/*子函數,用于讀取數據表中農歷月的大月或小月,如果該月為大返回1,為小返回0*/
bit get_moon_day(uchar month_p,uint table_addr){
uchar temp;
switch (month_p){
case 1:{temp=year_code[table_addr]&0x08;
if (temp==0)return(0);else return(1);}
case 2:{temp=year_code[table_addr]&0x04;
case 3:{temp=year_code[table_addr]&0x02;
case 4:{temp=year_code[table_addr]&0x01;
case 5:{temp=year_code[table_addr+1]&0x80;
if (temp==0) return(0);else return(1);}
case 6:{temp=year_code[table_addr+1]&0x40;
case 7:{temp=year_code[table_addr+1]&0x20;
case 8:{temp=year_code[table_addr+1]&0x10;
case 9:{temp=year_code[table_addr+1]&0x08;
case 10:{temp=year_code[table_addr+1]&0x04;
case 11:{temp=year_code[table_addr+1]&0x02;
case 12:{temp=year_code[table_addr+1]&0x01;
case 13:{temp=year_code[table_addr+2]&0x80;
/*函數功能:輸入BCD陽歷數據,輸出BCD陰歷數據(只允許1901-2099年)*/
void GetLunar(uchar yy,uchar mo,uchar dd){ //c=0 為21世紀,c=1 為19世紀 輸入輸出數據均為BCD數據 作者: kz0018 時間: 2024-2-28 15:53
