標題: stm32電梯控制故障 [打印本頁]
作者: jjudging    時間: 2025-5-27 18:48
標題: stm32電梯控制故障
我按下一個1樓上,不點擊其他按鍵,但是其他按鍵在電梯運行后自動響應,例如二樓上,二樓下,但是三樓下按下沒反應了,同時我的載重閾值也會自動響應,閾值減少,代碼設置的最多三個請求,然后一直三個請求循環
作者: GlenXu    時間: 2025-5-28 08:46
首先你的通訊可靠性沒有保障措施,例如采用MODBUS等。
其次你的設備地址或ID最好不要01、02~09這樣,例如一樓用51或E1,這樣可以有效減少別的“樓層”響應或錯誤執行你的指令
另外,通訊要有嚴格的防止意外的措施,否則你說的問題永遠存在。
作者: jjudging    時間: 2025-5-28 18:03
發表于 2025-5-28 08:46
其次你的設備地址或ID最好不要01、02~09這樣,例如 ...
#include "stm32f10x.h"                  // Device header
#include "OLED.H"
#include <stdio.h>
#include "Delay.h"
#include "Timer.H"
#include "AD.H"
#include "LED.h"
#include "key.h"
#include "HX711.h"
#include "PWM.h"
void MAIN_Cycle(void);
void OLED_UI_One(void);
u16 Time_Flag = 0;
u8 Time_1ms_Flag = 0;
u8 Time_2ms_Flag = 0;
u8 Time_5ms_Flag = 0;
u8 Time_10ms_Flag = 0;
u8 Time_20ms_Flag = 0;
u8 Time_50ms_Flag = 0;
u8 Time_100ms_Flag = 0;
u8 Time_200ms_Flag = 0;
u8 Time_500ms_Flag = 0;
u8 Time_1000ms_Flag = 0;
extern u32 weight;
u16 g_weight_threshold = 200;
u8 g_Lift_State = 0;
u8 g_Move_Flag = 0;
u8 g_Key_State = 0;
u8 g_Wait_Flag_Num[3] = {0,0,0};
u8 g_Control_Threshold_State = 0;
u16 Turn_door_flag = 0;
u16 KEY_perss_flag = 0;
int main(void)
        OLED_Init();
    OLED_UI_One();
    HX711_GPIO_Init();
        Get_Tare();
        LED_Init();
        Key_Init();
        PWM_Init();
//        Adc_Dma_Init();
        Timer_Init();
                MAIN_Cycle();
static void MAIN_Cycle(void)
        if( Time_1ms_Flag == 1)
                Time_1ms_Flag = 0;
        if( Time_2ms_Flag == 1)
                Time_2ms_Flag = 0;
        if( Time_5ms_Flag == 1)
                Time_5ms_Flag = 0;
        if( Time_10ms_Flag == 1)
                if( GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_8) == 0)
                        KEY_perss_flag++;
                Time_10ms_Flag = 0;
        if( Time_20ms_Flag == 1)
                OLED_ShowNumber(72,0,g_Lift_State,1,16);
                Time_20ms_Flag = 0;
        if( Time_50ms_Flag == 1)
        if( g_Wait_Flag_Num[0]!=0 )
                        if( g_Wait_Flag_Num[0] == 12)
                                if( g_Lift_State == 1 )
                                        PWM_SetStop_Rotation();Lift_Uplink_Off();Lift_Downlink_Off();
                                        Turn_door_flag++;
                                        if( Turn_door_flag < 20)
                                                OLED_ShowChar(104,0,' ',16);OLED_ShowChar(112,0,' ',16);OLED_ShowCHinese(88,0,8);OLED_ShowNumber(104,0,2,1,16);
                                        else if( Turn_door_flag < 40)
                                                OLED_ShowChar(104,0,' ',16);OLED_ShowChar(112,0,' ',16);OLED_ShowCHinese(88,0,8);OLED_ShowNumber(104,0,1,1,16);
                                        else if( Turn_door_flag < 60)
                                                OLED_ShowChar(104,0,' ',16);OLED_ShowChar(112,0,' ',16);OLED_ShowCHinese(88,0,9);OLED_ShowNumber(104,0,5,1,16);
                                                if( weight > g_weight_threshold )
                                                    while(weight > g_weight_threshold)
                                                    { Get_Weight();GPIO_SetBits(GPIOA,GPIO_Pin_1);}
                                                }else{GPIO_ResetBits(GPIOA,GPIO_Pin_1);}
                                        else if( Turn_door_flag < 80)
