無字庫12864液晶屏滾動顯示程序
huxiao
2015-1-24 15:23
無字庫12864液晶屏滾動顯示程序
同志們,做實驗的時候一定要把端口重新設置成和你的實際硬件一樣,不要說我是騙人的,著東西可編了我3個多小時,絕對沒問題!記得P0口加上拉,或者用其他端口,如果不顯示,參照《
12864及1602液晶的驅動指南
》,如果還不行,聯系本人,
這是個靜態圖片,大家看看,絕對真實!
#include<reg52.h>
#include<intrins.h>
#include<absacc.h>
#define Lcd_Bus P0 //MCU P0<------> LCM
#define Disp_On 0x3f//開顯示
#define Disp_Off 0x3e//關顯示
#define Col_Add 0x40//列地址
#define Page_Add 0xb8//頁地址
#define Start_Line 0xc0//起始頁
sbit cs1=P2^3; //Master chip enable
sbit cs2=P2^4; //Slave chip enable
sbit Enable=P2^2; // mode Enable single
sbit Di=P2^0; //Data or Instrument Select
sbit RW=P2^1; //Write or Read
sbit Lcd_Rst=P2^5; //Lcm reset
字模,此字體下對應的
點陣為:寬x高=16x16
unsigned char code Chinese_character[][32]=
{0x02,0xF2,0x12,0x12,0x12,0xFE,0x12,0x12,0x12,0xFE,0x12,0x12,0x12,0xF2,0x02,0x00 ,
0x00,0x7F,0x28,0x24,0x22,0x21,0x20,0x20,0x20,0x21,0x22,0x22,0x22,0x7F,0x00,0x00},/*"西",0*/
{0x80,0x90,0x8C,0x84,0x84,0xF4,0xA5,0x86,0x84,0x84,0x84,0x84,0x94,0x8C,0x84,0x00,
0x80,0x80,0x80,0x40,0x47,0x28,0x28,0x10,0x28,0x24,0x43,0xC0,0x40,0x00,0x00,0x00},/*"安",1*/
{0x00,0x42,0x62,0x5A,0xC6,0x10,0x54,0x54,0x54,0xFF,0x54,0x54,0x7C,0x10,0x10,0x00,
0x40,0x23,0x14,0x08,0x17,0x28,0x29,0x49,0x49,0x7F,0x49,0x49,0x49,0x49,0x40,0x00},/*"建",2*/
{0x10,0x48,0x47,0xCC,0x54,0x44,0x14,0xE8,0x27,0x24,0x2C,0xF4,0x04,0x04,0x04,0x00,
0x10,0x30,0x10,0x0F,0x88,0x48,0x30,0x0F,0x01,0x06,0x00,0x3F,0x40,0x40,0x70,0x00},/*"筑",3*/
{0x10,0x12,0x92,0x72,0xFE,0x51,0x91,0x00,0x22,0xCC,0x00,0x00,0xFF,0x00,0x00,0x00,
0x04,0x02,0x01,0x00,0xFF,0x00,0x04,0x04,0x04,0x02,0x02,0x02,0xFF,0x01,0x01,0x00},/*"科",4*/
{0x08,0x08,0x88,0xFF,0x48,0x28,0x00,0xC8,0x48,0x48,0x7F,0x48,0xC8,0x48,0x08,0x00,
0x01,0x41,0x80,0x7F,0x00,0x40,0x40,0x20,0x13,0x0C,0x0C,0x12,0x21,0x60,0x20,0x00},/*"技",5*/
{0x20,0x20,0x20,0x20,0x20,0x20,0xA0,0x7F,0xA0,0x20,0x20,0x20,0x20,0x20,0x20,0x00,
0x00,0x80,0x40,0x20,0x10,0x0C,0x03,0x00,0x01,0x06,0x08,0x30,0x60,0xC0,0x40,0x00},/*"大",6*/
{0x40,0x30,0x10,0x12,0x5C,0x54,0x50,0x51,0x5E,0xD4,0x50,0x18,0x57,0x32,0x10,0x00,
0x00,0x02,0x02,0x02,0x02,0x02,0x42,0x82,0x7F,0x02,0x02,0x02,0x02,0x02,0x02,0x00},/*"學",4*/
{0x00,0x02,0x1C,0xE8,0x00,0x40,0x60,0x58,0x47,0x22,0x20,0x28,0x30,0xE0,0x40,0x00,
0x02,0x02,0x7F,0x00,0x00,0x00,0x7F,0x21,0x21,0x21,0x21,0x21,0x7F,0x00,0x00,0x00},/*"冶",0*/
