單片機顯示問題 不理解為什么這個板子一開電源會出現0,而不是空白呢
深層次
2023-12-23 15:32
就是不理解為什么這個板子一開電源會出現0,而不是空白呢?
#include <reg52.h> //包含52頭文件
#define uint unsigned int //宏定義uint代替unsigned int
#define uchar unsigned char //宏定義uchar代替unsigned char
#define out P0
sbit lcdrs=P2^4;
sbit lcdrw=P2^5;
sbit lcden=P2^6;
sbit buzzer =P2^7;//蜂鳴器
sbit led=P3^1;
void check_busy(void);
void write_cmd(char cmd);
void write_data(uchar dat);
void write_str(uchar *str);
void lcd_init();
void keyscan();
void verify();
void beep();
void T1_init();
uchar key,num=100,flag,warn,time1,time2;
uint cnt=2;
unsigned char code password[6]={1,4,0,2,0,6};//密碼
uchar dat[]="0123456789";
uchar DispBuff[6];
void delay (uint xms) //毫秒函數定義
uint i,j;
for(i=0;i<xms;i++)
for(j=0;j<120;j++);
void main() //主函數
{ T1_init();
lcd_init();
num=0;
keyscan();
if(key!=0xff)
{ uchar i;
DispBuff[num]=key;
num++;
key=0xff;
write_cmd(0x01);//清除屏幕
delay(1);
write_cmd(0x80+0x40);
for(i=0;i<num;i++)
{ write_data(dat[DispBuff[ i]]); }
verify();
if(time2==4) //門鎖打開后4秒關閉
{ time2=0;
TR1=0; //關閉定時器1
/**********************檢查忙標志函數************************/
uchar dt;
out=0xff;
do
lcden=0;
lcdrs=0;
lcdrw=1;
lcden=1;
dt=out;
}while(dt&0x80);
lcden=0;
/**************************1602顯示****************************/
void write_cmd(char cmd) //寫指令函數
check_busy();
lcden=0;//再把EN拉低
lcdrs=0;
lcdrw=0;//先將RW拉低
out=cmd;
lcden=1;
lcden=0;
void write_data(uchar dat) //寫數據函數
check_busy();
lcden=0;//再把EN拉低
lcdrs=1;
lcdrw=0;//先將RW拉低
out=dat;
lcden=1;
lcden=0;
void write_str(uchar *str)//寫字符串函數
while(*str!='\0')
write_data(*str++);
delay(5);
/***************************初始化******************************/
void lcd_init()//初始化1602
write_cmd(0x38);//顯示模式設置
write_cmd(0x0c);//顯示開關,光標沒有閃爍
write_cmd(0x06);//顯示光標移動設置
delay(1);
void keyscan()
uchar temp,num;
P1=0xff; //先向P1寫1
P1=0xfe; //選中按鍵第一行
temp=P1; //把P1給中間變量
temp=temp&0xf0;//低四位清零
while(temp!=0xf0)
delay(5);
temp=P1;
temp=temp&0xf0;
while(temp!=0xf0)
temp=P1;
switch(temp)
case 0xee:key=0; break;
case 0xde:key=1; break;
case 0xbe:key=2; break;
case 0x7e:key=3; break;
while(temp!=0xf0)
temp=P1;
temp=temp&0xf0;
P1=0xfd;//選中按鍵第二行
temp=P1; //把P1給中間變量
while(temp!=0xf0)
delay(5);
temp=P1;
temp=temp&0xf0;
while(temp!=0xf0)
temp=P1;
switch(temp)
case 0xed:key=4; break;
case 0xdd:key=5; break;
case 0xbd:key=6; break;
case 0x7d:key=7; break;
while(temp!=0xf0)
temp=P1;
temp=temp&0xf0;
P1=0xfb;//選中按鍵第三行
temp=P1; //把P1給中間變量
while(temp!=0xf0)
delay(5);
temp=P1;
temp=temp&0xf0;
while(temp!=0xf0)
temp=P1;
switch(temp)
case 0xeb:key=8; break;
case 0xdb:key=9; break;
case 0xbb:key=10; break;
case 0x7b:key=11; break;
while(temp!=0xf0)
temp=P1;
temp=temp&0xf0;
P1=0xf7;//選中按鍵第四行
temp=P1; //把P1給中間變量
while(temp!=0xf0)
delay(5);
temp=P1;
temp=temp&0xf0;
while(temp!=0xf0)
temp=P1;
switch(temp)
case 0xe7:key=12; break;
case 0xd7:key=13; break;
case 0xb7:key=14; break;
case 0x77:key=15; break;
while(temp!=0xf0)
temp=P1;
temp=temp&0xf0;
while((num<50)&&(temp!=0xf0))
{delay(10);
num++;
num=0;
void verify()//對輸入密碼進行判斷
{ uchar j,Flag;
if(num==6)
{ num=0;
Flag=1;
for(j=0;j<6;j++)
Flag=(DispBuff[j]==password[j]);
if(Flag)
write_cmd(0x80+0x04);
write_str("Right! ");
write_str("Wrong! ");
warn++;
if(warn==3)
{ TR0=1; //定時器0啟動
beep();
led=~led;
warn=0; //累計清零
delay(2000);
write_cmd(0x80);
write_str(" ");
write_cmd(0xc0);
write_str(" ");
void beep()
{ buzzer=1;
delay(200);
buzzer=0;
delay(200);
void T1_init()
TMOD=TMOD|0x20; //設置T1為方式2
TH1=256-200; //置T1高8位,備用初值
TL1=256-200; //置T1低8位,初值
ET1=1; //開T1中斷
EA=1; //開總中斷
/**********T1中斷服務程序*********/
void T1_int() interrupt 3 //200us進入中斷
{ TH1=(65536-50000)/256;
TL1=(65536-50000)%256;
time1++;
if(time1==20)//一秒
time2++;
time1=0;
Hephaestus
2023-12-23 17:17
因為你沒有阻止write_data(dat[DispBuff[ i]]); 這個函數的運行,上電后按默認值就是顯示0。
深層次
2023-12-23 17:55
Hephaestus 發表于 2023-12-23 17:17
噢噢噢噢,我悟了
深層次
2023-12-24 11:11
那如何修改呢?我試了將i=1;的方式,發現不行,輸入結果會減少成5個數
国产传媒在线
成人免费公开视频
av资源在线
日本精品久久
午夜视频免费在线观看
亚洲天码中字
中文字幕理伦片免费看
欧美天堂
97人人草
aaa黄色片
久久激情视频
中文一区二区
欧美区在线
欧美久久网
91视频免费在线观看
中文字幕一区二区在线播放
精品少妇av
www视频在线观看网站
欧美黄色一级
色综合天天综合网天天狠天天
国产又黄又猛
激情综合网站
蜜臀99久久精品久久久久小说
视频一区二区在线
国产一区福利
亚洲激情在线观看
在线免费毛片
免费看一级黄色片
亚洲激情视频在线观看
一级做a爱片性色毛片
日韩在线欧美
国产一级生活片
亚洲福利视频一区
青草免费视频
97国产超碰
一区二区三区高清
国产一级特黄aaa大片
老女人性生活视频
午夜视频在线免费观看
亚洲男人天堂av
成人免费毛片入口
