STM32F103C8T6-I2C-1602A程序
AaronHuang1228
2021-3-6 09:30
使用STM32F103C8T6單片機驅動I2C-1602A模塊
#include <stm32f10x.h>
#include "delay.h"
#include "IIC_1602.h"
extern unsigned char LCD_data;
* @brief I2C_Configuration,初始化硬件IIC引腳
* @param 無
* @retval 無
void I2C_Configuration(void)
I2C_InitTypeDef I2C_InitStructure;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1,ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB,ENABLE);
/*STM32F103C8T6芯片的硬件I2C: PB6 -- SCL; PB7 -- SDA */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD;//I2C必須開漏輸出
GPIO_Init(GPIOB, &GPIO_InitStructure);
I2C_DeInit(I2C1);//使用I2C1
I2C_InitStructure.I2C_Mode = I2C_Mode_I2C;
I2C_InitStructure.I2C_DutyCycle = I2C_DutyCycle_2;
I2C_InitStructure.I2C_OwnAddress1 = 0x30;//主機的I2C地址,隨便寫的
I2C_InitStructure.I2C_Ack = I2C_Ack_Enable;
I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
I2C_InitStructure.I2C_ClockSpeed = 400000;//400K
I2C_Cmd(I2C1, ENABLE);
I2C_Init(I2C1, &I2C_InitStructure);
* @brief I2C_WriteByte,向OLED寄存器地址寫一個byte的數據
* @param addr:寄存器地址
* data:要寫入的數據
* @retval 無
void I2C_WriteByte(unsigned char data)
while(I2C_GetFlagStatus(I2C1, I2C_FLAG_BUSY));
I2C_GenerateSTART(I2C1, ENABLE);//開啟I2C1
while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT));/*EV5,主模式*/
I2C_Send7bitAddress(I2C1, LCD_ADDR, I2C_Direction_Transmitter);//器件地址 --
while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
// I2C_SendData(I2C1, addr);//寄存器地址
// while (!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
I2C_SendData(I2C1, data);//發送數據
I2C_GenerateSTOP(I2C1, ENABLE);//關閉I2C1總線
void LCD_EN()
LCD_data |= 1<<2;
I2C_WriteByte(LCD_data);//1 讀取數據
DelayUs(25);//延時
LCD_data ^= 1<<2;
I2C_WriteByte(LCD_data);//1→0 執行指令
void LCD_WriteCMD(unsigned char cmd)
DelayUs(25);
LCD_data &=~(1<<(1-1));//RS=0;
LCD_data &=~(1<<(2-1));//RW=0;
LCD_data &= 0X0f; //清高四位
LCD_data |= cmd & 0xf0; //寫指令高四位
LCD_EN();
cmd = cmd<<4;
LCD_data |= cmd & 0xf0; //寫指令低四位
LCD_EN();
void LCD_WriteDAT(unsigned char dat)
DelayUs(25);
LCD_data |= (1<<(1-1));//RS=0;
LCD_data |= dat & 0xf0; //寫數據高四位
LCD_EN();
dat = dat<<4;
LCD_data |= dat & 0xf0; //寫數據低四位
LCD_EN();
void Set_Position(unsigned char x,unsigned char y)
unsigned char x_pos;
x_pos = x%0x10;
if(y==0)
LCD_WriteCMD(0x80+x_pos);
LCD_WriteCMD(0xc0+x_pos);
void LCD_ShowStr(unsigned char x,unsigned char y,unsigned char * str)
Set_Position(x,y);
while(*str)
LCD_WriteDAT(*str);
str++;
void LCD_Init()
LCD_WriteCMD(0x28);//4線操作模式
LCD_WriteCMD(0x0c);//
LCD_WriteCMD(0x80);
LCD_WriteCMD(0x01);
DelayMs(5);
void LCD_DispConf(unsigned char DispON,unsigned char CursorON,unsigned char GlareON)
unsigned char x = 0x08;
if(DispON!=0)
x = x|(DispON<<2);
if(CursorON!=0)
x = x|(CursorON<<1);
if(GlareON!=0)
x = x|GlareON;
LCD_WriteCMD(x);
所有程序51hei提供下載:
IIC_1602A.7z
(21.31 KB, 下載次數: 106)
2021-3-6 15:52 上傳
wifingtta
2022-2-9 17:32
用STM32F103C6T6測試過,可以顯示,但液晶背光不受控制,背光會一直關閉。
在线理论片
18视频在线观看
九九精品网
自拍视频网
久久久三级
欧美一区二区三区成人
日本三级在线视频
久久精品在线
色妞网站
视频一区中文字幕
激情婷婷网
麻豆亚洲一区
中文字幕伊人
久久精品欧美一区二区
成人免费在线播放
欧美在线观看视频
日韩一区二区在线视频
日韩在线免费播放
久久激情网
999毛片
欧美精品日韩少妇
欧美日韩在线一区二区
天天综合天天做天天综合
久久99精品国产麻豆91樱花
久久免费网
日本成人免费网站
欧美视频二区
日韩成人小视频
国产成人在线免费观看
91成人精品
青青草一区二区
色黄大色黄女片免费中国
亚洲激情中文字幕
美女久久久久
超碰在线观看免费版
91av在线看
www免费视频
99久久精品国产一区二区三区
成年免费视频黄网站在线观看
欧美三级大片
日韩午夜激情