{0x40,0x40,0x20,0x20,0x50,0x48,0x44,0xC3,0x44,0x48,0x50,0x50,0x20,0x60,0x20,0x00,
0x40,0x40,0x42,0x42,0x4A,0x72,0x42,0x7F,0x42,0x62,0x5A,0x42,0x42,0x40,0x40,0x00},/*"金",1*/
{0x00,0x00,0x02,0x02,0x02,0x02,0x02,0xFE,0x02,0x02,0x02,0x02,0x02,0x02,0x00,0x00,
0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x3F,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x00},/*"工",2*/
{0x10,0x12,0xD2,0xFE,0x91,0x11,0x80,0xBF,0xA1,0xA1,0xA1,0xA1,0xBF,0x80,0x00,0x00,
0x04,0x03,0x00,0xFF,0x00,0x41,0x44,0x44,0x44,0x7F,0x44,0x44,0x44,0x44,0x40,0x00},/*"程",3*/
{0xFE,0x02,0x32,0x4A,0x86,0x0C,0x24,0x24,0x25,0x26,0x24,0x24,0x24,0x0C,0x04,0x00,
0xFF,0x00,0x02,0x04,0x83,0x41,0x31,0x0F,0x01,0x01,0x7F,0x81,0x81,0x81,0xF1,0x00},/*"院",5*/
{0x10,0x10,0xD0,0xFE,0x50,0x90,0x00,0x10,0x10,0x10,0xD0,0xFE,0x10,0x10,0x10,0x00,
0x08,0x06,0x01,0xFF,0x00,0x01,0x10,0x08,0x04,0x43,0x80,0x7F,0x00,0x00,0x00,0x00},/*"材",0*/
{0x20,0x24,0xA8,0x70,0xFF,0x68,0xA4,0x20,0x42,0x8C,0x00,0x00,0xFF,0x00,0x00,0x00,
0x08,0x06,0x01,0x00,0xFF,0x00,0x01,0x02,0x02,0x03,0x02,0x02,0xFF,0x01,0x01,0x00},/*"料",1*/
{0x00,0x08,0x08,0x08,0xFF,0x08,0x08,0xF8,0x00,0xF8,0x08,0x08,0x08,0xF8,0x00,0x00,
0x40,0x20,0x18,0x07,0x00,0x20,0x40,0x3F,0x00,0x7F,0x10,0x10,0x10,0x3F,0x00,0x00},/*"加",2*/
0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x3F,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x00},/*"工",4*/
0x04,0x03,0x00,0xFF,0x00,0x41,0x44,0x44,0x44,0x7F,0x44,0x44,0x44,0x44,0x40,0x00},/*"程",5*/
unsigned char code E[][16]=
{0xC0,0x30,0x08,0x08,0x08,0x08,0x38,0x00,0x07,0x18,0x20,0x20,0x20,0x10,0x08,0x00},/*"C",0*/
{0x80,0x80,0x80,0x00,0x80,0x80,0x80,0x00,0x20,0x20,0x3F,0x21,0x20,0x00,0x01,0x00},/*"r",1*/
{0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x19,0x24,0x22,0x22,0x22,0x3F,0x20},/*"a",2*/
{0x00,0x00,0x80,0x80,0x80,0x80,0x80,0x00,0x00,0x33,0x24,0x24,0x24,0x24,0x19,0x00},/*"s",3*/
{0x80,0x80,0x80,0x00,0x00,0x80,0x80,0x80,0x80,0x81,0x8E,0x70,0x18,0x06,0x01,0x00},/*"y",4*/
{0x08,0xF8,0x00,0x80,0x80,0x00,0x00,0x00,0x00,0x3F,0x11,0x20,0x20,0x11,0x0E,0x00},/*"b",5*/
{0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x1F,0x20,0x20,0x20,0x20,0x1F,0x00},/*"o",6*/
{0x80,0x80,0x80,0x00,0x00,0x80,0x80,0x80,0x80,0x81,0x8E,0x70,0x18,0x06,0x01,0x00},/*"y",7*/
{0x00,0x00,0x80,0x80,0x80,0x80,0x00,0x00,0x00,0x1F,0x22,0x22,0x22,0x22,0x13,0x00},/*"e",8*/
