標題: 求大佬解惑:用NRF24L01實現電腦和單片機通信,接收信息空白 [打印本頁]
作者: face-v    時間: 2025-4-20 19:57
求大佬解惑,或提供一下思路,忙活一天了
如圖,使用該模塊實現電腦對單片機通信
大致硬件連接如下
PB13     ------> SPI2_SCK
PB14     ------> SPI2_MISO
PB15     ------> SPI2_MOSI
PC13     ------> CSN
PC14     ------> CE
PC15     ------> IRQ
現在問題是電腦端NRF24L01接收無消息
這是cubemx設置
這是main代碼
  1. #include "main.h"
  2. #include "spi.h"
  3. #include "gpio.h"
  4. #include "nrf24l01.h"
  5. #include <stdio.h>
  6. #define u8 uint8_t
  7. #define u16 uint16_t
  8. void SystemClock_Config(void);
  9. int main(void)
  10. {
  11.   /* USER CODE BEGIN 1 */
  12.         u8 tmp_buf[32]={0};
  13.         u8 mode;
  14.         u8 t=0;
  15.   HAL_Init();
  16.   SystemClock_Config();
  17.   MX_GPIO_Init();
  18.   MX_SPI2_Init();
  19.
  20.         while(NRF24L01_Check())
  21.         {
  22.                 printf("NRF_ERROR!!!\r\n");
  23.                  HAL_Delay(200);
  24.         }
  25.         printf("NRF_OK!!!\r\n");
  26.
  27.         printf("SET NRF_TX_MODE ... \r\n");
  28.          HAL_Delay(200);
  29.         NRF24L01_TX_Mode();
  30.
  31.         /*
  32.         *        組裝數據幀,第一位是有效數據的長度
  33.         */
  34.         tmp_buf[0] = 5;
  35.         tmp_buf[1] = 'A';
  36.         tmp_buf[2] = 'B';
  37.         tmp_buf[3] = 'C';
  38.         tmp_buf[4] = 'D';
  39.         tmp_buf[5] = 'E';
  40.         printf("Send message: ");
  41.         for (t=0; t < 32; t++)
  42.         printf("%x ", tmp_buf[t]);
  43.         printf("\r\n");
  44.
  45.
  46.   while (1)
  47.   {
  48.
  49.                 if(NRF24L01_TxPacket(tmp_buf)==TX_OK)
  50.                 {
  51.                         printf("\r\nSend Date: ");
  52.                         for (t=0; t < 32; t++)
  53.                                 printf("%x ", tmp_buf[t]);
  54.                 }else
  55.                 {
  56.                         printf("\r\nSend failed!\r\n");
  57.                 }
  58.                 HAL_Delay(1500);
  59. /*
  60.                 if(mode==0)//RX
  61.                 {
  62.                         NRF24L01_RX_Mode();
  63.
  64.                 }
  65.
  66.                 else//TX模式
  67.          {
  68.                         NRF24L01_TX_Mode();
  69.          }
  70.                 */
  71.     /* USER CODE BEGIN 3 */
  72.   }
  73.   /* USER CODE END 3 */
  74. }
這是nrf24l01.c
  1. #include "nrf24L01.h"
  2. #include "spi.h"
  3. //const uint8_t TX_ADDRESS[TX_ADR_WIDTH]={0x34,0x43,0x10,0x10,0x01}; //發送地址
  4. //const uint8_t RX_ADDRESS[RX_ADR_WIDTH]={0x34,0x43,0x10,0x10,0x01}; //接收地址
  5. const uint8_t TX_ADDRESS[TX_ADR_WIDTH]={0xFF,0xFF,0xFF,0xFF,0xFF}; //發送地址
  6. const uint8_t RX_ADDRESS[RX_ADR_WIDTH]={0xFF,0xFF,0xFF,0xFF,0xFF}; //接收地址
  7. /**
  8.   * 函數功能: 往串行Flash讀取寫入一個字節數據并接收一個字節數據
  9.   * 輸入參數: byte:待發送數據
  10.   * 返 回 值: uint8_t:接收到的數據
  11.   * 說    明:無
  12.   */
  13. uint8_t SPIx_ReadWriteByte(SPI_HandleTypeDef* hspi,uint8_t byte)
  14. {
  15.     uint8_t d_read,d_send=byte;
  16.     if(HAL_SPI_TransmitReceive(hspi,&d_send,&d_read,1,0xFF)!=HAL_OK)
  17.     {
  18.         d_read=0xFF;
  19.     }
  20.     return d_read;
  21. }
  22. /**
  23.   * 函數功能: 檢測24L01是否存在
  24.   * 輸入參數: 無
  25.   * 返 回 值: 0,成功;1,失敗
  26.   * 說    明:無
  27.   */
  28. uint8_t NRF24L01_Check(void)
  29. {
  30.     uint8_t buf[5]={0XA5,0XA5,0XA5,0XA5,0XA5};
  31.     uint8_t i;
