基于8086的16X16點陣顯示程序Proteus仿真圖
liwujun
2022-6-30 22:17
本項目是基于8086的點陣顯示,可以通過按鍵顯示所要顯示的內容
(38.48 KB, 下載次數: 29)
2022-6-30 22:14 上傳
IOY0 EQU 0C400H ;片選第一片8255的地址
IOY1 EQU 0C440H ;片選第二片8255的地址
O8255_A EQU IOY0+00*2 ;第一片8255的地址的A口
O8255_B EQU IOY0+01*2 ;第一片8255的地址的B口
O8255_C EQU IOY0+10*2 ;第一片8255的地址的C口
O8255_MODE EQU IOY0+11*2 ;第一片8255的地址的控制字寄存器
T8255_A EQU IOY1+00*2 ;第二片8255的地址的A口
T8255_B EQU IOY1+01*2 ;第二片8255的地址的B口
T8255_C EQU IOY1+10*2 ;第二片8255的地址的C口
T8255_MODE EQU IOY1+11*2 ;第二片8255的地址的控制字寄存器
DATAS SEGMENT
;此處輸入數據段代碼
COUNT1 DB 00H
COUNT2 DB 01H
TAB DB 08H,02H,18H,02H,0C8H,3FH,14H,02H,32H,02H,11H,02H,0E8H,7FH,08H,08H
DB 0CH,08H,0EAH,7FH,08H,08H,88H,08H,88H,08H,08H,08H,08H,0AH,08H,04H ;待
DB 08H,00H,08H,1FH,08H,11H,7FH,11H,08H,11H,08H,11H,1CH,11H,2CH,11H
DB 2AH,11H,0AH,11H,89H,10H,88H,50H,48H,50H,48H,50H,28H,60H,08H,00H ;機
DB 00H,01H,00H,01H,3FH,01H,0A0H,7FH,0A1H,20H,52H,12H,14H,02H,08H,02H
DB 18H,02H,18H,06H,24H,05H,24H,09H,82H,18H,61H,70H,1CH,20H,00H,00H ;歡
DB 02H,00H,84H,01H,6CH,3EH,24H,22H,20H,22H,20H,22H,27H,22H,24H,22H
DB 0A4H,22H,64H,2AH,24H,12H,04H,02H,04H,02H,0AH,00H,0F1H,7FH,00H,00H ;迎
DB 80H,08H,82H,08H,84H,08H,0ECH,3FH,84H,08H,80H,08H,80H,08H,0EFH,7FH
DB 88H,08H,88H,08H,48H,08H,48H,08H,28H,08H,14H,00H,0E2H,7FH,00H,00H ;進
DB 30H,00H,60H,00H,40H,00H,80H,00H,0C0H,00H,40H,01H,40H,01H,20H,02H
DB 20H,04H,10H,04H,10H,08H,08H,10H,04H,70H,02H,20H,01H,00H,00H,00H ;入
DB 00H,3EH,0FCH,01H,40H,04H,20H,04H,10H,02H,0F8H,01H,0C0H,04H,30H,08H
DB 0FCH,1FH,08H,31H,20H,05H,10H,09H,08H,11H,04H,21H,42H,21H,80H,00H ;系
DB 08H,02H,08H,04H,0C4H,7FH,04H,02H,22H,02H,1FH,11H,90H,20H,0C8H,7FH
DB 04H,29H,3EH,09H,00H,09H,00H,09H,0B8H,48H,87H,48H,40H,70H,20H,00H ;統
DB 00H,00H,00H,00H,00H,00H,00H,00H,08H,00H,08H,00H,08H,00H,08H,00H
DB 08H,00H,08H,00H,08H,00H,08H,00H,08H,00H,00H,00H,08H,00H,00H,00H ;!
DB 0FEH,3FH,80H,00H,80H,00H,0F8H,0FH,88H,08H,88H,08H,0F8H,0FH,88H,08H
DB 88H,08H,88H,08H,0FFH,7FH,08H,08H,08H,08H,08H,08H,08H,0AH,08H,04H ;再
DB 0F8H,0FH,08H,08H,08H,08H,88H,08H,88H,08H,88H,08H,88H,08H,88H,08H
DB 48H,09H,40H,01H,20H,01H,20H,21H,10H,21H,0CH,61H,03H,3EH,00H,00H ;見
DATAS ENDS
STACKS SEGMENT
;此處輸入堆棧段代碼
N1 DB 100 DUP(?)