/***********************延時子程序***********************/
void delay(unsigned int k)
unsigned int i;
unsigned int j;
for(i=0;i<k;i++)
for(j=0;j<20;j++);
/***********************寫命令左***********************/
void write_cmd_1(unsigned char command)
cs1=1;cs2=0;
Di=0;
RW=0;
Lcd_Bus=command;
delay(0);
Enable=1;
delay(0);
Enable=0;
/***********************寫命令右***********************/
void write_cmd_2(unsigned char command)
cs1=0;cs2=1;
Di=0;
RW=0;
Lcd_Bus=command;
delay(0);
Enable=1;
delay(0);
Enable=0;
/***********************寫數據左***********************/
void write_data_1(unsigned char dis_data)
cs1=1;cs2=0;
Di=1;
RW=0;
Lcd_Bus=dis_data;
delay(0);
Enable=1;
delay(0);
Enable=0;
/***********************寫數據右***********************/
void write_data_2(unsigned char dis_data)
cs1=0;cs2=1;
Di=1;
RW=0;
Lcd_Bus=dis_data;
delay(0);
Enable=1;
delay(0);
Enable=0;
/***********************清內存左***********************/
void clear_1(void)
unsigned char j,k;
cs1=1;cs2=0;
write_cmd_1(Page_Add+0);
write_cmd_1(Col_Add+0);
for(k=0;k<8;k++){
write_cmd_1(Page_Add+k);
for(j=0;j<64;j++)write_data_1(0x00);
/***********************清內存右***********************/
void clear_2(void)
unsigned char j,k;
cs1=0;cs2=1;
write_cmd_2(Page_Add+0);
write_cmd_2(Col_Add+0);
for(k=0;k<8;k++){
write_cmd_2(Page_Add+k);
for(j=0;j<64;j++)write_data_2(0x00);
/***********************顯示漢字16*16左************************/
void Chinese_disp_1(unsigned char pag,unsigned char col,unsigned char n)
unsigned char i=0;
unsigned char j=0;
cs1=1;cs2=0;
for(i=0;i<2;i++)
write_cmd_1(Page_Add+pag+i);
write_cmd_1(Col_Add+col);
for(j=0;j<16;j++)
write_data_1(Chinese_character[n][16*i+j]);
/***********************顯示漢字16*16右***********************/
void Chinese_disp_2(unsigned char pag,unsigned char col,unsigned char n)
unsigned char i=0;
unsigned char j=0;
cs1=0;cs2=1;
for(i=0;i<2;i++)
write_cmd_2(Page_Add+pag+i);
write_cmd_2(Col_Add+col);
for(j=0;j<16;j++)
write_data_2(Chinese_character[n][16*i+j]);
/***********************顯示英文16*8左************************/
void E_disp_1(unsigned char pag,unsigned char col,unsigned char n)
unsigned char i=0;
unsigned char j=0;
cs1=1;cs2=0;
for(i=0;i<2;i++)
for(j=0;j<8;j++)
write_data_1(E[n][8*i+j]);
/***********************顯示英文16*8右***********************/
