STM32單片機+ads1292心率檢測顯示程序
1418233104
2023-3-20 00:48
該演示程序使用的芯片為:STM32F103C8T6
功能:
單片機采集ADS1292模塊數據,通過串口輸出。
串口:
UART1
波特率:115200
停止位:1
數據為:8
奇偶校驗:無
引腳定義及連線:
1292模塊--STM32F1:
VDD---3.3V/5V
GND---GND
DRDY---PA8
CS---PB12
SCK---PB13
MISO---PB14
MOSI---PB15
#include "ADS1292.h"
#include "spi.h"
#include "delay.h"
#include "usart.h"
#include "Timer.h"
#include "key.h"
#include "led.h"
#define DEBUG_ADS1292 //寄存器printf調試
u8 ADS1292_REG[12]; //ads1292寄存器數組
ADS1292_CONFIG1 Ads1292_Config1 ={DATA_RATE}; //CONFIG1
ADS1292_CONFIG2 Ads1292_Config2 ={PDB_LOFF_COMP,PDB_REFBUF,VREF,CLK_EN,INT_TEST}; //CONFIG2
ADS1292_CHSET Ads1292_Ch1set ={CNNNLE1_POWER,CNNNLE1_GAIN,CNNNLE1_MUX}; //CH1SET
ADS1292_CHSET Ads1292_Ch2set ={CNNNLE2_POWER,CNNNLE2_GAIN,CNNNLE2_MUX}; //CH2SET
ADS1292_RLD_SENS Ads1292_Rld_Sens ={PDB_RLD,RLD_LOFF_SENSE,RLD2N,RLD2P,RLD1N,RLD1P}; //RLD_SENS
ADS1292_LOFF_SENS Ads1292_Loff_Sens ={FLIP2,FLIP1,LOFF2N,LOFF2P,LOFF1N,LOFF1P}; //LOFF_SENS
ADS1292_RESP1 Ads1292_Resp1 ={RESP_DEMOD_EN1,RESP_MOD_EN,RESP_PH,RESP_CTRL}; //RSP1
ADS1292_RESP2 Ads1292_Resp2 ={CALIB,FREQ,RLDREF_INT}; //RSP2
//ADS1292的IO口初始化
void ADS1292_Init(void)
EXTI_InitTypeDef EXTI_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA |RCC_APB2Periph_GPIOB|RCC_APB2Periph_AFIO, ENABLE);
SPI2_Init();//初始化SPI引腳
//250ns 頻率4.5M 發送八組時鐘需要23 us
//125ns 頻率9M, 發送八組時鐘需要14 us
//55ns 頻率18M 發送八組時鐘需要9.2us
//30ns 36M 發送八組時鐘需要9.2us
//手冊10頁里寫的最小時鐘周期為50ns
//DRDY //待機時高電平,采集時低電平有效
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;//上拉輸入
GPIO_Init(GPIOC, &GPIO_InitStructure);
//CS
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;//推挽輸出
GPIO_Init(GPIOB, &GPIO_InitStructure);
// //RESRT
// GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
// GPIO_Init(GPIOA, &GPIO_InitStructure);
// //START
// GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
// //CLKSEL
// GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
//DRDY中斷初始化
EXTI_ClearITPendingBit(EXTI_Line8);//清除中斷標志
GPIO_EXTILineConfig(GPIO_PortSourceGPIOC,GPIO_PinSource8);//選擇管腳
EXTI_InitStructure.EXTI_Line=EXTI_Line8; //選擇中斷線路
EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt; //設置為中斷請求,非事件請求
EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling; //下降沿觸發
