標題: 自建24點陣數(shù)字字庫顯示不正常 [打印本頁]
作者: bobby_jack    時間: 2024-5-25 10:10
各位大佬,
前些天在用LCD0802做頻率計,總覺得顯示不好看,想改用12864(12832比較難買)。碰到的問題是用16點陣字體太小,一屏四行也用不完,想改成24點陣的。用PCTOLCD2000建了只0-9再加上小數(shù)點的小字庫,如下:
const unsigned char code F12X24[][36]=
{0x00,0x00,0x00,0x00,0x7F,0x80,0x01,0xFF,0xE0,0x03,0x80,0x70,0x06,0x00,0x18,0x04},
{0x00,0x08,0x04,0x00,0x08,0x06,0x00,0x18,0x03,0x80,0x70,0x01,0xFF,0xE0,0x00,0x7F},
{0x80,0x00,0x00,0x00},/*"0",0*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x00,0x08,0x02,0x00,0x08,0x02,0x00,0x08,0x03},
{0xFF,0xF8,0x07,0xFF,0xF8,0x00,0x00,0x08,0x00,0x00,0x08,0x00,0x00,0x08,0x00,0x00},
{0x00,0x00,0x00,0x00},/*"1",1*/
{0x00,0x00,0x00,0x01,0xC0,0x18,0x02,0xC0,0x38,0x04,0x00,0x48,0x04,0x00,0x88,0x04},
{0x03,0x08,0x04,0x06,0x08,0x06,0x0C,0x08,0x03,0xF8,0x08,0x01,0xE0,0x78,0x00,0x00},
{0x00,0x00,0x00,0x00},/*"2",2*/
{0x00,0x00,0x00,0x03,0x80,0x70,0x03,0x80,0x70,0x04,0x00,0x08,0x04,0x08,0x08,0x04},
{0x08,0x08,0x06,0x18,0x08,0x03,0xF4,0x18,0x01,0xE7,0xF0,0x00,0x01,0xE0,0x00,0x00},
{0x00,0x00,0x00,0x00},/*"3",3*/
{0x00,0x00,0x00,0x00,0x03,0x00,0x00,0x05,0x00,0x00,0x19,0x00,0x00,0x21,0x00,0x00},
{0xC1,0x08,0x01,0x01,0x08,0x07,0xFF,0xF8,0x07,0xFF,0xF8,0x00,0x01,0x08,0x00,0x01},
{0x08,0x00,0x01,0x00},/*"4",4*/
{0x00,0x00,0x00,0x00,0x00,0xE0,0x07,0xFC,0xD0,0x04,0x08,0x08,0x04,0x10,0x08,0x04},
{0x10,0x08,0x04,0x10,0x08,0x04,0x18,0x38,0x04,0x0F,0xF0,0x04,0x07,0xC0,0x00,0x00},
{0x00,0x00,0x00,0x00},/*"5",5*/
{0x00,0x00,0x00,0x00,0x3F,0x80,0x01,0xFF,0xE0,0x03,0x84,0x30,0x02,0x08,0x18,0x04},
{0x10,0x08,0x04,0x10,0x08,0x04,0x10,0x08,0x07,0x18,0x10,0x03,0x0F,0xF0,0x00,0x07},
{0xC0,0x00,0x00,0x00},/*"6",6*/
{0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x80,0x00,0x06,0x00,0x00,0x04,0x00,0x00,0x04},
{0x00,0xF8,0x04,0x07,0xF8,0x04,0x18,0x00,0x04,0xE0,0x00,0x07,0x00,0x00,0x06,0x00},
{0x00,0x00,0x00,0x00},/*"7",7*/
{0x00,0x00,0x00,0x01,0xC1,0xE0,0x03,0xF3,0xF0,0x06,0x36,0x10,0x04,0x18,0x08,0x04},
{0x08,0x08,0x04,0x0C,0x08,0x04,0x0C,0x08,0x06,0x16,0x18,0x03,0xF3,0xF0,0x01,0xC1},
{0xE0,0x00,0x00,0x00},/*"8",8*/
{0x00,0x00,0x00,0x00,0xF8,0x00,0x03,0xFC,0x30,0x03,0x06,0x38,0x04,0x02,0x08,0x04},
{0x02,0x08,0x04,0x02,0x08,0x04,0x04,0x10,0x03,0x08,0xF0,0x01,0xFF,0xC0,0x00,0x7F},
{0x00,0x00,0x00,0x00},/*"9",9*/
顯示函數(shù)如下(24點陣):
else if(Char_Size ==24)
                 c=chr-'/';
     OLED_Set_Pos(x, y);
        for (i = 0; i < 12; i++)
            OLED_WR_Byte(F12X24[c * 36 + i], OLED_DATA);  //18*2
        OLED_Set_Pos(x, y + 1);
            OLED_WR_Byte(F12X24[c * 36 + i +12], OLED_DATA);
            OLED_Set_Pos(x, y + 2);
            OLED_WR_Byte(F12X24[c * 36 + i +24], OLED_DATA);
其中c=chr-'/'是取偏移后的值。因為小字庫的第一位是‘0’,ASC值48,而‘/'是47,48-47=1,正好取首字符。
工作時16點陣正常,但在24點陣時僅能顯示24點陣麻點方塊,不是所需數(shù)字。
我對C語言的底層編程不內(nèi)行,故特地向各位請教。
謝謝。
作者: zhuls    時間: 2024-5-25 15:03
“其中c=chr-'/'是取偏移后的值。因為小字庫的第一位是‘0’,ASC值48,而‘/'是47,48-47=1,正好取首字符。”
總感覺哪里不對
作者: bobby_jack    時間: 2024-5-25 16:39
zhuls 發(fā)表于 2024-5-25 15:03
“其中c=chr-'/'是取偏移后的值。因為小字庫的第一位是‘0’,ASC值48,而‘/'是47,48-47=1,正好取首字符 ...