STACKS ENDS
CODES SEGMENT
ASSUME CS:CODES,DS:DATAS,SS:STACKS
START:
MOV AX,DATAS
MOV DS,AX
MOV DX,O8255_MODE
MOV AL,81H
OUT DX,AL ;第一片8255方式選擇
MOV DX,T8255_MODE
MOV AL,80H
OUT DX,AL ;第二片8255方式選擇
MOV CX,0
CALL C1
X: CALL C2
MOV SI,0000H ;指針賦值0
MOV AH,2 ;顯示“待機”
JMP X0
Y: CALL C2
MOV AH,7 ;顯示“歡迎進入系統”
MOV SI,0040H
MOV DI,SI
JMP X0
Z: CALL C2
MOV AH,2 ;顯示“再見”
MOV SI,0120H
MOV DI,SI
X0: PUSH CX
MOV BX,1024 ;整體循環1024次
X1: PUSH BX
MOV BH,COUNT1 ;初始化
MOV BL,COUNT2
CLC ;CF位清零
RER: MOV CX,16 ;循環次數
MOV SI,DI ;指向原來的位置
LOOP1:
MOV DX,T8255_A ;清除列
MOV AL,00H
OUT DX,AL
MOV DX,T8255_B
MOV AL,00H
OUT DX,AL
CALL FI
INC SI ;指針再次加1
RCL BL,1 ;每次循環向左移動1位
RCL BH,1 ;連帶CF位一同左移1位
DEC CX ;循環次數減1
CMP CX,0 ;循環次數大于0,就繼續循環
JNZ LOOP1
POP BX ;第二重循環計數
DEC BX
CMP BX,0
JNZ X1
LOOP3:
POP CX ;第三重循環,控制顯示哪些字
INC CX
MOV DI,SI
CMP CL,AH
JNZ X0 ;顯示程序結束
MOV DI,0000H
MOV AH,0
MOV CX,0
CALL C1
MOV AH,4CH
INT 21H
C1: MOV DX,O8255_C ;讀取C口狀態
IN AL,DX
CMP AL,0EH ;判斷按下的是第幾個按鍵,依次跳轉
JZ X
CMP AL,0DH
JZ Y
CMP AL,0BH
JZ Z
O: MOV DX,O8255_C ;初始化鍵盤掃描輸入
PUSH AX
MOV AL,0FH
OUT DX,AL
POP AX
JMP C1
RET
C2: MOV DX,O8255_C ;對數碼管的輸出
PUSH AX
CALL C3
OUT DX,AL
POP AX
RET
C3: CMP AL,0EH ;數碼管輸出變量
JZ M1
CMP AL,0DH
JZ M2
CMP AL,0BH
JZ M3
M1: MOV AL,17H
RET
M2: MOV AL,27H
RET
M3: MOV AL,37H
RET
FI: MOV DX,O8255_A ;循環行掃描
MOV AL,BL
OUT DX,AL
MOV DX,O8255_B
MOV AL,BH
OUT DX,AL
LOOP2:
MOV DX,T8255_A ;循環列掃描
MOV AL,TAB[SI]
OUT DX,AL
INC SI ;指針加1,指向下一個數據
MOV DX,T8255_B
MOV AL,TAB[SI]
OUT DX,AL
RET
CODES ENDS
END START
以上是代碼
附件只包含1個文件 Proteus仿真文件下載:
基于8086點陣.zip
(109.44 KB, 下載次數: 42)
2022-6-30 22:12 上傳
8086點陣
久久视频一区
欧美特黄一级
免费网站黄
久久久xxx
色婷婷香蕉在线一区二区
三上悠亚激情av一区二区三区
久久精品黄色
成人久久av
日日夜夜精品视频免费
日本国产精品
国产三级在线播放
国产精品视频网
欧美综合网
精东影业一区二区三区
国产午夜一区二区
福利小视频在线观看
91爱爱爱
91蜜桃婷婷狠狠久久综合9色
欧美日韩亚洲一区二区三区
99热在线免费观看
欧美视频在线观看免费
亚洲视频不卡
欧美黄色一区二区
久久精品视频网站
激情五月激情综合网
性做久久久
成人三级在线观看
中文字幕在线观看一区
国产美女自拍视频
av大全在线观看
精品在线看
黄色伊人
国产成人精品久久久
一级特黄毛片
一级理论片
蜜臀久久99精品久久久久宅男
中文字幕在线观看一区
亚洲二区在线
国产在线观看网站
欧美一区二区在线
国产一区福利
