單片機心率程序為什么沒有數據啊?就大神解答一下
零點一
2025-4-11 16:07
#include <reg52.h>
#include <intrins.h>
#include <stdio.h>
#define uint unsigned int
#define uchar unsigned char
// 定義心率引腳
sbit SCL = P3^3;
sbit SDA = P3^4;
sbit INT = P3^2;
// 定義MAX30102的I2C地址
#define MAX30102_ADDR 0xAE
// 定義 MAX30102 寄存器地址
#define REG_INTR_STATUS_1 0x00
#define REG_INTR_STATUS_2 0x01
#define REG_INTR_ENABLE_1 0x02
#define REG_INTR_ENABLE_2 0x03
#define REG_FIFO_WR_PTR 0x04
#define REG_OVF_COUNTER 0x05
#define REG_FIFO_RD_PTR 0x06
#define REG_FIFO_DATA 0x07
#define REG_FIFO_CONFIG 0x08
#define REG_MODE_CONFIG 0x09
#define REG_SPO2_CONFIG 0x0A
#define REG_LED1_PA 0x0C
#define REG_LED2_PA 0x0D
#define REG_PILOT_PA 0x10
#define REG_MULTI_LED_CTRL1 0x11
#define REG_MULTI_LED_CTRL2 0x12
#define REG_TEMP_INTR 0x1F
#define REG_TEMP_FRAC 0x20
#define REG_TEMP_CONFIG 0x21
#define REG_PROX_INT_THRESH 0x30
#define REG_REV_ID 0xFE
#define REG_PART_ID 0xFF
// 全局變量用于心率計算
unsigned int pulse_count = 0;
unsigned int prev_pulse_count = 0;
unsigned int heart_rate = 0;
uint count; // 計數
bit flag_1s = 0;
unsigned int one_second_count = 0;
// 微秒級延時函數
void delay(uint t) // @12T 1us
while (t--);
// I2C起始信號
void I2C_Start() {
SDA = 1;
SCL = 1;
delay(1);
SDA = 0;
delay(1);
SCL = 0;
// I2C停止信號
void I2C_Stop() {
SDA = 0;
SCL = 1;
delay(1);
SDA = 1;
delay(1);
// I2C發送一個字節
void I2C_SendByte(unsigned char dat) {
unsigned char i;
for (i = 0; i < 8; i++) {
SDA = (dat & 0x80) >> 7;
dat <<= 1;
SCL = 1;
delay(1);
SCL = 0;
delay(1);
// I2C接收一個字節
unsigned char I2C_ReceiveByte() {
unsigned char i, dat = 0;
SDA = 1;
SCL = 1;
dat <<= 1;
if (SDA) dat |= 0x01;
SCL = 0;
delay(1);
return dat;
// I2C發送應答信號
void I2C_SendAck(bit ack) {
SDA = ack;
SCL = 1;
delay(1);
SCL = 0;
delay(1);
// I2C接收應答信號
bit I2C_ReceiveAck() {
bit ack;
SDA = 1;
SCL = 1;
ack = SDA;
SCL = 0;
delay(1);
return ack;
// 向MAX30102寫一個字節數據
bit MAX30102_WriteByte(unsigned char reg, unsigned char dat) {
I2C_Start();
I2C_SendByte(MAX30102_ADDR & 0xFE); // 寫地址
if (I2C_ReceiveAck()) {
I2C_Stop();
return 0;
I2C_SendByte(reg);
I2C_Stop();
return 0;
I2C_SendByte(dat);
I2C_Stop();
return 0;
I2C_Stop();
return 1;
// 從MAX30102讀一個字節數據
bit MAX30102_ReadByte(unsigned char reg, unsigned char *dat) {
I2C_Start();
I2C_Stop();
return 0;
I2C_SendByte(reg);
I2C_Stop();
return 0;
I2C_Start();
I2C_SendByte(MAX30102_ADDR | 0x01); // 讀地址
I2C_Stop();
return 0;
*dat = I2C_ReceiveByte();
I2C_SendAck(1); // 非應答
I2C_Stop();
return 1;
// 初始化MAX30102
bit MAX30102_Init() {
unsigned char reg_val;
