用C語言編寫的10個通用RGB燈效算法
zenghl
2025-2-16 10:51
用C語言編寫的10個通用RGB燈效算法
以下是用C語言編寫的10個通用RGB燈效算法,適用于大多數RGB LED控制場景(非硬件特定版本)。每個算法都包含可調節參數,代碼設計為獨立函數形式,便于集成到不同項目中:
```c
#include <stdint.h>
#include <math.h>
// 顏色結構體(通用RGB格式)
typedef struct {
uint8_t r;
uint8_t g;
uint8_t b;
} RGBColor;
// 1. 呼吸燈效果(單色)
void breathEffect(RGBColor* leds, int numLeds, uint8_t* phase, uint8_t speed, RGBColor color) {
static uint8_t brightness = 0;
static int8_t direction = 1;
brightness += direction * speed;
if(brightness >= 255 - speed) direction = -1;
if(brightness <= speed) direction = 1;
for(int i=0; i<numLeds; i++) {
leds[i].r = (color.r * brightness) >> 8;
leds[i].g = (color.g * brightness) >> 8;
leds[i].b = (color.b * brightness) >> 8;
// 2. 彩虹波浪效果
void rainbowWave(RGBColor* leds, int numLeds, uint8_t* phase, uint8_t speed) {
*phase += speed;
uint8_t hue = *phase + (i * 255 / numLeds);
hsv2rgb(hue, 255, 255, &leds[i].r, &leds[i].g, &leds[i].b);
// 3. 跑馬燈效果(可調寬度)
void runningDot(RGBColor* leds, int numLeds, uint8_t* position, uint8_t speed, uint8_t width, RGBColor color) {
*position = (*position + speed) % numLeds;
uint8_t distance = abs((int)(*position) - i);
if(distance > width) {
leds[i] = (RGBColor){0,0,0};
} else {
uint8_t intensity = 255 - (distance * 255 / width);
leds[i].r = (color.r * intensity) >> 8;
leds[i].g = (color.g * intensity) >> 8;
leds[i].b = (color.b * intensity) >> 8;
// 4. 顏色漸變過渡
void colorTransition(RGBColor* leds, int numLeds, uint8_t* phase,
RGBColor start, RGBColor end, uint8_t step) {
*phase = (*phase + step) % 255;
leds[i].r = start.r + ((end.r - start.r) * *phase) / 255;
leds[i].g = start.g + ((end.g - start.g) * *phase) / 255;
leds[i].b = start.b + ((end.b - start.b) * *phase) / 255;
// 5. 隨機流星效果
void meteorShower(RGBColor* leds, int numLeds, uint8_t* pos, uint8_t speed,
uint8_t tailLength, RGBColor color) {
static uint8_t trail[64] = {0}; // 最大支持64長度拖尾
// 移動流星位置
*pos = (*pos + speed) % (numLeds + tailLength);
// 生成拖尾數據
for(int i=0; i<tailLength; i++) {
trail[i] = (255 * (tailLength - i)) / tailLength;
// 應用效果
int trailIndex = i - (*pos - tailLength);
if(trailIndex >=0 && trailIndex < tailLength) {
uint8_t intensity = trail[trailIndex];
} else {
// 6. 音頻頻譜風格效果
void spectrumAnalyzer(RGBColor* leds, int numLeds, uint8_t* heights,
uint8_t decay, RGBColor color) {
// 模擬隨機輸入數據(實際使用時替換為真實音頻數據)
if(rand()%20 == 0 && heights[i] < 240) heights[i] += 15;
// 高度衰減
if(heights[i] > decay) heights[i] -= decay;
else heights[i] = 0;
// 繪制柱狀圖
leds[i].r = (i < heights[i]/10) ? color.r : 0;
leds[i].g = (i < heights[i]/10) ? color.g : 0;
leds[i].b = (i < heights[i]/10) ? color.b : 0;
// 7. 火焰模擬效果
void fireEffect(RGBColor* leds, int numLeds, uint8_t* heat, uint8_t cooling, uint8_t sparking) {
// 生成隨機火花
if(rand()%255 < sparking) {
heat[i] = 255;
// 熱量擴散
for(int i=numLeds-1; i>=2; i--) {
heat[i] = (heat[i-1] + heat[i-2] + heat[i-2])/3;
// 應用顏色映射
uint8_t temp = heat[i];
leds[i].r = temp;
leds[i].g = temp/3;
leds[i].b = temp/10;
// 冷卻
if(heat[i] >= cooling) heat[i] -= cooling;
else heat[i] = 0;
// 8. 雙色交替掃描
void dualScan(RGBColor* leds, int numLeds, uint8_t* phase, uint8_t speed,
RGBColor color1, RGBColor color2) {
static uint8_t direction = 0;
*phase += speed;
if(*phase >= numLeds) {
*phase = 0;
direction = !direction;
if((direction && (i < *phase)) || (!direction && (i >= numLeds - *phase))) {
leds[i] = color1;
} else {
leds[i] = color2;
// 9. 星光閃爍效果
