標題: 求助stc8051U 定時器t0不工作,pwm也沒工作 [打印本頁]
作者: mhb7231    時間: 2025-1-24 11:23
/*根據電池容量的mAh,可以計算電池的持續放電時間的電流數去確定電池的容量。
以下用了一個STC12C5608AD去做檢測電池放電400mA的時間,再以公式400mA*時間=mAh
#include "stc8051U.h"
#include "intrins.h"
#define uchar unsigned char
#define uint unsigned int
#define ulong unsigned long
#define ADCTIM  (*(unsigned char volatile xdata *)0xfea8)
#define VREFH_ADDR CHIPID7
#define VREFL_ADDR CHIPID8
uint BGV;                                       //內部1.19V參考信號源值存放在idata中
typedef unsigned char BYTE;
uchar time1,time2,time3,pwm1;
uint fen=0,ad1=138,ad0;
sbit LED = P3^6;  //背光腳H亮
sbit rw = P2^5;
sbit  rs = P2^6;  //
sbit  en = P2^7;  //
sbit cs1 = P3^2;
sbit cs2 = P3^3;
sbit rst = P3^4;
sbit SPK = P3^5;  //蜂鳴器
sbit POW = P3^7;  //PWM
void InitADC();
uint GetADCResult(BYTE ch);
void Delayus(uint us);
void Delay(uchar  ms);
void lcdstate();
void write_command(uchar  command);
void   write_data(uchar  datas);
void   lcdinit();
void clearScreen();
void init();
void Timer0Init(void);
void dyADC();
void hz_display16(unsigned char pag, unsigned char col, unsigned char code *hzk);
unsigned char code    SZ[][16]=
{/*--  文字:  0  --*/
/*--  楷體_GB231212;  此字體下對應的點陣為:寬x高=8x16   --*/
0x00,0x00,0xF0,0x08,0x08,0x18,0xE0,0x00,0x00,0x00,0x0F,0x10,0x20,0x10,0x0F,0x00,
/*--  文字:  1  --*/
0x00,0x00,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0x10,0x00,0x00,0x00,
/*--  文字:  2  --*/
0x00,0x30,0x08,0x08,0x08,0xF8,0x00,0x00,0x00,0x00,0x18,0x14,0x13,0x10,0x08,0x00,
/*--  文字:  3  --*/
0x00,0x00,0x10,0x08,0x88,0x78,0x00,0x00,0x00,0x00,0x10,0x20,0x20,0x11,0x0E,0x00,
/*--  文字:  4  --*/
0x00,0x00,0xC0,0x20,0x10,0xF8,0x00,0x00,0x00,0x03,0x02,0x02,0x02,0x1F,0x02,0x00,
/*--  文字:  5  --*/
0x00,0x00,0x70,0x48,0xC8,0x88,0x00,0x00,0x00,0x10,0x10,0x20,0x10,0x0F,0x00,0x00,
/*--  文字:  6  --*/
0x00,0x00,0xE0,0x90,0x88,0x80,0x00,0x00,0x00,0x07,0x18,0x20,0x20,0x19,0x06,0x00,
/*--  文字:  7  --*/
0x00,0x10,0x08,0x08,0x88,0x78,0x00,0x00,0x00,0x00,0x00,0x18,0x07,0x00,0x00,0x00,
/*--  文字:  8  --*/
0x00,0x00,0x78,0x88,0x88,0x78,0x00,0x00,0x00,0x0C,0x12,0x21,0x21,0x1E,0x00,0x00,
/*--  文字:  9  --*/
0x00,0x60,0x98,0x08,0x08,0xF8,0xC0,0x00,0x00,0x00,0x21,0x12,0x09,0x07,0x00,0x00,
/*--  文字:  :  --*/
0x00,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0xC,0xC,0x00,0x00,0x00,0x00,0x00,
/*--  文字:  B  --*/
/*--  宋體12;  此字體下對應的點陣為:寬x高=8x16   --*/
0x08,0xF8,0x88,0x88,0x88,0x70,0x00,0x00,0x20,0x3F,0x20,0x20,0x20,0x11,0x0E,0x00,
/*--  文字:  a  --*/
0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x19,0x24,0x22,0x22,0x22,0x3F,0x20,
/*--  文字:  t  --*/
0x00,0x80,0x80,0xE0,0x80,0x80,0x00,0x00,0x00,0x00,0x00,0x1F,0x20,0x20,0x00,0x00,
/*--  文字:  T  --*/
0x18,0x08,0x08,0xF8,0x08,0x08,0x18,0x00,0x00,0x00,0x20,0x3F,0x20,0x00,0x00,0x00,
/*--  文字:  i  --*/
0x00,0x80,0x98,0x98,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,
/*--  文字:  m  --*/
0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x00,0x20,0x3F,0x20,0x00,0x3F,0x20,0x00,0x3F,
/*--  文字:  e  --*/
0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x1F,0x22,0x22,0x22,0x22,0x13,0x00,
/*--  文字:  V  --*/
0x08,0x78,0x88,0x00,0x00,0xC8,0x38,0x08,0x00,0x00,0x07,0x38,0x0E,0x01,0x00,0x00,