if (!MAX30102_WriteByte(REG_MODE_CONFIG, 0x40)) return 0; // 復位 MAX30102
do {
if (!MAX30102_ReadByte(REG_MODE_CONFIG, ®_val)) return 0;
} while (reg_val & 0x40);
if (!MAX30102_WriteByte(REG_FIFO_CONFIG, 0x00)) return 0; // 設置 FIFO 配置
if (!MAX30102_WriteByte(REG_MODE_CONFIG, 0x02)) return 0; // 設置模式配置為心率模式
if (!MAX30102_WriteByte(REG_SPO2_CONFIG, 0x27)) return 0; // 設置 SpO2 配置
if (!MAX30102_WriteByte(REG_LED1_PA, 0x2F)) return 0; // 設置 LED 強度
if (!MAX30102_WriteByte(REG_LED2_PA, 0x2F)) return 0;
return 1;
// 讀取 FIFO 數據
bit MAX30102_ReadFIFO(unsigned long *data) {
unsigned char byte1, byte2, byte3;
if (!MAX30102_ReadByte(REG_FIFO_DATA, &byte1)) return 0;
if (!MAX30102_ReadByte(REG_FIFO_DATA, &byte2)) return 0;
if (!MAX30102_ReadByte(REG_FIFO_DATA, &byte3)) return 0;
*data = ((unsigned long)byte1 << 16) | ((unsigned long)byte2 << 8) | (unsigned long)byte3;
return 1;
// 簡單的心率計算
int calculateHeartRate(unsigned long *data, int size) {
int peaks = 0;
int i;
for (i = 1; i < size - 1; i++) {
if (data[i] > data[i - 1] && data[i] > data[i + 1]) {
peaks++;
// 簡單估算心率,假設采樣率為 100Hz
int heartRate = peaks * 60 / (size / 100);
return heartRate;
// 定時器0初始化函數
void InitTimer0(void)
TMOD = 0x01;
TH0 = 0xFC;
TL0 = 0x18;
EA = 1;
ET0 = 1;
TR0 = 1;
// 外部中斷 0 服務函數,用于檢測心率脈沖
void External0_ISR() interrupt 0
static uint last_time = 0;
uint current_time = count;
if (current_time - last_time > 20) // 消抖處理,20ms
pulse_count++;
last_time = current_time;
// 定時器0中斷服務函數
void Timer0Interrupt() interrupt 1
static uint i;
TH0 = 0xFC;
TL0 = 0x18;
count++;
i++;
one_second_count++;
if (one_second_count >= 1000) // 1秒
flag_1s = 1;
// 主程序
unsigned long fifoData[1000]; // 定義為全局變量以減小 main 函數自動段大小
int i;
// 初始化定時器0
InitTimer0();
// 初始化外部中斷 0
IT0 = 1; // 下降沿觸發
EX0 = 1; // 使能外部中斷 0
EA = 1; // 使能全局中斷
IE0 = 0; // INT0中斷請求標志清0
// 初始化MAX30102
if (!MAX30102_Init()) {
while (1);
// 讀取FIFO數據
for (i = 0; i < 1000; i++) {
if (!MAX30102_ReadFIFO(&fifoData[i])) {
while (1);
// 計算初始心率
heart_rate = calculateHeartRate(fifoData, 1000);
while (1)
if (flag_1s) // 1秒
flag_1s = 0;
heart_rate = pulse_count * 60; // 計算心率
pulse_count = 0; // 清零脈沖計數
編譯能過,心率沒有數據
国产精品一区一区三区
成人午夜影院
蜜臀久久99精品久久久久宅男
亚洲 欧美 激情 另类 校园
男人添女荫道口图片
福利色导航
男女啪啪网站
天天看天天干
性一交一乱一伧老太
欧日韩av
日韩av免费看
欧美一区二区在线播放
在线一区二区视频
欧美韩日
国精产品一区二区
日韩网站免费观看
亚洲欧洲在线观看
青青草免费在线观看
毛片资源
国产第三页
国产成人免费在线视频
日韩激情一区
久久久久一区
一区二区在线看
成人激情综合网
日韩精品毛片
老女人毛片
国产一级片在线播放
青青草精品
国产精品久久久一区二区
天天干网站
成人免费视频一区二区
在线观看亚洲精品
国产精品无遮挡
一区二区影院
免费av网址在线观看
最新日韩av
国产日韩欧美一区二区
a视频在线免费观看
福利色导航
黄色片中文字幕
