標題: C語言函數聲明報錯error C141: syntax error near '*', expected ')' [打印本頁]
作者: 菲子叭叭    時間: 2024-2-29 19:08
#ifndef __W25Q32_H_
#define __W25Q32_H_
#include "main.h"
#define PAGESIZE      256//一頁最多輸入256字節
//SPI IO控制
#define SPI_SCL_1(_HANDLE_)                ( GPIO_WritePin((_HANDLE_)->uSCL_Port, (_HANDLE_)->uSCL_Pin, 1))
#define SPI_SCL_0(_HANDLE_)                ( GPIO_WritePin((_HANDLE_)->uSCL_Port, (_HANDLE_)->uSCL_Pin, 0))
#define SPI_MOSI_1(_HANDLE_)        ( GPIO_WritePin((_HANDLE_)->uMOSI_Port, (_HANDLE_)->uMOSI_Pin, 1))
#define SPI_MOSI_0(_HANDLE_)        ( GPIO_WritePin((_HANDLE_)->uMOSI_Port, (_HANDLE_)->uMOSI_Pin, 0))
#define SPI_MISO_1(_HANDLE_)        ( GPIO_WritePin((_HANDLE_)->uMISO_Port, (_HANDLE_)->uMISO_Pin, 1))
#define SPI_MISO_0(_HANDLE_)        ( GPIO_WritePin((_HANDLE_)->uMISO_Port, (_HANDLE_)->uMISO_Pin, 0))
#define SPI_CS_1(_HANDLE_)                ( GPIO_WritePin((_HANDLE_)->uCS_Port, (_HANDLE_)->uCS_Pin, 1))
#define SPI_CS_0(_HANDLE_)                ( GPIO_WritePin((_HANDLE_)->uCS_Port, (_HANDLE_)->uCS_Pin, 0))
#define SPI_MISO_R(_HANDLE_)        ( GPIO_ReadPin((_HANDLE_)->uMISO_Port, (_HANDLE_)->uMISO_Pin))
extern void  vW25Q32_Init(SPI_ObjectTypedef * hSPIx,
        uint8_t             uSCL_Port,
        uint8_t             uSCL_Pin ,
                   uint8_t             uMOSI_Port,
                   uint8_t             uMOSI_Pin ,
                   uint8_t             uMISO_Port,
                   uint8_t             uMISO_Pin ,
        uint8_t             uCS_Port,
                   uint8_t             uCS_Pin);
//獲取Flash ID
extern uint32_t W25Q32_Read_ID(SPI_ObjectTypedef * hSPIx);
//寫使能(啟動)
extern void W25Q32_Write_Enable(SPI_ObjectTypedef * hSPIx);
//等待保護(等待擦除或寫入操作,直到操作完成結束)
extern void W25Q32_Wait_End(SPI_ObjectTypedef * hSPIx);
//讀操作,*buf為內容,addr為地址,pagesize為要讀出的字節數
extern void W25Q32_Read_Page(SPI_ObjectTypedef * hSPIx, uint8_t *buf,uint32_t addr,uint8_t pagesize);
//芯片擦除,非易失存儲器,寫數據前應該擦除操作
extern void W25Q32_Delete(SPI_ObjectTypedef * hSPIx);
//頁寫操作,*buf為內容,addr為地址,pagesize為寫入字節數必須小于256個
extern void W25Q32_Write_Page(SPI_ObjectTypedef * hSPIx,uint8_t *buf, uint32_t addr,uint8_t pagesize);
#endif
Core\W25Q32.h(25): error C141: syntax error near '*', expected ')'
Core\W25Q32.h(39): error C141: syntax error near '*', expected ')'
Core\W25Q32.h(41): error C141: syntax error near '*', expected ')'
Core\W25Q32.h(43): error C141: syntax error near '*', expected ')'
Core\W25Q32.h(45): error C141: syntax error near '*', expected ')'
Core\W25Q32.h(47): error C141: syntax error near '*', expected ')'
Core\W25Q32.h(49): error C141: syntax error near '*', expected ')'
想問一下,為什么每個聲明語句都有報錯
作者: lkc8210    時間: 2024-2-29 20:59
要加分行符
  1. extern void  vW25Q32_Init(SPI_ObjectTypedef * hSPIx, \
  2.                                                         uint8_t uSCL_Port, \
  3.                                                         uint8_t uSCL_Pin, \
  4.                                                         uint8_t uMOSI_Port, \
  5.                                                         uint8_t uMOSI_Pin, \
  6.                                                         uint8_t uMISO_Port, \
  7.                                                         uint8_t uMISO_Pin, \
  8.                                                         uint8_t uCS_Port, \
  9.                                                         uint8_t uCS_Pin);
作者: Hephaestus    時間: 2024-3-1 16:54
這種#define不太好,inline更好一些。比如:
我會寫成:
inline void SPI_SCL_1(_HANDLE_) { GPIO_WritePin((_HANDLE_)->uSCL_Port, (_HANDLE_)->uSCL_Pin, 1))}
不過雖然編譯器都支持inline,但是這并不是c語言標準關鍵字,要查編譯器手冊才可以。
主站蜘蛛池模板: 欧美日韩小视频 | 国产精品成人av | 亚洲免费视频网站 | 亚洲天堂偷拍 | 久久精品99久久久久久 | avtt久久| www.亚洲精品 | 国产中文字幕在线 | 久久精品国产一区 | 国产免费av在线 | 久草网在线观看 | 欧美自拍一区 | 欧美一级在线观看 | 久久精品小视频 | 中文在线观看视频 | 免费一级a毛片 | 国产成人精品视频 | 国产一区在线视频 | av免费在线观看网站 | 超碰福利在线 | 亚洲精品久久久久久久久 | 91成人免费视频 | 国产黄色在线观看 | 天天狠狠 | 亚洲免费网站 | 日韩不卡在线 | 久久久不卡 | 中文字幕日韩视频 | 国产成人av一区二区三区在线观看 | www一级片 | 香港三日本三级少妇66 | 玖玖视频在线 | 国产精品美女 | 日韩视频一区二区三区 | 亚洲黄色影院 | 成人黄色一级片 | 国产精品一区二区久久 | 亚洲一级在线 | 亚洲天堂一区二区三区 | 日韩精品成人 | 国产在线观看网站 |