                                                OLED_ShowChar(104,0,' ',16);OLED_ShowChar(112,0,' ',16);OLED_ShowCHinese(88,0,9);OLED_ShowNumber(104,0,4,1,16);
                                        else if( Turn_door_flag < 100)
                                                OLED_ShowChar(104,0,' ',16);OLED_ShowChar(112,0,' ',16);OLED_ShowCHinese(88,0,9);OLED_ShowNumber(104,0,3,1,16);
                                        else if( Turn_door_flag < 120)
                                                OLED_ShowChar(104,0,' ',16);OLED_ShowChar(112,0,' ',16);OLED_ShowCHinese(88,0,9);OLED_ShowNumber(104,0,2,1,16);
                                        else if( Turn_door_flag < 140)
                                                OLED_ShowChar(104,0,' ',16);OLED_ShowChar(112,0,' ',16);OLED_ShowCHinese(88,0,9);OLED_ShowNumber(104,0,1,1,16);
                                                OLED_ShowChar(104,0,' ',16);OLED_ShowChar(112,0,' ',16);OLED_ShowCHinese(88,0,11);OLED_ShowCHinese(104,0,9);
                                                g_Wait_Flag_Num[0] = g_Wait_Flag_Num[1]; g_Wait_Flag_Num[1] = g_Wait_Flag_Num[2]; g_Wait_Flag_Num[2] = 0;
                                                OLED_ShowCHinese(0,2,13);Turn_door_flag = 0;
                                else if( g_Lift_State == 2 )
                    PWM_SetForward_Rotation();Lift_Downlink_On();
                                else if( g_Lift_State == 3 )
                        else if( g_Wait_Flag_Num[0] == 21)
                                        PWM_SetRollback_Rotation();Lift_Uplink_On();
                                                Turn_door_flag++;
                                                OLED_ShowCHinese(0,2,12);Turn_door_flag = 0;
                        else if( g_Wait_Flag_Num[0] == 23)
                                                Turn_door_flag++;
                        else if( g_Wait_Flag_Num[0] == 32)
                                                Turn_door_flag++;
                Time_50ms_Flag = 0;
        if( Time_100ms_Flag == 1)
                Get_Weight();
                OLED_ShowNumber(40,6,weight,4,16);
                OLED_ShowNumber(88,6,g_weight_threshold,4,16);
        Delay_ms(2);
        if( Time_200ms_Flag == 1)
                switch( g_Wait_Flag_Num[0] )
                        case 12:OLED_ShowNumber(72,2,1,1,16);;break;
                        case 21:OLED_ShowNumber(72,2,2,1,16);;break;
                        case 23:OLED_ShowNumber(72,2,2,1,16);;break;
                        case 32:OLED_ShowNumber(72,2,3,1,16);;break;
                        default:OLED_ShowChar(72,2,' ',16);
                switch( g_Wait_Flag_Num[1] )
                        case 12:OLED_ShowNumber(88,2,1,1,16);;break;
                        case 21:OLED_ShowNumber(88,2,2,1,16);;break;
                        case 23:OLED_ShowNumber(88,2,2,1,16);;break;
                        case 32:OLED_ShowNumber(88,2,3,1,16);;break;
                        default:OLED_ShowChar(88,2,' ',16);
                switch( g_Wait_Flag_Num[2] )
                        case 12:OLED_ShowNumber(104,2,1,1,16);;break;
                        case 21:OLED_ShowNumber(104,2,2,1,16);;break;
                        case 23:OLED_ShowNumber(104,2,2,1,16);;break;
                        case 32:OLED_ShowNumber(104,2,3,1,16);;break;