你好,謝謝關(guān)注。
在一般西文字庫里,大都會從 ‘ ’ 開始,即從 ‘ ’ - ‘~’,并按ASCII值排列,因此偏移值要減去 ‘ ’(ASCII值32),即 c=chr-' ’ ,即可得到所需顯示字符在字庫里的位置。但我的字庫里只有11個數(shù)字(多了內(nèi)存不夠),所以就自作聰明,減去 ‘/' 字符的ASCII值(47)了。
作者: zhuls    時間: 2024-5-25 17:29
bobby_jack 發(fā)表于 2024-5-25 16:39
你好,謝謝關(guān)注。
在一般西文字庫里,大都會從 ‘ ’ 開始,即從 ‘ ’ - ‘~’,并按ASCII值排列,因此 ...
理是這個理,要是顯示‘0’時,你-47,能對的上嗎?我覺得既然你的小字庫是0~9,那么首字當是‘0’,偏移量就應該是‘0’,即0x30,你用這個‘/’(0x2F)做偏移量真的對嗎?
  1. void OLED_ShowChar(u8 x,u8 y,u8 chr)
  2. {
  3.         unsigned char c=0,i=0;
  4. <font color="#ff0000">                c=chr-' ';//得到偏移后的值  //字庫從' '空格開始,偏移量就該是‘ ’空格的ASC碼</font>
  5.                 if(x>Max_Column-1){x=0;y=y+2;}
  6.                 if(SIZE ==16)
  7.                         {
  8.                         OLED_Set_Pos(x,y);
  9.                         for(i=0;i<8;i++)
  10.                         OLED_WR_Byte(F8X16[c*16+i],OLED_DATA);
  11.                         OLED_Set_Pos(x,y+1);
  12.                         for(i=0;i<8;i++)
  13.                         OLED_WR_Byte(F8X16[c*16+i+8],OLED_DATA);
  14.                         }
  15.                         else {
  16.                                 OLED_Set_Pos(x,y+1);
  17.                                 for(i=0;i<6;i++)
  18.                                 OLED_WR_Byte(F6x8[c][i],OLED_DATA);
  19.
  20.                         }
  21. }
//常用ASCII表
//偏移量32
const unsigned char code F8X16[]=
作者: bobby_jack    時間: 2024-5-25 22:17
zhuls 發(fā)表于 2024-5-25 17:29
理是這個理,要是顯示‘0’時,你-47,能對的上嗎?我覺得既然你的小字庫是0~9,那么首字當是‘0’,偏移 ...
你好,謝謝再次支招。
問題已經(jīng)解決,主要有三點:
第一即是如你所說的應該改去‘0’,因為C語言都是從0開始計數(shù),而我忽略了。
第二是調(diào)用函數(shù)有誤。它是從網(wǎng)上摘錄下來的,估計發(fā)布者也沒有對此驗證。正確的寫法應該是:
  1.                 else if(Char_Size ==24)
  2.                 {
  3.           if(x>Max_Column-1){x=0;y=y+2;}
  4.                  c=chr-'0';
  5.      OLED_Set_Pos(x, y);
  6.         for (i = 0; i < 12; i++)
  7.             OLED_WR_Byte(F12X24[c] [i], OLED_DATA);
  8.         OLED_Set_Pos(x, y + 1);
  9.         for (i = 0; i < 12; i++)
  10.             OLED_WR_Byte(F12X24[c] [i +12], OLED_DATA);
  11.             OLED_Set_Pos(x, y + 2);
  12.         for (i = 0; i < 12; i++)
  13.             OLED_WR_Byte(F12X24[c] [i +24], OLED_DATA);
  14.                 }
即F12X24本身是二維的,而在原程序調(diào)用時寫成一維。
第三是pctolcd取模時在正向,而我用反了。
再次謝謝。
主站蜘蛛池模板: 夜夜嗷 | 九九精品视频在线观看 | 天天搞天天干 | 亚洲精品久久久蜜桃 | 国产精品二区一区二区aⅴ污介绍 | 黄色国产网站 | 亚洲天堂av在线 | 中国毛片视频 | 天堂成人网 | 中文字幕在线视频观看 | 久久视频在线 | 日韩综合久久 | 亚洲一区中文 | 亚洲一区自拍 | 日韩欧美一区二区在线 | 黄色国产视频 | 亚洲第一视频网站 | 国产黄色免费网站 | 成人在线视频免费观看 | 一区二区三区四区精品 | 国产视频福利 | 欧美日韩第一区 | 免费网站av | 免费国产视频 | 中文字幕国产在线 | 伊人久久精品视频 | 中文字幕免费观看 | 成人免费在线播放 | 欧美手机在线 | 超碰97免费 | 嫩草国产 | a级片在线免费观看 | 这里只有精品视频 | 男女啪啪免费 | 91欧美日韩 | 中文有码在线 | 精品久久免费视频 | 成人高清视频在线观看 | 免费一级a毛片夜夜看 | 999在线视频 | 日本精品国产 |