/*--  文字:  A  --*/
0x00,0x00,0xC0,0x38,0xE0,0x00,0x00,0x00,0x20,0x3C,0x23,0x02,0x02,0x27,0x38,0x20,
/*--  文字:  h  --*/
0x08,0xF8,0x00,0x80,0x80,0x80,0x00,0x00,0x20,0x3F,0x21,0x00,0x00,0x20,0x3F,0x20,
/*--  文字:  一  --*/
/*--  宋體12;  此字體下對應的點陣為:寬x高=16x16   --*/
0x00,0x00,0x0,0x0,0x0,0x0,0x00,0x00,0x00,0x20,0x20,0x20,0x20,0x20,0x20,0x00,
/*--  文字: .  --*/
0x00,0x0,0x0,0x00,0x00,0x00,0x00,0x00,0x00,0xC,0x0,0x00,0x00,0x00,0x00,0x00,
讀取ADC結果
uint GetADCResult(BYTE channel)
    ADC_RES = 0;
    ADC_RESL = 0;
  ADC_CONTR = (ADC_CONTR & 0xF0) | 0x40 | channel;    //啟動 AD 轉換
    _nop_();                        //等待4個NOP
    _nop_();
    _nop_();
    _nop_();
    while (!(ADC_CONTR & 0x20));                //查詢ADC完成標志
    ADC_CONTR &= ~0x20;
        return (((int)ADC_RES << 8) | ADC_RESL);        //adc_data*4的意思是左移兩位,4 = 2的2次方。
                                    //然后左移后加上adc_low的值,這個值應該是adc轉換的低兩位。
初始化ADC
void InitADC()
    P_SW2 |= 0x80;                   //擴展 RAM 區特殊功能寄存器(XFR)訪問控制寄存器
    ADCTIM = 0x3f;                              //ADC時序控制寄存器3f=00111111
    P_SW2 &= 0x7f;
    ADCCFG = 0x2f;                              //設置ADC時鐘為系統時鐘/2/16
    ADC_CONTR = 0x80;                           //使能ADC模塊,并選擇第15通道 8f=10001111                       //ADC上電并延時
void    lcdstate()  //讀狀態指令
uchar  lcd=0x00; /*設置初值為0,全部為低,方便后面的判忙*/
rs=0; /*根據時序圖拉低,選擇寫指令*/
rw=1; /*根據時序圖拉低,選擇寫模式*/
do
en=1; /*使能,使液晶輸出信號,檢查是否忙*/
_nop_();_nop_();_nop_();_nop_();/*延時4US*/
lcd=P0; /*把P0口的狀態值讀回來給lcd*/
en=0; /*使能端跳變*/;
}while(lcd&0x80); /*結果的高位保留,如果高位DB7為一,則表示忙*/
void Delayus(uint us)                //@12.000MHz
   while(--us)
                _nop_();
                _nop_();
                _nop_();
                _nop_();
void delay(uchar  ms)
{ uchar   i;
   uchar   j;
  for(i=0;i<100;i++)
   for(j=0;j<ms;j++);
lcdstate();
  rs=0;                                //RS=0;為往MCU進行指令操作
  rw=0;                                //RW=0;為往MCU寫入操作
  en=0;
  en=1;
  P0=command;
  en=0;
   lcdstate();
   rs=1;
   rw=0;
   en=0;
   en=1;
   P0=datas;
   en=0;
void   lcdinit()
    delay(100);                                         //
    cs1=1;
        cs2=1;
        delay(100);
        lcdstate();                                 //
        write_command(0x3e);                 //
        write_command(0xb8+0);                         //
        write_command(0xc0+0);                 //
        write_command(0x40+0);                 //
        write_command(0x3f);
void clearScreen(  )
{   uchar i,j;
    lcdstate();
    cs1=1;
        cs2=1;
        write_command(0x3f);                        //設置顯示開
        write_command(0xb8);                    //Y        設置第0頁;
        write_command(0x40);                         //        設置第0列
   for(i=0;i<8;i++)
     write_command(0xb8+i);
     for(j=0;j<64;j++)
           //write_command(0x40+j);
       write_data(0x00);
void Timer0Init(void)                //2毫秒@12.000MHz
        AUXR &= 0x7F;                //定時器時鐘12T模式
        TMOD &= 0xF0;                //設置定時器模式
        TMOD |= 0x01;                //設置定時器模式