                        default:OLED_ShowChar(104,2,' ',16);
        if( Time_500ms_Flag == 1)
                static u8 i = 0;
                i = 1-i;
//                if( Turn_door_flag != 60)
                        if( g_Move_Flag == 1 )
                                if(i){ OLED_ShowCHinese(0,2,12); }
                                else{OLED_ShowCHinese(0,2,14);}
                        else if( g_Move_Flag == 2 )
                                if(i){ OLED_ShowCHinese(0,2,13); }
                        else if( g_Move_Flag == 0 )
//                                if(i){ OLED_ShowCHinese(0,2,12); }
//                                else{OLED_ShowCHinese(0,2,14);}
        if( Time_1000ms_Flag == 1)
//                if( Time_flag == 0)
//                        PWM_SetForward_Rotation();
//                        Lift_Uplink_On();
//                        Lift_Downlink_On();
//                        Time_flag = 1;
//                else if( Time_flag == 1)
//                        PWM_SetStop_Rotation();
//                        Lift_Uplink_Off();
//                        Lift_Downlink_Off();
//                        Time_flag = 2;
//                else if( Time_flag == 2)
//                        PWM_SetRollback_Rotation();
//                        Time_flag = 3;
//                else if( Time_flag == 3)
//                        Time_flag = 0;
//                Buzzer_Turn();
void EXTI0_IRQHandler(void)
        if(EXTI_GetITStatus(EXTI_Line0) != RESET)
//                Delay_ms(10);
                if( GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_0)==0 )
                        g_Lift_State = 3;
                EXTI_ClearITPendingBit(EXTI_Line0);
void EXTI4_IRQHandler(void)
        if(EXTI_GetITStatus(EXTI_Line4) != RESET)
//                Delay_ms(10);
                if( GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_4)==0 )
                        g_Lift_State = 2;
                EXTI_ClearITPendingBit(EXTI_Line4);
void EXTI9_5_IRQHandler(void)
        if(EXTI_GetITStatus(EXTI_Line5) != RESET)
//                Delay_ms(10);
                if( GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_5)==0 )
                        g_Lift_State = 1;
                EXTI_ClearITPendingBit(EXTI_Line5);
        if(EXTI_GetITStatus(EXTI_Line8) != RESET)
                g_Control_Threshold_State = 1;
        g_weight_threshold = g_weight_threshold - 10;
                if( g_weight_threshold < 10){ g_weight_threshold = 10;}
                EXTI_ClearITPendingBit(EXTI_Line8);
        if(EXTI_GetITStatus(EXTI_Line9) != RESET)
                g_Control_Threshold_State = 2;
        g_weight_threshold = g_weight_threshold + 10;
                if( g_weight_threshold > 3000){ g_weight_threshold = 3000;}
                EXTI_ClearITPendingBit(EXTI_Line9);
void EXTI15_10_IRQHandler(void)
        if(EXTI_GetITStatus(EXTI_Line12) != RESET)
                if( g_Key_State != 12 )
                        if( g_Wait_Flag_Num[0] != 32 && g_Wait_Flag_Num[0] != 23 )
                                        g_Key_State = 12;
                                        if( g_Wait_Flag_Num[0] == 0 )
                                                g_Wait_Flag_Num[0] = 12;
                                        else if( g_Wait_Flag_Num[1] == 0 )