EXTI_InitStructure.EXTI_LineCmd = ENABLE; //外部中斷使能
EXTI_Init(&EXTI_InitStructure);
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
NVIC_InitStructure.NVIC_IRQChannel = EXTI9_5_IRQn; //選擇中斷通道
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1; //搶占優先級
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1; //子優先級
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //使能外部中斷通道
EXTI->IMR &= ~(EXTI_Line8);//屏蔽外部中斷
ADS_CS=1;
ADS1292_PowerOnInit();//上電復位,進入待機模式
volatile u8 ads1292_recive_flag=0; //數據讀取完成標志
volatile u8 ads1292_Cache[9]; //數據緩沖區
void EXTI9_5_IRQHandler(void)
if(EXTI->IMR&EXTI_Line8 && ADS_DRDY==0)//數據接收中斷
ADS1292_Read_Data(ads1292_Cache);//數據存到9字節緩沖區
ads1292_recive_flag=1;
//讀取72位的數據1100+LOFF_STAT[4:0]+GPIO[1:0]+13個0+2CHx24位,共9字節
// 1100 LOFF_STAT[4 3 2 1 0 ] //導聯脫落相關的信息在LOFF_STAT寄存器里
// RLD 1N2N 1N2P 1N1N 1N1P
// 例 C0 00 00 FF E1 1A FF E1 52
u8 ADS1292_Read_Data(u8 *data)//72M時鐘下函數耗時大約10us 8M時鐘下 函數耗時大約 100us
u8 i;
ADS_CS=0;//讀9個字節的數據
//delay_us(10);
for(i=0;i<9;i++)
*data=ADS1292_SPI(0X00);
data++;
//delay_us(10);
ADS_CS=1;
return 0;
//設置寄存器數組
void ADS1292_SET_REGBUFF(void)
ADS1292_REG[ID] = ADS1292_DEVICE;//ID只讀
ADS1292_REG[CONFIG1] = 0x00; //0000 0aaa [7] 0連續轉換模式 [6:3] 必須為0
ADS1292_REG[CONFIG1] |= Ads1292_Config1.Data_Rate;//[2:0] aaa 采樣率設置采樣率
ADS1292_REG[CONFIG2] = 0x00; //1abc d0e1 [7] 必須為1 [2] 必須為0 [0] 設置測試信號為1HZ、±1mV方波
ADS1292_REG[CONFIG2] |= Ads1292_Config2.Pdb_Loff_Comp<<6; //[6]a 導聯脫落比較器是否掉電
ADS1292_REG[CONFIG2] |= Ads1292_Config2.Pdb_Refbuf<<5; //[5]b 內部參考緩沖器是否掉電
ADS1292_REG[CONFIG2] |= Ads1292_Config2.Vref<<4; //[4]c 內部參考電壓設置,默認2.42V
ADS1292_REG[CONFIG2] |= Ads1292_Config2.Clk_EN<<3; //[3]d CLK引腳輸出時鐘脈沖?
ADS1292_REG[CONFIG2] |= Ads1292_Config2.Int_Test<<1; //[1]e 是否打開內部測試信號,
ADS1292_REG[CONFIG2] |= 0x81;//設置默認位
ADS1292_REG[LOFF] = 0x10;//[7:5] 設置導聯脫落比較器閾值 [4] 必須為1 [3:2] 導聯脫落電流幅值 [1] 必須為0 [0] 導聯脫落檢測方式 0 DC 1 AC
ADS1292_REG[CH1SET] = 0x00; //abbb cccc
ADS1292_REG[CH1SET] |=Ads1292_Ch1set.PD<<7; //[7] a 通道1斷電?
ADS1292_REG[CH1SET] |=Ads1292_Ch1set.GAIN<<4; //[6:4]bbb 設置PGA增益
ADS1292_REG[CH1SET] |=Ads1292_Ch1set.MUX; //[3:0]cccc 設置通道1輸入方式
ADS1292_REG[CH2SET] = 0x00; //abbb cccc
ADS1292_REG[CH2SET] |=Ads1292_Ch2set.PD<<7; //[7] a 通道2斷電?