        TL0 = 0x30;                //設置定時初值
        TH0 = 0xF8;                //設置定時初值
        TF0 = 0;                //清除TF0標志
        TR0 = 0;                //定時器0開始計時
void Timer1Init(void)                //5毫秒@12.000MHz
        AUXR &= 0xBF;                //定時器時鐘12T模式
        TMOD &= 0x0F;                //設置定時器模式
        TMOD |= 0x10;                //設置定時器模式
        TL1 = 0x78;                //設置定時初值
        TH1 = 0xEC;                //設置定時初值
        TF1 = 0;                //清除TF1標志
        TR1 = 1;                //定時器1開始計時
void hz_display8(unsigned char pag, unsigned char col, unsigned char  zi)
        uchar j=0;
        uchar i=0;
        for(j=0;j<2;j++)                          //這里寫四頁
                write_command(0xb8+pag+j);          //page在這里就是從page表示的這頁開始寫起。
                write_command(0x40+col);          //從列為col表示的列開始
                for(i=0;i<8;i++)                           //這里寫32列
                write_data(SZ[zi][8*j+i]);        //J為頁,I,為第J行第I個數
void dyADC()
int res,ad1;
int xes;
GetADCResult(15);
GetADCResult(15);
res=GetADCResult(15);//讀內部基準ADC, 讀15通道
GetADCResult(0);
GetADCResult(0);
xes=GetADCResult(0);//讀p1.1外部電壓ADC
ad1=(int)((long)xes* BGV / res);  //計算p5.5外部電壓, vcc為1.19V,
ad0=ad1/10;
   bit q1=0,q2=0,q3=0;
    uchar k1;
    ulong ww=1667;
    P_SW2 = 0X80; //使能訪問 XFR,沒有沖突不用關閉
    CKCON = 0x00; //設置外部數據總線速度為最快
    WTST = 0x00;
    P0M0 = 0x00;       //00上拉準雙向口/10浮空輸入
    P0M1 = 0x00;       //11開漏輸出/01推挽輸出
    P1M0 = 0x00;
    P1M1 = 0x01;    //設置P1.0為ADC
    P2M0 = 0x00;
    P2M1 = 0x00;
    P3M0 = 0x00;       //00上拉準雙向口/10浮空輸入
    P3M1 = 0x00;       //11開漏輸出/01推挽輸出
    P4M0 = 0x00;
    P4M1 = 0x00;
    P5M0 = 0x00;
    P5M1 = 0x00;
BGV = (VREFH_ADDR << 8) + VREFL_ADDR; //從 CHIPID 中讀取內部參考電壓值
        POW=0;
        SPK=0;
      lcdinit();
       clearScreen();
        InitADC();
        Timer0Init();
        Timer1Init();
        TR0 = 1;                        //timer0 start running
    ET0 = 1;                        //enable timer0 interrupt
   // TR1 = 1;                        //timer1 start running
   // ET1 = 1;                        //enable timer1 interrupt
    EA = 1;                         //open global interrupt switch
        for(k1=255;k1>0;k1--)
                   SPK=~SPK;
                Delayus(k1);
           SPK=0;
    cs1=1;
    cs2=0;
hz_display8(0,0,11); //Batt:
hz_display8(0,8,12);
hz_display8(0,16,13);
hz_display8(0,24,13);
hz_display8(0,32,10);
hz_display8(6,0,14);  //time:
hz_display8(6,8,15);
hz_display8(6,16,16);
hz_display8(6,24,17);
hz_display8(6,32,10);
   if(EA==1)
                 cs1=1;
            cs2=0;
            hz_display8(6,40,(time3%100/10));  //時
            hz_display8(6,48,(time3%10/1));
            hz_display8(6,56,10);  //:
                  cs1=0;
            cs2=1;
            hz_display8(6,0,(time2%100/10));  //分
            hz_display8(6,8,(time2%10/1));
            hz_display8(6,16,10);  //:
            hz_display8(6,24,(time1%100/10));  //秒
            hz_display8(6,32,(time1%10/1));
          if(q1==0&time1==2)
              dyADC();
              cs1=1;
              cs2=0;