  32.     NRF24L01_Write_Buf(NRF_WRITE_REG+TX_ADDR,buf,5);//寫入5個字節的地址.
  33.     NRF24L01_Read_Buf(TX_ADDR,buf,5); //讀出寫入的地址
  34.     for(i=0;i<5;i++)if(buf[i]!=0XA5)break;
  35.     if(i!=5)return 1;   //檢測24L01錯誤
  36.     return 0;                         //檢測到24L01
  37. }
  38. /**
  39.   * 函數功能: SPI寫寄存器
  40.   * 輸入參數: 無
  41.   * 返 回 值: 無
  42.   * 說    明:reg:指定寄存器地址
  43.   *
  44.   */
  45. uint8_t NRF24L01_Write_Reg(uint8_t reg,uint8_t value)
  46. {
  47.     uint8_t status;
  48.     NRF24L01_SPI_CS_ENABLE();                 //使能SPI傳輸
  49.     status =SPIx_ReadWriteByte(&hspi2,reg);   //發送寄存器號
  50.     SPIx_ReadWriteByte(&hspi2,value);         //寫入寄存器的值
  51.     NRF24L01_SPI_CS_DISABLE();                //禁止SPI傳輸
  52.     return(status);                               //返回狀態值
  53. }
  54. /**
  55.   * 函數功能: 讀取SPI寄存器值
  56.   * 輸入參數: 無
  57.   * 返 回 值: 無
  58.   * 說    明:reg:要讀的寄存器
  59.   *
  60.   */
  61. uint8_t NRF24L01_Read_Reg(uint8_t reg)
  62. {
  63.     uint8_t reg_val;
  64.     NRF24L01_SPI_CS_ENABLE();          //使能SPI傳輸
  65.     SPIx_ReadWriteByte(&hspi2,reg);   //發送寄存器號
  66.     reg_val=SPIx_ReadWriteByte(&hspi2,0XFF);//讀取寄存器內容
  67.     NRF24L01_SPI_CS_DISABLE();          //禁止SPI傳輸
  68.     return(reg_val);           //返回狀態值
  69. }
  70. /**
  71.   * 函數功能: 在指定位置讀出指定長度的數據
  72.   * 輸入參數: 無
  73.   * 返 回 值: 此次讀到的狀態寄存器值
  74.   * 說    明:無
  75.   *
  76.   */
  77. uint8_t NRF24L01_Read_Buf(uint8_t reg,uint8_t *pBuf,uint8_t len)
  78. {
  79.     uint8_t status,uint8_t_ctr;
  80.     NRF24L01_SPI_CS_ENABLE();           //使能SPI傳輸
  81.     status=SPIx_ReadWriteByte(&hspi2,reg);//發送寄存器值(位置),并讀取狀態值
  82.     for(uint8_t_ctr=0;uint8_t_ctr<len;uint8_t_ctr++)
  83.     {
  84.         pBuf[uint8_t_ctr]=SPIx_ReadWriteByte(&hspi2,0XFF);//讀出數據
  85.     }
  86.     NRF24L01_SPI_CS_DISABLE();       //關閉SPI傳輸
  87.     return status;        //返回讀到的狀態值
  88. }
  89. /**
  90.   * 函數功能: 在指定位置寫指定長度的數據
  91.   * 輸入參數: 無
  92.   * 返 回 值: 無
  93.   * 說    明:reg:寄存器(位置)  *pBuf:數據指針  len:數據長度
  94.   *
  95.   */
  96. uint8_t NRF24L01_Write_Buf(uint8_t reg, uint8_t *pBuf, uint8_t len)
  97. {
  98.     uint8_t status,uint8_t_ctr;
  99.     NRF24L01_SPI_CS_ENABLE();          //使能SPI傳輸
  100.     status = SPIx_ReadWriteByte(&hspi2,reg);//發送寄存器值(位置),并讀取狀態值
  101.     for(uint8_t_ctr=0; uint8_t_ctr<len; uint8_t_ctr++)
  102.     {
  103.         SPIx_ReadWriteByte(&hspi2,*pBuf++); //寫入數據
  104.     }