void starTwinkle(RGBColor* leds, int numLeds, uint8_t* states, uint8_t fadeSpeed) {
if(states[i] == 0 && rand()%1000 == 0) {
states[i] = 255; // 隨機點亮
if(states[i] > 0) {
leds[i].r = states[i];
leds[i].g = states[i];
leds[i].b = states[i];
if(states[i] > fadeSpeed) states[i] -= fadeSpeed;
else states[i] = 0;
} else {
// 10. 三維立方體效果
void cubeEffect(RGBColor* leds, int numLeds, uint8_t* angle, uint8_t speed,
RGBColor color) {
// 假設LED排列為8x8x8立方體(需要根據實際布局修改坐標計算)
static const uint8_t cubeSize = 8;
*angle += speed;
for(int x=0; x<cubeSize; x++) {
for(int y=0; y<cubeSize; y++) {
for(int z=0; z<cubeSize; z++) {
int index = x + y*cubeSize + z*cubeSize*cubeSize;
uint8_t intensity =
(sin8(x*32 + *angle) +
sin8(y*32 + *angle/2) +
sin8(z*32 + *angle/3)) / 3;
leds[index].r = (color.r * intensity) >> 8;
leds[index].g = (color.g * intensity) >> 8;
leds[index].b = (color.b * intensity) >> 8;
// HSV轉RGB輔助函數(優化整數版本)
void hsv2rgb(uint8_t hue, uint8_t sat, uint8_t val,
uint8_t* r, uint8_t* g, uint8_t* b) {
uint8_t region, remainder;
uint8_t p, q, t;
if(sat == 0) {
*r = *g = *b = val;
return;
region = hue / 43;
remainder = (hue - (region * 43)) * 6;
p = (val * (255 - sat)) >> 8;
q = (val * (255 - ((sat * remainder) >> 8))) >> 8;
t = (val * (255 - ((sat * (255 - remainder)) >> 8))) >> 8;
switch(region) {
case 0: *r = val; *g = t; *b = p; break;
case 1: *r = q; *g = val; *b = p; break;
case 2: *r = p; *g = val; *b = t; break;
case 3: *r = p; *g = q; *b = val; break;
case 4: *r = t; *g = p; *b = val; break;
default: *r = val; *g = p; *b = q; break;
// 正弦查表函數(0-255輸入,0-255輸出)
uint8_t sin8(uint8_t theta) {
static const uint8_t sineTable[] = {
128, 140, 152, 165, 176, 188, 199, 209, 219, 228, 236, 243, 249, 254,
255, 254, 249, 243, 236, 228, 219, 209, 199, 188, 176, 165, 152, 140,
128, 115, 103, 90, 79, 67, 56, 46, 36, 27, 19, 12, 6, 1, 0, 1, 6, 12,
19, 27, 36, 46, 56, 67, 79, 90, 103, 115
return sineTable[theta % 64];
### 使用說明:
1. **數據結構**:
- 使用`RGBColor`結構體存儲顏色值
- LED數組按順序排列,長度由`numLeds`參數指定
2. **狀態管理**:
- 帶`*phase`參數的效果需要調用者維護狀態變量
- 多LED效果(如流星、火焰)需要預先分配狀態數組
3. **性能優化**:
- 使用查表法實現三角函數(`sin8`)
- 全部使用整數運算,避免浮點計算
- 可調節的speed參數控制動畫速度
4. **典型調用方式**:
```c
int main() {
const int NUM_LEDS = 64;
RGBColor leds[NUM_LEDS];
// 狀態變量
uint8_t phase = 0;
uint8_t meteorPos = 0;
uint8_t fireHeat[NUM_LEDS] = {0};
uint8_t starStates[NUM_LEDS] = {0};
while(1) {
// 選擇要運行的效果(示例)
fireEffect(leds, NUM_LEDS, fireHeat, 30, 100);
// rainbowWave(leds, NUM_LEDS, &phase, 3);
// meteorShower(leds, NUM_LEDS, &meteorPos, 2, 10, (RGBColor){255,0,0});
// 此處插入實際硬件更新代碼
// ws2812_update(leds, NUM_LEDS);
delay_ms(30);
### 擴展建議:
1. **顏色混合**:添加顏色混合函數實現更復雜效果
2. **參數動態調整**:通過外部輸入(旋鈕、傳感器等)實時控制參數
3. **效果組合**:使用多層混合實現組合效果
4. **內存優化**:對于資源受限系統,可減少狀態變量數量
5. **時間同步**:使用定時器中斷確保穩定的刷新率
這些算法經過模塊化設計,可根據具體硬件平臺輕松適配,適合從Arduino到嵌入式Linux系統的各種應用場景。
keemee
2025-2-17 03:34
請問流星效果,跟落雪是一樣的嗎?
wkman
2025-2-17 11:48
各種視覺效果,都是數學問題,哈哈
Lang2i
2025-2-17 15:19
<H1>可以</H1>
WFX777888
2025-2-18 07:13
謝謝分享資料
hbsuntt
2025-3-6 09:43
謝謝分享,學習
qzyhlf
2025-3-7 07:35
各種視覺效果,都是數學問題,哈哈
亚洲一区二区三区视频
91视频精品
狠狠操夜夜操
www.精品国产
中文字幕理伦片免费看
欧美一区二区三区的
视频在线一区
懂色av懂色av粉嫩av
久久免费福利视频
高潮毛片无遮挡免费看
国产精品免费一区二区三区
黄色小视频在线
日本特级黄色片
四虎影视在线播放
www.4hu95.com四虎 丰满岳乱妇一区二区
亚洲二级片
国产日韩在线播放
天堂网久久
天天摸天天操
欧美成年人视频
丁香婷婷六月天
精品久久久久久久
国产三级免费观看
日韩小视频
亚洲精品影院
亚洲精品国产精品国自产观看
国产亚洲欧美日韩高清
免费毛片网
日韩一级片
中国免费毛片
欧美一区二区三区的
成人福利视频在线观看
黄色资源在线观看
伊人9999
日韩精品不卡
黄色片网站在线观看
亚洲激情综合网
日韩视频一区二区
少妇xxxx69
日本精品久久
亚洲va视频