                   hz_display8(0,40,(ad0/100));
                   hz_display8(0,48,22);
                   hz_display8(0,56,(ad0%100/10));
              cs1=0;
              cs2=1;
                   hz_display8(0,0,(ad0%10));
                   hz_display8(0,8,18);  //v
               q1=1;
                                   for(k1=0;k1<255;k1++)
                                         SPK=~SPK;
                                         Delayus(150);
                                   Delay(100);
                                          SPK=~SPK;
                                          Delayus(150);
                    SPK=0;
                    CCON = 0;                       //PCA控制寄存器CCON
        //PCA timer stop running
                                                               //Clear CF flag
        //Clear all module interrupt flag
                     CL = 0;                         //PCA的16位計數器 — 低8位CL和高8位CH
                     CH = 0;
                     CMOD = 0x08;                    //工作模式寄存器CMOD
        //Disable PCA timer overflow interrupt
                     CCAP1H = CCAP1L = 0xFF;         //模塊0的捕捉/比較寄存器用來控制輸出的占?比
                     CCAPM1 = 0x42;                  //PCA比較/捕獲寄存器CCAPMn (n=0,1,2,3) PCA interrupt
                     PCA_PWM1 = 0x40;
                     CCON |= CR;                         //PCA計數器陣列, 運行控制位
                      TR1 = 1;
                      ET1 = 1;
          dyADC();
           cs1=0;
           cs2=1;
           hz_display8(0,16,(ad0/100));
           hz_display8(0,24,22);
           hz_display8(0,32,(ad0%100/10));
           hz_display8(0,40,(ad0%10));
           hz_display8(0,48,18);  //v
            if(fen>=1)LED=0;
            if(ad0<=286)q3=1;
                            while(q3==1)
                                 for(k1=0;k1<100;k1++)
                                        SPK=~SPK;
                                        Delayus(110);
                                       SPK=0;
                                       LED=~LED;
                                       POW=0;
                                       EA=0;
                                       Delay(500);
        dyADC();
                                     //  ad0=GetADCResult(0);
                                                       cs1=0;
                                        cs2=1;
                                                            hz_display8(0,16,(ad0%1000/100));
                                                            hz_display8(0,24,10);
                                                            hz_display8(0,16,(ad0%100/10));
                                                            hz_display8(0,16,(ad0%10/1));
                                                            hz_display8(0,24,18);  //v
                                                if(!q2)
                                                   ww*=fen;
                                                   ww*=4;
                                                         cs1=1;
                                                   cs2=2;