  105.     NRF24L01_SPI_CS_DISABLE();       //關閉SPI傳輸
  106.     return status;          //返回讀到的狀態值
  107. }
  108. /**
  109.   * 函數功能: 啟動NRF24L01發送一次數據
  110.   * 輸入參數: 無
  111.   * 返 回 值: 發送完成狀況
  112.   * 說    明:txbuf:待發送數據首地址
  113.   *
  114.   */
  115. uint8_t NRF24L01_TxPacket(uint8_t *txbuf)
  116. {
  117.     uint8_t sta;
  118.     NRF24L01_CE_LOW();
  119.     NRF24L01_Write_Buf(WR_TX_PLOAD,txbuf,TX_PLOAD_WIDTH);//寫數據到TX BUF  32個字節
  120.     NRF24L01_CE_HIGH();//啟動發送
  121.     while(NRF24L01_IRQ_PIN_READ()!=0);//等待發送完成
  122.     sta=NRF24L01_Read_Reg(STATUS);  //讀取狀態寄存器的值
  123.     NRF24L01_Write_Reg(NRF_WRITE_REG+STATUS,sta); //清除TX_DS或MAX_RT中斷標志
  124.     if(sta&MAX_TX)//達到最大重發次數
  125.     {
  126.         NRF24L01_Write_Reg(FLUSH_TX,0xff);//清除TX FIFO寄存器
  127.         return MAX_TX;
  128.     }
  129.     if(sta&TX_OK)//發送完成
  130.     {
  131.         return TX_OK;
  132.     }
  133.     return 0xff;//其他原因發送失敗
  134. }
  135. /**
  136.   * 函數功能:啟動NRF24L01接收一次數據
  137.   * 輸入參數: 無
  138.   * 返 回 值: 無
  139.   * 說    明:無
  140.   *
  141.   */
  142. uint8_t NRF24L01_RxPacket(uint8_t *rxbuf)
  143. {
  144.     uint8_t sta;
  145.     sta=NRF24L01_Read_Reg(STATUS);  //讀取狀態寄存器的值
  146.     NRF24L01_Write_Reg(NRF_WRITE_REG+STATUS,sta); //清除TX_DS或MAX_RT中斷標志
  147.     if(sta&RX_OK)//接收到數據
  148.     {
  149.         NRF24L01_Read_Buf(RD_RX_PLOAD,rxbuf,RX_PLOAD_WIDTH);//讀取數據
  150.         NRF24L01_Write_Reg(FLUSH_RX,0xff);//清除RX FIFO寄存器
  151.         return 0;
  152.     }
  153.     return 1;//沒收到任何數據
  154. }
  155. /**
  156.   * 函數功能: 該函數初始化NRF24L01到RX模式
  157.   * 輸入參數: 無
  158.   * 返 回 值: 無
  159.   * 說    明:無
  160.   *
  161.   */
  162. void NRF24L01_RX_Mode(void)
  163. {
  164.     NRF24L01_CE_LOW();
  165.     NRF24L01_Write_Reg(NRF_WRITE_REG+CONFIG, 0x0F);//配置基本工作模式的參數;PWR_UP,EN_CRC,16BIT_CRC
  166.     NRF24L01_Write_Reg(NRF_WRITE_REG+EN_AA,0x01);    //使能通道0的自動應答
  167.     NRF24L01_Write_Reg(NRF_WRITE_REG+EN_RXADDR,0x01);//使能通道0的接收地址
  168.     //NRF24L01_Write_Reg(NRF_WRITE_REG+RF_CH,40);             //設置RF通信頻率
  169.           NRF24L01_Write_Reg(NRF_WRITE_REG+RF_CH,0);             //設置RF通信頻率
  170.     NRF24L01_Write_Reg(NRF_WRITE_REG+RF_SETUP,0x0f);//設置TX發射參數,0db增益,2Mbps,低噪聲增益開啟
  171.     NRF24L01_Write_Reg(NRF_WRITE_REG+RX_PW_P0,RX_PLOAD_WIDTH);//選擇通道0的有效數據寬度
  172.     NRF24L01_Write_Buf(NRF_WRITE_REG+RX_ADDR_P0,(uint8_t*)RX_ADDRESS,RX_ADR_WIDTH);//寫RX節點地址
  173.     NRF24L01_CE_HIGH(); //CE為高,進入接收模式
  174.     HAL_Delay(1);
