____ CD=0 采樣通道0
ATD1DIEN0=0x00; /*數字輸入允許寄存器,禁止數字輸入*/
ATD1DIEN1=0x00; /*數字輸入允許寄存器,禁止數字輸入*/
unsigned int ATD0Sample(unsigned char ADChannel)
ATD0CTL5=0x80;
ATD0CTL5+=ADChannel; /*ADChannel可設為0-7,則可選擇0-7中的任一通道*/
while(ATD0STAT0_SCF==0){}; /*等待當前隊列轉換完成,當轉換正在進行SCF=0,則為真,一直空循環*/
ATD0STAT0_SCF=1; /*當置SCF為1時,將使該標志位清零*/
return ATD0DR0;
unsigned int ATD1Sample(unsigned char ADChannel)
ATD1CTL5=0x80;
ATD1CTL5+=ADChannel;
while(ATD1STAT0_SCF==0){}; /*等待當前隊列轉換完成,!邏輯非,當轉換正在進行SCF=0,則為真,一直循環*/
ATD1STAT0_SCF=1; /*當置SCF為1時,將使該標志位清零*/
return ATD1DR0;
/*平均值濾波函數*/
float ResultsMeanAverageFilter(unsigned char SelectATDConverter,unsigned char i)
unsigned char count,j,k;
unsigned int valueBuf[N];
unsigned int temp;
unsigned int sum=0;
if(SelectATDConverter==0) /*當使用轉換器0進行采樣時的處理函數*/
for (count=0;count<N;count++)
valueBuf[count]=ATD0Sample(i);
for (count=1;count<N-1;count++)
sum+=valueBuf[count];
return ((float)sum/(N-2));
if(SelectATDConverter==1) /*當使用轉換器1進行采樣時的處理函數*/
valueBuf[count]=ATD1Sample(i);
/*限幅濾波函數*/
unsigned int ResultsLimiteFilter(unsigned char SelectATDConverter,unsigned char i,unsigned char A)
unsigned int a[2];
a[0]=ATD0Sample(i);
a[1]=ATD0Sample(i);
if ((a[1]-a[0]>A)||(a[0]-a[1]>A))
{return a[0];}
{return a[1];}
a[0]=ATD1Sample(i);
a[1]=ATD1Sample(i);
{return a[0];}
{return a[1];}
void PWM_Initial(void)
PWMPOL=0x00; /*PWM脈寬極性選擇,初始輸出為低電平*/
PWMCLK=0xff; /*選擇SA,SB時鐘*/
PWMPRCLK=0x22; /*A,B時鐘預分頻為4總線時鐘頻率*/
PWMCAE=0x00; /*PWM波形采用左對齊模式*/
PWMCTL=0x00; /*設置通道為獨立工作模式*/
PWMSCLA=60; /*A的時間常數為60*/
PWMSCLB=60;
PWMPER0=100; /*0-7通道250hz*/
PWMPER1=0x63; /*0x63對應數值為99*/
PWMPER2=0x63;
PWMPER3=0x63;
PWMPER4=0x63;
PWMPER5=0x63;
PWMPER6=0x63;
PWMPER7=0x63;
PWME=0xff; /*PWM使能寄存器,使能8路PWM控制*/
PWMDTY0=100; /*各通道占空比初始化為0*/
PWMDTY1=100;
PWMDTY2=100;
PWMDTY3=100;
PWMDTY4=100;
PWMDTY5=100;
PWMDTY6=100;
PWMDTY7=100;
void PWM_Initial0_5khz(void)
PWMPRCLK=0x00; /*A,B時鐘預分頻為0總線時鐘頻率*/
PWMSCLB=60;
PWMPER0=100; /*0-7通道1khz*/
PWMPER1=100; /*0x63對應數值為99*/
PWMPER2=100;
PWMPER3=100;
PWMPER4=100;
PWMPER5=100;
PWMPER6=100;
PWMPER7=100;
PWMDTY1=100;
PWMDTY2=100;
PWMDTY3=100;
PWMDTY4=100;
PWMDTY5=100;
PWMDTY6=100;
PWMDTY7=100;
void PWM_Initial2khz(void)
PWMSCLA=30; /*A的時間常數為30*/
PWMSCLB=30;
PWMPER2=100;
PWMPER3=100;
PWMPER4=100;
PWMPER5=100;
PWMPER6=100;
PWMPER7=100;
PWMDTY1=100;
PWMDTY2=100;
PWMDTY3=100;
PWMDTY4=100;
PWMDTY5=100;
PWMDTY6=100;
PWMDTY7=100;
void PWM_Initial3khz(void)
PWMSCLA=20; /*A的時間常數為60*/
PWMSCLB=20;
PWMPER2=100;
PWMPER3=100;
PWMPER4=100;
PWMPER5=100;
PWMPER6=100;
PWMPER7=100;
PWMDTY1=100;
PWMDTY2=100;
PWMDTY3=100;
PWMDTY4=100;
PWMDTY5=100;
PWMDTY6=100;
PWMDTY7=100;
void PWM_Initial4khz(void)
PWMSCLA=15; /*A的時間常數為60*/
PWMSCLB=15;
PWMPER2=100;
PWMPER3=100;
PWMPER4=100;
PWMPER5=100;
PWMPER6=100;
PWMPER7=100;
PWMDTY1=100;
PWMDTY2=100;
PWMDTY3=100;
PWMDTY4=100;
PWMDTY5=100;
PWMDTY6=100;
PWMDTY7=100;
(4.47 KB, 下載次數: 46)
2021-1-4 14:56 上傳
頭文件51hei下載地址:
SubFunctions.7z
(2.88 KB, 下載次數: 2)
2021-1-4 14:57 上傳
久久亚洲精品视频
日本激情视频
www.日韩av
午夜综合网
久久伊人国产
中文在线观看免费视频
欧美在线视频免费
91成人在线观看喷潮
日韩在线网址
日本高清网站
欧美亚洲激情
午夜免费在线
黄色天堂
久久精品在线观看
av网址在线播放
成人免费看
亚洲午夜一区
日韩综合久久
人人九九精
日韩欧美精品一区二区
亚洲精品91
av青青草
久久怡红院
久久艳片www.17c.com
成人欧美一区二区三区白人
国产成人精品亚洲男人的天堂
特黄一级片
在线看片你懂的
欧美在线网站
在线播放a
亚洲色网址
精品久久网站
日韩色在线
精品成人av
国产日韩在线播放
欧美综合久久
91午夜精品亚洲一区二区三区
中文字幕在线一区二区三区
午夜男人影院
九色网址
午夜激情网
