有人可以幫改一下這個程序嗎?不知道怎么改
學渣渣渣渣
2024-11-28 20:03
#include <reg52.h>
sbit SPK = P1 ^ 2; //定義喇叭接口
sbit KEY = P3 ^ 3; //設置獨立按鍵INT1,按下按鍵時切換歌曲
sbit LED = P1 ^ 7; //用于切換歌曲的顯示,當LED = 1時播放鈴兒響叮當,否則播放Spider Dance
int Timer0_H, Timer0_L, Time; //定義定時器變量和時間變量
code unsigned char MUSIC1[] = { //歌曲“鈴兒響叮當”的樂譜,每個音由3個變量構成,前兩個變量用來確定音樂頻率,第三個變量確定持續時間
3,2,2,3,2,2, 3,2,4, 3,2,2,3,2,2, 3,2,4,
3,2,2,5,2,2, 1,2,3,2,2,1, 3,2,8,
4,2,2,4,2,2, 4,2,2,4,2,2, 4,2,2,3,2,2, 3,2,2,3,2,2,
5,2,2,5,2,2, 4,2,2,2,2,2, 1,2,4, 1,3,4, 0,0,0
code unsigned char MUSIC2[] = { //歌曲“Spider Dance”的樂譜,如果前兩個變量為(0,0)時則為空拍
6,3,4, 3,3,4, 1,3,4, 6,2,4,
0,0,2, 2,3,2, 2,3,2, 0,0,4, 2,3,2, 1,3,2, 5,2,2, 6,2,2,
0,0,2, 3,3,2, 2,3,2, 1,3,2, 2,3,2, 3,3,2, 5,2,2, 6,2,2,
1,3,2, 6,2,2, 5,2,2, 6,3,2, 0,0,2, 5,3,2, 3,3,1, 2,3,1, 1,3,2,
6,2,4, 4,2,4, 7,2,4, 4,2,4,
1,3,4, 4,2,4, 2,3,8,
3,3,4, 2,3,4, 6,3,4, 3,3,4,
5,3,4, 4,3,4, 3,3,4, 0,0,4,
6,3,2, 3,4,2, 2,4,2, 3,4,2, 6,3,2, 3,4,2, 2,4,2, 3,4,2,
3,3,2, 2,4,2, 2,4,2, 2,4,2, 3,3,2, 3,4,2, 7,3,2, 2,4,2,
6,3,2, 3,4,2, 2,4,2, 3,4,2, 7,3,2, 3,4,2, 2,4,2, 3,4,2,
1,4,2, 3,4,2, 2,4,2, 3,4,2, 2,4,2, 4,4,2, 3,4,2, 4,4,2,
4,3,2, 1,4,2, 7,3,2, 1,4,2, 4,3,2, 2,4,2, 1,4,2, 2,4,2,
4,3,2, 3,4,2, 2,4,2, 3,4,2, 4,3,2, 4,4,2, 3,4,2, 4,4,2, 0,0,0
code unsigned char FREQH[]= { //頻率表前八位,第0行頻率為低兩個8度的音,第1行頻率為低一個8度的音,第2行為正常音,第3行為高8度的音
//(抱歉,樂理基礎沒學好,音的標準說法忘了咋說了,懂意思就好)
// 比如說正常音la,持續時間為2,那就是(6,2,2)
0xF2,0XF3,0xF5,0xF5,0XF6,0XF7,0XF8,
0xF9,0XF9,0XFA,0XFA,0XFB,0XFB,0XFC,0XFC,
0xFC,0XFD,0XFD,0XFD,0XFD,0XFE,
0xFE,0XFE,0XFE,0XFE,0XFE,0XFE,0XFF
code unsigned char FREQL[]= { //頻率表后八位
0x42,0xC1,0x17,0xB6,0xD0,0xD1,0xB6,
0x21,0xE1,0x8C,0xD8,0x68,0xE9,0x5B,0x8F,
0xEE,0x44,0x6B,0xB4,0xF4,0x2D,
0x47,0x77,0xA2,0xB6,0xDA,0xFA,0x16
void DelayUs2x(unsigned char t) //延遲函數
while (--t)