ADS1292_REG[CH2SET] |=Ads1292_Ch2set.GAIN<<4; //[6:4]bbb 設置PGA增益
ADS1292_REG[CH2SET] |=Ads1292_Ch2set.MUX; //[3:0]cccc 設置通道2輸入方式
ADS1292_REG[RLD_SENS] = 0X00; //11ab cdef [7:6] 11 PGA斬波頻率 fMOD/4
ADS1292_REG[RLD_SENS] |=Ads1292_Rld_Sens.Pdb_Rld<<5; //[5]a 該位決定RLD緩沖電源狀態
ADS1292_REG[RLD_SENS] |=Ads1292_Rld_Sens.Rld_Loff_Sense<<4; //[4]b 該位使能RLD導聯脫落檢測功能
ADS1292_REG[RLD_SENS] |=Ads1292_Rld_Sens.Rld2N<<3; //[3]c 這個位控制通道2負輸入 用于右腿驅動的輸出
ADS1292_REG[RLD_SENS] |=Ads1292_Rld_Sens.Rld2P<<2; //[2]d 該位控制通道2正輸入 用于右腿驅動的輸出
ADS1292_REG[RLD_SENS] |=Ads1292_Rld_Sens.Rld1N<<1; //[1]e 這個位控制通道1負輸入 用于右腿驅動的輸出
ADS1292_REG[RLD_SENS] |=Ads1292_Rld_Sens.Rld1P; //[0]f 該位控制通道1正輸入 用于右腿驅動的輸出
ADS1292_REG[RLD_SENS] |= 0xc0;//設置默認位
ADS1292_REG[LOFF_SENS] = 0X00; //00ab cdef [7:6] 必須為0
ADS1292_REG[LOFF_SENS] |=Ads1292_Loff_Sens.Flip2<<5; //[5]a 這個位用于控制導聯脫落檢測通道2的電流的方向
ADS1292_REG[LOFF_SENS] |=Ads1292_Loff_Sens.Flip1<<4; //[4]b 這個位控制用于導聯脫落檢測通道1的電流的方向
ADS1292_REG[LOFF_SENS] |=Ads1292_Loff_Sens.Loff2N<<3; //[3]c 該位控制通道2負輸入端的導聯脫落檢測
ADS1292_REG[LOFF_SENS] |=Ads1292_Loff_Sens.Loff2P<<2; //[2]d 該位控制通道2正輸入端的導聯脫落檢測
ADS1292_REG[LOFF_SENS] |=Ads1292_Loff_Sens.Loff1N<<1; //[1]e 該位控制通道1負輸入端的導聯脫落檢測
ADS1292_REG[LOFF_SENS] |=Ads1292_Loff_Sens.Loff1P; //[0]f 該位控制通道1正輸入端的導聯脫落檢測
ADS1292_REG[LOFF_STAT] = 0x00; //[6]0 設置fCLK和fMOD之間的模分頻比 fCLK=fMOD/4 [4:0]只讀,導聯脫落和電極連接狀態
ADS1292_REG[RESP1] = 0X00;//abcc cc1d
ADS1292_REG[RESP1] |=Ads1292_Resp1.RESP_DemodEN<<7;//[7]a 這個位啟用和禁用通道1上的解調電路
ADS1292_REG[RESP1] |=Ads1292_Resp1.RESP_modEN<<6; //[6]b 這個位啟用和禁用通道1上的調制電路
ADS1292_REG[RESP1] |=Ads1292_Resp1.RESP_ph<<2; //[5:2]c 這些位控制呼吸解調控制信號的相位
ADS1292_REG[RESP1] |=Ads1292_Resp1.RESP_Ctrl; //[0]d 這個位設置呼吸回路的模式
ADS1292_REG[RESP1] |= 0x02;//設置默認位
ADS1292_REG[RESP2] = 0x00; //a000 0bc1 [6:3]必須為0 [0]必須為1
ADS1292_REG[RESP2] |= Ads1292_Resp2.Calib<<7; //[7]a 啟動通道偏移校正?
ADS1292_REG[RESP2] |= Ads1292_Resp2.freq<<2; //[2]b 呼吸頻率設置
ADS1292_REG[RESP2] |= Ads1292_Resp2.Rldref_Int<<1; //[1]c RLDREF信號源外部饋電?
ADS1292_REG[RESP2] |= 0X01;//設置默認位
ADS1292_REG[GPIO] = 0x0C; //GPIO設為輸入 [7:4]必須為0 [3:2]11 GPIO為輸入 [1:0] 設置輸入時,指示引腳電平,設置輸出時控制引腳電平
//通過SPI總線與ADS1292通信
u8 ADS1292_SPI(u8 com)
return SPI2_ReadWriteByte(com);
//寫命令
void ADS1292_Send_CMD(u8 data)
ADS_CS=0;
delay_us(100);
ADS1292_SPI(data);
delay_us(100);
ADS_CS=1;
/*ADS1291、ADS1292和ADS1292R串行接口以字節形式解碼命令,需要4個tCLK周期來解碼和執行.