                                                g_Wait_Flag_Num[1] = 12;
                                        else if( g_Wait_Flag_Num[2] == 0 )
                                                g_Wait_Flag_Num[2] = 12;
                EXTI_ClearITPendingBit(EXTI_Line12);
        if(EXTI_GetITStatus(EXTI_Line13) != RESET)
                if( g_Key_State != 21 )
                                        g_Key_State = 21;
                                                g_Wait_Flag_Num[0] = 21;
                                                g_Wait_Flag_Num[1] = 21;
                                                g_Wait_Flag_Num[2] = 21;
                EXTI_ClearITPendingBit(EXTI_Line13);
        if(EXTI_GetITStatus(EXTI_Line14) != RESET)
                if( g_Key_State != 23 )
                        g_Key_State = 23;
                        if( g_Wait_Flag_Num[0] != 12 && g_Wait_Flag_Num[0] != 21 )
                                                g_Wait_Flag_Num[0] = 23;
                                                g_Wait_Flag_Num[1] = 23;
                                                g_Wait_Flag_Num[2] = 23;
                EXTI_ClearITPendingBit(EXTI_Line14);
        if(EXTI_GetITStatus(EXTI_Line15) != RESET)
                if( g_Key_State != 32 )
                        g_Key_State = 32;
                                                g_Wait_Flag_Num[0] = 32;
                                                g_Wait_Flag_Num[1] = 32;
                                                g_Wait_Flag_Num[2] = 32;
                EXTI_ClearITPendingBit(EXTI_Line15);
void TIM2_IRQHandler(void)
        if(TIM_GetITStatus(TIM2,TIM_IT_Update) == SET)
                TIM_ClearITPendingBit (TIM2,TIM_IT_Update);
                Time_Flag++;
                if( Time_Flag % 1    == 0){ Time_1ms_Flag    = 1; }
                if( Time_Flag % 2    == 0){ Time_2ms_Flag    = 1; }
                if( Time_Flag % 5    == 0){ Time_5ms_Flag    = 1; }
                if( Time_Flag % 10   == 0){ Time_10ms_Flag   = 1; }
                if( Time_Flag % 20   == 0){ Time_20ms_Flag   = 1; }
                if( Time_Flag % 50   == 0){ Time_50ms_Flag   = 1; }
                if( Time_Flag % 100  == 0){ Time_100ms_Flag  = 1; }
                if( Time_Flag % 200  == 0){ Time_200ms_Flag  = 1; }
                if( Time_Flag % 500  == 0){ Time_500ms_Flag  = 1; }
                if( Time_Flag % 1000 == 0){ Time_1000ms_Flag = 1;
                                    Time_Flag = 0;        }
        OLED_ShowCHinese(0,0,0);
        OLED_ShowCHinese(16,0,1);
        OLED_ShowCHinese(32,0,2);
        OLED_ShowCHinese(48,0,3);
        OLED_ShowChar(64,1,':',8);
        OLED_ShowCHinese(32,2,6);
        OLED_ShowCHinese(48,2,7);
        OLED_ShowChar(64,3,':',8);
        OLED_ShowCHinese(0,6,4);
        OLED_ShowCHinese(16,6,5);
        OLED_ShowChar(32,7,':',8);
程序是這個樣子是哪里出現問題的呀
主站蜘蛛池模板: 性高朝久久久久久久3小时 av一区二区三区四区 | 欧美在线日韩 | 亚洲第一成人影院 | 99久久国产综合精品麻豆 | 一道本不卡| 91亚洲国产成人久久精品网站 | 欧美一区二区三区一在线观看 | 东方伊人免费在线观看 | 国产在线观看一区二区三区 | 高清av在线 | 国产丝袜一区二区三区免费视频 | 97精品国产97久久久久久免费 | 国产精品久久精品 | 日韩欧美网 | 蜜臀网| 国产激情三区 | av入口| 81精品国产乱码久久久久久 | 免费一级黄色录像 | 国产精品视频一区二区三区不卡 | 国产一二区在线 | 欧美一级大片免费观看 | 亚洲视频欧美视频 | 日本国产精品视频 | 精品国产伦一区二区三区观看说明 | 成人av看片 | 亚洲国产精品人人爽夜夜爽 | 日韩黄色av | 国产精品毛片无码 | 国产精品成人在线观看 | 亚洲网一区 | 精品一区二区三区免费视频 | 久久不卡 | 国产线视频精品免费观看视频 | 国产精品一区二区不卡 | 天堂久久久久久久 | 亚洲精品日韩在线 | 亚洲深夜福利 | av看片网站 | 澳门永久av免费网站 | 嫩草黄色影院 |