void E_disp_2(unsigned char pag,unsigned char col,unsigned char n)
unsigned char i=0;
unsigned char j=0;
cs1=0;cs2=1;
for(i=0;i<2;i++)
for(j=0;j<8;j++)
write_data_2(E[n][8*i+j]);
/***********************液晶屏初始化***********************/
void init_lcd()
Lcd_Rst=0;
delay(100);
Lcd_Rst=1;
delay(100);
write_cmd_1(Disp_Off); write_cmd_2(Disp_Off);
write_cmd_1(Page_Add+0); write_cmd_2(Page_Add+0);
write_cmd_1(Start_Line+0); write_cmd_2(Start_Line+0);
write_cmd_1(Col_Add+0); write_cmd_2(Col_Add+0);
write_cmd_1(Disp_On); write_cmd_2(Disp_On);
/***********************LCD顯示子程序***********************/
void display(void)
unsigned char i;
for(i=Start_Line;i<0xff;i++)
Chinese_disp_1(0,0, 0);
Chinese_disp_1(0,16,1);
Chinese_disp_1(0,32,2);
Chinese_disp_1(0,48,3);
Chinese_disp_2(0,0, 4);
Chinese_disp_2(0,16,5);
Chinese_disp_2(0,32,6);
Chinese_disp_2(0,48,7);
//西安建筑科技大學
Chinese_disp_1(2,16,8);
Chinese_disp_1(2,32,9);
Chinese_disp_1(2,48,10);
Chinese_disp_2(2,0,11);
Chinese_disp_2(2,16,12);
Chinese_disp_2(2,32,13);
//冶金工程學院
Chinese_disp_1(4,16,14);
Chinese_disp_1(4,32,15);
Chinese_disp_1(4,48,16);
Chinese_disp_2(4,0,17);
Chinese_disp_2(4,16,18);
Chinese_disp_2(4,32,19);
//材料加工工程
E_disp_1(6,24,0);
E_disp_1(6,32,1);
E_disp_1(6,40,2);
E_disp_1(6,48,3);
E_disp_1(6,56,4);
E_disp_2(6,0,5);
E_disp_2(6,8,6);
E_disp_2(6,16,7);
E_disp_2(6,24,8);
//Crasyboye
write_cmd_1(i);
write_cmd_2(i);
delay(3000);//調整滾動速度
//delay(60000);
/***********主程序************/
void main(void)
{ init_lcd();
clear_1();
clear_2();
display();
jxr0345
2015-1-24 22:34
3小時能寫出也算是大俠了。謝謝分享
629168335@
2015-3-7 12:50
程序編譯不了
曹世鵬
2016-9-29 17:00
來個視頻看看呀
阿澤
2019-4-27 22:08
主芯片和從芯片是啥意思啊
zctwss321
2019-4-28 09:39
電路原理呢?大神
zctwss321
2019-4-28 09:42
cs1和cs2管腳啥意思。繘]看懂,老哥
zctwss321
2019-4-28 09:45
寫命令左,寫命令右都是啥意思啊?啥右左了的
18839723190
2019-4-29 19:35
用的什么字模軟件啊,取模方式是什么
yinqing452
2019-9-11 17:25
顯示亂碼,不知道為什么
中文字幕一区二区三区日韩精品
日日av
欧美性网站
欧美激情在线播放
国产精品久久久久久久久久免费看
欧美激情视频一区二区三区免费
日韩欧美一区二区三区免费观看
精品一区二区三区91
国产精品久久久久久久久久久久久久
www午夜视频
日韩欧美网
日韩美女在线看免费观看
九九亚洲
国产激情在线观看视频
免费a大片
精品国产一区二区在线
亚洲精品久久嫩草网站秘色
成人在线观看免费观看
中文av在线播放
天天操天天插天天干
美女拍拍拍网站
亚洲性在线
精品国产乱码久久久久久闺蜜
亚洲成人精品久久
视频一区二区三区中文字幕
国产精品久久久久久久久久免费看
黄色网址在线免费观看
亚洲一区在线日韩在线深爱
视频一区二区在线观看
色精品视频
性生生活大片免费看视频
欧一区
日韩视频区
www.性色
午夜在线
亚洲综合在线一区
99久久久久久99国产精品免
日韩中文在线视频
国内自拍偷拍
国产999精品久久久影片官网
免费在线观看一区二区