因此,在發送多字節命令時,4 tCLK周期必須將一個字節(或操作碼)的結束與下一個字節(或操作碼)分開。
假設CLK(時鐘)為512 kHz,則tSDECODE (4 tCLK)為7.8125 us。
當SCLK(數據速率)為16mhz時,一個字節可以在500ns中傳輸,此字節傳輸時間不符合tSDECODE規范;
因此,必須插入一個延遲,以便第二個字節的末尾晚于7.3125us到達。
如果SCLK為1 MHz,則在8u秒內傳輸一個字節。由于此傳輸時間超過tSDECODE規范,處理器可以不延遲地發送后續字節。
在后面的場景中,可以對串行端口進行編程,使其從每個循環的單字節傳輸轉移到多個字節*/
//讀寫多個寄存器
void ADS1292_WR_REGS(u8 reg,u8 len,u8 *data)
u8 i;
ADS_CS=0;
delay_us(100);
ADS1292_SPI(reg);
delay_us(100);
ADS1292_SPI(len-1);
if(reg&0x40) //寫
for(i=0;i<len;i++)
delay_us(100);
ADS1292_SPI(*data);
data++;
else //讀
for(i=0;i<len;i++)
delay_us(100);
*data = ADS1292_SPI(0);
data++;
delay_us(100);
ADS_CS=1;
//寄存器數組寫入寄存器
u8 ADS1292_WRITE_REGBUFF(void)
u8 i,res=0;
u8 REG_Cache[12]; //存儲寄存器數據
ADS1292_SET_REGBUFF();//設置寄存器數組
ADS1292_WR_REGS(WREG|CONFIG1,11,ADS1292_REG+1);//數組變量寫入寄存器
delay_ms(10);
ADS1292_WR_REGS(RREG|ID,12,REG_Cache);//讀寄存器
delay_ms(10);
// #ifdef DEBUG_ADS1292
// printf("WRITE REG:\r\n");
// for(i=0;i<12;i++ )//要寫的數據
// printf("%d %x\r\n",i,ADS1292_REG[i]);
// printf("READ REG:\r\n");
// #endif
for(i=0;i<12;i++ ) //檢查寄存器
if(ADS1292_REG[i] != REG_Cache[i])
if(i!= 0 && i!=8 && i != 11) //0 8 和11是ID 導聯脫落和GPIO相關
res=1;
continue;
// printf("%d %x\r\n",i,REG_Cache[i]); //讀到的數據
// #endif
if(res == 0)
printf("REG write success\r\n");
printf("REG write err\r\n");
#endif
return res;
void ADS1292_PowerOnInit(void)
u8 i;
u8 REG_Cache[12];
// ADS_CLKSEL=1;//啟用內部時鐘
// ADS_START=0; //停止數據輸出
// ADS_RESET=0; //復位
// delay_ms(1000);
// ADS_RESET=1;//芯片上電,可以使用
// delay_ms(100); //等待穩定
ADS1292_Send_CMD(SDATAC);//發送停止連續讀取數據命令
delay_ms(100);
ADS1292_Send_CMD(RESET);//復位
delay_s(1);
delay_ms(100);
//#ifdef DEBUG_ADS1292
// ADS1292_WR_REGS(RREG|ID,12,REG_Cache);
// printf("read default REG:\r\n");
// for(i=0;i<12;i++ ) //讀默認寄存器
//#endif
//ADS1292_Send_CMD(STANDBY);//進入待機模式
//設置通道1內部1mV測試信號
u8 ADS1292_Single_Test(void) //注意1292R開了呼吸解調,會對通道一的內部測試信號波形造成影響,這里只參考通道2即可,1292不受影響
u8 res=0;
Ads1292_Config2.Int_Test = INT_TEST_ON;//打開內部測試信號
Ads1292_Ch1set.MUX=MUX_Test_signal;//測試信號輸入
Ads1292_Ch2set.MUX=MUX_Test_signal;//測試信號輸入
if(ADS1292_WRITE_REGBUFF())//寫入寄存器
res=1;
delay_ms(10);
return res;
//設置內部噪聲測試
u8 ADS1292_Noise_Test(void)
u8 res=0;
Ads1292_Config2.Int_Test = INT_TEST_OFF;//關內部測試信號
Ads1292_Ch1set.MUX = MUX_input_shorted;//輸入短路
Ads1292_Ch2set.MUX = MUX_input_shorted;//輸入短路
res=1;
delay_ms(10);
return res;
//正常信號采集模式
u8 ADS1292_Single_Read(void)
u8 res=0;
Ads1292_Ch1set.MUX = MUX_Normal_input;//普通電極輸入
Ads1292_Ch2set.MUX = MUX_Normal_input;//普通電極輸入
res=1;
delay_ms(10);
return res;
//配置ads1292采集方式
u8 Set_ADS1292_Collect(u8 mode)
u8 res;
delay_ms(10);