  175. }
  176. /**
  177.   * 函數功能: 該函數初始化NRF24L01到TX模式
  178.   * 輸入參數: 無
  179.   * 返 回 值: 無
  180.   * 說    明:無
  181.   *
  182.   */
  183. void NRF24L01_TX_Mode(void)
  184. {
  185.     NRF24L01_CE_LOW();
  186.     NRF24L01_Write_Buf(NRF_WRITE_REG+TX_ADDR,(uint8_t*)TX_ADDRESS,TX_ADR_WIDTH);//寫TX節點地址
  187.     NRF24L01_Write_Buf(NRF_WRITE_REG+RX_ADDR_P0,(uint8_t*)RX_ADDRESS,RX_ADR_WIDTH); //設置TX節點地址,主要為了使能ACK
  188.     NRF24L01_Write_Reg(NRF_WRITE_REG+EN_AA,0x01);     //使能通道0的自動應答
  189.     NRF24L01_Write_Reg(NRF_WRITE_REG+EN_RXADDR,0x01); //使能通道0的接收地址
  190.     NRF24L01_Write_Reg(NRF_WRITE_REG+SETUP_RETR,0xff);//設置自動重發間隔時間:4000us + 86us;最大自動重發次數:15次
  191.     NRF24L01_Write_Reg(NRF_WRITE_REG+RF_CH,40);       //設置RF通道為40
  192.     NRF24L01_Write_Reg(NRF_WRITE_REG+RF_SETUP,0x0f);  //設置TX發射參數,0db增益,2Mbps,低噪聲增益開啟
  193.     NRF24L01_Write_Reg(NRF_WRITE_REG+CONFIG,0x0e);    //配置基本工作模式的參數;PWR_UP,EN_CRC,16BIT_CRC,接收模式,開啟所有中斷
  194.     NRF24L01_CE_HIGH();//CE為高,10us后啟動發送
  195.     HAL_Delay(1);
  196. }
  197. /**
  198.   * 函數功能: 該函數NRF24L01進入低功耗模式
  199.   * 輸入參數: 無
  200.   * 返 回 值: 無
  201.   * 說    明:無
  202.   *
  203.   */
  204. void NRF_LowPower_Mode(void)
  205. {
  206.     NRF24L01_CE_LOW();
  207.     NRF24L01_Write_Reg(NRF_WRITE_REG+CONFIG, 0x00);                //配置工作模式:掉電模式
  208. }
這是nrf24l01.h
  1. #ifndef _NRF24L01_H
  2. #define _NRF24L01_H
  3. #include "main.h"
  4. /* 宏定義 --------------------------------------------------------------------*/
  5. #define NRF24L01_SPI_CS_ENABLE()    HAL_GPIO_WritePin(CS_GPIO_Port,CS_Pin,GPIO_PIN_RESET)
  6. #define NRF24L01_SPI_CS_DISABLE()   HAL_GPIO_WritePin(CS_GPIO_Port,CS_Pin,GPIO_PIN_SET)
  7. #define NRF24L01_CE_LOW()   HAL_GPIO_WritePin(CE_GPIO_Port,CE_Pin,GPIO_PIN_RESET)
  8. #define NRF24L01_CE_HIGH() HAL_GPIO_WritePin(CE_GPIO_Port,CE_Pin,GPIO_PIN_SET)
  9. #define NRF24L01_IRQ_PIN_READ()  HAL_GPIO_ReadPin(IRQ_GPIO_Port,IRQ_Pin)
  10. // NRF24L01發送接收數據寬度定義
  11. #define TX_ADR_WIDTH                                  5           //5字節的地址寬度
  12. #define RX_ADR_WIDTH                                  5           //5字節的地址寬度
  13. #define TX_PLOAD_WIDTH                                32          //32字節的用戶數據寬度
  14. #define RX_PLOAD_WIDTH                                32          //32字節的用戶數據寬度
  15. //NRF24L01寄存器操作命令
  16. #define NRF_READ_REG                                  0x00  //讀配置寄存器,低5位為寄存器地址
  17. #define NRF_WRITE_REG                                 0x20  //寫配置寄存器,低5位為寄存器地址