void DelayMs(unsigned char t) //延遲時間函數,略微修改,時間不準
while (--t)
DelayUs2x(245);
void delay(unsigned char t) //延遲時間函數
unsigned char i;
for (i = 0; i < t; i++)
DelayMs(125);
TR0 = 0;
void Init_Timer0(void) //定時器初始化函數
TMOD |= 0x01; //模式1,16位定時器/計數器
EA = 1; //總中斷打開
ET0 = 1; //定時器中斷打開
void TIM0_ISR() interrupt 1 //定時器中斷函數,用于讀取音符頻率值,產生對應的音符
TR0 = 0; //定時器暫停
SPK = !SPK; //喇叭反轉
TH0 = Timer0_H; //重置定時
TL0 = Timer0_L;
TR0 = 1; //定時器開始
void Song()
if (Timer0_H == -1 && Timer0_L == -1) //空拍判斷,喇叭不發聲
delay(Time);
TL0 = Timer0_L;
TR0 = 1;
delay(Time);
void main(void)
unsigned char k, i;
Init_Timer0();
KEY = 1;
LED = 1;
while (1)
i = 0;
if (LED) //播放“鈴兒響叮當”
while (i < 76) //這個數字是MUSIC數組里的變量數
k = MUSIC1[i] + 7 * MUSIC1[i + 1] - 1;//頻率位置,用兩個變量進行判斷
Timer0_H = FREQH[k];// 獲取頻率高八位
Timer0_L = FREQL[k];// 獲取頻率低八位
Time = MUSIC1[i + 2];// 獲取持續時間
i += 3;
Song();
if (!KEY) //判斷獨立按鍵按下
while (!KEY) //判斷按鍵釋放
LED = !LED; //切歌
while (i < 280) //播放“Spider Dance”
k = MUSIC2[i] + 7 * MUSIC2[i + 1] - 1;
Time = MUSIC2[i + 2];
i += 3;
Song();
if (!KEY)
while (!KEY)
LED = !LED;
錯誤: Build target 'Target 1'
compiling aaaaa.c...
AAAAA.C(33): error C141: syntax error near ';'
AAAAA.C(34): error C141: syntax error near ';'
Target not created
huashanhui20
2024-11-29 08:11
我幫你試過了,程序編譯沒有問題,編譯直接通過
(142 KB, 下載次數: 0)
2024-11-29 08:11 上傳
kxcuser
2024-11-29 08:43
我編譯是可以通過啊,你要改成什么樣都不說明,別人怎么幫你改
man1234567
2024-11-29 14:41
編譯正常通過,蛔蟲知道答案
国产综合视频
国产在线麻豆精品观看
www.久久久
国产精品毛片久久久久久久
欧美日韩精品一区二区在线播放
国产一级一片免费播放放a 免费国产视频
触手繁殖の地狱3d啪啪
av网站免费在线观看
国产精品理论片
狠狠操综合
a级片在线观看
免费人成
亚洲一区三区
www.久
久久亚洲国产
婷婷狠狠
国产精品午夜视频
亚洲美女一区
国产成人精品av在线观
国产日韩欧美日韩大片
激情网五月天
一区二区中文
亚洲在线视频
激情小说在线视频
国产福利在线观看
国产香蕉av
婷婷久久综合
欧美日韩国产三级
国产全肉乱妇杂乱视频
四虎影
免费午夜视频
一级做a爱片性色毛片
亚洲精品少妇
国产一级在线视频
在线中文字幕视频
色哟哟av
黄网站免费观看
天天操天
国产呦小j女精品视频
日韩精品在线免费观看
亚洲天堂一区二区三区