                                                   hz_display8(6,0,21);  //-------
        hz_display8(6,8,21);
        hz_display8(6,16,21);
        hz_display8(6,24,21);
        hz_display8(6,32,21);
        hz_display8(6,40,21);
        hz_display8(6,48,21);
        hz_display8(6,56,21);
        cs1=0;
        cs2=1;
        hz_display8(6,0,(ww%100000000/10000000));
        hz_display8(6,8,(ww%10000000/1000000));
        hz_display8(6,16,(ww%1000000/100000));
        hz_display8(6,24,(ww%100000/10000));
        hz_display8(6,32,(ww%10000/1000));
        hz_display8(6,40,16);  //mah
        hz_display8(6,48,19);
        hz_display8(6,56,20);
        Delay(1000);
        q2=1;
void tm0_isr() interrupt 1 using 1
  static uchar i1,i2;
        i1++;
  if(i1>=50)
    i1=0;
    i2++;
    if(i2>=10)
             i2=0;
             time1++;
            if(time1>=60)
                     time1=0;
                     time2++;
                     fen++;
     if(time2>=60)
               time2=0;
                   time3++;
                   if(time3>=24)time3=0;
void tm1_isr() interrupt 3 using 1
        if(ad0>=428)CCAP1H = CCAP1L = 142;    //模塊0的捕捉/比較寄存器用來控制輸出的占?比
        if(ad0<=427&&ad0>424)CCAP1H = CCAP1L = 142;
        if(ad0<=424&&ad0>420)CCAP1H = CCAP1L = 141;
        if(ad0<=420&&ad0>416)CCAP1H = CCAP1L = 140;
        if(ad0<=416&&ad0>412)CCAP1H = CCAP1L = 139;
        if(ad0<=412&&ad0>408)CCAP1H = CCAP1L = 138;
        if(ad0<=408&&ad0>404)CCAP1H = CCAP1L = 137;
        if(ad0<=404&&ad0>400)CCAP1H = CCAP1L = 136;
        if(ad0<=400&&ad0>396)CCAP1H = CCAP1L = 135;
        if(ad0<=396&&ad0>392)CCAP1H = CCAP1L = 134;
        if(ad0<=392&&ad0>388)CCAP1H = CCAP1L = 132;//
        if(ad0<=388&&ad0>384)CCAP1H = CCAP1L = 131;
        if(ad0<=384&&ad0>380)CCAP1H = CCAP1L = 129;
        if(ad0<=380&&ad0>376)CCAP1H = CCAP1L = 128;
        if(ad0<=376&&ad0>372)CCAP1H = CCAP1L = 127;
        if(ad0<=372&&ad0>368)CCAP1H = CCAP1L = 126;//
        if(ad0<=368&&ad0>364)CCAP1H = CCAP1L = 125;
        if(ad0<=364&&ad0>360)CCAP1H = CCAP1L = 123;
        if(ad0<=360&&ad0>356)CCAP1H = CCAP1L = 122;
        if(ad0<=356&&ad0>352)CCAP1H = CCAP1L = 120;
        if(ad0<=352&&ad0>348)CCAP1H = CCAP1L = 119;
        if(ad0<=348&&ad0>344)CCAP1H = CCAP1L = 117;
        if(ad0<=344&&ad0>340)CCAP1H = CCAP1L = 116;
        if(ad0<=340&&ad0>336)CCAP1H = CCAP1L = 114;
        if(ad0<=336&&ad0>332)CCAP1H = CCAP1L = 113;
        if(ad0<=332&&ad0>328)CCAP1H = CCAP1L = 111;
        if(ad0<=328&&ad0>324)CCAP1H = CCAP1L = 109;
        if(ad0<=324&&ad0>320)CCAP1H = CCAP1L = 108;
        if(ad0<=320&&ad0>316)CCAP1H = CCAP1L = 106;
        if(ad0<=316&&ad0>312)CCAP1H = CCAP1L = 105;
        if(ad0<=312&&ad0>308)CCAP1H = CCAP1L = 103;
        if(ad0<=304&&ad0>300)CCAP1H = CCAP1L = 100;
        if(ad0<=300&&ad0>296)CCAP1H = CCAP1L = 98;
        if(ad0<=296&&ad0>292)CCAP1H = CCAP1L = 97;
        if(ad0<=292&&ad0>288)CCAP1H = CCAP1L = 94;
        if(ad0<=288&&ad0>284)CCAP1H = CCAP1L = 91;
        if(ad0<=284)CCAP1H = CCAP1L = 0xFF;
        //CCAPM0 = 0x42;*/
作者: lkc8210    時間: 2025-1-26 16:05
LCD有沒有顯示?