  18. #define RD_RX_PLOAD                                   0x61  //讀RX有效數據,1~32字節
  19. #define WR_TX_PLOAD                                   0xA0  //寫TX有效數據,1~32字節
  20. #define FLUSH_TX                                      0xE1  //清除TX FIFO寄存器.發射模式下用
  21. #define FLUSH_RX                                      0xE2  //清除RX FIFO寄存器.接收模式下用
  22. #define REUSE_TX_PL                                   0xE3  //重新使用上一包數據,CE為高,數據包被不斷發送.
  23. #define NOP                                           0xFF  //空操作,可以用來讀狀態寄存器
  24. //SPI(NRF24L01)寄存器地址
  25. #define CONFIG                                        0x00  //配置寄存器地址;bit0:1接收模式,0發射模式;bit1:電選擇;bit2:CRC模式;bit3:CRC使能;
  26. //bit4:中斷MAX_RT(達到最大重發次數中斷)使能;bit5:中斷TX_DS使能;bit6:中斷RX_DR使能
  27. #define EN_AA                                         0x01  //使能自動應答功能  bit0~5,對應通道0~5
  28. #define EN_RXADDR                                     0x02  //接收地址允許,bit0~5,對應通道0~5
  29. #define SETUP_AW                                      0x03  //設置地址寬度(所有數據通道):bit1,0:00,3字節;01,4字節;02,5字節;
  30. #define SETUP_RETR                                    0x04  //建立自動重發;bit3:0,自動重發計數器;bit7:4,自動重發延時 250*x+86us
  31. #define RF_CH                                         0x05  //RF通道,bit6:0,工作通道頻率;
  32. #define RF_SETUP                                      0x06  //RF寄存器;bit3:傳輸速率(0:1Mbps,1:2Mbps);bit2:1,發射功率;bit0:低噪聲放大器增益
  33. #define STATUS                                        0x07  //狀態寄存器;bit0:TX FIFO滿標志;bit3:1,接收數據通道號(最大:6);bit4,達到最多次重發
  34. //bit5:數據發送完成中斷;bit6:接收數據中斷;
  35. #define MAX_TX                                                    0x10  //達到最大發送次數中斷
  36. #define TX_OK                                                     0x20  //TX發送完成中斷
  37. #define RX_OK                                                     0x40  //接收到數據中斷
  38. #define OBSERVE_TX                                    0x08  //發送檢測寄存器,bit7:4,數據包丟失計數器;bit3:0,重發計數器
  39. #define CD                                            0x09  //載波檢測寄存器,bit0,載波檢測;
  40. #define RX_ADDR_P0                                    0x0A  //數據通道0接收地址,最大長度5個字節,低字節在前
  41. #define RX_ADDR_P1                                    0x0B  //數據通道1接收地址,最大長度5個字節,低字節在前
  42. #define RX_ADDR_P2                                    0x0C  //數據通道2接收地址,最低字節可設置,高字節,必須同RX_ADDR_P1[39:8]相等;
  43. #define RX_ADDR_P3                                    0x0D  //數據通道3接收地址,最低字節可設置,高字節,必須同RX_ADDR_P1[39:8]相等;
  44. #define RX_ADDR_P4                                    0x0E  //數據通道4接收地址,最低字節可設置,高字節,必須同RX_ADDR_P1[39:8]相等;
