STM32+W5100S以太網芯片程序與資料
雷勞謀
2021-1-19 21:05
stm控制W5100S的程序
(5.27 KB, 下載次數: 89)
2021-1-19 21:47 上傳
#include "socket.h"
static uint16 local_port;
extern uint16 sent_ptr;
#define __MACRAW__
@brief This Socket function initialize the channel in perticular mode, and set the port and wait for W5200 done it.
@return 1 for sucess else 0.
void setkeepalive(SOCKET s);
uint8 socket(SOCKET s, uint8 protocol, uint16 port, uint8 flag) // 2017-07-17
uint8 ret;
if (
((protocol&0x0F) == Sn_MR_TCP) ||
((protocol&0x0F) == Sn_MR_UDP) ||
((protocol&0x0F) == Sn_MR_IPRAW) ||
((protocol&0x0F) == Sn_MR_MACRAW)
close(s);
if((protocol&0x0F)==Sn_MR_TCP)
setkeepalive(s);
IINCHIP_WRITE(W5100S_Sn_MR(s) ,protocol | flag);
if (port != 0) {
IINCHIP_WRITE( W5100S_Sn_PORT0(s) ,(uint8)((port & 0xff00) >> 8));
IINCHIP_WRITE( W5100S_Sn_PORT1(s) ,(uint8)(port & 0x00ff));
} else {
local_port++; // if don't set the source port, set local_port number.
IINCHIP_WRITE(W5100S_Sn_PORT0(s) ,(uint8)((local_port & 0xff00) >> 8));
IINCHIP_WRITE(W5100S_Sn_PORT1(s) ,(uint8)(local_port & 0x00ff));
IINCHIP_WRITE( W5100S_Sn_CR(s) ,Sn_CR_OPEN); // run sockinit Sn_CR
/* wait to process the command... */
while( IINCHIP_READ(W5100S_Sn_CR(s)) )
ret = 1;
ret = 0;
return ret;
@brief This function close the socket and parameter is "s" which represent the socket number
void close(SOCKET s)
IINCHIP_WRITE( W5100S_Sn_CR(s) ,Sn_CR_CLOSE); //SOCKET關閉
while( IINCHIP_READ(W5100S_Sn_CR(s) ) )
/* all clear */
IINCHIP_WRITE( W5100S_Sn_IR(s) , 0xFF);
@brief This function established the connection for the channel in passive (server) mode. This function waits for the request from the peer.
@return 1 for success else 0.
uint8 listen(SOCKET s) //設置為等待客戶端發出請求模式
uint8 ret;
if (IINCHIP_READ( W5100S_Sn_SR(s) ) == Sn_SR_INIT) //指示SOCKET打開并處于TCP模式
IINCHIP_WRITE(W5100S_Sn_CR(s) ,Sn_CR_LISTEN); //設置為等待客戶端發出請求模式
while( IINCHIP_READ(W5100S_Sn_CR(s) ) ) //等待設置完成
ret = 1;
ret = 0;
return ret;
@brief This function established the connection for the channel in Active (client) mode.
This function waits for the untill the connection is established.