作者: mhb7231    時間: 2025-1-27 20:55
以下用了stc8051U去做檢測電池放電400mA的時間,再以公式400mA*時間=mAh
sbit LED1 = P1^7;
sbit rw = P2^5;
sbit  rs = P2^6;  //
sbit  en = P2^7;  //
sbit cs1 = P3^2;
sbit cs2 = P3^3;
sbit rst = P3^4;
void InitADC();
void lcdstate();
void   lcdinit();
void clearScreen();
void init();
void Timer1Init(void);
void dyADC();
{/*--  文字:  0  --*/
/*--  文字:  1  --*/
/*--  文字:  2  --*/
/*--  文字:  3  --*/
/*--  文字:  4  --*/
/*--  文字:  5  --*/
/*--  文字:  6  --*/
/*--  文字:  7  --*/
/*--  文字:  8  --*/
/*--  文字:  9  --*/
/*--  文字:  :  --*/
/*--  文字:  B  --*/
/*--  文字:  a  --*/
/*--  文字:  t  --*/
/*--  文字:  T  --*/
/*--  文字:  i  --*/
/*--  文字:  m  --*/
/*--  文字:  e  --*/
/*--  文字:  V  --*/
/*--  文字:  A  --*/
/*--  文字:  h  --*/
/*--  文字:  一  --*/
/*--  文字: .  --*/
讀取ADC結果
    ADC_RES = 0;
    ADC_RESL = 0;
    _nop_();                        //等待4個NOP
    _nop_();
    _nop_();
    _nop_();
    ADC_CONTR &= ~0x20;
初始化ADC
void InitADC()
    P_SW2 &= 0x7f;
do
en=0; /*使能端跳變*/;
   while(--us)
                _nop_();
                _nop_();
                _nop_();
                _nop_();
{ uchar   i;
   uchar   j;
  for(i=0;i<100;i++)
   for(j=0;j<ms;j++);
lcdstate();
  en=0;
  en=1;
  P0=command;
  en=0;
   lcdstate();
   rs=1;
   rw=0;
   en=0;
   en=1;
   P0=datas;
   en=0;
void   lcdinit()
    delay(100);                                         //
    cs1=1;
        cs2=1;
        delay(100);
        lcdstate();                                 //
void clearScreen(  )
{   uchar i,j;
    lcdstate();
    cs1=1;
        cs2=1;
   for(i=0;i<8;i++)
     for(j=0;j<64;j++)
       write_data(0x00);
void Timer0Init(void)                //2毫秒@12.000MHz   時間
        TF0 = 0;                //清除TF0標志
        TR0 = 0;                //定時器0開始計時
        TL0 = 0xB0;                                //設置定時初始值
        TH0 = 0x3C;                        //設置定時初值
        TF1 = 0;                //清除TF1標志
        TR1 = 0;                //定時器1開始計時
        uchar j=0;
        uchar i=0;
void dyADC()
int res,ad1;
int xes;
GetADCResult(15);
GetADCResult(15);
GetADCResult(0);
GetADCResult(0);
ad1=(int)((long)xes* BGV / res);  //計算p1.1外部電壓, vcc為1.19V,
ad0=ad1/10;
   bit q1=0,q2=0,q3=0;
  //  uchar k1;
    ulong ww=1667;
    WTST = 0x00;
    P1M0 = 0x00;
    P2M0 = 0x00;
    P2M1 = 0x00;
    P4M0 = 0x00;
    P4M1 = 0x00;
    P5M0 = 0x00;
    P5M1 = 0x00;
        POW=1;
        LED1=1;
        SPK=0;
      lcdinit();
       clearScreen();
        InitADC();
        Timer0Init();
        Timer1Init();
        TR0 = 1;                        //timer0  時間
    ET0 = 1;                        // 時間
    cs1=1;
    cs2=0;
   if(EA==1)
                 cs1=1;
            cs2=0;
                  cs1=0;
            cs2=1;