  45. #define RX_ADDR_P5                                    0x0F  //數據通道5接收地址,最低字節可設置,高字節,必須同RX_ADDR_P1[39:8]相等;
  46. #define TX_ADDR                                       0x10  //發送地址(低字節在前),ShockBurstTM模式下,RX_ADDR_P0與此地址相等
  47. #define RX_PW_P0                                      0x11  //接收數據通道0有效數據寬度(1~32字節),設置為0則非法
  48. #define RX_PW_P1                                      0x12  //接收數據通道1有效數據寬度(1~32字節),設置為0則非法
  49. #define RX_PW_P2                                      0x13  //接收數據通道2有效數據寬度(1~32字節),設置為0則非法
  50. #define RX_PW_P3                                      0x14  //接收數據通道3有效數據寬度(1~32字節),設置為0則非法
  51. #define RX_PW_P4                                      0x15  //接收數據通道4有效數據寬度(1~32字節),設置為0則非法
  52. #define RX_PW_P5                                      0x16  //接收數據通道5有效數據寬度(1~32字節),設置為0則非法
  53. #define NRF_FIFO_STATUS                               0x17  //FIFO狀態寄存器;bit0,RX FIFO寄存器空標志;bit1,RX FIFO滿標志;bit2,3,保留
  54. //bit4,TX FIFO空標志;bit5,TX FIFO滿標志;bit6,1,循環發送上一數據包.0,不循環;
  55. /* 函數聲明 ------------------------------------------------------------------*/
  56. void NRF24L01_RX_Mode(void);                                        //配置為接收模式
  57. void NRF24L01_TX_Mode(void);                                        //配置為發送模式
  58. uint8_t NRF24L01_Write_Buf(uint8_t reg, uint8_t *pBuf, uint8_t uint8_ts);//寫數據區
  59. uint8_t NRF24L01_Read_Buf(uint8_t reg, uint8_t *pBuf, uint8_t uint8_ts);        //讀數據區
  60. uint8_t NRF24L01_Read_Reg(uint8_t reg);                                        //讀寄存器
  61. uint8_t NRF24L01_Write_Reg(uint8_t reg, uint8_t value);                //寫寄存器
  62. uint8_t NRF24L01_Check(void);                                                //檢查24L01是否存在
  63. uint8_t NRF24L01_TxPacket(uint8_t *txbuf);                                //發送一個包的數據
  64. uint8_t NRF24L01_RxPacket(uint8_t *rxbuf);                                //接收一個包的數據
  65. void NRF_LowPower_Mode(void);
  66. #endif
作者: 黃youhui    時間: 2025-4-22 20:46
以前玩過,太久了有點忘了,不過你去網上找一下,很多低成本的32開發板都帶這個模塊的。
主站蜘蛛池模板: 日本免费黄色网址 | av天天操 | 黄色a一级片 | 国产三级在线观看 | 国产一区二区免费看 | 国产91视频在线观看 | 中文字幕在线免费看 | 午夜天堂在线 | 久久瑟瑟 | 国产免费一级片 | 免费在线看a | 亚洲香蕉在线 | 亚洲天堂网址 | 在线看片a| av手机天堂| 日韩高清一区二区 | 午夜视频免费观看 | 少妇搡bbbb搡bbb搡毛茸茸 | 国产精品美女毛片真酒店 | 国产在线成人 | 四虎av| 五月天久久久 | 日本欧美久久久久免费播放网 | 男女啪啪免费视频 | 欧美成人一级 | 日本乱子伦 | 亚洲综合婷婷 | 亚洲激情偷拍 | 午夜在线| 国产精品一区二区在线播放 | 国产精品成人国产乱 | 精品一区av | 男人天堂2020| 欧美一区二区三区在线观看 | 亚洲啪啪网| 在线播放国产精品 | 成人一级片 | 四川一级毛毛片 | 最新理论片| 在线免费黄色网址 | av看片|