switch(mode)//設置采集方式
case 0:
res =ADS1292_Single_Read();
case 1:
res =ADS1292_Single_Test();
case 2:
res =ADS1292_Noise_Test();
if(res)return 1;//寄存器設置失敗
ADS1292_Send_CMD(RDATAC); //啟動連續模式
delay_ms(10);
ADS1292_Send_CMD(START); //發送開始數據轉換(等效于拉高START引腳)
delay_ms(10);
return 0;
#include "sys.h" //系統配置
#include "delay.h" //延時
#include "usart.h" //串口
#include "led.h"
#include "Timer.h"
#include "dma.h"
u8 xinlv;
extern u8 xinlv1;
s32 get_volt(u32 num);
u8 flag;
u16 flag1;
//main
int main(void)
u8 res,i,sum;
u8 data_to_send[60];//串口發送緩存
u8 usbstatus=0;
u32 cannle[2]; //存儲兩個通道的數據
s32 p_Temp[2]; //數據緩存
data_to_send[0]=0xAA;
data_to_send[1]=0xAA;
data_to_send[2]=0xF1;
data_to_send[3]=8;
data_to_send[13] = 0X0D; //校驗和
data_to_send[14] = 0X0A; //校驗和
//初始化系統時鐘 72M
SystemInit();
delay_init();
delay_ms(100);
uart1_init(500000);//串口初始化為115200
DMA_Config(DMA1_Channel4,(u32)&USART1->DR,(u32)data_to_send);//串口1DMA設置
USART_DMACmd(USART1,USART_DMAReq_Tx,ENABLE); //DMA
LED_Init();
ADS1292_Init(); //初始化ads1292
while(Set_ADS1292_Collect(0))
printf("1292寄存器設置失敗\r\n");
delay_s(1);
printf("寄存器設置成功\r\n");
delay_s(1);
TIM2_Init(50,1439);//系統指示
TIM4_Init(50,1439);//打印心率
EXTI->IMR |= EXTI_Line8;//開DRDY中斷
while(1)//循環發送數據
if(ads1292_recive_flag==1)
flag1++;
cannle[0]=ads1292_Cache[3]<<16 | ads1292_Cache[4]<<8 | ads1292_Cache[5];//獲取原始數據
cannle[1]=ads1292_Cache[6]<<16 | ads1292_Cache[7]<<8 | ads1292_Cache[8]; //
p_Temp[0] = get_volt(cannle[0]); //把采到的3個字節轉成有符號32位數
p_Temp[1] = get_volt(cannle[1]); //把采到的3個字節轉成有符號32位數
cannle[0] = p_Temp[0];
cannle[1] = p_Temp[1];
data_to_send[4]=cannle[0]>>24; //25-32位
data_to_send[5]=cannle[0]>>16; //17-24
data_to_send[6]=cannle[0]>>8; //9-16
data_to_send[7]=cannle[0]; //1-8
data_to_send[8]=cannle[1]>>24; //25-32位
data_to_send[9]=cannle[1]>>16; //17-24
data_to_send[10]=cannle[1]>>8; //9-16
data_to_send[11]=cannle[1]; //1-8
for(i=0;i<12;i++)
sum += data_to_send[i];
// printf("%d\r\n",sum);
data_to_send[12] = sum; //校驗和
// DMA_Enable(DMA1_Channel4,13);//串口1DMA
sum = 0;
if((p_Temp[1]>265000)&&(flag==1))
xinlv++;
flag=0;
else if((p_Temp[1]<265000)&&(flag==0))
flag=1;
/*功能:把采到的3個字節轉成有符號32位數 */
s32 temp;
temp = num;
temp <<= 8;
temp >>= 8;
return temp;
Keil代碼下載:
代碼.7z
(207.13 KB, 下載次數: 50)
2023-3-21 20:01 上傳
亚洲精品网站在线观看
美女一级片
av免费观看在线
亚洲三级黄色片
久草免费在线观看视频
国产日产av
日韩专区中文字幕
国产成人精品一区二区三区福利
久操福利视频
伦一理一级一a一片
日韩一二三
96看片
91在线亚洲
亚洲国产精
欧美 日韩 国产 在线
欧美精品一区在线
少妇一级淫片
中文字幕在线观看一区二区三区
久久久免费看
国产精品成人免费视频
欧美一区二区三区视频
久久久久久黄色
亚洲另类自拍
久久怡红院
毛片网站视频
日韩精品免费一区二区夜夜嗨
四虎三级
www.午夜
久久精品一区二区三区四区五区
成人午夜视频在线观看
欧美三级又粗又硬
免费中文字幕
久草视频免费在线观看
美女黄色小说
在线a视频
www一级片
欧美成人专区
www.色综合
亚洲一区二区精品视频
97视频免费
四虎网站在线观看