          if(q1==0&time1==2)  //q1=0 time1=2  才執行括號里的程序
              dyADC();
              cs1=1;
              cs2=0;
              cs1=0;
              cs2=1;
               q1=1;
                     CH = 0;
                    PCA_PWM1 = 0x40;                                                        //Disable PCA timer overflow interrupt
                     CCAP1H = CCAP1L = 0x01;         //模塊0的捕捉/比較寄存器用來控制輸出的占?比
                    // while(1);
        TR1 = 1;      // 時間
                      ET1 = 1;
          dyADC();
                                        //ad0=GetADCResult(0);
           cs1=0;
           cs2=1;
            if(fen>=1)LED=0;
            if(ad0<=286)q3=1;
                            while(q3==1)
                                       LED=~LED;
                                      // CCAP1H = CCAP1L = 0x00;
                                       POW=0;
                                       EA=0;
                                       Delay(500);
        Delay(500);
        Delay(500);
        Delay(500);
        Delay(500);
        Delay(500);
        Delay(500);
        Delay(500);
        Delay(500);
        dyADC();
                                                       cs1=0;
                                     cs2=1;
                                                if(!q2)
                                                   ww*=fen;
                                                   ww*=4;
                                                         cs1=1;
                                                   cs2=2;
        cs1=0;
        cs2=1;
        Delay(1000);
        q2=1;
  static uchar i1,i2;
        TL0 = 0x30;                //設置定時初值  2ms
        i1++;
  if(i1>=50)
    i1=0;
    i2++;
    if(i2>=10)
             i2=0;
             time1++;
            if(time1>=60)
                     time1=0;
                     time2++;
                     fen++;
     if(time2>=60)
               time2=0;
                   time3++;
//dyADC();
//dyADC();
作者: mhb7231    時間: 2025-1-27 20:59
運行時間和檢測電壓都正常,就是PMW不正常無輸出,把ADC關掉PMW有輸出
作者: 太陽雨ZW    時間: 2025-1-28 11:09
mhb7231 發表于 2025-1-27 20:59
這里的TL0,TH0改為TL1,TH1試試
作者: 太陽雨ZW    時間: 2025-1-28 11:27
還有這里的初始化,TL0,TH0改為TL1,TH1
作者: mhb7231    時間: 2025-1-30 02:35
TL0,TH0改為TL1,TH1,還是不行,
主站蜘蛛池模板: 午夜影院中文字幕 | 可以免费观看的av片 | 精品成人在线观看 | 亚洲在线 | 日韩乱码av | 国产视频久久久 | 日韩精品一区二区三区在线播放 | 国产精品免费一区二区三区 | 涩涩导航| 日本一区二区三区在线观看 | 欧美日韩精品一区二区三区四区 | 羞羞视频网站免费看 | av一区二区三区四区 | 亚洲国产精品99久久久久久久久 | 亚洲一级视频在线 | 免费久久精品视频 | 精品一二区 | 成人永久免费视频 | 一区二区视频在线 | 成人夜晚看av | 亚洲精品电影网在线观看 | 国产三级大片 | 日韩av成人在线观看 | 日韩成人性视频 | 午夜无码国产理论在线 | 99精品在线| 天天操夜夜操 | 午夜合集 | 午夜久久av | 91精品国产乱码久久久久久久久 | 午夜影院在线观看 | 91中文视频| 成人精品一区二区三区中文字幕 | 亚洲协和影视 | 97伊人| 国产精品久久片 | 久久伊人久久 | 亚洲精品国产成人 | 欧美久久久 | 免费国产网站 | 日本三级精品 |
