標(biāo)題:
stm32f10x_exti.c
liuda
2015-1-23 03:46
標(biāo)題:
stm32f10x_exti.c
* @file stm32f10x_exti.c
* @author MCD Application Team
* @version V3.5.0
* @date 11-March-2011
* @brief This file provides all the EXTI firmware functions.
* @attention
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
* TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
* DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
* FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
* CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
* <h2><center>© COPYRIGHT 2011 STMicroelectronics</center></h2>
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x_exti.h"
/** @addtogroup STM32F10x_StdPeriph_Driver
/** @defgroup EXTI
* @brief EXTI driver modules
/** @defgroup EXTI_Private_TypesDefinitions
/** @defgroup EXTI_Private_Defines
#define EXTI_LINENONE ((uint32_t)0x00000) /* No interrupt selected */
/** @defgroup EXTI_Private_Macros
/** @defgroup EXTI_Private_Variables
/** @defgroup EXTI_Private_FunctionPrototypes
/** @defgroup EXTI_Private_Functions
* @brief Deinitializes the EXTI peripheral registers to their default reset values.
* @param None
* @retval None
void EXTI_DeInit(void)//外部中斷初始化為默認值
EXTI->IMR = 0x00000000;
EXTI->EMR = 0x00000000;
EXTI->RTSR = 0x00000000;
EXTI->FTSR = 0x00000000;
EXTI->PR = 0x000FFFFF;
* @brief Initializes the EXTI peripheral according to the specified
* parameters in the EXTI_InitStruct.
* @param EXTI_InitStruct: pointer to a EXTI_InitTypeDef structure
* that contains the configuration information for the EXTI peripheral.
* @retval None
void EXTI_Init(EXTI_InitTypeDef* EXTI_InitStruct)//外部中斷根據(jù)結(jié)構(gòu)體的參數(shù)進行初始化
uint32_t tmp = 0;
/* Check the parameters */
assert_param(IS_EXTI_MODE(EXTI_InitStruct->EXTI_Mode));
assert_param(IS_EXTI_TRIGGER(EXTI_InitStruct->EXTI_Trigger));
assert_param(IS_EXTI_LINE(EXTI_InitStruct->EXTI_Line));
assert_param(IS_FUNCTIONAL_STATE(EXTI_InitStruct->EXTI_LineCmd));
tmp = (uint32_t)EXTI_BASE;
if (EXTI_InitStruct->EXTI_LineCmd != DISABLE)
/* Clear EXTI line configuration */
EXTI->IMR &= ~EXTI_InitStruct->EXTI_Line;
EXTI->EMR &= ~EXTI_InitStruct->EXTI_Line;
tmp += EXTI_InitStruct->EXTI_Mode;
*(__IO uint32_t *) tmp |= EXTI_InitStruct->EXTI_Line;
/* Clear Rising Falling edge configuration */
EXTI->RTSR &= ~EXTI_InitStruct->EXTI_Line;
EXTI->FTSR &= ~EXTI_InitStruct->EXTI_Line;
/* Select the trigger for the selected external interrupts */
if (EXTI_InitStruct->EXTI_Trigger == EXTI_Trigger_Rising_Falling)
/* Rising Falling edge */
EXTI->RTSR |= EXTI_InitStruct->EXTI_Line;
EXTI->FTSR |= EXTI_InitStruct->EXTI_Line;
tmp += EXTI_InitStruct->EXTI_Trigger;
/* Disable the selected external lines */
*(__IO uint32_t *) tmp &= ~EXTI_InitStruct->EXTI_Line;
* @brief Fills each EXTI_InitStruct member with its reset value.
* @param EXTI_InitStruct: pointer to a EXTI_InitTypeDef structure which will
* be initialized.
* @retval None
void EXTI_StructInit(EXTI_InitTypeDef* EXTI_InitStruct)//外部中斷的結(jié)構(gòu)體參數(shù)恢復(fù)為默認值
EXTI_InitStruct->EXTI_Line = EXTI_LINENONE;
EXTI_InitStruct->EXTI_Mode = EXTI_Mode_Interrupt;
EXTI_InitStruct->EXTI_Trigger = EXTI_Trigger_Falling;
EXTI_InitStruct->EXTI_LineCmd = DISABLE;
* @brief Generates a Software interrupt.
* @param EXTI_Line: specifies the EXTI lines to be enabled or disabled.
* This parameter can be any combination of EXTI_Linex where x can be (0..19).
* @retval None
void EXTI_GenerateSWInterrupt(uint32_t EXTI_Line)//產(chǎn)生一個軟件中斷
assert_param(IS_EXTI_LINE(EXTI_Line));
EXTI->SWIER |= EXTI_Line;
* @brief Checks whether the specified EXTI line flag is set or not.
* @param EXTI_Line: specifies the EXTI line flag to check.
* This parameter can be:
* @arg EXTI_Linex: External interrupt line x where x(0..19)
* @retval The new state of EXTI_Line (SET or RESET).
FlagStatus EXTI_GetFlagStatus(uint32_t EXTI_Line)//檢測外部中斷的標(biāo)志的狀態(tài)
FlagStatus bitstatus = RESET;
assert_param(IS_GET_EXTI_LINE(EXTI_Line));
if ((EXTI->PR & EXTI_Line) != (uint32_t)RESET)
bitstatus = SET;
bitstatus = RESET;
return bitstatus;
* @brief Clears the EXTI's line pending flags.
* @param EXTI_Line: specifies the EXTI lines flags to clear.
* @retval None
void EXTI_ClearFlag(uint32_t EXTI_Line)//清除外部中斷的標(biāo)志
EXTI->PR = EXTI_Line;
* @brief Checks whether the specified EXTI line is asserted or not.
* @param EXTI_Line: specifies the EXTI line to check.
ITStatus EXTI_GetITStatus(uint32_t EXTI_Line)//檢測使能的外部中斷的標(biāo)志的狀態(tài)
ITStatus bitstatus = RESET;
uint32_t enablestatus = 0;
enablestatus = EXTI->IMR & EXTI_Line;
if (((EXTI->PR & EXTI_Line) != (uint32_t)RESET) && (enablestatus != (uint32_t)RESET))
bitstatus = SET;
bitstatus = RESET;
return bitstatus;
* @brief Clears the EXTI's line pending bits.
* @param EXTI_Line: specifies the EXTI lines to clear.
* @retval None
void EXTI_ClearITPendingBit(uint32_t EXTI_Line)//清除外部中斷的掛起位
/******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
99精品九九
人人看人人草
久久激情视频
91av视频在线观看
国产永久免费
婷婷久久精品一区二区
91看片免费版
888久久久
在线观看亚洲
欧美高清视频在线观看
国产精品揄拍一区二区
国产精品久久久久久久久久久久
久久国产精品99久久久久久丝袜
美女日批免费视频
久久久久久久电影
免费一区二区三区
成av在线
欧美成人一区二区三区
国产精品不卡一区二区三区
91精品国产91久久综合桃花
国产欧美一区二区三区日本久久久
日韩成人免费视频
中文字幕在线观看国产
亚洲一区在线观看视频
欧美精品一区二区三区一线天视频
欧美视频第三页
日韩精品一二三
国产一区二区三区在线看
午夜精品一区二区三区免费视频
国产精品一区久久久
91色视频在线观看
永久www成人看片
欧美 中文字幕
精品99在线
久久国产美女视频
一区二区三区国产精品
91影院
欧美一级特黄aaa大片在线观看
999久久久久久久久6666
亚洲二区在线
精品国产一区二区三区四区在线