uint8 connect(SOCKET s, uint8 * addr, uint16 port)
uint8 ret; // ret定義為是否連接的標志位,ret=0 連接中斷;ret=1連接成功
if
((addr[0] == 0xFF) && (addr[1] == 0xFF) && (addr[2] == 0xFF) && (addr[3] == 0xFF)) ||
((addr[0] == 0x00) && (addr[1] == 0x00) && (addr[2] == 0x00) && (addr[3] == 0x00)) ||
(port == 0x00)
ret = 0; // 如果IP地址和Port無法獲取,則連接中斷
else // 如果目的IP和Port未設置,則進行設置
ret = 1;
IINCHIP_WRITE( W5100S_Sn_DIPR0(s), addr[0]);
IINCHIP_WRITE( W5100S_Sn_DIPR1(s), addr[1]);
IINCHIP_WRITE( W5100S_Sn_DIPR2(s), addr[2]);
IINCHIP_WRITE( W5100S_Sn_DIPR3(s), addr[3]);
IINCHIP_WRITE( W5100S_Sn_DPORT0(s), (uint8)((port & 0xff00) >> 8));
IINCHIP_WRITE( W5100S_Sn_DPORT1(s), (uint8)(port & 0x00ff));
IINCHIP_WRITE( W5100S_Sn_CR(s) ,Sn_CR_CONNECT); // Sn_CR數值設為0x04,并執行TCP連接請求命令
while ( IINCHIP_READ(W5100S_Sn_CR(s) ) ) ; // MCU讀取Sn_CR(s)的數值
while ( IINCHIP_READ(W5100S_Sn_SR(s)) != Sn_SR_SYNSEND ) // 此時Sn_SR(s)寄存器應該處于SOCK_SYNSENT,下面排除不在該狀態的幾種情況
if(IINCHIP_READ(W5100S_Sn_SR(s)) == Sn_SR_ESTABLISHED) // Socket連接已經建立,正常連接
if (getSn_IR(s) & Sn_IR_TIMEOUT) // 當ARPto或TCPto超時,異常
IINCHIP_WRITE(W5100S_Sn_IR(s), (Sn_IR_TIMEOUT)); // 通知MCU該中斷,并清中斷
ret = 0; // ret置0,連接中斷
return ret;
@brief This function used for disconnect the socket and parameter is "s" which represent the socket number
void disconnect(SOCKET s)
IINCHIP_WRITE( W5100S_Sn_CR(s) ,Sn_CR_DISCON);
@brief This function used to send the data in TCP mode
uint16 send(SOCKET s, const uint8 * buf, uint16 len)
uint8 status=0;
uint16 ret=0;
uint16 freesize=0;
if (len > getSn_TXBUF_SIZE( s)*1024)
ret = getSn_TXBUF_SIZE( s)*1024;
else ret = len;
do
freesize = getSn_TX_FSR(s);
status = IINCHIP_READ(W5100S_Sn_SR(s));
if ((status != Sn_SR_ESTABLISHED) && (status != Sn_SR_CLOSE_WAIT))
printf("status break\r\n");
ret = 0;
while (freesize < ret);
send_data_processing(s, (uint8 *)buf, ret);
…………限于本文篇幅 余下代碼請從51黑下載附件…………
網絡調試助手:
http://m.zg4o1577.cn/bbs/dpj-201792-1.html
STM32F407通過W5100S進行網絡通信.7z
(5.15 MB, 下載次數: 58)
2021-1-19 22:35 上傳
TobbyHH
2021-7-17 16:10
這個例程怎么用呀。。
chen707070yi
2022-12-22 10:37
你這個比世偉的驅動好多了,世偉的里面很多bug,在判斷sock端口改變那里用了太多while等待,而且一些極端情況考慮的不是很周到導致經常莫名宕機,你這個比他們的好太多。
王富貴兒
2025-5-22 16:07
這個例
程太棒了
欧美综合一区二区
一级片国产
九色91popny蝌蚪
色综合久久久久
国产91清纯白嫩初高中在线观看
黄色在线免费网站
欧美精品久久久久久久多人混战
国产精品久久久久久久免费看
国产日韩精品在线
手机在线免费看av
欧美一级免费看
日本在线观看一区
精品视频在线免费观看
香蕉视频一区二区
a在线观看
丰满女人裸体淫交
国产欧美精品一区二区三区
国产精品91在线
色在线视频
av福利在线
亚洲欧美日韩精品
午夜高清
日韩国产一区二区
成人在线国产
午夜www
香蕉视频在线播放
中文字幕永久免费
日韩免费小视频
黄色小视频免费
四虎影院免费观看
久久在线免费观看
嫩草嫩草嫩草嫩草
在线一区二区三区
国产精品久久久久久久午夜
亚洲一级二级三级
午夜在线
超碰在线人人
久久久久一区二区
黄色录像免费看
白白色免费视频
欧美精品福利
